Hello, it seems to be working kind of better now… like it didn’t shuffle anymore (or it seems until now)
I first tried disabling it from the bios (prior to this thread) and I think it was worse… it was still being shown in the system and messing the output even more.
I will post anyway the results of the
sudo alsa-info.sh --upload
But right now I have an issue when I updated Manjaro and I am trying to fix it first since I can’t run the console on the DE sadly…
I will update this as soon as I can, thanks a lot anyway for the info.
EDIT: I uploaded it but couldn’t find where, so I saved it to a file:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.0
!!Script ran on: Thu Aug 26 02:16:40 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: To Be Filled By O.E.M.
Product Name: To Be Filled By O.E.M.
Product Version: To Be Filled By O.E.M.
Firmware Version: P2.60
System SKU: To Be Filled By O.E.M.
Board Vendor: ASRock
Board Name: FM2A68M-DG3+
!!ACPI Device Status Information
/sys/bus/acpi/devices/LNXVIDEO:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0401:00/status 15
/sys/bus/acpi/devices/PNP0501:00/status 15
/sys/bus/acpi/devices/PNP0A08:00/status 15
/sys/bus/acpi/devices/PNP0C01:00/status 15
/sys/bus/acpi/devices/PNP0C02:05/status 15
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 11
/sys/bus/acpi/devices/PNP0C0F:01/status 11
/sys/bus/acpi/devices/PNP0C0F:02/status 11
/sys/bus/acpi/devices/PNP0C0F:03/status 11
/sys/bus/acpi/devices/PNP0C0F:04/status 11
/sys/bus/acpi/devices/PNP0C0F:05/status 11
/sys/bus/acpi/devices/PNP0C0F:06/status 11
/sys/bus/acpi/devices/PNP0C0F:07/status 11
/sys/bus/acpi/devices/device:23/status 15
/sys/bus/acpi/devices/device:24/status 15
/sys/bus/acpi/devices/device:27/status 15
!!Kernel Information
Kernel release: 5.10.59-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.10.59-1-MANJARO
Library version: 1.2.5.1
Utilities version: 1.2.5.1
!!Loaded ALSA modules
snd_ice1724 (card 0)
snd_hda_intel (card 1)
snd_hda_intel (card 2)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [ICE1724 ]: ICE1724 - ICEnsemble ICE1724
ICEnsemble ICE1724 at 0xd080, irq 20
1 [HDMI ]: HDA-Intel - HDA ATI HDMI
HDA ATI HDMI at 0xfeb64000 irq 34
2 [Generic ]: HDA-Intel - HD-Audio Generic
HD-Audio Generic at 0xfeb60000 irq 16
!!PCI Soundcards installed in the system
02:05.0 Multimedia audio controller [0401]: VIA Technologies Inc. VT1720/24 [Envy24PT/HT] PCI Multi-Channel Audio Controller [1412:1724] (rev 01)
Subsystem: VIA Technologies Inc. Device [1412:2403]
00:01.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Kaveri HDMI/DP Audio Controller [1002:1308]
Subsystem: ASRock Incorporation Device [1849:1308]
00:14.2 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller [1022:780d] (rev 01)
Subsystem: ASRock Incorporation Device [1849:7662]
!!Loaded sound module options
!!Module: snd_ice1724
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable_msi : -1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_ice1724
Tree:
!!Card: /sys/class/sound/card1
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card2
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100500
No Modem Function Group found
Default PCM:
rates [0x70]: 32000 44100 48000
bits [0x2]: 16
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Converter: stream=0, channel=0
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Pincap 0x00000094: OUT Detect HDMI
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=01, enabled=1
Connection: 1
0x02
Node 0x04 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x05 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x04
Node 0x06 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x07 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x08 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x09 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x08
Node 0x0a [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0b [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0a
