Sometimes X11 server die after left-click after the last update (Maybe Qt problem)
Hello there!
I have encountered another issue with the latest update. I’m unsure of when it occurs, but occasionally, when I left-click, my X11 will break. I see a black screen for a minute, after which I return to SDDM, and logging in doesn’t work. If we look at the journalctl, we can see that the problem is linked with Qt.
journalctl for that case:
мар 18 18:53:23 poh9shka-pc kioworker[52376]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:23 poh9shka-pc kioworker[52376]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:23 poh9shka-pc kioworker[52376]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                 Available platform plugins are: linuxfb, xcb, minimalegl, wayland, vkkhrdisplay, minimal, vnc, eglfs, offscreen, wayland-egl.
мар 18 18:53:23 poh9shka-pc systemd-coredump[52380]: [🡕] Process 52376 (kioworker) of user 1000 dumped core.
                                                        Stack trace of thread 52376:
                                                        #0  0x00007fb97c0ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007fb97c05a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007fb97c0424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007fb97c28a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007fb97c28b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007fb97a0d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007fb97a174a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007fb97c33db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007fb97a174ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007fb9768f53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x00007fb97cadc7b0 kdemain (thumbnail.so + 0xb7b0)
                                                        #11 0x000056458323c220 n/a (kioworker + 0x1220)
                                                        #12 0x00007fb97c043cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #13 0x00007fb97c043d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #14 0x000056458323c4e5 n/a (kioworker + 0x14e5)
                                                        Stack trace of thread 52377:
                                                        #0  0x00007fb97c1190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007fb97b37f2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007fb97b31f162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007fb97c5739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007fb97c343d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007fb97c42106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007fb97bcb09df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007fb97c4a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007fb97c0a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007fb97c126a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:24 poh9shka-pc systemd-coredump[52398]: [🡕] Process 1120 (Xorg) of user 0 dumped core.
                                                        Stack trace of thread 1120:
                                                        #0  0x00007f8c886d532c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f8c886846c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f8c8866c4b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000055b0e113ea30 OsAbort (/usr/lib/Xorg (deleted) + 0x159a30)
                                                        #4  0x000055b0e113ed6b FatalError (/usr/lib/Xorg (deleted) + 0x159d6b)
                                                        #5  0x000055b0e1136ce6 n/a (/usr/lib/Xorg (deleted) + 0x151ce6)
                                                        #6  0x00007f8c88684770 n/a (libc.so.6 + 0x40770)
                                                        #7  0x00007f8c876b0ee5 n/a (nvidia_drv.so + 0x4b0ee5)
мар 18 18:53:24 poh9shka-pc baloorunner[9251]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc krunner[14265]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc pulseaudio[2674]: X11 I/O error handler called
мар 18 18:53:24 poh9shka-pc pulseaudio[2674]: X11 I/O error exit handler called, preparing to tear down X11 modules
мар 18 18:53:24 poh9shka-pc xdg-desktop-portal-kde[2509]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc kscreen_backend_launcher[2531]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc kaccess[2655]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc kwalletd6[2361]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc msm_kde_notifier[2629]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc pamac-tray-plasma[2657]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc org_kde_powerdevil[2508]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc xembedsniproxy[2510]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc kdeconnectd[2632]: 2024-03-18T18:53:24 default: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc gmenudbusmenuproxy[2506]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc kactivitymanagerd[2503]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc kded6[2434]: The X11 connection broke: I/O error (code 1)
мар 18 18:53:24 poh9shka-pc kglobalacceld[2391]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc polkit-kde-authentication-agent-1[2507]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc plasmashell[2462]: The X11 connection broke (error 1). Did the X11 server die?
мар 18 18:53:24 poh9shka-pc kwin_x11[2435]: The X11 connection broke: I/O error (code 1)
мар 18 18:53:24 poh9shka-pc systemd[2339]: dbus-:1.45-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc kglobalacceld[2391]: The X11 connection broke: I/O error (code 1)
мар 18 18:53:24 poh9shka-pc krunner[14265]: QSocketNotifier: Socket notifiers cannot be enabled or disabled from another thread
мар 18 18:53:24 poh9shka-pc kdeconnectd[2632]: 2024-03-18T18:53:24 org.kde.pulseaudio: No object for name "alsa_output.pci-0000_2d_00.4.analog-stereo"
мар 18 18:53:24 poh9shka-pc kdeconnectd[2632]: 2024-03-18T18:53:24 org.kde.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC404_96k-00.multichannel-input"
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc krunner[14265]: QSocketNotifier: Invalid socket 36 and type 'Exception', disabling...
мар 18 18:53:24 poh9shka-pc systemd[2339]: bamfdaemon.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc systemd[2339]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc systemd[2339]: app-kaccess@autostart.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-kded6.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc systemd[2339]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc xembedsniproxy[52467]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:24 poh9shka-pc xembedsniproxy[52467]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:24 poh9shka-pc xembedsniproxy[52467]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:24 poh9shka-pc bamfdaemon[52475]: cannot open display: :0
мар 18 18:53:24 poh9shka-pc systemd[2339]: Failed to start BAMF Application Matcher Framework.
мар 18 18:53:24 poh9shka-pc systemd[2339]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
мар 18 18:53:24 poh9shka-pc sddm-helper[2333]: Signal received: SIGTERM
мар 18 18:53:24 poh9shka-pc gmenudbusmenuproxy[52483]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:24 poh9shka-pc gmenudbusmenuproxy[52483]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:24 poh9shka-pc gmenudbusmenuproxy[52483]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:24 poh9shka-pc sddm[1105]: Auth: sddm-helper exited with 255
мар 18 18:53:24 poh9shka-pc systemd-coredump[52437]: [🡕] Process 2432 (ksmserver) of user 1000 dumped core.
                                                        Stack trace of thread 2432:
                                                        #0  0x00007f0e255f7a2c _ZN10QXcbScreen23updateColorSpaceAndEdidEv (libQt6XcbQpa.so.6 + 0x5da2c)
                                                        #1  0x00007f0e255d32b5 _ZN14QXcbConnection20updateScreen_monitorEP10QXcbScreenP24xcb_randr_monitor_info_tj (libQt6XcbQpa.so.6 + 0x392b5)
                                                        #2  0x00007f0e255d5572 _ZN14QXcbConnection28initializeScreensFromMonitorEP21xcb_screen_iterator_tiPP10QXcbScreenb (libQt6XcbQpa.so.6 + 0x3b572)
                                                        #3  0x00007f0e255d5cfe _ZN14QXcbConnection17initializeScreensEb (libQt6XcbQpa.so.6 + 0x3bcfe)
                                                        #4  0x00007f0e255cb751 _ZN14QXcbConnection14handleXcbEventEP19xcb_generic_event_t (libQt6XcbQpa.so.6 + 0x31751)
                                                        #5  0x00007f0e255d176c _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6XcbQpa.so.6 + 0x3776c)
                                                        #6  0x00007f0e255e6bd7 n/a (libQt6XcbQpa.so.6 + 0x4cbd7)
                                                        #7  0x00007f0e294bcf69 n/a (libglib-2.0.so.0 + 0x59f69)
                                                        #8  0x00007f0e2951b3a7 n/a (libglib-2.0.so.0 + 0xb83a7)
                                                        #9  0x00007f0e294bb162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #10 0x00007f0e2a3739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #11 0x00007f0e2a143d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #12 0x00007f0e2a13c2b8 _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x13c2b8)
                                                        #13 0x0000558ecdc9aef6 n/a (ksmserver + 0xaef6)
                                                        #14 0x00007f0e29a43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #15 0x00007f0e29a43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #16 0x0000558ecdc9bc55 n/a (ksmserver + 0xbc55)
                                                        Stack trace of thread 2445:
                                                        #0  0x00007f0e2a180e80 _ZN7QObjectD1Ev (libQt6Core.so.6 + 0x180e80)
                                                        #1  0x00007f0e2a37488d _ZN20QEventDispatcherGlibD0Ev (libQt6Core.so.6 + 0x37488d)
                                                        #2  0x00007f0e2a3d5621 n/a (libQt6Core.so.6 + 0x3d5621)
                                                        #3  0x00007f0e2a2a0be2 n/a (libQt6Core.so.6 + 0x2a0be2)
                                                        #4  0x00007f0e29aa955a n/a (libc.so.6 + 0x8f55a)
                                                        #5  0x00007f0e29b26a3c n/a (libc.so.6 + 0x10ca3c)
                                                        Stack trace of thread 2444:
                                                        #0  0x00007f0e29b190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f0e2951b2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f0e294bb162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f0e2a3739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f0e2a143d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f0e2a22106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f0e2aed09df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f0e2a2a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f0e29aa955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f0e29b26a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:24 poh9shka-pc systemd-coredump[52481]: [🡕] Process 52467 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 52467:
                                                        #0  0x00007f3532cab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f3532c5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f3532c424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f353328a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f353328b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f35338d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f3533974a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f353333db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f3533974ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f353396c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x000055c2b78c4233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x00007f3532c43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f3532c43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x000055c2b78c4595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 52477:
                                                        #0  0x00007f3532d190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f3532b862f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f3532b26162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f35335739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f3533343d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f353342106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f353422f9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f35334a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f3532ca955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f3532d26a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-xembedsniproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-xembedsniproxy.service: Failed with result 'core-dump'.
