Sound popping/crackling randomly
Hello,
I installed Manjaro XFCE last week and I have a little issue with my sound on any application. Randomly I have a pop/crack sound and I see the sound level notification appear (Without touching the sound level). I tried everything I found, but nothing seems to work.
First, I tried with (~/.pulse/default.pa):
load-module module-udev-detect tsched=0
Changing buffer size (~/.pulse/default.pa):
update-sink-proplist alsa_output.pci-0000_00_1f.3.analog-stereo device.buffering.buffer_size=1048576
The snd-hda-intel (/etc/modprobe.d/sound.conf):
options snd-hda-intel vid=8086 pid=8ca0 snoop=0
Disabling flat volumes (/etc/pulse/daemon.conf):
flat-volumes = no
Everytime I restart pulseaudio and, if I heard a new pop/crack, I restart my computer too.
I have 2 audio outputs, audio jack for music/video/games/etc… and an usb output for voice (discord/TS/etc…). The issue is only for jack output, so, I don’t think it’s related to my issue, but I have a config for my voice channel because usb has 4 channels but I only need 1:
load-module module-combine-sink sink_name=voiceChannel slaves=alsa_output.usb-Allen___Heath_ZEDi10-00.analog-surround-40 channels=1
update-sink-proplist voiceChannel device.description="Voice Channel"
This is my sink list:
sinks
4 sink(s) available.
    index: 0
        driver: <module-alsa-card.c>
        flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: SUSPENDED
        suspend cause: IDLE
        priority: 9049
        volume: front-left: 65536 / 100% / 0,00 dB,   front-right: 65536 / 100% / 0,00 dB,   rear-left: 65536 / 100% / 0,00 dB,   rear-right: 65536 / 100% / 0,00 dB
                balance 0,00
        base volume: 65536 / 100% / 0,00 dB
        volume steps: 65537
        muted: no
        current latency: 0,00 ms
        max request: 0 KiB
        max rewind: 0 KiB
        monitor source: 0
        sample spec: s16le 4ch 44100Hz
        channel map: front-left,front-right,rear-left,rear-right
                     Surround 4.0
        used by: 0
        linked by: 0
        configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
        card: 0 <alsa_card.usb-Allen___Heath_ZEDi10-00>
        module: 6
        properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "USB Audio"
                alsa.id = "USB Audio"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "5"
                alsa.card_name = "ZEDi10"
                alsa.long_card_name = "Allen & Heath ZEDi10 at usb-0000:00:14.0-10, high speed"
                alsa.driver_name = "snd_usb_audio"
                device.bus_path = "pci-0000:00:14.0-usb-0:10:1.0"
                sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0/sound/card5"
                udev.id = "usb-Allen___Heath_ZEDi10-00"
                device.bus = "usb"
                device.vendor.id = "22f0"
                device.vendor.name = "Allen & Heath"
                device.product.id = "0016"
                device.product.name = "ZEDi10"
                device.serial = "Allen___Heath_ZEDi10"
                device.string = "surround40:5"
                device.buffering.buffer_size = "705600"
                device.buffering.fragment_size = "352800"
                device.access_mode = "mmap+timer"
                device.profile.name = "analog-surround-40"
                device.profile.description = "Surround analogique 4.0"
                device.description = "ZEDi10 Surround analogique 4.0"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-usb"
        ports:
                analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
                        properties:
        active port: <analog-output>
  * index: 1
        flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: RUNNING
        suspend cause: (none)
        priority: 9039
        volume: front-left: 53084 /  81% / -5,49 dB,   front-right: 53084 /  81% / -5,49 dB
                balance 0,00
        volume steps: 65537
        muted: no
        current latency: 761,80 ms
        max request: 168 KiB
        max rewind: 168 KiB
        monitor source: 2
        sample spec: s16le 2ch 44100Hz
                     Stéréo
        used by: 1
        linked by: 1
        configured latency: 980,00 ms; range is 0,50 .. 2000,00 ms
        card: 2 <alsa_card.pci-0000_00_1f.3>
        module: 8
        properties:
                device.api = "alsa"
                alsa.name = "Generic Analog"
                alsa.id = "Generic Analog"
                alsa.device = "0"
                alsa.card = "0"
                alsa.long_card_name = "HDA Intel PCH at 0x4000110000 irq 139"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "a348"
                device.product.name = "Cannon Lake PCH cAVS"
                device.string = "front:0"
                device.buffering.buffer_size = "1048576"
                device.buffering.fragment_size = "176400"
                device.profile.name = "analog-stereo"
                device.profile.description = "Stéréo analogique"
                device.description = "Audio interne Stéréo analogique"
                device.icon_name = "audio-card-pci"
        ports:
                analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: yes)
                        properties:
                analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
                        properties:
        active port: <analog-output-lineout>
    index: 2
        driver: <module-combine-sink.c>
        flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: SUSPENDED
        suspend cause: IDLE
        priority: 1000
        volume: mono: 66031 / 101% / 0,20 dB
                balance 0,00
        volume steps: 65537
        muted: no
        max request: 17 KiB
        max rewind: 0 KiB
        monitor source: 3
        sample spec: s16le 1ch 44100Hz
        channel map: mono
                     Mono
        used by: 0
        linked by: 0
        configured latency: 0,00 ms; range is 0,50 .. 200,00 ms
        module: 26
        properties:
                device.class = "filter"
                combine.slaves = "alsa_output.usb-Allen___Heath_ZEDi10-00.analog-surround-40"
                device.description = "Voice Channel"
                device.icon_name = "audio-card"
    index: 9
        state: SUSPENDED
        suspend cause: IDLE
        priority: 9030
                balance 0,00
        volume steps: 65537
        muted: no
        max request: 0 KiB
        max rewind: 0 KiB
        monitor source: 13
                     Stéréo
        used by: 0
        linked by: 0
        configured latency: 0,00 ms; range is 0,50 .. 1999,82 ms
        card: 1 <alsa_card.pci-0000_02_00.1>
        module: 7
        properties:
                device.api = "alsa"
                alsa.name = "HDMI 1"
                alsa.id = "HDMI 1"
                alsa.device = "7"
                alsa.card = "1"
                alsa.card_name = "HDA NVidia"
                alsa.long_card_name = "HDA NVidia at 0xa4080000 irq 17"
                device.bus_path = "pci-0000:02:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:1b.4/0000:02:00.1/sound/card1"
                device.bus = "pci"
                device.vendor.id = "10de"
                device.vendor.name = "NVIDIA Corporation"
                device.product.id = "10f8"
                device.product.name = "TU104 HD Audio Controller"
                device.string = "hdmi:1,1"
                device.buffering.buffer_size = "352768"
                device.buffering.fragment_size = "176384"
                device.profile.name = "hdmi-stereo-extra1"
                device.profile.description = "Digital Stereo (HDMI 2)"
                device.description = "TU104 HD Audio Controller Digital Stereo (HDMI 2)"
        ports:
                hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: yes)
                        properties:
                                device.product.name = "2460G5
        active port: <hdmi-output-1>
I think I said everything
thank you in advance for help
Could you also provide an inxi --admin --verbosity=7 --filter --no-host --widthas that would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:+1:
Sorry, I didn’t know this command ^^
  Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=0b0ab2db-0785-4bf5-8027-01de48737025 rw intel_iommu=on quiet
  apparmor=1 security=apparmor udev.log_priority=3 intel_iommu=igfx_off
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0
  serial: <filter> UEFI: American Megatrends v: 1.30 date: 11/13/2018
