oneno
19 September 2021 09:01
1
After the last update , the audio does not work unless the audio jack is removed from the back of the motherboard and reinserted on 2 machines:
XFCE freshly installed:
Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=9f8eac0f-a4d1-49c3-a677-2295fcac5372 rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: ASRock model: AM1H-ITX serial: <filter>
UEFI: American Megatrends v: P1.50 date: 04/29/2015
Info: Quad Core model: AMD Athlon 5350 APU with Radeon R3 bits: 64 type: MCP
arch: Jaguar family: 16 (22) model-id: 0 stepping: 1 microcode: 700010F
cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 16404
Speed: 939 MHz min/max: 800/2050 MHz Core speeds (MHz): 1: 939 2: 862
3: 1345 4: 859
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM] vendor: ASUSTeK
driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:6779 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
OpenGL: renderer: AMD CAICOS (DRM 2.50.0 / 5.13.15-1-MANJARO LLVM 12.0.1)
v: 3.3 Mesa 21.2.1 compat-v: 3.1 direct render: Yes
Device-1: AMD FCH Azalia vendor: ASRock QC5000-ITX/PH driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
vendor: ASRock driver: r8169 v: kernel port: c000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 387.53 GiB used: 9.72 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253X2256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 9A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3160815AS
size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: C scheme: GPT
ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 8.93 GiB (29.8%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 568 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 40 GiB size: 40 GiB (100.00%) used: 814.4 MiB (2.0%)
fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-4: /var/log raw-size: 30 GiB size: 30 GiB (100.00%)
used: 8.93 GiB (29.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 11.8 C mobo: N/A gpu: radeon temp: 34.5 C
Processes: 228 Uptime: 2m wakeups: 0 Memory: 7.7 GiB used: 813.4 MiB (10.3%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages:
pacman: 1194 lib: 321 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
inxi: 3.3.06
KDE Updated
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=28e31491-f18c-4a8f-a340-2c2a70429840 ro quiet udev.log_priority=3
snd_hda_intel.dmic_detect=0
Type: Desktop System: Gigabyte product: N/A v: N/A serial: Chassis:
type: 3 serial:
Mobo: Gigabyte model: F2A88XM-D3H serial: UEFI: American Megatrends
v: F8 date: 04/09/2015
Info: Dual Core model: AMD A6-6400K APU with Radeon HD Graphics bits: 64
type: MCP arch: Piledriver family: 15 (21) model-id: 13 (19) stepping: 1
microcode: 6001119 cache: L2: 1024 KiB
bogomips: 15576
Speed: 2980 MHz min/max: 1800/3900 MHz boost: enabled Core speeds (MHz):
1: 2980 2: 2768
Type: spectre_v2
Device-1: AMD Richland [Radeon HD 8470D] vendor: Gigabyte driver: radeon
v: kernel bus-ID: 00:01.0 chip-ID: 1002:9996 class-ID: 0300
Display: x11 server: [X.Org](http://X.Org) 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
Screen-1: 0 s-res: 1600x1200 s-dpi: 96 s-size: 423x317mm (16.7x12.5")
s-diag: 529mm (20.8")
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.10.61-1-MANJARO LLVM 12.0.1)
v: 4.3 Mesa 21.2.1 compat-v: 3.1 direct render: Yes
Device-1: AMD Trinity HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac:
Local Storage: total: 1.14 TiB used: 29.21 GiB (2.5%)
type: SSD serial: rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-75M2NA0
type: HDD rpm: 7200 serial: rev: 1A01 scheme: MBR
ID-1: / raw-size: 20 GiB size: 19.56 GiB (97.81%) used: 11.46 GiB (58.6%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 20 GiB size: 19.56 GiB (97.81%)
used: 17.75 GiB (90.7%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 24 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 27.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1165 fan-2: 575 fan-3: 521 fan-4: 0 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.26
Processes: 173 Uptime: 10m wakeups: 0 Memory: 22.75 GiB
used: 1.48 GiB (6.5%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1323 lib: 388 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
oneno
19 September 2021 20:46
4
For machine in item 4 of your post above:
$ inxi --admin --verbosity=7 --filter --no-host --width
udev.log_priority=3
RAM: total: 7.7 GiB used: 1.21 GiB (15.7%)