мар 18 18:53:24 poh9shka-pc pipewire[2596]: spa.v4l2: Cannot open '/dev/video0': 13, Permission denied
мар 18 18:53:24 poh9shka-pc pipewire[2596]: spa.v4l2: error: Permission denied
мар 18 18:53:24 poh9shka-pc pipewire[2596]: default: can't setup properties: Permission denied
мар 18 18:53:24 poh9shka-pc systemd-coredump[52490]: [🡕] Process 52483 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 52483:
                                                        #0  0x00007f41f20ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f41f205a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f41f20424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f41f268a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f41f268b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f41f2cd9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f41f2d74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f41f273db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f41f2d74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f41f2d6c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x000055919429ec23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x00007f41f2043cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f41f2043d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x000055919429eee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 52486:
                                                        #0  0x00007f41f21190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f41f1ee52f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f41f1e85162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f41f29739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f41f2743d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f41f282106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f41f35d49df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f41f28a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f41f20a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f41f2126a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-gmenudbusmenuproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-gmenudbusmenuproxy.service: Failed with result 'core-dump'.
мар 18 18:53:24 poh9shka-pc telegram-desktop[2887]: kf.statusnotifieritem: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-ksmserver.service: Main process exited, code=dumped, status=11/SEGV
мар 18 18:53:24 poh9shka-pc systemd[2339]: plasma-ksmserver.service: Failed with result 'core-dump'.
мар 18 18:53:24 poh9shka-pc systemd[2339]: graphical-session.target: Failed to enqueue stop job, ignoring: Transaction for graphical-session.target/stop is destructive (bamfdaemon.service has 'start' job queued, but 'stop' is included in transaction).
мар 18 18:53:24 poh9shka-pc systemd[2339]: dbus-:1.2-org.telegram.desktop@0.service: Failed with result 'exit-code'.
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52511]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52511]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52511]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52514]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52514]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52514]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:25 poh9shka-pc bamfdaemon[52508]: cannot open display: :0
мар 18 18:53:25 poh9shka-pc systemd[2339]: bamfdaemon.service: Failed with result 'exit-code'.
мар 18 18:53:25 poh9shka-pc systemd[2339]: Failed to start BAMF Application Matcher Framework.
мар 18 18:53:25 poh9shka-pc systemd-coredump[52539]: [🡕] Process 52514 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 52514:
                                                        #0  0x00007f4706aab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f4706a5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f4706a424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f470708a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f470708b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f47076d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f4707774a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f470713db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f4707774ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f470776c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00005593d251fc23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x00007f4706a43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f4706a43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005593d251fee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 52516:
                                                        #0  0x00007f4706b190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f47068432f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f47067e3162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f47073739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f4707143d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f470722106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f4707f279df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f47072a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f4706aa955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f4706b26a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:25 poh9shka-pc systemd-coredump[52542]: [🡕] Process 52511 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 52511:
                                                        #0  0x00007f02e7eab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f02e7e5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f02e7e424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f02e848a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f02e848b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f02e8ad9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f02e8b74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f02e853db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f02e8b74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f02e8b6c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00005561a2b3a233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x00007f02e7e43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f02e7e43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005561a2b3a595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 52515:
                                                        #0  0x00007f02e7f190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f02e7d362f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f02e7cd6162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f02e87739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f02e8543d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f02e862106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f02e94069df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f02e86a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f02e7ea955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f02e7f26a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:25 poh9shka-pc systemd[2339]: plasma-gmenudbusmenuproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 18 18:53:25 poh9shka-pc systemd[2339]: plasma-gmenudbusmenuproxy.service: Failed with result 'core-dump'.
мар 18 18:53:25 poh9shka-pc systemd[2339]: plasma-xembedsniproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 18 18:53:25 poh9shka-pc systemd[2339]: plasma-xembedsniproxy.service: Failed with result 'core-dump'.
мар 18 18:53:25 poh9shka-pc bamfdaemon[52555]: cannot open display: :0
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52576]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52576]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52576]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:25 poh9shka-pc bamfdaemon[52575]: cannot open display: :0
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52577]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52577]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52577]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:25 poh9shka-pc systemd[52548]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
мар 18 18:53:25 poh9shka-pc systemd[52548]: Failed to start Update XDG user dir configuration.
мар 18 18:53:25 poh9shka-pc dbus-broker-launch[52597]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
мар 18 18:53:25 poh9shka-pc dbus-broker-launch[52597]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
мар 18 18:53:25 poh9shka-pc dbus-broker-launch[52597]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
мар 18 18:53:25 poh9shka-pc systemd-coredump[52586]: [🡕] Process 52576 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 52576:
                                                        #0  0x00007f7ea30ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f7ea305a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f7ea30424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f7ea368a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f7ea368b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f7ea3cd9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f7ea3d74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f7ea373db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f7ea3d74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f7ea3d6c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x0000564929224c23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x00007f7ea3043cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f7ea3043d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x0000564929224ee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 52578:
                                                        #0  0x00007f7ea31190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f7ea2df32f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f7ea2d93162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f7ea39739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f7ea3743d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f7ea382106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f7ea449b9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f7ea38a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f7ea30a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f7ea3126a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:25 poh9shka-pc systemd-coredump[52587]: [🡕] Process 52577 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 52577:
                                                        #0  0x00007f5cc36ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f5cc365a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f5cc36424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f5cc3c8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f5cc3c8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f5cc42d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f5cc4374a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f5cc3d3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f5cc4374ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f5cc436c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00005616f440d233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x00007f5cc3643cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f5cc3643d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005616f440d595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 52580:
                                                        #0  0x00007f5cc37190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f5cc33f72f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f5cc3397162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f5cc3f739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f5cc3d43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f5cc3e2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f5cc4abb9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f5cc3ea0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f5cc36a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f5cc3726a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:25 poh9shka-pc sddm-greeter-qt6[52593]: QObject: Cannot create children for a parent that is in a different thread.
