Speaker and microphone issues
Hey!
I connect my microphone from aux port to laptop, but it uses laptops own microphone.
How can I set the microphone I want
When I run inxi -Aa it shows this
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
And my microphone does not work either
How can I fix?
install sof firmware and reboot:
sudo pacman -S sof-firmware
reboot
I have an Asus laptop that only has a port for connecting headphones and a microphone at the same time. My problem is that when I just insert the microphone, it detects headphones and prevents the microphone from being used, and no sound comes out of the speakers. How can I prevent this?
“There was a Realtek program on Windows where I could choose which one to use”
check your manual what kind of plug you need (3-pole or 4-pole) first and make sure that it isn’t any hardware-related trouble.
second: please post the output of the inxi command described below:
  1. Please read this:
    [HowTo] Provide System Information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
Please do not create multiple topics for the same issues. I’ve merged your posts.
  Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
    root=UUID=d605539e-4132-49d1-b207-98af51ce347f rw quiet apparmor=1
    security=apparmor resume=UUID=9c2d2721-f8d8-407a-9d0b-c1a7c16d4cd1
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: X556UQ v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: X556UQ v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X556UQ.316 date: 04/16/2019
  ID-1: BAT0 charge: 29.5 Wh (97.0%) condition: 30.4/31.2 Wh (97.7%)
    volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: charging cycles: 191
  RAM: total: 7.63 GiB used: 4.76 GiB (62.4%)
  RAM Report:
  Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
    family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xF0
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 500 min/max: 400/3100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 20810
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
    cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
    epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
    v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:1916 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nvidia
    v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-05) arch: Maxwell pcie: gen: 1 speed: 2.5 GT/s
    lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d
    class-ID: 0302
  Device-3: Realtek USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-6:4 chip-ID: 0bda:57de class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x38ed built: 2014 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.0.4
    direct render: Yes
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
  IP v4: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy scope: link
  Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
    chip-ID: 13d3:3496 class-ID: e001
  Local Storage: total: 447.13 GiB used: 321.04 GiB (71.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 480GB SSD
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 0KA3 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00
    dev-links: cdrom
  ID-1: / raw-size: 17.29 GiB size: 16.85 GiB (97.46%) used: 15.25 GiB (90.5%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: d605539e-4132-49d1-b207-98af51ce347f
    used: 292 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: NO_LABEL
    uuid: 5E13-0E01
  ID-3: /run/media/ilya/01D82B25105FAE80 raw-size: 211.84 GiB
    size: 211.84 GiB (100.00%) used: 161.57 GiB (76.3%) fs: ntfs dev: /dev/sda7
    maj-min: 8:7 label: N/A uuid: 01D82B25105FAE80
  ID-4: /run/media/ilya/F45432B554327A86 raw-size: 171.7 GiB
    size: 171.7 GiB (100.00%) used: 144.22 GiB (84.0%) fs: ntfs dev: /dev/sda3
    maj-min: 8:3 label: N/A uuid: F45432B554327A86
  ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda6 maj-min: 8:6 label: N/A
    uuid: 9c2d2721-f8d8-407a-9d0b-c1a7c16d4cd1
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: 6028-0EE2
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: [Maxxter] Optical gaming mouse type: Mouse,Keyboard
    power: 100mA chip-ID: 18f8:0f99 class-ID: 0301
  Device-2: 1-5:3 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-3: 1-6:4 info: Realtek USB2.0 VGA UVC WebCam type: Video
  Device-4: 1-8:5 info: IMC Networks type: Bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 13d3:3496
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 46.0 C pch: 45.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 3000
  Processes: 229 Uptime: 52m wakeups: 5700 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1317
  pacman: 1306 lib: 343 flatpak: 0 snap: 11 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.16