  RAM: total: 31.3 GiB used: 5.7 GiB (18.2%)
  Info: 8-Core model: Intel Core i7-9700K bits: 64 type: MCP arch: Kaby Lake
  note: check family: 6 model-id: 9E (158) stepping: C (12) microcode: DE
  cache: L2: 12 MiB bogomips: 57616
  Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
  f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
  rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
  Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Gigabyte
  driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
  chip-ID: 10de:1e84 class-ID: 0300
  Device-2: MacroSilicon USB Video type: USB
  driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 1-3.2:9
  chip-ID: 534d:2109 class-ID: 0300
  Device-3: Valve 3D Camera type: USB driver: uvcvideo bus-ID: 2-1.1:4
  chip-ID: 28de:2400 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
  screens: 1
  Screen-1: 0 s-res: 4920x1920 s-dpi: 96 s-size: 1302x508mm (51.3x20.0")
  s-diag: 1398mm (55")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
  diag: 598mm (23.5")
  Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
  diag: 609mm (24")
  Monitor-3: DP-5 res: 1080x1920 hz: 60
  OpenGL: renderer: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2
  v: 4.6.0 NVIDIA 465.31 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
  bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
  v: kernel bus-ID: 02:00.1 chip-ID: 10de:10f8 class-ID: 0403
  Device-3: Valve Valve VR Radio type: USB driver: cdc_acm,hid-generic,usbhid
  bus-ID: 1-1.3.2:10 chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
  Device-4: Valve Valve VR Radio & HMD Mic type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3.3:13
  chip-ID: 28de:2102 class-ID: 0102 serial: <filter>
  Device-5: Allen & Heath ZEDi10 type: USB driver: snd-usb-audio
  bus-ID: 1-10:14 chip-ID: 22f0:0016 class-ID: fe01
  Device-6: MacroSilicon USB Video type: USB
  Device-7: C-Media USB MICROPHONE type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-9:11 chip-ID: 0d8c:0134
  class-ID: 0300
  Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: no
  Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
  v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  driver: btusb v: 0.8 bus-ID: 1-6:8 chip-ID: 0a12:0001 class-ID: e001
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 6.39 TiB used: 892.81 GiB (13.6%)
  model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
  logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
  rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT525MX300SSD1
  size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: R031 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZRX-00A3KB0
  rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST31000528AS
  size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: HP35 scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
  model: WD Elements 25A3 size: 3.64 TiB block-size: physical: 4096 B
  logical: 512 B serial: <filter> rev: 1029 scheme: GPT
  ID-1: / raw-size: 97.16 GiB size: 95.07 GiB (97.85%) used: 45.51 GiB (47.9%)
  fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
  uuid: 0b0ab2db-0785-4bf5-8027-01de48737025
  used: 308 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
  uuid: 2D8D-ED23
  ID-3: /home/data raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
  used: 193.87 GiB (20.8%) fs: fuseblk dev: /dev/sdb1 maj-min: 8:17
  label: Data uuid: E600FF6700FF3D5D
  ID-4: /home/games raw-size: 488.51 GiB size: 488.51 GiB (100.00%)
  used: 442.83 GiB (90.6%) fs: fuseblk dev: /dev/sda2 maj-min: 8:2 label: Jeux
  uuid: 3AF4B193F4B151BD
  ID-5: /home/games-nvme raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
  used: 69.97 GiB (47.8%) fs: fuseblk dev: /dev/nvme0n1p4 maj-min: 259:4
  label: Jeux NVMe uuid: F852748352744900
  ID-6: /home/windows raw-size: 221.12 GiB size: 221.12 GiB (100.00%)
  used: 140.63 GiB (63.6%) fs: fuseblk dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: E230F79930F77341
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 300 MiB fs: <superuser required>
  label: N/A uuid: E236-E636
  ID-3: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: <superuser required>
  label: N/A uuid: 5CF9-A560
  ID-4: /dev/sdc1 maj-min: 8:33 size: 99 MiB fs: <superuser required>
  ID-5: /dev/sdc2 maj-min: 8:34 size: 931.41 GiB fs: <superuser required>
  label: Data 2 uuid: 9E6E628F6E62604F
  ID-6: /dev/sdd1 maj-min: 8:49 size: 3.64 TiB fs: <superuser required>
  label: Elements uuid: ACEC9BB4EC9B7774
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Hub-2: 1-1:2 info: Valve ports: 3 rev: 2.0 speed: 480 Mb/s power: 2mA
  chip-ID: 28de:2613 class-ID: 0900
  Hub-3: 1-1.3:4 info: Microchip (formerly SMSC) Hub ports: 5 rev: 2.1
  speed: 480 Mb/s chip-ID: 0424:2744 class-ID: 0900
  Device-1: 1-1.3.1:7 info: Valve Index HMD type: HID
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 28de:2300 class-ID: 0300 serial: <filter>
  Device-2: 1-1.3.2:10 info: Valve Valve VR Radio
  type: HID,Abstract (modem),CDC-Data driver: cdc_acm,hid-generic,usbhid
  interfaces: 3 rev: 2.0 speed: 12 Mb/s chip-ID: 28de:2102 class-ID: 0a00
  serial: <filter>
  Device-3: 1-1.3.3:13 info: Valve Valve VR Radio & HMD Mic type: HID,Audio
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s chip-ID: 28de:2102 class-ID: 0102 serial: <filter>
  Device-4: 1-1.3.5:16 info: Microchip (formerly SMSC) Hub Controller
  type: Hub driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
  chip-ID: 0424:2740 class-ID: 0000
  Hub-4: 1-2:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 0bda:5411 class-ID: 0900
  Device-1: 1-2.3:17 info: Xiaomi Mi/Redmi series (MTP)
  type: <vendor specific> driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s
  power: 500mA chip-ID: 2717:ff40 class-ID: 0000 serial: <filter>
  Hub-5: 1-3:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  power: 500mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-3.2:9 info: MacroSilicon USB Video type: Video,Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 5 rev: 2.0
  speed: 480 Mb/s power: 500mA chip-ID: 534d:2109 class-ID: 0300
  Device-2: 1-3.3:12 info: Corsair Gaming M65 Pro RGB Mouse type: Mouse,HID
  driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
  chip-ID: 1b1c:1b2e class-ID: 0300 serial: <filter>
  Device-3: 1-3.4:15 info: Corsair CORSAIR K68 RGB Mechanical Gaming Keyboard
  type: Keyboard,HID driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 1b1c:1b4f class-ID: 0300 serial: <filter>
  Device-4: 1-6:8 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 0a12:0001 class-ID: e001
  Device-5: 1-9:11 info: C-Media USB MICROPHONE type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300
  Device-6: 1-10:14 info: Allen & Heath ZEDi10 type: Audio
  driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s
  Hub-6: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-7: 2-1:2 info: Microchip (formerly SMSC) Hub ports: 4 rev: 3.2
  speed: 5 Gb/s chip-ID: 0424:5744 class-ID: 0900
  Device-1: 2-1.1:4 info: Valve 3D Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 3.2 speed: 5 Gb/s power: 800mA chip-ID: 28de:2400
  Hub-8: 2-2:3 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 0bda:0411 class-ID: 0900
  Device-1: 2-2.4:6 info: Western Digital Elements Desktop (WDBWLG)
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
  power: 8mA chip-ID: 1058:25a3 class-ID: 0806 serial: <filter>
  Hub-9: 2-3:5 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
  chip-ID: 05e3:0612 class-ID: 0900
  Hub-10: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-11: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
  System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 44 C
  Processes: 322 Uptime: 5h 35m wakeups: 0 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: 1196 pacman: 1178 lib: 345
  flatpak: 6 snap: 12 Shell: Bash v: 5.1.8 running-in: terminus inxi: 3.3.04
  1. I don’t have your hardware, but this looks old:
    Try upgrading your firmware first.
  2. Does this also happen on kernel 5.4?
  3. Just to be absolutely sure: this is happening on your Intel sink and not on HDMI connected to a TV or HiFi, correct?
:thinking:
  1. Seems to not have update for UEFI:
Devices with no available firmware updates:
 • UEFI dbx
 • ZEDi10
  1. Ok, I try
  2. I didn’t tried HDMI sound, but this isn’t happenning with my voice channel, only with intel sink.
This is happening on kermel 5.4 too :cry:
I have the same issue too while listening to on-line music.