                                                        (Parent is QGuiApplication(0x7fff59389e80), parent's thread is QThread(0x55a560dac570), current thread is QThread(0x55a560e67ea0)
мар 18 18:53:25 poh9shka-pc sddm-greeter-qt6[52593]: Cannot create directory for user data "/var/lib/sddm/.config/qtvirtualkeyboard"
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52628]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52628]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52628]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52627]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52627]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52627]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:25 poh9shka-pc bamfdaemon[52624]: cannot open display: :0
мар 18 18:53:25 poh9shka-pc xdg-desktop-por[52626]: No skeleton to export
мар 18 18:53:25 poh9shka-pc systemd-coredump[52644]: [🡕] Process 52628 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 52628:
                                                        #0  0x00007f2850aab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f2850a5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f2850a424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f285108a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f285108b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f28516d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f2851774a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f285113db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f2851774ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f285176c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x0000565180716233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x00007f2850a43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f2850a43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x0000565180716595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 52636:
                                                        #0  0x00007f28509fa098 _dbus_hash_table_lookup_int (libdbus-1.so.3 + 0x31098)
                                                        #1  0x00007f28509e2236 dbus_connection_dispatch (libdbus-1.so.3 + 0x19236)
                                                        #2  0x00007f2851fa157a n/a (libQt6DBus.so.6 + 0x4d57a)
                                                        #3  0x00007f2851190ca9 n/a (libQt6Core.so.6 + 0x190ca9)
                                                        #4  0x00007f2851198530 _ZN15QSocketNotifier5eventEP6QEvent (libQt6Core.so.6 + 0x198530)
                                                        #5  0x00007f285113979c _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x13979c)
                                                        #6  0x00007f28513754d1 n/a (libQt6Core.so.6 + 0x3754d1)
                                                        #7  0x00007f2850886f69 n/a (libglib-2.0.so.0 + 0x59f69)
                                                        #8  0x00007f28508e53a7 n/a (libglib-2.0.so.0 + 0xb83a7)
                                                        #9  0x00007f2850885162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #10 0x00007f28513739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #11 0x00007f2851143d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #12 0x00007f285122106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #13 0x00007f2851f7d9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #14 0x00007f28512a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #15 0x00007f2850aa955a n/a (libc.so.6 + 0x8f55a)
                                                        #16 0x00007f2850b26a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:25 poh9shka-pc systemd-coredump[52645]: [🡕] Process 52627 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 52627:
                                                        #0  0x00007f7e74aab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f7e74a5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f7e74a424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f7e7508a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f7e7508b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f7e756d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f7e75774a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f7e7513db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f7e75774ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f7e7576c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00005606fb9cdc23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x00007f7e74a43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f7e74a43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005606fb9cdee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 52637:
                                                        #0  0x00007f7e74b190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f7e747f32f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f7e74793162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f7e753739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f7e75143d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f7e7522106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f7e75ed09df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f7e752a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f7e74aa955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f7e74b26a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:25 poh9shka-pc systemd[2339]: bamfdaemon.service: Start request repeated too quickly.
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52681]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52681]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:25 poh9shka-pc gmenudbusmenuproxy[52681]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52682]: qt.qpa.xcb: could not connect to display :0
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52682]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 18 18:53:25 poh9shka-pc xembedsniproxy[52682]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 18 18:53:26 poh9shka-pc systemd-coredump[52689]: [🡕] Process 52681 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 52681:
                                                        #0  0x00007f5759cab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007f5759c5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007f5759c424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007f575a28a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007f575a28b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007f575a8d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007f575a974a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007f575a33db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007f575a974ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007f575a96c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x0000565394474c23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x00007f5759c43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007f5759c43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x0000565394474ee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 52683:
                                                        #0  0x00007f5759d190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007f57599f32f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007f5759993162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007f575a5739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007f575a343d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007f575a42106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007f575b10b9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007f575a4a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007f5759ca955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007f5759d26a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:26 poh9shka-pc systemd-coredump[52691]: [🡕] Process 52682 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 52682:
                                                        #0  0x00007fec6a6ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007fec6a65a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007fec6a6424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007fec6ac8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007fec6ac8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007fec6b2d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007fec6b374a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007fec6ad3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007fec6b374ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007fec6b36c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x0000555c41bcb233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x00007fec6a643cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007fec6a643d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x0000555c41bcb595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 52687:
                                                        #0  0x00007fec6ba89c54 n/a (libdbus-1.so.3 + 0x14c54)
                                                        #1  0x00007fec6ba8e3ce dbus_connection_dispatch (libdbus-1.so.3 + 0x193ce)
                                                        #2  0x00007fec6bb5757a n/a (libQt6DBus.so.6 + 0x4d57a)
                                                        #3  0x00007fec6ad90ca9 n/a (libQt6Core.so.6 + 0x190ca9)
                                                        #4  0x00007fec6ad98530 _ZN15QSocketNotifier5eventEP6QEvent (libQt6Core.so.6 + 0x198530)
                                                        #5  0x00007fec6ad3979c _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x13979c)
                                                        #6  0x00007fec6af754d1 n/a (libQt6Core.so.6 + 0x3754d1)
                                                        #7  0x00007fec6a3e9f69 n/a (libglib-2.0.so.0 + 0x59f69)
                                                        #8  0x00007fec6a4483a7 n/a (libglib-2.0.so.0 + 0xb83a7)
                                                        #9  0x00007fec6a3e8162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #10 0x00007fec6af739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #11 0x00007fec6ad43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #12 0x00007fec6ae2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #13 0x00007fec6bb339df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #14 0x00007fec6aea0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #15 0x00007fec6a6a955a n/a (libc.so.6 + 0x8f55a)
                                                        #16 0x00007fec6a726a3c n/a (libc.so.6 + 0x10ca3c)
мар 18 18:53:26 poh9shka-pc systemd[2339]: plasma-gmenudbusmenuproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 18 18:53:26 poh9shka-pc systemd[2339]: plasma-gmenudbusmenuproxy.service: Failed with result 'core-dump'.
мар 18 18:53:26 poh9shka-pc systemd[2339]: plasma-xembedsniproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 18 18:53:26 poh9shka-pc systemd[2339]: plasma-xembedsniproxy.service: Failed with result 'core-dump'.
мар 18 18:53:26 poh9shka-pc systemd[2339]: plasma-gmenudbusmenuproxy.service: Start request repeated too quickly.
мар 18 18:53:26 poh9shka-pc systemd[2339]: Failed to start Proxies GTK DBus menus to a Plasma readable format.
мар 18 18:53:26 poh9shka-pc systemd[2339]: plasma-xembedsniproxy.service: Start request repeated too quickly.
мар 18 18:53:26 poh9shka-pc systemd[2339]: Failed to start Handle legacy xembed system tray icons.
мар 18 18:53:32 poh9shka-pc sddm-greeter-qt6[52593]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
мар 18 18:53:32 poh9shka-pc startplasma-x11[52732]: org.kde.startup: Could not start systemd managed Plasma session: "org.freedesktop.systemd1.TransactionIsDestructive" "Transaction for plasma-workspace-x11.target/start is destructive (graphical-session.target has 'stop' job queued, but 'start' is included in transaction)."
мар 18 18:53:32 poh9shka-pc ksplashqml[52746]: qt.accessibility.atspi: Error in contacting registry: "org.freedesktop.DBus.Error.Disconnected" "Not connected to D-Bus server"
мар 18 18:53:32 poh9shka-pc ksplashqml[52746]: Texture 0x7fb50060a900 () used with different accesses within the same pass, this is not allowed.
мар 18 18:53:32 poh9shka-pc ksplashqml[52746]: Texture 0x7fb5107261a0 () used with different accesses within the same pass, this is not allowed.
мар 18 18:53:32 poh9shka-pc ksplashqml[52746]: Texture 0x7fb4fc616070 () used with different accesses within the same pass, this is not allowed.
