Does anyone have experience with this kind of error when installing a QT application? My guess is, anaconda has something to do with it in the present case. I am thankful for any help.
> Making package: lightly-qt 0.4-1 (Mon 08 Feb 2021 10:05:23 CET)
> ==> Checking runtime dependencies...
> ==> Checking buildtime dependencies...
> ==> WARNING: Using existing $srcdir/ tree
> ==> Starting build()...
> -- The C compiler identification is GNU 10.2.0
> -- The CXX compiler identification is GNU 10.2.0
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working C compiler: /usr/bin/cc - skipped
> -- Detecting C compile features
> -- Detecting C compile features - done
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++ - skipped
> -- Detecting CXX compile features
> -- Detecting CXX compile features - done
> Installing in /usr. Run /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/prefix.sh to set the environment for lightly.
> -- Looking for __GLIBC__
> -- Looking for __GLIBC__ - found
> -- Performing Test _OFFT_IS_64BIT
> -- Performing Test _OFFT_IS_64BIT - Success
> -- Performing Test HAVE_DATE_TIME
> -- Performing Test HAVE_DATE_TIME - Success
> -- Found KF5CoreAddons: /usr/lib64/cmake/KF5CoreAddons/KF5CoreAddonsConfig.cmake (found version "5.78.0")
> -- Found KF5GuiAddons: /usr/lib64/cmake/KF5GuiAddons/KF5GuiAddonsConfig.cmake (found version "5.78.0")
> -- Found KF5ConfigWidgets: /usr/lib64/cmake/KF5ConfigWidgets/KF5ConfigWidgetsConfig.cmake (found version "5.78.0")
> -- Found KF5WindowSystem: /usr/lib64/cmake/KF5WindowSystem/KF5WindowSystemConfig.cmake (found version "5.78.0")
> -- Found Gettext: /usr/bin/msgmerge (found version "0.21")
> -- Found KF5I18n: /usr/lib64/cmake/KF5I18n/KF5I18nConfig.cmake (found version "5.78.0")
> -- Found KF5IconThemes: /usr/lib64/cmake/KF5IconThemes/KF5IconThemesConfig.cmake (found version "5.78.0")
> -- Found KF5: success (found version "5.78.0") found components: CoreAddons GuiAddons ConfigWidgets WindowSystem I18n IconThemes
> -- Found PkgConfig: /usr/bin/pkg-config (found version "1.7.3")
> -- Found XCB_XCB: /usr/lib/libxcb.so (found version "1.14")
> -- Found XCB: /usr/lib/libxcb.so (found version "1.14") found components: XCB
> -- Warning: Property URL already set to "https://xcb.freedesktop.org/", overriding it with "https://xcb.freedesktop.org"
> -- Performing Test COMPILER_HAS_HIDDEN_VISIBILITY
> -- Performing Test COMPILER_HAS_HIDDEN_VISIBILITY - Success
> -- Performing Test COMPILER_HAS_HIDDEN_INLINE_VISIBILITY
> -- Performing Test COMPILER_HAS_HIDDEN_INLINE_VISIBILITY - Success
> -- Performing Test COMPILER_HAS_DEPRECATED_ATTR
> -- Performing Test COMPILER_HAS_DEPRECATED_ATTR - Success
> -- Found KF5Config: /usr/lib64/cmake/KF5Config/KF5ConfigConfig.cmake (found version "5.78.0")
> -- Found KF5: success (found version "5.78.0") found components: I18n Config GuiAddons IconThemes ConfigWidgets WindowSystem
> -- Warning: Property URL already set to "https://xcb.freedesktop.org", overriding it with "https://xcb.freedesktop.org/"
> Installing in /usr. Run /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/misc/kde4lightly/prefix.sh to set the environment for lightly.
> -- Found KF5: success (found version "5.78.0") found components: CoreAddons Config
> CMake Warning (dev) at /usr/share/ECM/modules/ECMPackageConfigHelpers.cmake:63 (message):
> Your project already requires a version of CMake that includes the
> find_dependency macro via the CMakeFindDependencyMacro module. You should
> use CMakePackageConfigHelpers instead of ECMPackageConfigHelpers.
