Headphones, Speaker playing simultaneously
Hi, I am new to linux,
The speakers on my PC work fine, but when I plug in headphones (which also work fine) I expect the computer speakers to mute. They don’t.
How can I get my speakers to mute automatically when I plug my headphones into the jack?
Check with alsamixer if automute is enabled for your audio card.
I dont have this much of options in my alsamixer, why?
Try with F6 and select different sound card.
I selected another sound card. Tried searching for this option in 3 tabs but its not available
Looks like there is an issue with Realtek ACL8987 chipset. I see many problem reports and solutions: realtek alc887 headphone mute - بحث Google‏. You will need to find solution that works for you.