Node 0x0c [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0d [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0c
Node 0x0e [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0f [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0e
Codec: Realtek ALC662 rev1
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0662
Subsystem Id: 0x18497662
Revision Id: 0x100101
Default PCM:
rates [0x160]: 44100 48000 96000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x1d: Stereo Amp-Out
Control: name="Headphone+LO Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC662 rev1 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
Amp-Out vals: [0x3d 0x3d]
Converter: stream=5, channel=0
PCM:
formats [0x1]: PCM
Node 0x03 [Audio Output] wcaps 0x1d: Stereo Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x1d: Stereo Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
PCM:
formats [0x1]: PCM
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x211: Stereo Digital
Digital:
PCM:
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x09, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x9f 0x9f]
Converter: stream=1, channel=0
SDI-Select: 0
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC662 rev1 Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
SDI-Select: 0
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Rear Mic Playback Volume", index=0, device=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 9
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0001003c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=04, enabled=1
Connection: 1
0x0c
Node 0x15 [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pincap 0x00010034: IN OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x20: IN
Connection: 1
0x0d
Node 0x16 [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Pincap 0x00000034: IN OUT Detect
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0e
Node 0x17 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x18 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Control: name="Rear Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00001734: IN OUT Detect
Vref caps: HIZ 50 GRD 80
Pin Default 0x01a19040: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 1
0x0e
Node 0x19 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Amp-In vals: [0x01 0x01]
Pincap 0x0000173c: IN OUT HP Detect
Pin Default 0x02a19150: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Misc = NO_PRESENCE
Connection: 2
0x0c* 0x0e
Node 0x1a [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Pin Default 0x0181304f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Pin-ctls: 0x20: IN
Unsolicited: tag=03, enabled=1
Connection: 1
0x0d
Node 0x1b [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pin Default 0x02214120: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Connection: 2
0x0c* 0x0e
Node 0x1c [Pin Complex] wcaps 0x400001: Stereo
Pincap 0x00000020: IN
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400000: Mono
Pin Default 0x40a4c601: [N/A] Mic at Ext N/A
Conn = RCA, Color = UNKNOWN
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400300: Mono Digital
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=12
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 10
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x26 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!AC97 Codec information
--startcollapse--
0-0/0: VIA Technologies VIA1617A
PCI Subsys Vendor: 0x0000
PCI Subsys Device: 0x0000
Flags: 0
Revision : 0x00
Compat. Class : 0x00
Subsys. Vendor ID: 0xffff
Subsys. ID : 0xffff
Capabilities : -headphone out-
DAC resolution : 18-bit
ADC resolution : 18-bit
3D enhancement : IC Ensemble/KS Waves
Current setup
Mic gain : +0dB [+0dB]
POP path : pre 3D
Sim. stereo : off
3D enhancement : off
Loudness : off
Mono output : MIX
Mic select : Mic1
ADC/DAC loopback : off
Double rate slots: 10/11
Extended ID : codec=0 rev=2 LDAC SDAC CDAC DSA=0 SPDIF DRA VRA
Extended status : SPCV LDAC SDAC CDAC SPDIF=10/11 VRA
PCM front DAC : 48000Hz
PCM Surr DAC : 48000Hz
PCM LFE DAC : 48000Hz
PCM ADC : 48000Hz
