Hi,
OS: Manjaro XFCE
NVIDIA video card(GTX1060) HDMI interface.
I have no sound when playing any audio files…streaming, saved/stored etc.
I have tried multiple kernels with the same result.
When I disconnect and reconnect the HDMI cable, everything works fine…
Does anybody have any ideas?
Thanks
This will help you help us to know more about your system [HowTo] Provide System Information
inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=a50c54d7-246c-462a-abd3-710239d7ed2f rw quiet apparmor=1
security=apparmor resume=UUID=0a79cb12-388a-4272-87df-0e5849f9bc25
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P3.90 date: 12/09/2019
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 90%
rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech K350 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 31.28 GiB used: 2.35 GiB (7.5%)
RAM Report:
Info: model: AMD Athlon 3000G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1590 high: 1839 min/max: 1600/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1475 2: 1532
3: 1839 4: 1515 bogomips: 27956
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 46
size: 1060x626mm (41.7x24.6") diag: 1231mm (48.5")
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
Local Storage: total: 1.83 TiB used: 31.37 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR020 temp: 33.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 033 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra Fit
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 907.15 GiB (98.31%)
used: 31.37 GiB (3.5%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: a50c54d7-246c-462a-abd3-710239d7ed2f
dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
uuid: 0a79cb12-388a-4272-87df-0e5849f9bc25
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System Reserved
uuid: D424008B240072B2
ID-2: /dev/sda2 maj-min: 8:2 size: 930.93 GiB fs: ntfs label: N/A
uuid: 5626033226031323
ID-3: /dev/sda3 maj-min: 8:3 size: 548 MiB fs: ntfs label: N/A
uuid: 0EE40A0AE409F52D
ID-4: /dev/sdb1 maj-min: 8:17 size: 2.96 GiB fs: iso9660
ID-5: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: N/A
uuid: 84B3-1470
ID-6: /dev/sdb3 maj-min: 8:19 size: 11.36 GiB fs: ext4 label: writable
uuid: 7ccf816c-4421-4506-ac2f-dc621c680ef7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-6:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-3:2 info: SanDisk Ultra Fit type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0781:5583 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
Device-2: 3-4:3 info: CH Products Flight Sim Pedals type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.0 speed: 1.5 Mb/s
power: 32mA chip-ID: 068e:00f2 class-ID: 0300
Device-3: 3-5:4 info: CH Products Flight Sim Yoke type: HID
power: 32mA chip-ID: 068e:00ff class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 37 C
Processes: 242 Uptime: 9m wakeups: 5 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1288 pacman: 1283 lib: 318
flatpak: 5 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.13
Hi
I have posted the output of “inxi --admin --verbosity=7 --filter --width”
Additionally, Windows 11 is running on the same computer with the same HDMI cable flawlessly, therefore, the cable is fine.
I have tried many flavors of Linx(Ubuntu, Debian, Manjaro, PopOS, Mint, MXLinux) and I don’t have any sound on any of these distros until I disconnect, and then reconnect the hdmi cable.
Thanks for any help
I would suggest to install manjaro-pipewire and see if after reboot that helps.
You should consider updating motherboard BIOS - ASRock > B450M Pro4
I suspect system is using onboard analog audio as default-sink for audio output
and reconnecting HDMI cable is probably causing PulseAudio module module-switch-on-port-available to switch audio streams to HDMI output
Please post response to this command to show configuration of PulseAudio output sinks
pacmd list-sinks
the default-sink will be marked with an asterisk *
Thanks for your suggestion bogdancovaciu.
I installed “manjaro-pipewire” but, no change.
nikgnomic: thanks for your reply.
I ran “pacmd list-sinks” “bash: pacmd: command not found” was output.
I’m assuming this is because I installed “manjaro-pipewire”, which uninstalls “pulseaudio”
I ran “pipewire list-sinks” in terminal, the ouput is:
[E][01463.630418] mod.protocol-native | [module-protocol-: 609 lock_socket()] server 0x55a943dff440: unable to lock lockfile ‘/run/user/1000/pipewire-0.lock’: Resource temporarily unavailable (maybe another daemon is running)
[E][01463.630596] pw.conf | [ conf.c: 560 load_module()] 0x55a943dc1ea0: could not load mandatory module “libpipewire-module-protocol-native”: Resource temporarily unavailable
[E][01463.630635] pw.conf | [ conf.c: 647 create_object()] can’t find factory spa-node-factory
I’m not sure what this means, or if it is relevant?
Thanks for any help
AT THE TIME OF RUNNING THIS COMMAND IN TERMINAL, THE SOUND WAS WORKING FINE, AS I ALREADY DISONNECTED/RECONNECTED HDMI CABLE.