мар 18 18:53:43 poh9shka-pc sddm[1105]: Auth: sddm-helper exited with 1
мар 18 18:54:01 poh9shka-pc sddm[1105]: Signal received: SIGTERM
мар 18 18:54:08 poh9shka-pc dbus-broker-launch[836]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
мар 18 18:54:08 poh9shka-pc nm-openvpn[5879]: event_wait : Interrupted system call (code=4)
мар 18 18:54:09 poh9shka-pc nm-openvpn[5879]: sitnl_send: rtnl: generic error (-1): Operation not permitted
мар 18 18:54:09 poh9shka-pc nm-openvpn[5879]: Linux can't del IP from iface tun0
inxi -Fazy
  Kernel: 6.1.82-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=68e99e1c-f1de-4330-b179-b15a707ab09c rw nvidia_drm.modeset=1
    quiet apparmor=1 security=apparmor
    resume=UUID=8c187444-6fd2-42cd-8c23-4f8d88747ddc udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
    wm: kwin_x11 with: plank vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7C90 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MPG B550 GAMING CARBON WIFI (MS-7C90) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.70 date: 06/25/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K270
    status: discharging
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2487 high: 3700 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2879 2: 2879
    3: 2200 4: 2200 5: 2880 6: 3700 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
    12: 2200 13: 2800 14: 2200 15: 3598 16: 2879 17: 2879 18: 2200 19: 2200
    20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177671
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
    driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DVI-D-1,DVI-I-1,HDMI-A-1 empty: DP-1
    bus-ID: 2b:00.0 chip-ID: 10de:13c2 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1080 s-dpi: 81 s-size: 1405x343mm (55.31x13.50")
    s-diag: 1446mm (56.94")
  Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled pos: bottom-l
    model: LG (GoldStar) L1952HQ serial: <filter> built: 2006 res: 1280x1024
    hz: 60 dpi: 86 gamma: 1.2 size: 376x301mm (14.8x11.85") diag: 482mm (19")
    ratio: 5:4 modes: max: 1280x1024 min: 640x480
  Monitor-2: DVI-I-1 note: disabled pos: primary,top-center
    model: BenQ ZOWIE XL LCD serial: <filter> built: 2016 res: 1920x1080 dpi: 82
    gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: max: 1920x1080 min: 640x480
  Monitor-3: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-r
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 970 driver: nvidia v: 550.54.14 device-ID: 10de:13c2
    surfaces: xcb,xlib
  Device-1: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 2b:00.1 chip-ID: 10de:0fbb class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: BEHRINGER GmbH UMC404 96k driver: snd-usb-audio type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 1397:0502
    class-ID: fe01
  API: ALSA v: k6.1.82-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.4 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 2.73 TiB used: 213.94 GiB (7.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 39.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX001-1CM164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-1: / raw-size: 301 GiB size: 295.21 GiB (98.08%) used: 213.93 GiB (72.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 8 GiB used: 12.2 MiB (0.1%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 55.2 C mobo: N/A gpu: nvidia temp: 45 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 35%
  Memory: total: 16 GiB available: 15.54 GiB used: 3.13 GiB (20.2%)
  Processes: 460 Power: uptime: 0m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 255 default: graphical tool: systemctl
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1936 libs: 425 tools: pamac
    pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh
    v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
It has just happened again. :disappointed_relieved:
journalctl:
мар 19 20:52:50 poh9shka-pc baloorunner[11873]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
мар 19 20:52:50 poh9shka-pc baloorunner[11873]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
мар 19 20:52:50 poh9shka-pc kwin_x11[2562]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
мар 19 20:52:50 poh9shka-pc kwin_x11[2562]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
мар 19 20:52:57 poh9shka-pc systemd-coredump[18110]: [🡕] Process 1030 (Xorg) of user 0 dumped core.
                                                        Stack trace of thread 1030:
                                                        #0  0x00007e256de2c32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007e256dddb6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007e256ddc34b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000065427b0dfa30 OsAbort (Xorg + 0x159a30)
                                                        #4  0x000065427b0dfd6b FatalError (Xorg + 0x159d6b)
                                                        #5  0x000065427b0d7ce6 n/a (Xorg + 0x151ce6)
                                                        #6  0x00007e256dddb770 n/a (libc.so.6 + 0x40770)
                                                        #7  0x00007e256ccb0ee5 n/a (nvidia_drv.so + 0x4b0ee5)
мар 19 20:52:57 poh9shka-pc dolphin[18092]: The X11 connection broke: I/O error (code 1)
мар 19 20:52:57 poh9shka-pc pulseaudio[2961]: X11 I/O error handler called
мар 19 20:52:57 poh9shka-pc pulseaudio[2961]: X11 I/O error exit handler called, preparing to tear down X11 modules
мар 19 20:52:57 poh9shka-pc kaccess[2943]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc msm_kde_notifier[2918]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc kdeconnectd[2920]: 2024-03-19T20:52:57 default: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc org_kde_powerdevil[2666]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc polkit-kde-authentication-agent-1[2665]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc kscreen_backend_launcher[2641]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc pamac-tray-plasma[2945]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc kactivitymanagerd[2663]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc xembedsniproxy[2668]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc gmenudbusmenuproxy[2664]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc kded6[2561]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc plasmashell[2599]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc kwalletd6[2488]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc kdeconnectd[2920]: 2024-03-19T20:52:57 org.kde.pulseaudio: No object for name "bluez_sink.08_EB_ED_E1_52_E3.a2dp_sink"
мар 19 20:52:57 poh9shka-pc systemd[2468]: dbus-:1.45-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc xdg-desktop-portal-kde[2667]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc kdeconnectd[2920]: 2024-03-19T20:52:57 org.kde.pulseaudio: No object for name "alsa_input.usb-BEHRINGER_UMC404_96k-00.multichannel-input"
мар 19 20:52:57 poh9shka-pc kglobalacceld[2518]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-kscreen.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc kglobalacceld[2518]: The X11 connection broke: I/O error (code 1)
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc kwin_x11[2562]: The X11 connection broke: I/O error (code 1)
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-kglobalaccel.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc avahi-daemon[772]: IPV6_ADD_MEMBERSHIP failed: No such device
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd[2468]: app-kaccess@autostart.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd[2468]: bamfdaemon.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd[2468]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-kded6.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd[2468]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-kwin_x11.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd[2468]: app-plank@autostart.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc xembedsniproxy[18182]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:57 poh9shka-pc xembedsniproxy[18182]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:57 poh9shka-pc xembedsniproxy[18182]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:57 poh9shka-pc systemd[2468]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd-coredump[18145]: [🡕] Process 2559 (ksmserver) of user 1000 dumped core.
                                                        Stack trace of thread 2559:
                                                        #0  0x0000729772e45a2c _ZN10QXcbScreen23updateColorSpaceAndEdidEv (libQt6XcbQpa.so.6 + 0x5da2c)
                                                        #1  0x0000729772e212b5 _ZN14QXcbConnection20updateScreen_monitorEP10QXcbScreenP24xcb_randr_monitor_info_tj (libQt6XcbQpa.so.6 + 0x392b5)
                                                        #2  0x0000729772e23572 _ZN14QXcbConnection28initializeScreensFromMonitorEP21xcb_screen_iterator_tiPP10QXcbScreenb (libQt6XcbQpa.so.6 + 0x3b572)
                                                        #3  0x0000729772e23cfe _ZN14QXcbConnection17initializeScreensEb (libQt6XcbQpa.so.6 + 0x3bcfe)
                                                        #4  0x0000729772e19751 _ZN14QXcbConnection14handleXcbEventEP19xcb_generic_event_t (libQt6XcbQpa.so.6 + 0x31751)
                                                        #5  0x0000729772e1f76c _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6XcbQpa.so.6 + 0x3776c)
                                                        #6  0x0000729772e34bd7 n/a (libQt6XcbQpa.so.6 + 0x4cbd7)
                                                        #7  0x0000729776cc4f69 n/a (libglib-2.0.so.0 + 0x59f69)
                                                        #8  0x0000729776d233a7 n/a (libglib-2.0.so.0 + 0xb83a7)
                                                        #9  0x0000729776cc3162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #10 0x0000729777b739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #11 0x0000729777943d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #12 0x000072977793c2b8 _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x13c2b8)
                                                        #13 0x000058685064cef6 n/a (ksmserver + 0xaef6)
                                                        #14 0x0000729777243cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #15 0x0000729777243d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #16 0x000058685064dc55 n/a (ksmserver + 0xbc55)
                                                        Stack trace of thread 2569:
                                                        #0  0x00007297773190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x0000729776d232f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x0000729776cc3162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x0000729777b739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x0000729777943d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x0000729777a2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007297786d09df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x0000729777aa0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007297772a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x0000729777326a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:57 poh9shka-pc gmenudbusmenuproxy[18195]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:57 poh9shka-pc gmenudbusmenuproxy[18195]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:57 poh9shka-pc gmenudbusmenuproxy[18195]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:57 poh9shka-pc bamfdaemon[18194]: cannot open display: :0
мар 19 20:52:57 poh9shka-pc systemd[2468]: Failed to start BAMF Application Matcher Framework.
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-plasmashell.service: Failed with result 'exit-code'.
мар 19 20:52:57 poh9shka-pc systemd[2468]: graphical-session.target: Failed to enqueue stop job, ignoring: Transaction for graphical-session.target/stop is destructive (plasma-kwin_x11.service has 'start' job queued, but 'stop' is included in transaction).
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-ksmserver.service: Main process exited, code=dumped, status=11/SEGV
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-ksmserver.service: Failed with result 'core-dump'.
мар 19 20:52:57 poh9shka-pc baloorunner[11873]: The X11 connection broke (error 1). Did the X11 server die?