SPDIF Control : Consumer PCM Category=0x2 Generation=1 Rate=48kHz
0:00 = 6d50
0:02 = 0000
0:04 = 0000
0:06 = 801f
0:08 = 0000
0:0a = 801e
0:0c = 801f
0:0e = 801f
0:10 = 9f1f
0:12 = 9f1f
0:14 = 0000
0:16 = 9f1f
0:18 = 0404
0:1a = 0000
0:1c = 0808
0:1e = 0000
0:20 = 0000
0:22 = 0000
0:24 = 0001
0:26 = 800f
0:28 = 09c7
0:2a = 05f1
0:2c = bb80
0:2e = bb80
0:30 = bb80
0:32 = bb80
0:34 = 0000
0:36 = 0000
0:38 = 0000
0:3a = 2824
0:3c = 0000
0:3e = 0000
0:40 = 0000
0:42 = 0000
0:44 = 0000
0:46 = 0000
0:48 = 0000
0:4a = 0000
0:4c = 0000
0:4e = 0000
0:50 = 0000
0:52 = 0000
0:54 = 0000
0:56 = 0000
0:58 = 0000
0:5a = 8200
0:5c = 0020
0:5e = 0000
0:60 = 0000
0:62 = ffff
0:64 = ffff
0:66 = 0000
0:68 = 0000
0:6a = 0000
0:6c = 3760
0:6e = 0000
0:70 = 0000
0:72 = 0000
0:74 = 0004
0:76 = 0000
0:78 = 0070
0:7a = 0370
0:7c = 5649
0:7e = 4170
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 9 Aug 25 22:47 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 4 Aug 25 22:47 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 14 Aug 25 22:47 /dev/snd/controlC2
crw-rw----+ 1 root audio 116, 3 Aug 25 22:47 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 13 Aug 25 22:47 /dev/snd/hwC2D0
crw-rw----+ 1 root audio 116, 6 Aug 25 22:47 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 5 Aug 25 23:14 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 8 Aug 25 22:47 /dev/snd/pcmC0D1c
crw-rw----+ 1 root audio 116, 7 Aug 25 22:47 /dev/snd/pcmC0D1p
crw-rw----+ 1 root audio 116, 2 Aug 25 22:47 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 11 Aug 25 22:47 /dev/snd/pcmC2D0c
crw-rw----+ 1 root audio 116, 10 Aug 25 22:47 /dev/snd/pcmC2D0p
crw-rw----+ 1 root audio 116, 12 Aug 25 22:47 /dev/snd/pcmC2D2c
crw-rw----+ 1 root audio 116, 1 Aug 25 22:47 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Aug 25 22:47 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 100 Aug 25 22:47 .
drwxr-xr-x 3 root root 360 Aug 25 22:47 ..
lrwxrwxrwx 1 root root 12 Aug 25 22:47 pci-0000:00:01.1 -> ../controlC1
lrwxrwxrwx 1 root root 12 Aug 25 22:47 pci-0000:00:14.2 -> ../controlC2
lrwxrwxrwx 1 root root 12 Aug 25 22:47 pci-0000:02:05.0 -> ../controlC0
!!ALSA configuration files
!!System wide config file (/etc/asound.conf)
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: ICE1724 [ICEnsemble ICE1724], device 0: ICE1724 [ICE1724]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: ICE1724 [ICEnsemble ICE1724], device 1: ICE1724 IEC958 [ICE1724 IEC958]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 2: ALC662 rev1 Alt Analog [ALC662 rev1 Alt Analog]
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card ICE1724
Card sysdefault:0 'ICE1724'/'ICEnsemble ICE1724 at 0xd080, irq 20'
Mixer name : 'VIA Technologies VIA1617A'
Components : 'AC97a:56494170'
Controls : 59
Simple ctrls : 37
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 31
Mono: Playback 31 [100%] [0.00dB] [on]
Simple mixer control 'Master Mono',0
Mono: Playback 0 [0%] [-46.50dB] [off]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch pswitch-joined
Mono:
Front Left: Playback 31 [100%] [0.00dB] [on]
Front Right: Playback 31 [100%] [0.00dB] [on]
Simple mixer control '3D Control - Center',0
Capabilities: volume volume-joined
Capture channels: Mono
Limits: 0 - 15
Mono: 0 [0%]
Simple mixer control '3D Control - Depth',0
Limits: Playback 0 - 15
Simple mixer control '3D Control - Switch',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'PCM',0
Mono:
Front Left: Playback 27 [87%] [6.00dB] [on]
Front Right: Playback 27 [87%] [6.00dB] [on]
Simple mixer control 'Front',0
Mono:
Simple mixer control 'Surround',0
Mono:
Simple mixer control 'Center',0
Simple mixer control 'Center/LFE Exchange',0
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Capabilities: pvolume pswitch pswitch-joined cswitch cswitch-exclusive
Capture exclusive group: 0
Front Left: Playback 0 [0%] [-34.50dB] [off] Capture [off]
Front Right: Playback 0 [0%] [-34.50dB] [off] Capture [off]
Simple mixer control 'CD',0
Simple mixer control 'Mic',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined cswitch cswitch-exclusive
