Sound can only be at 30 or 40%
i think it happened after last update, i cant be sure, my speakers also died ( i dont know if its related )
i replaced speakers and they work now but problem with only 30% or 40% volume power remains
inxi -A
 Device-1: Intel Comet Lake PCH-V cAVS driver: snd_hda_intel
  Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
    Series] driver: snd_hda_intel
  API: ALSA v: k6.1.44-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 0.3.77 status: active
inxi -F
  Host: d Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 Desktop: KDE Plasma
    v: 5.27.7 Distro: Manjaro Linux
  Type: Desktop Mobo: ASRock model: B460M-HDV serial: <superuser required>
    BIOS: American Megatrends v: P1.60 date: 06/23/2020
  Info: dual core model: Intel Pentium Gold G6405 bits: 64 type: MT MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 975 min/max: 800/4100 cores: 1: 800 2: 1500 3: 800
    4: 800
  Device-1: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E] driver: radeon
    v: kernel
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: radeon
    unloaded: modesetting dri: radeonsi gpu: radeon resolution:
    1: 1920x1080~60Hz 2: 1920x1080~60Hz
  API: OpenGL v: 4.5 Mesa 23.1.5 renderer: VERDE ( LLVM 15.0.7 DRM 2.50
    6.1.44-1-MANJARO)
  Device-1: Intel Ethernet I219-V driver: e1000e
  IF: eno1 state: up speed: 100 Mbps duplex: full mac: a8:a1:59:59:1e:d2
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    type: USB
  Local Storage: total: 2.04 TiB used: 1.19 TiB (58.3%)
  ID-1: /dev/sda vendor: Patriot model: Blast size: 223.57 GiB
  ID-2: /dev/sdb vendor: Hitachi model: HDS723020BLA642 size: 1.82 TiB
  ID-1: / size: 214.77 GiB used: 184.71 GiB (86.0%) fs: btrfs dev: /dev/sda1
  ID-2: /home size: 214.77 GiB used: 184.71 GiB (86.0%) fs: btrfs
    dev: /dev/sda1
  ID-3: /var/log size: 214.77 GiB used: 184.71 GiB (86.0%) fs: btrfs
    dev: /dev/sda1
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/sda2
  System Temperatures: cpu: 39.0 C mobo: N/A gpu: radeon temp: 43.0 C
  Processes: 234 Uptime: 41m Memory: total: 16 GiB available: 15.55 GiB
  used: 2.66 GiB (17.1%) Shell: Zsh inxi: 3.3.28
is there a way to reload audio drivers, or reinstall ?
Is that some kind of estimation / your personal assessment of the situation
or is that based upon some actual numbers and if so, where and how and when do you get to see them?
Without knowing anything about your speakers, are they the right impedance for your sound card?
Also, show us the current levels from
amixer
Assuming that wireplumber is installed, you could also do
wpctl get-volume @DEFAULT_SINK@
its based on whenever i try to scroll up and down volume it goes to either 30 or 40%, same happens if i try to adjust volume with volume up/down keys,
one extra thing that i see multiple of same audio outputs
To see ALSA audio controls for onboard audio codec (Realtek ALC887-VD)
amixer --card=PCH
or
amixer --card=0
i dont know what is “impedance of my sound card”
amixer
Simple mixer control 'Master',0
  Capabilities: pvolume pswitch pswitch-joined
  Limits: Playback 0 - 65536
  Mono:
  Front Left: Playback 33423 [51%] [on]
  Front Right: Playback 33423 [51%] [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cvolume-joined cswitch cswitch-joined
  Capture channels: Mono
  Limits: Capture 0 - 65536
  Mono: Capture 0 [0%] [on]
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Items: 'Front Mic' 'Rear Mic' 'Line'
  Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Rear Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
this looks strange, i currently have audio, but as i said i cant adjust it
Multiple outputs in Audio GUI controls is due to a bug in latest version of PipeWire
Bluetooth headset showing multiple entries in KDE after update
amixer response for onboard audio codec should show a lot more audio controls
HW probe of ASRock B460M-HDV Desktop Computer #c9af89da15: amixer
scroll up in terminal to find audio playback controls for ‘Master’ ‘PCM’ and ‘Front’
Speakers, not sound card.
I have the same problem after last update, but with my laptop if laptop lid close and open again
Also mute button work one time then freeze and I have to restart
