Hello,
I am a complete newbie to Manjaro and Linux in general. I just installed the latest stable release on my laptop (Thinkpad L460). The built-in speakers don’t seem to be working. In the case of bluetooth headphones or speakers, there is audio coming, but of very bad quality. I looked through the forum for similar posts to troubleshoot, but can’t figure out what to do. Thanks in advance for any help! Also, apologies if I unknowingly violate any forum rules or guidelines.
Terminal outputs
inxi -Fazy
inxi -Fazy
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3d02c6e6-a262-450c-a9d2-e2ed4f871a31 rw quiet splash apparmor=1
security=apparmor resume=UUID=ae3fd5aa-701c-47df-9fbe-f3d7a534702d
udev.log_priority=3
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: LENOVO product: 20FVS07400 v: ThinkPad L460
Mobo: LENOVO model: 20FVS07400 v: SDK0J40705 WIN
serial: <superuser required> UEFI: LENOVO v: R08ET71W (1.45 )
date: 08/01/2022
ID-1: BAT0 charge: 12.1 Wh (100.0%) condition: 12.1/23.2 Wh (52.1%)
volts: 12.3 min: 11.1 model: SANYO LNV-45N1 type: Li-ion serial: <filter>
status: not charging
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 400/3000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 20004
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 5986:066b class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x2e3c built: 2013 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-7:7 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 223.58 GiB used: 17.83 GiB (8.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: GPT
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 11.6 GiB (29.7%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 316 KiB
(0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 32.59 GiB size: 31.78 GiB (97.52%) used: 6.23 GiB
(19.6%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 43.0 C pch: 40.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 249 Uptime: 1h 51m wakeups: 5 Memory: 7.62 GiB used: 2.92 GiB
(38.3%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1260 libs: 343
tools: gnome-software,pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.22
pacmd dump
pacmd dump
### Configuration dump generated at Fri Oct 28 12:47:13 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1f.3.analog-stereo 0x10000
set-sink-mute alsa_output.pci-0000_00_1f.3.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.analog-stereo no
set-source-volume alsa_output.pci-0000_00_1f.3.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.analog-stereo.monitor no
set-source-volume alsa_input.pci-0000_00_1f.3.analog-stereo 0xae6c
set-source-mute alsa_input.pci-0000_00_1f.3.analog-stereo no
suspend-source alsa_input.pci-0000_00_1f.3.analog-stereo no
set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_00_1f.3.analog-stereo
set-default-source alsa_input.pci-0000_00_1f.3.analog-stereo
### EOF
amixer --card=0
amixer --card=0
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Line Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Line Out',0
Mono:
Simple mixer control 'Mic Boost',0
Limits: 0 - 3
Front Left: 2 [67%] [20.00dB]
Front Right: 2 [67%] [20.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 63 [100%] [30.00dB] [on]
Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Dock Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Dock Mic' 'Mic' 'Line'
Item0: 'Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Dock Mic'