Mono: Playback 0 [0%] [-34.50dB] [off]
Front Left: Capture [on]
Front Right: Capture [on]
Simple mixer control 'Mic Boost (+20dB)',0
Simple mixer control 'Mic Select',0
Capabilities: enum
Items: 'Mic1' 'Mic2'
Item0: 'Mic1'
Simple mixer control 'Video',0
Capabilities: cswitch cswitch-exclusive
Front Left: Capture [off]
Front Right: Capture [off]
Simple mixer control 'Phone',0
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined penum
Items: 'PCM Out' 'H/W In 0' 'H/W In 1' 'IEC958 In L' 'IEC958 In R'
Item0: 'PCM Out'
Simple mixer control 'IEC958 Output',0
Mono: Playback [on]
Simple mixer control 'IEC958 Playback AC97-SPSA',0
Limits: 0 - 3
Mono: 3 [100%]
Simple mixer control 'IEC958',1
Capabilities: penum
Item0: 'PCM Out'
Simple mixer control 'Beep',0
Mono: Playback 0 [0%] [-45.00dB] [off]
Simple mixer control 'Aux',0
Simple mixer control 'Mono Output Select',0
Capabilities: enum
Items: 'Mix' 'Mic'
Item0: 'Mix'
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch cswitch-joined
Limits: Capture 0 - 15
Front Left: Capture 8 [53%] [12.00dB] [on]
Front Right: Capture 8 [53%] [12.00dB] [on]
Simple mixer control 'Mix',0
Simple mixer control 'Mix Mono',0
Simple mixer control 'Alternate Level to Surround Out',0
Mono: Playback [on]
Simple mixer control 'Downmix LFE and Center to Front',0
Simple mixer control 'Downmix Surround to Front',0
Simple mixer control 'External Amplifier',0
Simple mixer control 'Multi Track Internal Clock',0
Capabilities: enum
Items: '8000' '9600' '11025' '12000' '16000' '22050' '24000' '32000' '44100' '48000' 'IEC958 In'
Item0: '48000'
Simple mixer control 'Multi Track Rate Locking',0
Simple mixer control 'Multi Track Rate Reset',0
Mono: Playback [on]
Simple mixer control 'Smart 5.1 Select',0
Capabilities: enum
Items: 'LineIn Mic1' 'LineIn Mic1 Mic3' 'Surr LFE/C Mic3' 'LineIn LFE/C Mic3' 'LineIn Mic2' 'LineIn Mic2 Mic1' 'Surr LFE Mic1' 'Surr LFE Mic1 Mic2'
Item0: 'LineIn Mic1'
!!-------Mixer controls for card HDMI
Card sysdefault:1 'HDMI'/'HDA ATI HDMI at 0xfeb64000 irq 34'
Mixer name : 'ATI R6xx HDMI'
Components : 'HDA:1002aa01,00aa0100,00100500'
Controls : 7
Simple ctrls : 1
Mono: Playback [on]
!!-------Mixer controls for card Generic
Card sysdefault:2 'Generic'/'HD-Audio Generic at 0xfeb60000 irq 16'
Mixer name : 'Realtek ALC662 rev1'
Components : 'HDA:10ec0662,18497662,00100101'
Controls : 36
Simple ctrls : 19
Limits: Playback 0 - 64
Mono: Playback 61 [95%] [-3.00dB] [on]
Mono:
Front Left: Playback [off]
Front Right: Playback [off]
Simple mixer control 'Headphone+LO',0
Mono:
Front Left: Playback 64 [100%] [0.00dB]
Front Right: Playback 64 [100%] [0.00dB]
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'Front Mic',0
Mono:
Simple mixer control 'Front Mic Boost',0
Limits: 0 - 3
Front Left: 1 [33%] [10.00dB]
Front Right: 1 [33%] [10.00dB]
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Mono: Playback 64 [100%] [0.00dB] [on]
Mono:
Limits: Capture 0 - 31
Front Left: Capture 31 [100%] [33.00dB] [off]
Front Right: Capture 31 [100%] [33.00dB] [off]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-13.50dB] [off]
Front Right: Capture 0 [0%] [-13.50dB] [off]
Simple mixer control 'Channel Mode',0
Capabilities: enum
Items: '2ch' '4ch' '6ch'
Item0: '2ch'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
!!Alsactl output
--startcollapse--
state.ICE1724 {
control.1 {
iface MIXER
name 'Center/LFE Exchange'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'Smart 5.1 Select'
value 'LineIn Mic1'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'LineIn Mic1'
item.1 'LineIn Mic1 Mic3'
item.2 'Surr LFE/C Mic3'
item.3 'LineIn LFE/C Mic3'
item.4 'LineIn Mic2'
item.5 'LineIn Mic2 Mic1'
item.6 'Surr LFE Mic1'
item.7 'Surr LFE Mic1 Mic2'
control.3 {
iface MIXER
name 'Front Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.4 {
iface MIXER
name 'Front Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -4650
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.5 {
iface MIXER
