Speaker works however mic doesn't work
internal microphone is not working.
I checked some of the available solutions but it didn’t work
  Kernel: 5.15.72-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=a484b0a3-2218-4496-adda-bdbde04f13ea rw quiet
    resume=UUID=3d8f1007-14a2-4d7f-988f-0fde06bdf942 udev.log_priority=3
  Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Portable System: Dell product: Inspiron 3521 v: A09
    serial: <superuser required> Chassis: type: 8 v: A09
  Mobo: Dell model: 0X2H5X v: A00 serial: <superuser required> UEFI: Dell
    v: A09 date: 06/25/2013
  ID-1: BAT1 charge: 10.3 Wh (53.9%) condition: 19.1/41.4 Wh (46.1%)
    volts: 16.8 min: 14.8 model: Simplo DELL FW1MN31P type: Unknown
    serial: <filter> status: charging
  RAM: total: 3.7 GiB used: 2.09 GiB (56.3%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Celeron 1017U bits: 64 type: MCP arch: Ivy Bridge
    level: v2 built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58)
    stepping: 9 microcode: 0x21
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
    desc: 1x2 MiB
  Speed (MHz): avg: 1047 high: 1229 min/max: 800/1600 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1229 2: 866
    bogomips: 6387
  Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs lahf_lm
    lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
    pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp
    rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
    xsaveopt xtopology xtpr
    disabled
    prctl and seccomp
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
    v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
    active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0156 class-ID: 0300
  Device-2: Suyin Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 1-1.4:5 chip-ID: 064e:8132 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: LVDS-1 model: LG Display 0x03ab built: 2012 res: 1366x768
    hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1366x768
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Sound API: ALSA v: k5.15.72-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.58 running: no
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
    vendor: Dell driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
  Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-1.1:6 chip-ID: 0cf3:0036 class-ID: e001
  Local Storage: total: 298.09 GiB used: 13.93 GiB (4.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545032A7E380
    size: 298.09 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: A950 scheme: GPT
  Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A5HH rev: SD11
    dev-links: cdrom
  ID-1: / raw-size: 289.65 GiB size: 284.04 GiB (98.06%) used: 13.93 GiB
    (4.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: a484b0a3-2218-4496-adda-bdbde04f13ea
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: E92C-5968
  ID-1: swap-1 type: partition size: 8.15 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 3d8f1007-14a2-4d7f-988f-0fde06bdf942
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:6 info: Qualcomm Atheros AR9462 Bluetooth type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
  Device-2: 1-1.3:4 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-3: 1-1.4:5 info: Suyin Laptop_Integrated_Webcam_HD type: Video
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:2 info: Kensington PocketMouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 047d:1012 class-ID: 0301
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 48.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 203 Uptime: 4m wakeups: 27718 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 941 libs: 288 tools: pamac Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.22
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
Please post more information about system as requested
and more information about audio devices
amixer -D sysdefault info; amixer -D sysdefault
Card sysdefault 'PCH'/'HDA Intel PCH at 0xc0610000 irq 29'
  Mixer name	: 'Realtek ALC3221'
  Components	: 'HDA:10ec0282,10280597,00100003 HDA:80862806,80860101,00100000'
  Controls      : 28
  Simple ctrls  : 11
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 81 [93%] [-4.50dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 25 [81%] [3.00dB] [on]
  Front Right: Playback 25 [81%] [3.00dB] [on]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 63 [100%] [30.00dB] [on]
  Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
  Front Left: 2 [67%] [24.00dB]
  Front Right: 2 [67%] [24.00dB]
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Hi, I too am facing the issue with mic. I tried all the troubleshooting examples on ArchWiki PulseAudio but no luck. If I pair the bluetooth earphones mic doesn’t work for that as well. Any help tried every other solution I could find on internet.
ALSA controls for internal (and external) microphone are turned on and levels turned up (maybe too high in the mic boost settings)
I suggest checking PulseAudio configuration:
pactl list cards; pacmd dump | grep -E 'source|profile'
i am a beginner and i honestly don’t know what should i check here. So i have pasted the output from the line of code you have suggested
Card #0
	Driver: module-alsa-card.c
	Owner Module: 6
	Properties:
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xc0610000 irq 29"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "1e20"
		device.product.name = "7 Series/C216 Chipset Family High Definition Audio Controller"
		device.string = "0"
		device.description = "Built-in Audio"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Profiles:
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 32833, available: yes)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 39333, available: yes)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: yes)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
	Active Profile: output:analog-stereo+input:analog-stereo
	Ports:
		analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: -10000 usec, available)
			Properties:
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, available)
			Properties:
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
set-source-volume alsa_output.pci-0000_00_1b.0.analog-stereo.monitor 0xa3d7
set-source-mute alsa_output.pci-0000_00_1b.0.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_00_1b.0.analog-stereo 0xa189
set-source-mute alsa_input.pci-0000_00_1b.0.analog-stereo no
suspend-source alsa_input.pci-0000_00_1b.0.analog-stereo yes
set-card-profile alsa_card.pci-0000_00_1b.0 output:analog-stereo+input:analog-stereo
set-default-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor
Data shows the Port for the internal-mic is not available
Removable devices connected via a jack socket usually show as available when plugged in and not available when unplugged, but internal devices should not have any jack-detection functions and should show as unknown at all times
Please post more information about ALSA devices and drivers
sudo alsa-info.sh --upload
If there are no other problems except for the internal microphone, It should be possible to retask the microphone connection so it is detected as unknown rather than not available
[sudo] password for swornimstha:
/usr/bin/alsa-info.sh: line 661: tree: command not found
Uploading information to www.alsa-project.org ... Done!
Your ALSA information is located at http://alsa-project.org/db/?f=0b3ae1f66f2715c1cace4c0c4898a40244baf8fa
Please inform the person helping you.