cache: L2: 2 MiB bogomips: 16406
Speed: 800 MHz min/max: 800/2050 MHz Core speeds (MHz): 1: 800 2: 1174
3: 1169 4: 871
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 bpext clflush
cmov cmp_legacy constant_tsc cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht hw_pstate ibs
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni popcnt
proc_feedback pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
wdt xsave xsaveopt
Type: spectre_v2
s-diag: 583mm (23")
Local Storage: total: 387.53 GiB used: 9.74 GiB (2.5%)
ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 8.94 GiB (29.8%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 9f8eac0f-a4d1-49c3-a677-2295fcac5372
used: 568 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 22AA-4149
ID-3: /home raw-size: 40 GiB size: 40 GiB (100.00%) used: 812.4 MiB (2.0%)
fs: btrfs dev: /dev/sdb4 maj-min: 8:20 label: N/A
uuid: 15483a2b-9edd-4ce6-9de1-6d1305279676
ID-4: /var/cache raw-size: 30 GiB size: 30 GiB (100.00%)
used: 8.94 GiB (29.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
ID-5: /var/log raw-size: 30 GiB size: 30 GiB (100.00%)
dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 4cc50e01-087e-4fbd-b5ca-1eb0f3f14b78
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: ECEE-788B
ID-2: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 64 GiB fs: ntfs label: N/A
uuid: C81A0AAD1A0A9918
ID-4: /dev/sda4 maj-min: 8:4 size: 174.25 GiB fs: ntfs label: N/A
uuid: 9CD6E11AD6E0F584
ID-5: /dev/sdb5 maj-min: 8:21 size: 70.05 GiB fs: btrfs label: N/A
uuid: 7faf88ab-cc85-4ade-a127-06d1f9e0577f
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-2: 1-3:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 2 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2512 class-ID: 0900
Device-1: 1-3.2:3 info: Logitech Internet 350 Keyboard type: Keyboard,HID
power: 100mA chip-ID: 046d:c313 class-ID: 0300
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1 speed: 12 Mb/s
Device-1: 4-3:2 info: Logitech Optical Wheel Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c016 class-ID: 0301
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-8: 6-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Hub-9: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-10: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 8.9 C mobo: N/A gpu: radeon temp: 37.0 C
Processes: 234 Uptime: 3m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1194 lib: 321 Shell: Bash v: 5.1.8
$ pacmd dump
### Configuration dump generated at Sun Sep 19 13:39:05 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="0" name="pci-0000_00_14.2" card_name="alsa_card.pci-0000_00_14.2" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0.0 xauthority=/home/quest/.Xauthority
load-module module-x11-xsmp display=:0.0 xauthority=/home/quest/.Xauthority session_manager=local/rjd:@/tmp/.ICE-unix/921,unix/rjd:/tmp/.ICE-unix/921
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_14.2.analog-stereo 0x8000
set-sink-mute alsa_output.pci-0000_00_14.2.analog-stereo no
suspend-sink alsa_output.pci-0000_00_14.2.analog-stereo yes
set-source-volume alsa_output.pci-0000_00_14.2.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_14.2.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_14.2.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_00_14.2.analog-stereo 0xa3d
set-source-mute alsa_input.pci-0000_00_14.2.analog-stereo yes
suspend-source alsa_input.pci-0000_00_14.2.analog-stereo yes
set-card-profile alsa_card.pci-0000_01_00.1 off
set-card-profile alsa_card.pci-0000_00_14.2 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_00_14.2.analog-stereo
set-default-source alsa_input.pci-0000_00_14.2.analog-stereo
### EOF
Fabby
19 September 2021 21:00
5
5.10.63-MANJARO is what we need and what I meant with:
No PipeWire running, that’s good.
Have a look at:
alsamixer
too and see if anything is muted. If not, please:
pamac install alsa-tools
hdajackretask
provide a screenshot of that.
oneno
20 September 2021 01:21
6
First for the machine with k5.13.15-1 clicked on the volume icon and clicked on “audio mixer…” to display “Volume Control” dialog.
Noticed under the “Output Devices” tab, the selection was for “Headphones”.
Changed that to “Line Out (plugged in)” and sound works:
Volume Control
Confirmed working on both machines (k5.10.63-1 & k5.13.15-1)
So this is the fix.
system
Closed
22 September 2021 15:22
7