> Call Stack (most recent call first):
> misc/kde4lightly/CMakeLists.txt:12 (include)
> This warning is for project developers. Use -Wno-dev to suppress it.
> -- The following OPTIONAL packages have been found:
> * Qt5Network (required version >= 5.9.7)
> * Qt5Qml (required version >= 5.9.7)
> * Qt5Quick
> * KF5FrameworkIntegration, KF5 Framework Integration, <https://projects.kde.org/projects/frameworks/frameworkintegration>
> Required to use KStyle convenience functionalities in style
> * PkgConfig
> * XCB, X protocol C-language Binding, <https://xcb.freedesktop.org>
> Required to pass style properties to native Windows on X11 Platform
> * KF5Wayland
> * KF5Auth (required version >= 5.78.0)
> * KF5Codecs (required version >= 5.78.0)
> * KF5WidgetsAddons (required version >= 5.78.0)
> * KF5Service (required version >= 5.78.0)
> * KF5KCMUtils, KF5 KCM utils Framework, <https://projects.kde.org/projects/frameworks/kcmutils>
> Required for lightly-settings5 application to build
> * Qt5Core (required version >= 5.14.0)
> -- The following REQUIRED packages have been found:
> * KDecoration2
> * Gettext
> * KF5I18n
> * KF5GuiAddons
> * KF5WindowSystem
> * KF5IconThemes (required version >= 5.78.0)
> * Qt5X11Extras
> * KF5ConfigWidgets (required version >= 5.78.0)
> * ECM (required version >= 0.0.13)
> * Qt5Widgets
> * Qt5
> * KF5CoreAddons
> * Qt5DBus (required version >= 5.14.0)
> * KF5Config
> * KF5
> -- Configuring done
> CMake Warning at kdecoration/CMakeLists.txt:67 (add_library):
> Cannot generate a safe runtime search path for target lightlydecoration
> because files in some directories may conflict with libraries in implicit
> directories:
> runtime library [libxcb.so.1] in /usr/lib may be hidden by files in:
> /home/meck/anaconda3/lib
> runtime library [libQt5Xml.so.5] in /usr/lib may be hidden by files in:
> runtime library [libQt5DBus.so.5] in /usr/lib may be hidden by files in:
> runtime library [libQt5Widgets.so.5] in /usr/lib may be hidden by files in:
> runtime library [libQt5Gui.so.5] in /usr/lib may be hidden by files in:
> Some of these libraries may not be found correctly.
> CMake Warning at liblightlycommon/CMakeLists.txt:10 (add_library):
> Cannot generate a safe runtime search path for target lightlycommon5
> directories:
> CMake Warning at kstyle/CMakeLists.txt:104 (add_library):
> Cannot generate a safe runtime search path for target lightly because files
> in some directories may conflict with libraries in implicit directories:
> CMake Warning at kstyle/config/CMakeLists.txt:31 (add_executable):
> Cannot generate a safe runtime search path for target lightly-settings5
> directories:
> Cannot generate a safe dependent library path for target lightly-settings5
> directories:
> CMake Warning at kstyle/config/CMakeLists.txt:11 (add_library):
> Cannot generate a safe runtime search path for target kstyle_lightly_config
> directories:
> CMake Warning at misc/kde4lightly/src/CMakeLists.txt:9 (add_executable):
> Cannot generate a safe runtime search path for target kde4lightly because
> directories:
> -- Generating done
> -- Build files have been written to: /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build
> Scanning dependencies of target lightly-settings5_autogen
> Scanning dependencies of target kstyle_lightly_config_autogen
> Scanning dependencies of target lightlycommon5_autogen
> Scanning dependencies of target kde4lightly_autogen
> [ 2%] Automatic MOC for target kstyle_lightly_config
> [ 2%] Automatic MOC for target lightly-settings5
> [ 4%] Automatic MOC for target kde4lightly
> [ 4%] Automatic MOC for target lightlycommon5
> AutoMoc subprocess error
> The moc process failed to compile
> "SRC:/kstyle/config/lightlystyleconfig.h"
> into
> "SRC:/build/kstyle/config/kstyle_lightly_config_autogen/EWIEGA46WW/moc_lightlystyleconfig.cpp"
> Command
