Some steam games render in red colors
I’m having problems with some Steam games. The output is in red shades (from black to red).
I’m running Manjaro Gnome 21.1.2 using Wayland or Xorg. Cause of the old graphics card (ATI Radeon HD 5850) I have to run the steam games using PROTON_USE_WINED3D=1.
These problems did not occur with older versions of Manjaro.
Output of LANG=C inxi --admin --verbosity=7 --filter --no-host --width:
  Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=c9a97edf-e1ca-4036-a4a4-ffa41e3041f4 rw quiet splash apparmor=1
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop Mobo: Gigabyte model: P55A-UD3 v: x.x serial: <filter>
  BIOS: Award v: F6 date: 02/11/2010
  RAM: total: 5.79 GiB used: 2.43 GiB (41.9%)
  Info: Quad Core model: Intel Core i5 760 bits: 64 type: MCP arch: Nehalem
  family: 6 model-id: 1E (30) stepping: 5 microcode: A cache: L2: 8 MiB
  bogomips: 23050
  Speed: 2012 MHz min/max: N/A Core speeds (MHz): 1: 2012 2: 2880 3: 2880
  4: 1489
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
  cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d fpu fxsr
  ht ibpb ibrs lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae
  pat pbe pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good sep smx ssbd
  sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc vme vmx
  vnmi vpid xtopology xtpr
  Type: l1tf
  Type: mds
  status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
  Device-1: AMD Cypress PRO [Radeon HD 5850] vendor: ASUSTeK driver: radeon
  v: kernel bus-ID: 01:00.0 chip-ID: 1002:6899 class-ID: 0300
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa display-ID: 0
  OpenGL: renderer: AMD CYPRESS (DRM 2.50.0 / 5.13.13-1-MANJARO LLVM 12.0.1)
  v: 4.3 Mesa 21.2.1 compat-v: 3.1 direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
  class-ID: 0403
  Device-2: AMD Cypress HDMI Audio [Radeon HD 5830/5850/5870 / 6850/6870
  Rebrand]
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 1002:aa50 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: no
  vendor: Gigabyte driver: r8169 v: kernel port: be00 bus-ID: 03:00.0
  Device-2: Ralink RT2501/RT2573 Wireless Adapter type: USB driver: rt73usb
  bus-ID: 1-5:2 chip-ID: 148f:2573 class-ID: 0000
  IF: wlp0s26f7u5 state: up mac: <filter>
  Local Storage: total: 987.42 GiB used: 294.99 GiB (29.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
  size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: SSD serial: <filter> rev: 4B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Corsair CSSD-F60GB2
  size: 55.9 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: SSD serial: <filter> rev: 1.0 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
  model: WD5000AAKS-007AA0 size: 465.76 GiB block-size: physical: 512 B
  logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1D05
  scheme: MBR
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-S223C rev: SB03
  dev-links: cdrom
  Features: speed: 52 multisession: yes audio: yes dvd: yes
  Optical-2: /dev/sr1 vendor: HL-DT-ST model: BDDVDRW CH08NS10 rev: 2.00
  dev-links: N/A
  ID-1: / raw-size: 139.73 GiB size: 136.48 GiB (97.67%)
  used: 31.84 GiB (23.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: c9a97edf-e1ca-4036-a4a4-ffa41e3041f4
  ID-2: /mnt/Linux Programme raw-size: 326.02 GiB size: 319.91 GiB (98.12%)
  used: 263.15 GiB (82.3%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  label: Linux Programme uuid: 2d228820-27f7-41e0-be35-40b556c07459
  ID-1: /dev/sda1 maj-min: 8:1 size: 8 MiB fs: <superuser required> label: N/A
  uuid: N/A
  ID-2: /dev/sdb1 maj-min: 8:17 size: 55.9 GiB fs: ext4 label: Daten-60
  uuid: b43452ab-d4b1-4de7-be15-aa3be0fbf74d
  ID-3: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ext4 label: Store
  uuid: 3e84298b-ec9e-4838-ba60-0b2d67634864
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 1-5:2 info: Ralink RT2501/RT2573 Wireless Adapter type: Network
  driver: rt73usb interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 300mA
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  chip-ID: 1d6b:0001 class-ID: 0900
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-9: 9-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Device-1: 9-1:2 info: Logitech Advanced Corded Mouse M500s type: Mouse,HID
  power: 300mA chip-ID: 046d:c093 class-ID: 0300 serial: <filter>
  Device-2: 9-2:3 info: Microsoft Sidewinder X4 type: Keyboard,HID
  power: 500mA chip-ID: 045e:0768 class-ID: 0300
  Hub-10: 10-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-11: 11-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0
  speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: radeon temp: 58.0 C
  Processes: 240 Uptime: 26m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1228 lib: 368 flatpak: 0 Shell: Zsh
  v: 5.8 running-in: gnome-terminal inxi: 3.3.06
  1. Please read this:
    How to provide good information
    and press the three dots below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
With logging enabled (PROTON_LOG=1 %command%), the following lines are output repeatedly:
1933.300:010c:0140:err:d3d:wined3d_debug_callback 0x3cd3088: "GL_INVALID_ENUM in glDisable(GL_FRAGMENT_PROGRAM_ARB)".
1933.300:010c:0140:err:d3d:wined3d_debug_callback 0x3cd3088: "GL_INVALID_ENUM in glIsEnabled(GL_VERTEX_PROGRAM_ARB)".
1933.300:010c:0140:err:d3d:wined3d_debug_callback 0x3cd3088: "GL_INVALID_ENUM in glDisable(GL_VERTEX_PROGRAM_ARB)".
1933.300:010c:0140:err:d3d:wined3d_debug_callback 0x3cd3088: "GL_INVALID_ENUM in glIsEnabled(GL_FRAGMENT_SHADER_ATI)".
1933.300:010c:0140:err:d3d:wined3d_debug_callback 0x3cd3088: "GL_INVALID_ENUM in glDisable(GL_FRAGMENT_SHADER_ATI)".
1933.300:010c:0140:err:d3d:wined3d_debug_callback 0x3cd3088: "GL_INVALID_VALUE in glBindBufferRange(size=0)".
Please read this:
Especially the Linux has multiple kernels section, then try an LTS kernel and hopefully the problem will go away “automagically”. :grin:
:crossed_fingers:
P.S. If that doesn’t help, keep researching and posting additional information until someone actually running steam ( != me) shows up.
Using the Manjaro Settings Manager, I installed the last two LTS kernels (5.10.68-1 and 5.4.148-1), rebooted and selected the kernels in GRUB. To no avail.
Then I tried downgrading Steam’s Proton 6.3-6 to Proton 5.13-6 and the graphics look fine. It seems to be up to Proton, probably with the translation to OpenGL.
Try 5.14 bleeding edge then…
:scream:
