krabs
21 April 2022 12:16
1
Hi folks,
I have an odd problem whereby the sound from my laptop is coming out through a speaker as well as through the internal laptop speakers. It doesn’t matter what I connect to the audio jack on the laptop. If it’s a speaker or a pair of headphones, the sounds still comes out of the laptop as well. I am not sure what is causing this. What details do I need to provide to help resolve this? Many thanks!
Hello @krabs
Does removing this module help?
sudo modprobe -r -v pcspkr
krabs
21 April 2022 12:35
3
Thanks. Unfortunately it seems that this made no difference.
Interestingly, when I select ‘Speaker’ from the Port list as shown in the right of this picture, I get no sound at all. If I select ‘Headphones’, the sound outputs from both the laptop speakers and the external speaker or headphones (whatever is connected to the audio jack). I’m puzzled by this.
Could be a wrong pin mapping for your device.
Could you provide what system you are running?
inxi --admin --verbosity=7 --filter --width
krabs
21 April 2022 12:48
5
Thanks I was just about to post that
Kernel: 5.16.2-2-rt19-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-rt-x86_64
root=UUID=2836a4eb-b853-4176-a54b-316b57a3a67a rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HUAWEI product: HKD-WXX v: M1010
serial: <superuser required>
Mobo: HUAWEI model: HKD-WXX-PCB-B1 v: M1010 serial: <superuser required>
UEFI: HUAWEI v: 1.18 date: 12/29/2021
ID-1: BAT1 charge: 59.8 Wh (100.0%) condition: 59.8/59.7 Wh (100.3%)
volts: 13.2 min: 11.6 model: SUNWODA HB5781P1EEW-31T type: Li-ion
serial: <filter> status: full cycles: 15
RAM: total: 15.42 GiB used: 3.41 GiB (22.1%)
RAM Report:
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x9A
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 967 high: 1149 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 932 2: 906 3: 966 4: 1051
5: 1149 6: 823 7: 989 8: 920 bogomips: 52838
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: QUANTA
driver: i915 v: kernel ports: active: DP-3 off: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Luxvisions Innotech USB Camera type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 30c9:0041 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.61x14.96")
s-diag: 775mm (30.53")
Monitor-1: DP-3 pos: primary model: Samsung LF27T850 serial: <filter>
built: 2020 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: eDP-1 note: disabled model: TL142GDXP02-0 built: 2021
res: 2560x1440 dpi: 213 gamma: 1.2 size: 300x200mm (11.81x7.87")
diag: 361mm (14.2") ratio: 3:2 modes: 2520x1680
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: QUANTA
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
Sound Server-1: ALSA v: k5.16.2-2-rt19-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:6 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 32.63 GiB (6.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: 511BS0512GB size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: ECFO13.3 temp: 25.9 C scheme: GPT
ID-1: / raw-size: 210.27 GiB size: 205.91 GiB (97.93%)
used: 32.59 GiB (15.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 2836a4eb-b853-4176-a54b-316b57a3a67a
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 46.4 MiB (23.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 862E-ABBE
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 246.95 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 512 MiB fs: vfat label: WINPE
uuid: 2430-EF1C
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 18 GiB fs: ntfs label: Onekey
uuid: CAE03321E0331365
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1024 MiB fs: ntfs label: WinRE
uuid: CA94352194351185
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 2-3:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-5: 3-2:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Hub-6: 3-2.4:16 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-2.4.1:17 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
Device-2: 3-2.4.2:18 info: Microdia Redragon Mitra RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
Device-3: 3-2.5:7 info: VIA Labs USB Billboard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 2109:8888 class-ID: 1100 serial: <filter>
Device-4: 3-4:3 info: Shenzhen Goodix Fingerprint Device
type: Communication,CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5125 class-ID: 0a00
serial: <filter>
Device-5: 3-6:4 info: Luxvisions Innotech USB Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-6: 3-10:6 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 297 Uptime: 3h 14m wakeups: 1 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1257
lib: 361 flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.15
Ok it is a SOF Driver. No idea how to do that there. snd_hda_intel
should also work: Intel Tiger Lake-LP Smart Sound Technology Audio Controller
So try this:
stop pulseaudio:
systemctl --user stop pulseaudio
remove the driver:
sudo modprobe -r -v sof-audio-pci-intel-tgl
add this driver:
sudo modprobe -v snd_hda_intel
check if it is loaded:
inxi -Aazy
and start pulseaudio:
systemctl --user start pulseaudio
Here are models: HD-Audio Codec-Specific Models — The Linux Kernel documentation
Check which codec:
cat /proc/asound/card*/codec* | grep Codec
Sometimes it does not detect the correct one. Therefore it needs to be set like this:
sudo modprobe -v snd_hda_intel model=MODELNAME
This only for temporary testing at this moment. A reboot will reset this.