  Kernel: 5.12.14-arch1-1-surface x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-linux-surface
  root=UUID=967e3b8e-27e5-45c6-a447-4fdb42245305 rw quiet loglevel=3
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Microsoft product: Surface Pro 6
  v: 124000000000000000000000D:0B:13F:5C:10P:38S:01E:0 serial: <filter>
  Chassis: type: 9 serial: <filter>
  Mobo: Microsoft model: Surface Pro 6 serial: <filter> UEFI: Microsoft
  v: 235.3732.768 date: 04.20.2021
  ID-1: BAT1 charge: 32.4 Wh (100.0%) condition: 32.4/45.0 Wh (71.9%)
  volts: 8.2 min: 7.6 model: SMP M1009169 type: Li-ion serial: <filter>
  status: Full cycles: 347
  RAM: total: 7.69 GiB used: 3.13 GiB (40.8%)
  Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: EA cache: L2: 6 MiB bogomips: 28808
  Speed: 700 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 700 2: 2158
  3: 1666 4: 775 5: 800 6: 800 7: 800 8: 791
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Microsoft driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 2736x1824 s-dpi: 193 s-size: 361x241mm (14.2x9.5")
  s-diag: 434mm (17.1")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.3
  direct render: Yes
  Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
  Unit
  driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0 chip-ID: 8086:1919
  class-ID: 0480
  Device-2: Intel CSI-2 Host driver: ipu3-cio2 alternate: ipu3_cio2
  bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
  Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
  alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.12.14-arch1-1-surface running: yes
  Sound Server-4: PipeWire v: 0.3.31 running: no
  Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
  v: 1.0 port: 3000 bus-ID: 01:00.0 chip-ID: 11ab:2b38 class-ID: 0200
  Device-1: Marvell Bluetooth and Wireless LAN Composite type: USB
  driver: btusb v: 0.8 bus-ID: 1-5:3 chip-ID: 1286:204c class-ID: e001
  serial: <filter>
  Local Storage: total: 238.47 GiB used: 63.79 GiB (26.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
  lanes: 2 rotation: SSD serial: <filter> rev: ADMS0101 scheme: GPT
  ID-1: / raw-size: 92.09 GiB size: 90.08 GiB (97.82%) used: 23.47 GiB (26.1%)
  fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: Manjaro
  uuid: 967e3b8e-27e5-45c6-a447-4fdb42245305
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 34.8 MiB (13.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM uuid: C8B8-2E22
  ID-3: /home/<filter>/C raw-size: 50.06 GiB size: 50.06 GiB (100.00%)
  used: 30.53 GiB (61.0%) fs: fuseblk dev: /dev/nvme0n1p3 maj-min: 259:3
  label: C uuid: 000C27AD0C279CA2
  ID-4: /home/<filter>/D raw-size: 96.06 GiB size: 96.06 GiB (100.00%)
  used: 9.75 GiB (10.2%) fs: fuseblk dev: /dev/nvme0n1p4 maj-min: 259:4
  label: D uuid: 224C64D04C649FF1
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-5:3 info: Marvell Bluetooth and Wireless LAN Composite
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 480 Mb/s
  power: 500mA chip-ID: 1286:204c class-ID: e001 serial: <filter>
  Device-2: 1-7:2 info: Microsoft Surface Type Cover type: HID
  driver: hid-multitouch,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
  power: 100mA chip-ID: 045e:09c0 class-ID: 0300
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 38.0 C mobo: N/A
  Processes: 223 Uptime: 1h 24m wakeups: 2 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1086 lib: 295
  Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
I am using a SONY WH-1000XM3 bluetooth earphone, and I am sure that it is OK.
I am at unstable channel and I recently updated:
libmfx-21.2.3-1  nspr-4.32-1  pango-1:1.48.7-1
I solved it by
sudo pacman -Rsu pulseaudio-bluetooth pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio pulseaudio-ctl pulseaudio-qt
sudo pacman -S pipewire-pulse
But now I cannot control the volume by my keyboard.
I don’t understand what I have to do with this.
I can’t install manjaro-pipewire, because there’s a conflict with manjaro-pulse. Then pipewire-pulse is in conflict with pulseaudio.
So I need to uninstall pulseaudio and manjaro-pulse? But, is my config with combine will work with pipewire things?
Check if hotkeys for volume control are set correctly in System Settings. That’s all I can think of.
The volume control keys is system default which you can see the Surface Pro keyboard
Try pipewire pulse, this is better and I have been using without problems