мар 19 20:52:57 poh9shka-pc startplasma-x11[2489]: org.kde.startup: "kdeinit5_shutdown" QList() exited with code 255
мар 19 20:52:57 poh9shka-pc systemd-coredump[18190]: [🡕] Process 18182 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 18182:
                                                        #0  0x000071ddf72ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x000071ddf725a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x000071ddf72424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000071ddf788a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x000071ddf788b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x000071ddf7ed9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x000071ddf7f74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x000071ddf793db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x000071ddf7f74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x000071ddf7f6c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00006205e7f40233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x000071ddf7243cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x000071ddf7243d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00006205e7f40595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 18185:
                                                        #0  0x000071ddf73190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x000071ddf70482f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x000071ddf6fe8162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x000071ddf7b739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x000071ddf7943d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x000071ddf7a2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x000071ddf86ef9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x000071ddf7aa0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x000071ddf72a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x000071ddf7326a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:57 poh9shka-pc sddm-helper[2462]: Signal received: SIGTERM
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-xembedsniproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-xembedsniproxy.service: Failed with result 'core-dump'.
мар 19 20:52:57 poh9shka-pc sddm[931]: Auth: sddm-helper exited with 255
мар 19 20:52:57 poh9shka-pc systemd-coredump[18203]: [🡕] Process 18195 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 18195:
                                                        #0  0x000079ade4aab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x000079ade4a5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x000079ade4a424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000079ade508a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x000079ade508b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x000079ade56d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x000079ade5774a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x000079ade513db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x000079ade5774ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x000079ade576c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00005c728e211c23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x000079ade4a43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x000079ade4a43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005c728e211ee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 18200:
                                                        #0  0x000079ade4b190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x000079ade48e52f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x000079ade4885162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x000079ade53739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x000079ade5143d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x000079ade522106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x000079ade5fcd9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x000079ade52a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x000079ade4aa955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x000079ade4b26a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-gmenudbusmenuproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 19 20:52:57 poh9shka-pc systemd[2468]: plasma-gmenudbusmenuproxy.service: Failed with result 'core-dump'.
мар 19 20:52:58 poh9shka-pc kwin_x11[18205]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc kwin_x11[18205]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc kwin_x11[18205]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc plasmashell[18241]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18242]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc plasmashell[18241]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18240]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18242]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc plasmashell[18241]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18240]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18242]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18240]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                          Available platform plugins are: linuxfb, xcb, minimalegl, wayland, vkkhrdisplay, minimal, vnc, eglfs, offscreen, wayland-egl.
мар 19 20:52:58 poh9shka-pc bamfdaemon[18239]: cannot open display: :0
мар 19 20:52:58 poh9shka-pc systemd[2468]: bamfdaemon.service: Failed with result 'exit-code'.
мар 19 20:52:58 poh9shka-pc systemd[2468]: Failed to start BAMF Application Matcher Framework.
мар 19 20:52:58 poh9shka-pc systemd-coredump[18260]: [🡕] Process 18242 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 18242:
                                                        #0  0x00007840e92ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007840e925a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007840e92424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007840e988a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007840e988b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007840e9ed9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007840e9f74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007840e993db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007840e9f74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007840e9f6c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x000063d42c92c233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x00007840e9243cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007840e9243d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x000063d42c92c595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 18244:
                                                        #0  0x00007840e93190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007840e90482f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007840e8fe8162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007840e9b739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007840e9943d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007840e9a2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007840ea73c9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007840e9aa0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007840e92a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007840e9326a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-xembedsniproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-xembedsniproxy.service: Failed with result 'core-dump'.
мар 19 20:52:58 poh9shka-pc systemd-coredump[18266]: [🡕] Process 18240 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 18240:
                                                        #0  0x000071c5b30ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x000071c5b305a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x000071c5b30424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000071c5b368a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x000071c5b368b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x000071c5b3cd9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x000071c5b3d74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x000071c5b373db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x000071c5b3d74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x000071c5b3d6c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00005cc57f9c8c23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x000071c5b3043cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x000071c5b3043d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005cc57f9c8ee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 18243:
                                                        #0  0x000071c5b31190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x000071c5b2df32f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x000071c5b2d93162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x000071c5b39739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x000071c5b3743d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x000071c5b382106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x000071c5b450d9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x000071c5b38a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x000071c5b30a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x000071c5b3126a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-gmenudbusmenuproxy.service: Main process exited, code=dumped, status=6/ABRT
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-gmenudbusmenuproxy.service: Failed with result 'core-dump'.
мар 19 20:52:58 poh9shka-pc bamfdaemon[18288]: cannot open display: :0
мар 19 20:52:58 poh9shka-pc systemd-coredump[18265]: [🡕] Process 18241 (plasmashell) of user 1000 dumped core.
                                                        Stack trace of thread 18241:
                                                        #0  0x00007cb0554ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007cb05545a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007cb0554424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007cb055a8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007cb055a8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007cb0560d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007cb056174a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007cb055b3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007cb056174ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007cb0578f53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x00005b058fda06a6 n/a (plasmashell + 0x246a6)
                                                        #11 0x00007cb055443cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007cb055443d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005b058fda3c65 n/a (plasmashell + 0x27c65)
                                                        Stack trace of thread 18245:
                                                        #0  0x00007cb0555190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007cb05469e2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007cb05463e162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007cb055d739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007cb055b43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007cb055c2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007cb0568b89df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007cb055ca0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007cb0554a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007cb055526a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd-coredump[18264]: [🡕] Process 18205 (kwin_x11) of user 1000 dumped core.
                                                        Stack trace of thread 18205:
                                                        #0  0x00007cc2148ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007cc21485a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007cc2148424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007cc214e8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007cc214e8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007cc2154d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007cc215574a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007cc214f3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007cc215574ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007cc215ef53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x00007cc21783f595 _ZN4KWin11ApplicationC1ENS0_13OperationModeERiPPc (libkwin.so.6 + 0x23f595)
                                                        #11 0x00006465c6b8f7ca n/a (kwin_x11 + 0x397ca)
                                                        #12 0x00007cc214843cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #13 0x00007cc214843d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #14 0x00006465c6b93ef5 n/a (kwin_x11 + 0x3def5)
                                                        Stack trace of thread 18216:
                                                        #0  0x00007cc2149190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007cc213e972f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007cc213e37162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007cc2151739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007cc214f43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007cc21502106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007cc2165029df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007cc2150a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007cc2148a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007cc214926a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-plasmashell.service: Main process exited, code=dumped, status=6/ABRT
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-plasmashell.service: Failed with result 'core-dump'.
мар 19 20:52:58 poh9shka-pc systemd[2468]: Failed to start KDE Plasma Workspace.
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-kwin_x11.service: Main process exited, code=dumped, status=6/ABRT
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-kwin_x11.service: Failed with result 'core-dump'.
мар 19 20:52:58 poh9shka-pc systemd[2468]: Failed to start KDE Window Manager.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18316]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18316]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18316]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc systemd[18271]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
мар 19 20:52:58 poh9shka-pc systemd[18271]: Failed to start Update XDG user dir configuration.
мар 19 20:52:58 poh9shka-pc unknown[18314]: cannot open display: :0
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18320]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18320]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18320]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc dbus-broker-launch[18340]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
мар 19 20:52:58 poh9shka-pc dbus-broker-launch[18340]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
мар 19 20:52:58 poh9shka-pc dbus-broker-launch[18340]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
мар 19 20:52:58 poh9shka-pc plasmashell[18319]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc plasmashell[18319]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc plasmashell[18319]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc kwin_x11[18318]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc kwin_x11[18318]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc kwin_x11[18318]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc systemd-coredump[18336]: [🡕] Process 18316 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 18316:
                                                        #0  0x000075354a4ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x000075354a45a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x000075354a4424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000075354aa8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x000075354aa8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x000075354b0d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x000075354b174a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x000075354ab3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x000075354b174ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x000075354b16c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x000059c34edc8c23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x000075354a443cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x000075354a443d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x000059c34edc8ee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 18325:
                                                        #0  0x000075354a5190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x000075354a2e52f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x000075354a285162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x000075354ad739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x000075354ab43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x000075354ac2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x000075354b98a9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x000075354aca0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x000075354a4a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x000075354a526a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd-coredump[18337]: [🡕] Process 18320 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 18320:
                                                        #0  0x0000796a142ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x0000796a1425a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x0000796a142424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x0000796a1488a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x0000796a1488b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x0000796a14ed9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x0000796a14f74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x0000796a1493db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x0000796a14f74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x0000796a14f6c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x000064bb51b90233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x0000796a14243cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x0000796a14243d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x000064bb51b90595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 18331:
                                                        #0  0x0000796a143190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x0000796a141362f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x0000796a140d6162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x0000796a14b739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x0000796a14943d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x0000796a14a2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x0000796a157f19df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x0000796a14aa0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x0000796a142a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x0000796a14326a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc sddm-greeter-qt6[18324]: QObject: Cannot create children for a parent that is in a different thread.