name 'Center Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface MIXER
name 'Center Playback Volume'
value 31
comment {
access 'read write'
type INTEGER
count 1
range '0 - 31'
dbmin -4650
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
name 'LFE Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.8 {
iface MIXER
name 'LFE Playback Volume'
value 31
comment {
access 'read write'
type INTEGER
count 1
range '0 - 31'
dbmin -4650
dbmax 0
dbvalue.0 0
control.9 {
iface MIXER
name 'Surround Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.10 {
iface MIXER
name 'Surround Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -4650
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.11 {
iface MIXER
name 'Headphone Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface MIXER
name 'Headphone Playback Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -4650
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.13 {
iface MIXER
name 'Master Mono Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.14 {
iface MIXER
name 'Master Mono Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 31'
dbmin -4650
dbmax 0
dbvalue.0 -4650
control.15 {
iface MIXER
name 'Beep Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.16 {
iface MIXER
name 'Beep Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -4500
dbmax 0
dbvalue.0 -4500
control.17 {
iface MIXER
name 'Phone Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface MIXER
name 'Phone Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
control.19 {
iface MIXER
name 'Mic Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.20 {
iface MIXER
name 'Mic Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
control.21 {
iface MIXER
name 'Mic Boost (+20dB)'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.22 {
iface MIXER
name 'Line Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.23 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.24 {
iface MIXER
name 'CD Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.25 {
iface MIXER
name 'CD Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.26 {
iface MIXER
name 'Aux Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.27 {
iface MIXER
name 'Aux Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.28 {
iface MIXER
name 'PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.29 {
iface MIXER
name 'PCM Playback Volume'
value.0 27
value.1 27
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 600
dbvalue.1 600
control.30 {
iface MIXER
name 'Capture Source'
value.0 Mic
value.1 Mic
comment {
access 'read write'
type ENUMERATED
count 2
item.0 Mic
item.1 CD
item.2 Video
item.3 Aux
item.4 Line
item.5 Mix
item.6 'Mix Mono'
item.7 Phone
control.31 {
iface MIXER
name 'Capture Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.32 {
iface MIXER
name 'Capture Volume'
value.0 8
value.1 8
comment {
access 'read write'
type INTEGER
count 2
range '0 - 15'
dbmin 0
dbmax 2250
dbvalue.0 1200
dbvalue.1 1200
control.33 {
iface MIXER
name '3D Control - Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.34 {
iface MIXER
name 'Mono Output Select'
value Mix
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Mix
item.1 Mic
control.35 {
iface MIXER
name 'Mic Select'
value Mic1
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Mic1
item.1 Mic2
control.36 {
iface MIXER
name '3D Control - Center'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
control.37 {
iface MIXER
name '3D Control - Depth'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
control.38 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value cf00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
name 'IEC958 Playback Default'
value '0082000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.41 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.42 {
iface MIXER
name 'IEC958 Playback AC97-SPSA'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 3'
control.43 {
iface MIXER
name 'Alternate Level to Surround Out'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.44 {
iface MIXER
name 'Downmix LFE and Center to Front'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.45 {