kisun
21 April 2022 13:18
7
Instead that is a driver problem have you take a look if “Auto Mute” is enabled in Alsamixer?
You can start ‘alsamixer’ from terminal, choose the right soundcard with ‘F6’ and navigate to the right to the “Auto Mute”-option.
There were similar post in the forum, like this:
Hi, I am new to linux,
The speakers on my PC work fine, but when I plug in headphones (which also work fine) I expect the computer speakers to mute. They don’t.
How can I get my speakers to mute automatically when I plug my headphones into the jack?
or this:
The sound is playing from my speakers and headphones, In Linux Mint I used HDAjackretask to fix this issue but it doesn’t appear to be available for Arch.
Perhaps it helps.
krabs
21 April 2022 13:36
8
Thank you! I’ve gone through this, but it still seems to be the same. @kisun may have a point about the auto mute option?
krabs
21 April 2022 13:37
9
Thanks for this! You may be on to something. From the screenshot below, it looks as though auto-mute is disabled? How do I enable it? Thanks!
krabs
21 April 2022 13:38
10
Sorry just to answer this as well. I think mine looks correct?
cat /proc/asound/card*/codec* | grep Codec ✔
Codec: Conexant CX8070
Codec: Intel Tigerlake HDMI
krabs:
Oh ok, that one is really new. Nothing at the documentation. So forget about changing model.
Arrow Key RIGHT → until Auto-Mute is highlighted → Press ENTER / Arrow Key Up/Down
krabs
21 April 2022 13:59
13
Thanks! I just enabled it. Now it only plays audio through the laptop speakers, but ONLY when something is connected to the headphone jack. Basically, the opposite of what it’s supposed to do. I’ll restart here and go through the settings again.
krabs
21 April 2022 14:04
14
So it seems Manjaro thinks my headphones are my internal speakers. When I select the internal speakers, I get no audio. So it seems they are the wrong way around. I might just try a fresh re-install. Very odd problem!
It’s likely due to the ALSA path profiles.
You can find the relevant .conf
file, make a backup copy of it, and modify the original file to correct the issue:
/usr/share/pulseaudio/alsa-mixer/paths/
The config file of interest might be: analog-output-speaker.conf
You’re going to look for something like “Element Front Speaker” and an option for toggling the device, etc.
It’s convoluted, and the naming scheme is confusing. In fact, it’s different for each computer.
Maybe try this:
For the file analog-output-headphones.conf
in the above directory, make a copy of it (for backup).
Then look for the section [Jack Front Headphone]
And change it to appear like this:
required-any = any
state.plugged = yes
state.unplugged = unknown
Then restart the pulseaudio service and/or reboot the computer.
See if you can now manually select between ports, to change which device outputs audio.
(Disable “auto-mute” which you did earlier, since you might not need it now. It’s up to you.)
The problem for me was that my inputs for microphones and speakers weren’t correctly recognized.
Here’s the solution that I referenced that worked on Linux Mint and also later on Manjaro.
krabs
21 April 2022 15:06
17
Thanks for that. I edited the file (and backed it up), then restarted. It didn’t appear to make any difference. I then decided to go ahead and do a fresh install. The issue is the same. Incidentally, I dual boot this machine with Windows 11 and it works fine there.
I’ll have a read through the possible solution that @francois072 posted and see how that one goes. Thanks a lot for the help with this!
krabs
21 April 2022 15:08
18
Thanks. I’ll have a read throught his!
The problem is, each laptop/desktop will require a different file / section to edit. That’s what makes it tricky.
krabs
21 April 2022 15:20
20
Yes it’s a bit of a headache alright! Would be great if I could get this sorted. I really don’t like Windows 11, but find myself using it most of the time, purely because of this sound issue. I guess I will just need to be patient until I can get it sussed out.