                                                        (Parent is QGuiApplication(0x7ffdc3a760b0), parent's thread is QThread(0x5cf7ab52a570), current thread is QThread(0x5cf7ab5e5af0)
мар 19 20:52:58 poh9shka-pc systemd-coredump[18346]: [🡕] Process 18319 (plasmashell) of user 1000 dumped core.
                                                        Stack trace of thread 18319:
                                                        #0  0x000075875b4ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x000075875b45a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x000075875b4424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000075875ba8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x000075875ba8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x000075875c0d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x000075875c174a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x000075875bb3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x000075875c174ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x000075875d8f53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x00005c6e94ab16a6 n/a (plasmashell + 0x246a6)
                                                        #11 0x000075875b443cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x000075875b443d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005c6e94ab4c65 n/a (plasmashell + 0x27c65)
                                                        Stack trace of thread 18342:
                                                        #0  0x000075875b5190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x000075875a74c2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x000075875a6ec162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x000075875bd739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x000075875bb43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x000075875bc2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x000075875c8b89df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x000075875bca0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x000075875b4a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x000075875b526a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd-coredump[18351]: [🡕] Process 18318 (kwin_x11) of user 1000 dumped core.
                                                        Stack trace of thread 18318:
                                                        #0  0x0000731ce8aab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x0000731ce8a5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x0000731ce8a424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x0000731ce908a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x0000731ce908b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x0000731ce96d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x0000731ce9774a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x0000731ce913db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x0000731ce9774ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x0000731cea0f53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x0000731cebc3f595 _ZN4KWin11ApplicationC1ENS0_13OperationModeERiPPc (libkwin.so.6 + 0x23f595)
                                                        #11 0x000059e520b5f7ca n/a (kwin_x11 + 0x397ca)
                                                        #12 0x0000731ce8a43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #13 0x0000731ce8a43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #14 0x000059e520b63ef5 n/a (kwin_x11 + 0x3def5)
                                                        Stack trace of thread 18347:
                                                        #0  0x0000731ce8b190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x0000731ce816c2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x0000731ce810c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x0000731ce93739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x0000731ce9143d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x0000731ce922106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x0000731cea8bd9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x0000731ce92a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x0000731ce8aa955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x0000731ce8b26a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc bamfdaemon[18379]: cannot open display: :0
мар 19 20:52:58 poh9shka-pc xdg-desktop-por[18395]: No skeleton to export
мар 19 20:52:58 poh9shka-pc sddm-greeter-qt6[18324]: Cannot create directory for user data "/var/lib/sddm/.config/qtvirtualkeyboard"
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18418]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18418]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18417]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18418]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18417]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18417]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc plasmashell[18432]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc plasmashell[18432]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc plasmashell[18432]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc kwin_x11[18431]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc kwin_x11[18431]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc kwin_x11[18431]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc systemd-coredump[18428]: [🡕] Process 18417 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 18417:
                                                        #0  0x000075c78e8ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x000075c78e85a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x000075c78e8424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000075c78ee8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x000075c78ee8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x000075c78f4d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x000075c78f574a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x000075c78ef3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x000075c78f574ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x000075c78f56c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00005e894012dc23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x000075c78e843cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x000075c78e843d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005e894012dee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 18421:
                                                        #0  0x000075c78e9190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x000075c78e6432f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x000075c78e5e3162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x000075c78f1739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x000075c78ef43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x000075c78f02106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x000075c78fd599df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x000075c78f0a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x000075c78e8a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x000075c78e926a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd-coredump[18429]: [🡕] Process 18418 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 18418:
                                                        #0  0x000074cfd1cab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x000074cfd1c5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x000074cfd1c424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000074cfd228a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x000074cfd228b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x000074cfd28d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x000074cfd2974a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x000074cfd233db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x000074cfd2974ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x000074cfd296c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x0000613f2de45233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x000074cfd1c43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x000074cfd1c43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x0000613f2de45595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 18420:
                                                        #0  0x000074cfd1d190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x000074cfd19f72f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x000074cfd1997162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x000074cfd25739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x000074cfd2343d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x000074cfd242106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x000074cfd305f9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x000074cfd24a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x000074cfd1ca955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x000074cfd1d26a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd[2468]: bamfdaemon.service: Start request repeated too quickly.
мар 19 20:52:58 poh9shka-pc systemd-coredump[18438]: [🡕] Process 18432 (plasmashell) of user 1000 dumped core.
                                                        Stack trace of thread 18432:
                                                        #0  0x00007a7851eab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007a7851e5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007a7851e424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007a785248a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007a785248b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007a7852ad9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007a7852b74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007a785253db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007a7852b74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007a78542f53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x00005c2a3315c6a6 n/a (plasmashell + 0x246a6)
                                                        #11 0x00007a7851e43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x00007a7851e43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005c2a3315fc65 n/a (plasmashell + 0x27c65)
                                                        Stack trace of thread 18433:
                                                        #0  0x00007a7851f190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007a78510b72f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007a7851057162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007a78527739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007a7852543d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007a785262106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007a78532b89df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007a78526a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007a7851ea955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007a7851f26a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd-coredump[18444]: [🡕] Process 18431 (kwin_x11) of user 1000 dumped core.
                                                        Stack trace of thread 18431:
                                                        #0  0x00007ebc094ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007ebc0945a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007ebc094424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007ebc09a8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007ebc09a8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007ebc0a0d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007ebc0a174a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007ebc09b3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007ebc0a174ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007ebc0aaf53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x00007ebc0c63f595 _ZN4KWin11ApplicationC1ENS0_13OperationModeERiPPc (libkwin.so.6 + 0x23f595)
                                                        #11 0x00005ed2162d37ca n/a (kwin_x11 + 0x397ca)
                                                        #12 0x00007ebc09443cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #13 0x00007ebc09443d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #14 0x00005ed2162d7ef5 n/a (kwin_x11 + 0x3def5)
                                                        Stack trace of thread 18437:
                                                        #0  0x00007ebc095190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007ebc08b6c2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007ebc08b0c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007ebc09d739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007ebc09b43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007ebc09c2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007ebc0b2449df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007ebc09ca0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007ebc094a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007ebc09526a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd[2468]: plasma-plasmashell.service: Start request repeated too quickly.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18476]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18476]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc gmenudbusmenuproxy[18476]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18478]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18478]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc xembedsniproxy[18478]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc kwin_x11[18477]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:58 poh9shka-pc kwin_x11[18477]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:58 poh9shka-pc kwin_x11[18477]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:58 poh9shka-pc systemd-coredump[18484]: [🡕] Process 18476 (gmenudbusmenupr) of user 1000 dumped core.
                                                        Stack trace of thread 18476:
                                                        #0  0x0000790d0bcab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x0000790d0bc5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x0000790d0bc424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x0000790d0c28a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x0000790d0c28b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x0000790d0c8d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x0000790d0c974a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x0000790d0c33db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x0000790d0c974ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x0000790d0c96c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x00005784f22d8c23 n/a (gmenudbusmenuproxy + 0x9c23)
                                                        #11 0x0000790d0bc43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x0000790d0bc43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x00005784f22d8ee5 n/a (gmenudbusmenuproxy + 0x9ee5)
                                                        Stack trace of thread 18479:
                                                        #0  0x0000790d0bd190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x0000790d0b9f32f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x0000790d0b993162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x0000790d0c5739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x0000790d0c343d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x0000790d0c42106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x0000790d0d0ad9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x0000790d0c4a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x0000790d0bca955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x0000790d0bd26a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd-coredump[18487]: [🡕] Process 18478 (xembedsniproxy) of user 1000 dumped core.