iface MIXER
name 'Downmix Surround to Front'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.46 {
iface MIXER
name 'Master Playback Volume'
value 31
comment {
access 'read write'
type INTEGER
count 1
range '0 - 31'
dbmin -4650
dbmax 0
dbvalue.0 0
control.47 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.48 {
iface MIXER
name 'External Amplifier'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.49 {
iface CARD
name 'ICE1724 EEPROM'
value '240314121c01020210c3ff0000ff0000ff0000000101010001000000000000000000000000000000ff000000ff000000ff000000'
comment {
access read
type BYTES
count 52
control.50 {
iface MIXER
name 'Multi Track Internal Clock'
value '48000'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '8000'
item.1 '9600'
item.2 '11025'
item.3 '12000'
item.4 '16000'
item.5 '22050'
item.6 '24000'
item.7 '32000'
item.8 '44100'
item.9 '48000'
item.10 'IEC958 In'
control.51 {
iface MIXER
name 'Multi Track Rate Locking'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.52 {
iface MIXER
name 'Multi Track Rate Reset'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.53 {
iface PCM
name 'Multi Track Peak'
value.0 34
value.1 34
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
value.8 0
value.9 0
value.10 3
value.11 1
value.12 0
value.13 0
value.14 0
value.15 0
value.16 0
value.17 0
value.18 0
value.19 0
value.20 0
value.21 0
comment {
access 'read volatile'
type INTEGER
count 22
range '0 - 255'
control.54 {
iface MIXER
name 'IEC958 Playback Route'
value 'PCM Out'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'PCM Out'
item.1 'H/W In 0'
item.2 'H/W In 1'
item.3 'IEC958 In L'
item.4 'IEC958 In R'
control.55 {
iface MIXER
index 1
value 'PCM Out'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'PCM Out'
item.1 'H/W In 0'
item.2 'H/W In 1'
control.56 {
iface MIXER
name 'IEC958 Output Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.57 {
iface PCM
device 1
value '0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.58 {
iface PCM
device 1
value '3fff000f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.59 {
iface PCM
device 1
value df00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
comment {
access read
type IEC958
count 1
state.HDMI {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
type BYTES
count 0
control.7 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.Generic {
control.1 {
iface MIXER
name 'Channel Mode'
value '2ch'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '2ch'
item.1 '4ch'
item.2 '6ch'
control.2 {
iface MIXER
name 'Headphone+LO Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.3 {
iface MIXER
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.4 {
iface MIXER
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.5 {
iface MIXER
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.6 {
iface MIXER
value 64
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
value 64
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
control.8 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.10 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.12 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.13 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.14 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.15 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.16 {
iface MIXER
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.17 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.18 {
iface MIXER
name 'Input Source'
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.19 {
iface MIXER
name 'Input Source'
index 1
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.20 {
iface MIXER
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1350
dbmax 3300
dbvalue.0 3300
dbvalue.1 3300
control.21 {
iface MIXER
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.22 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1350
dbmax 3300
dbvalue.0 -1350
dbvalue.1 -1350
control.23 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.24 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 1
value.1 1
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 1000
dbvalue.1 1000
control.25 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.26 {
iface MIXER
value 61
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -300
control.27 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.28 {
iface CARD
name 'Front Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.29 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.30 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.31 {
iface CARD
name 'Line Out Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface CARD
name 'Front Headphone Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.33 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.34 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.35 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.36 {
iface MIXER
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_cpufreq
aesni_intel
agpgart
amdgpu
ccp
cec
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
edac_mce_amd
ext4
fam15h_power
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
gpu_sched
hid_logitech_dj
hid_logitech_hidpp
i2c_algo_bit
i2c_piix4
ip_tables
irqbypass
jbd2
joydev
k10temp
kvm
kvm_amd
ledtrig_audio
libphy
loop
mac_hid
mbcache
mdio_devres
mousedev
parport
parport_pc
pcspkr
ppdev
r8169
radeon
realtek
rfkill
rng_core
snd
snd_ac97_codec
snd_ak4113
snd_ak4114
snd_ak4xxx_adda
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_i2c
snd_ice1724
snd_ice17xx_ak4xxx
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_pt2258
snd_rawmidi
snd_seq_device
snd_soc_core
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sp5100_tco
squashfs
syscopyarea
sysfillrect
sysimgblt
ttm
uas
usb_storage
usbhid
vfat
video
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x185600f0
0x05 0x585600f0
0x07 0x585600f0
0x09 0x585600f0
0x0b 0x585600f0
0x0d 0x585600f0
0x0f 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
/sys/class/sound/hwC2D0/init_pin_configs:
0x14 0x01014010
0x15 0x40000000
0x16 0x411111f0
0x18 0x01a19040
0x19 0x02a19150
0x1a 0x0181304f
0x1b 0x02214120
0x1c 0x411111f0
0x1d 0x40a4c601
0x1e 0x411111f0
/sys/class/sound/hwC2D0/driver_pin_configs:
/sys/class/sound/hwC2D0/user_pin_configs:
/sys/class/sound/hwC2D0/init_verbs:
/sys/class/sound/hwC2D0/hints:
!!ALSA/HDA dmesg
[ 0.243311] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.243311] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.243311] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 10.298917] radeon 0000:00:01.0: fence driver on ring 7 use gpu addr 0x0000000040000c1c
[ 10.319255] snd_ice1724 0000:02:05.0: No matching model found for ID 0x12140324
[ 10.356139] radeon 0000:00:01.0: radeon: using MSI.
[ 10.453156] [drm] ring test on 4 succeeded in 3 usecs
[ 10.492230] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[ 10.527958] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card1/input27
[ 10.693816] [drm] ring test on 5 succeeded in 1 usecs
[ 10.726672] ppdev: user-space parallel port driver
[ 10.728542] snd_hda_codec_realtek hdaudioC2D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 10.728547] snd_hda_codec_realtek hdaudioC2D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 10.728548] snd_hda_codec_realtek hdaudioC2D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 10.728550] snd_hda_codec_realtek hdaudioC2D0: mono: mono_out=0x0
[ 10.728551] snd_hda_codec_realtek hdaudioC2D0: inputs:
[ 10.728553] snd_hda_codec_realtek hdaudioC2D0: Front Mic=0x19
[ 10.728555] snd_hda_codec_realtek hdaudioC2D0: Rear Mic=0x18
[ 10.728556] snd_hda_codec_realtek hdaudioC2D0: Line=0x1a
[ 10.750667] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card2/input28
[ 10.750741] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:14.2/sound/card2/input29
[ 10.750807] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:14.2/sound/card2/input30
[ 10.773547] r8169 0000:01:00.0 enp1s0: renamed from eth0
[ 12.855097] [drm] Connector 2:
[ 12.855098] [drm] HDMI-A-1
[ 12.855099] [drm] HPD2