                                                        Stack trace of thread 18478:
                                                        #0  0x000078e831eab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x000078e831e5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x000078e831e424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x000078e83248a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x000078e83248b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x000078e832ad9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x000078e832b74a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x000078e83253db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x000078e832b74ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x000078e832b6c4fb _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x16c4fb)
                                                        #10 0x0000606dda721233 n/a (xembedsniproxy + 0x6233)
                                                        #11 0x000078e831e43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #12 0x000078e831e43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #13 0x0000606dda721595 n/a (xembedsniproxy + 0x6595)
                                                        Stack trace of thread 18485:
                                                        #0  0x000078e831f196bc read (libc.so.6 + 0xff6bc)
                                                        #1  0x000078e831be6e50 n/a (libglib-2.0.so.0 + 0xa7e50)
                                                        #2  0x000078e831b9a1f4 n/a (libglib-2.0.so.0 + 0x5b1f4)
                                                        #3  0x000078e831bf7210 n/a (libglib-2.0.so.0 + 0xb8210)
                                                        #4  0x000078e831b97162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #5  0x000078e8327739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #6  0x000078e832543d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #7  0x000078e83262106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #8  0x000078e8332829df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #9  0x000078e8326a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #10 0x000078e831ea955a n/a (libc.so.6 + 0x8f55a)
                                                        #11 0x000078e831f26a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:58 poh9shka-pc systemd-coredump[18494]: [🡕] Process 18477 (kwin_x11) of user 1000 dumped core.
                                                        Stack trace of thread 18477:
                                                        #0  0x0000721f10aab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x0000721f10a5a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x0000721f10a424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x0000721f1108a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x0000721f1108b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x0000721f116d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x0000721f11774a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x0000721f1113db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x0000721f11774ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x0000721f120f53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x0000721f13c3f595 _ZN4KWin11ApplicationC1ENS0_13OperationModeERiPPc (libkwin.so.6 + 0x23f595)
                                                        #11 0x00006397f9a697ca n/a (kwin_x11 + 0x397ca)
                                                        #12 0x0000721f10a43cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #13 0x0000721f10a43d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #14 0x00006397f9a6def5 n/a (kwin_x11 + 0x3def5)
                                                        Stack trace of thread 18490:
                                                        #0  0x0000721f10b190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x0000721f1016c2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x0000721f1010c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x0000721f113739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x0000721f11143d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x0000721f1122106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x0000721f128139df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x0000721f112a0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x0000721f10aa955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x0000721f10b26a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:59 poh9shka-pc systemd[2468]: plasma-gmenudbusmenuproxy.service: Start request repeated too quickly.
мар 19 20:52:59 poh9shka-pc systemd[2468]: plasma-gmenudbusmenuproxy.service: Failed with result 'core-dump'.
мар 19 20:52:59 poh9shka-pc systemd[2468]: Failed to start Proxies GTK DBus menus to a Plasma readable format.
мар 19 20:52:59 poh9shka-pc systemd[2468]: plasma-xembedsniproxy.service: Start request repeated too quickly.
мар 19 20:52:59 poh9shka-pc systemd[2468]: plasma-xembedsniproxy.service: Failed with result 'core-dump'.
мар 19 20:52:59 poh9shka-pc systemd[2468]: Failed to start Handle legacy xembed system tray icons.
мар 19 20:52:59 poh9shka-pc kwin_x11[18529]: qt.qpa.xcb: could not connect to display :0
мар 19 20:52:59 poh9shka-pc kwin_x11[18529]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
мар 19 20:52:59 poh9shka-pc kwin_x11[18529]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
мар 19 20:52:59 poh9shka-pc systemd-coredump[18535]: [🡕] Process 18529 (kwin_x11) of user 1000 dumped core.
                                                        Stack trace of thread 18529:
                                                        #0  0x00007e110f6ab32c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007e110f65a6c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007e110f6424b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x00007e110fc8a924 n/a (libQt6Core.so.6 + 0x8a924)
                                                        #4  0x00007e110fc8b135 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8b135)
                                                        #5  0x00007e11102d9be9 n/a (libQt6Gui.so.6 + 0xd9be9)
                                                        #6  0x00007e1110374a18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x174a18)
                                                        #7  0x00007e110fd3db15 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x13db15)
                                                        #8  0x00007e1110374ac1 _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x174ac1)
                                                        #9  0x00007e1110cf53ee _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf53ee)
                                                        #10 0x00007e111263f595 _ZN4KWin11ApplicationC1ENS0_13OperationModeERiPPc (libkwin.so.6 + 0x23f595)
                                                        #11 0x00006383b21907ca n/a (kwin_x11 + 0x397ca)
                                                        #12 0x00007e110f643cd0 n/a (libc.so.6 + 0x29cd0)
                                                        #13 0x00007e110f643d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #14 0x00006383b2194ef5 n/a (kwin_x11 + 0x3def5)
                                                        Stack trace of thread 18531:
                                                        #0  0x00007e110f7190bf __poll (libc.so.6 + 0xff0bf)
                                                        #1  0x00007e110ed1c2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                        #2  0x00007e110ecbc162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                        #3  0x00007e110ff739c4 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3739c4)
                                                        #4  0x00007e110fd43d6e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x143d6e)
                                                        #5  0x00007e110fe2106f _ZN7QThread4execEv (libQt6Core.so.6 + 0x22106f)
                                                        #6  0x00007e111137b9df n/a (libQt6DBus.so.6 + 0x299df)
                                                        #7  0x00007e110fea0bd3 n/a (libQt6Core.so.6 + 0x2a0bd3)
                                                        #8  0x00007e110f6a955a n/a (libc.so.6 + 0x8f55a)
                                                        #9  0x00007e110f726a3c n/a (libc.so.6 + 0x10ca3c)
мар 19 20:52:59 poh9shka-pc systemd[2468]: plasma-kwin_x11.service: Main process exited, code=dumped, status=6/ABRT
мар 19 20:52:59 poh9shka-pc systemd[2468]: plasma-kwin_x11.service: Failed with result 'core-dump'.
мар 19 20:52:59 poh9shka-pc systemd[2468]: Failed to start KDE Window Manager.
мар 19 20:52:59 poh9shka-pc systemd[2468]: plasma-kwin_x11.service: Start request repeated too quickly.
мар 19 20:53:11 poh9shka-pc sddm-greeter-qt6[18324]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
мар 19 20:53:11 poh9shka-pc dbus-broker-launch[18609]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
мар 19 20:53:11 poh9shka-pc dbus-broker-launch[18609]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
мар 19 20:53:11 poh9shka-pc dbus-broker-launch[18609]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
мар 19 20:53:11 poh9shka-pc kded6[18670]: kf.coreaddons: The plugin "/usr/lib/qt6/plugins/kaccounts/daemonplugins/kaccounts_kio_webdav_plugin.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
мар 19 20:53:11 poh9shka-pc ksplashqml[18613]: Texture 0x7d34442dfa50 () used with different accesses within the same pass, this is not allowed.
мар 19 20:53:11 poh9shka-pc ksplashqml[18613]: Texture 0x7d345c608300 () used with different accesses within the same pass, this is not allowed.
мар 19 20:53:11 poh9shka-pc ksplashqml[18613]: Texture 0x7d3448706dd0 () used with different accesses within the same pass, this is not allowed.
мар 19 20:53:12 poh9shka-pc kded6[18670]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
мар 19 20:53:12 poh9shka-pc kded6[18670]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
мар 19 20:53:12 poh9shka-pc kconf_update[18743]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
мар 19 20:53:12 poh9shka-pc kded6[18670]: kf.bluezqt: PendingCall Error: "The name is not activatable"
мар 19 20:53:12 poh9shka-pc plasmashell[18688]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
мар 19 20:53:12 poh9shka-pc plasmashell[18688]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
мар 19 20:53:12 poh9shka-pc kded6[18670]: kscreen.kded: PowerDevil SuspendSession action not available!
мар 19 20:53:13 poh9shka-pc plasmashell[18688]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
мар 19 20:53:13 poh9shka-pc plasmashell[18688]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
мар 19 20:53:13 poh9shka-pc backlighthelper[18810]: org.kde.powerdevil: no kernel backlight interface found
мар 19 20:53:13 poh9shka-pc org_kde_powerdevil[18760]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
мар 19 20:53:13 poh9shka-pc org_kde_powerdevil[18760]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
мар 19 20:53:13 poh9shka-pc kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00002b00] Failed to grab modeset ownership
мар 19 20:53:13 poh9shka-pc org_kde_powerdevil[18760]: busno=3, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
мар 19 20:53:13 poh9shka-pc org_kde_powerdevil[18760]: busno=5, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
мар 19 20:53:14 poh9shka-pc kwin_x11[18672]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "qrc:/qt/qml/org/kde/desktop/private/TextFieldContextMenu.qml" and "qrc:/qt/qml/org/kde/desktop/MenuItem.qml"
мар 19 20:53:14 poh9shka-pc plasmashell[18688]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
мар 19 20:53:14 poh9shka-pc plasmashell[18688]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "qrc:/qt/qml/org/kde/desktop/private/TextFieldContextMenu.qml" and "qrc:/qt/qml/org/kde/desktop/MenuItem.qml"
мар 19 20:53:14 poh9shka-pc plasmashell[18688]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
мар 19 20:53:14 poh9shka-pc org_kde_powerdevil[18760]: org.kde.powerdevil: Handle button events action could not check for screen configuration
мар 19 20:53:14 poh9shka-pc org_kde_powerdevil[18760]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
мар 19 20:53:15 poh9shka-pc kdeconnectd[18861]: 2024-03-19T20:53:15 qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "stateChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMState
мар 19 20:53:15 poh9shka-pc kdeconnectd[18861]: 2024-03-19T20:53:15 qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "connectivityChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMConnectivityState
мар 19 20:53:15 poh9shka-pc kdeconnectd[18861]: 2024-03-19T20:53:15 qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "deviceTypeChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMDeviceType
мар 19 20:53:15 poh9shka-pc kdeconnectd[18861]: 2024-03-19T20:53:15 qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "meteredChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMMetered
мар 19 20:53:15 poh9shka-pc kdeconnectd[18861]: 2024-03-19T20:53:15 default: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
мар 19 20:53:15 poh9shka-pc kdeconnectd[18861]: 2024-03-19T20:53:15 kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
мар 19 20:53:15 poh9shka-pc kdeconnectd[18861]: 2024-03-19T20:53:15 kdeconnect.plugin.battery: Total quantity of batteries found:  2
мар 19 20:53:15 poh9shka-pc kdeconnectd[18861]: 2024-03-19T20:53:15 kdeconnect.plugin.battery: Primary Battery seems to have been removed. Suspending packets until it is reconnected.
мар 19 20:53:15 poh9shka-pc plasmashell[18688]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
мар 19 20:53:15 poh9shka-pc plasmashell[18688]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
мар 19 20:53:15 poh9shka-pc plasmashell[18688]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
мар 19 20:53:15 poh9shka-pc plasmashell[18688]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
мар 19 20:53:15 poh9shka-pc plasmashell[18688]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
мар 19 20:53:16 poh9shka-pc plasmashell[18688]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
мар 19 20:53:16 poh9shka-pc plasmashell[18688]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
мар 19 20:53:17 poh9shka-pc plasmashell[18688]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Maybe try to set QT_QPA_PLATFORM_PLUGIN_PATH? But I have three folders in /usr/lib/:
ls -l /usr/lib/ | grep 'qt'
drwxr-xr-x   6 root root      4096 мар 14  2022 qt
drwxr-xr-x   3 root root      4096 мар 14  2022 qt5
drwxr-xr-x   8 root root      4096 мар 19 19:23 qt6
qt5 doesn’t have plugins folder. So I can try to set only qt or qt6.
Has anyone encountered something similar?
I’ve searched for this issue for a long time because I have the same! Actually seems like it happens in libc.so.6 + 0x9132c. Here is what journalctl -b-1 -p4 --no-pager command shows (after crash I rebooted the PC, that’s why here is a part from previous bootlog):
apr 26 19:03:12 home-desktop systemd-coredump[76404]: [🡕] Process 67767 (Xorg) of user 0 dumped core.
                                                         Stack trace of thread 67767:
                                                         #0  0x00007f6db256232c n/a (libc.so.6 + 0x9132c)
                                                         #1  0x00007f6db25116c8 raise (libc.so.6 + 0x406c8)
                                                         #2  0x00007f6db24f94b8 abort (libc.so.6 + 0x284b8)
                                                         #3  0x000055ae7aae8b00 OsAbort (Xorg + 0x159b00)
                                                         #4  0x000055ae7aae8e3b FatalError (Xorg + 0x159e3b)
                                                         #5  0x000055ae7aae0d46 n/a (Xorg + 0x151d46)
                                                         #6  0x00007f6db2511770 n/a (libc.so.6 + 0x40770)
                                                         #7  0x00007f6db256232c n/a (libc.so.6 + 0x9132c)
                                                         #8  0x00007f6db25116c8 raise (libc.so.6 + 0x406c8)
                                                         #9  0x00007f6db24f94b8 abort (libc.so.6 + 0x284b8)
                                                         #10 0x00007f6db24fa395 n/a (libc.so.6 + 0x29395)
                                                         #11 0x00007f6db256c2a7 n/a (libc.so.6 + 0x9b2a7)
                                                         #12 0x00007f6db2570a4c malloc (libc.so.6 + 0x9fa4c)
                                                         #13 0x00007f6db2a8560c n/a (libpixman-1.so.0 + 0x4f60c)
                                                         #14 0x00007f6db2a86f0b n/a (libpixman-1.so.0 + 0x50f0b)
                                                         #15 0x00007f6db2a8ce29 pixman_region_union (libpixman-1.so.0 + 0x56e29)
                                                         #16 0x000055ae7aa59c2c n/a (Xorg + 0xcac2c)
                                                         #17 0x000055ae7aa5f46d n/a (Xorg + 0xd046d)
                                                         #18 0x00007f6db14c32be n/a (nvidia_drv.so + 0x4c32be)
And here is another example:
apr 26 20:37:33 home-desktop systemd-coredump[2856]: [🡕] Process 873 (Xorg) of user 0 dumped core.
                                                        Stack trace of thread 873:
                                                        #0  0x00007fe28e4c432c n/a (libc.so.6 + 0x9132c)
                                                        #1  0x00007fe28e4736c8 raise (libc.so.6 + 0x406c8)
                                                        #2  0x00007fe28e45b4b8 abort (libc.so.6 + 0x284b8)
                                                        #3  0x0000560dcf168b00 OsAbort (Xorg + 0x159b00)
                                                        #4  0x0000560dcf168e3b FatalError (Xorg + 0x159e3b)
                                                        #5  0x0000560dcf160d46 n/a (Xorg + 0x151d46)
                                                        #6  0x00007fe28e473770 n/a (libc.so.6 + 0x40770)
                                                        #7  0x00007fe28e4c432c n/a (libc.so.6 + 0x9132c)
                                                        #8  0x00007fe28e4736c8 raise (libc.so.6 + 0x406c8)
                                                        #9  0x00007fe28e45b4b8 abort (libc.so.6 + 0x284b8)
                                                        #10 0x00007fe28e45c395 n/a (libc.so.6 + 0x29395)
                                                        #11 0x00007fe28e4ce2a7 n/a (libc.so.6 + 0x9b2a7)
                                                        #12 0x00007fe28e4d2a4c malloc (libc.so.6 + 0x9fa4c)
                                                        #13 0x0000560dcf0e9800 n/a (Xorg + 0xda800)
                                                        #14 0x0000560dcf04e04e n/a (Xorg + 0x3f04e)
                                                        #15 0x00007fe28e45ccd0 n/a (libc.so.6 + 0x29cd0)
                                                        #16 0x00007fe28e45cd8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                        #17 0x0000560dcf04e605 _start (Xorg + 0x3f605)
                                                        Stack trace of thread 1063:
                                                        #0  0x00007fe28e4bf110 n/a (libc.so.6 + 0x8c110)
                                                        #1  0x00007fe28e4c5a0a pthread_mutex_lock (libc.so.6 + 0x92a0a)
                                                        #2  0x0000560dcf15ae75 n/a (Xorg + 0x14be75)
                                                        #3  0x0000560dcf15b8e2 n/a (Xorg + 0x14c8e2)
                                                        #4  0x0000560dcf15f6e9 n/a (Xorg + 0x1506e9)
                                                        #5  0x00007fe28e4c255a n/a (libc.so.6 + 0x8f55a)
                                                        #6  0x00007fe28e53fa3c n/a (libc.so.6 + 0x10ca3c)
For me the crash occurs almost always when I click something in Jetbrains IDEA code editor. It can work for several hours or crash just instanly after first couple of clicks in the IDE.
Are you fully up to date?
I had downgraded my system to the stable branch after it occurred for a few times.
But I am glad to hear that it has been fixed.