> /home/meck/anaconda3/bin/moc -DKCOREADDONS_LIB -DQT_CORE_LIB -DQT_DBUS_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_WIDGETS_LIB -DQT_XML_LIB "-DTRANSLATION_DOMAIN=\"lightly_style_config\"" -D_GNU_SOURCE -D_LARGEFILE64_SOURCE -Dkstyle_lightly_config_EXPORTS -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/config -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/animations -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/debug -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/liblightlycommon -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/liblightlycommon -I/home/meck/anaconda3/include/qt -I/home/meck/anaconda3/include/qt/QtCore -I/home/meck/anaconda3/mkspecs/linux-g++ -I/usr/include/qt -I/usr/include/qt/QtGui -I/usr/include/qt/QtWidgets -I/usr/include/qt/QtDBus -I/usr/include/KF5/KConfigCore -I/usr/include/KF5 -I/usr/include/KF5/KConfigWidgets -I/usr/include/KF5/KCodecs -I/usr/include/KF5/KWidgetsAddons -I/usr/include/KF5/KConfigGui -I/usr/include/qt/QtXml -I/usr/include/KF5/KAuth -I/usr/include/KF5/KCoreAddons -I/usr/include/KF5/KI18n -I/usr/include/c++/10.2.0 -I/usr/include/c++/10.2.0/x86_64-pc-linux-gnu -I/usr/include/c++/10.2.0/backward -I/usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/include -I/usr/local/include -I/usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/include-fixed -I/usr/include --include /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config/kstyle_lightly_config_autogen/moc_predefs.h --output-dep-file -o /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config/kstyle_lightly_config_autogen/EWIEGA46WW/moc_lightlystyleconfig.cpp /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/config/lightlystyleconfig.h
> Output
> Unknown option 'output-dep-file'.
> "SRC:/kstyle/config/lightlystyleconfigmodule.cpp"
> into
> "SRC:/build/kstyle/config/kstyle_lightly_config_autogen/include/lightlystyleconfigmodule.moc"
> included by
> Command
> /home/meck/anaconda3/bin/moc -DKCOREADDONS_LIB -DQT_CORE_LIB -DQT_DBUS_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_WIDGETS_LIB -DQT_XML_LIB "-DTRANSLATION_DOMAIN=\"lightly_style_config\"" -D_GNU_SOURCE -D_LARGEFILE64_SOURCE -Dkstyle_lightly_config_EXPORTS -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/config -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/animations -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/debug -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/liblightlycommon -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/liblightlycommon -I/home/meck/anaconda3/include/qt -I/home/meck/anaconda3/include/qt/QtCore -I/home/meck/anaconda3/mkspecs/linux-g++ -I/usr/include/qt -I/usr/include/qt/QtGui -I/usr/include/qt/QtWidgets -I/usr/include/qt/QtDBus -I/usr/include/KF5/KConfigCore -I/usr/include/KF5 -I/usr/include/KF5/KConfigWidgets -I/usr/include/KF5/KCodecs -I/usr/include/KF5/KWidgetsAddons -I/usr/include/KF5/KConfigGui -I/usr/include/qt/QtXml -I/usr/include/KF5/KAuth -I/usr/include/KF5/KCoreAddons -I/usr/include/KF5/KI18n -I/usr/include/c++/10.2.0 -I/usr/include/c++/10.2.0/x86_64-pc-linux-gnu -I/usr/include/c++/10.2.0/backward -I/usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/include -I/usr/local/include -I/usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/include-fixed -I/usr/include --include /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config/kstyle_lightly_config_autogen/moc_predefs.h --output-dep-file -o /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config/kstyle_lightly_config_autogen/include/lightlystyleconfigmodule.moc /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/config/lightlystyleconfigmodule.cpp
> Output
> "SRC:/kstyle/config/lightlystyleconfigmodule.h"
> into
> "SRC:/build/kstyle/config/kstyle_lightly_config_autogen/EWIEGA46WW/moc_lightlystyleconfigmodule.cpp"
> Command
> /home/meck/anaconda3/bin/moc -DKCOREADDONS_LIB -DQT_CORE_LIB -DQT_DBUS_LIB -DQT_GUI_LIB -DQT_NO_DEBUG -DQT_WIDGETS_LIB -DQT_XML_LIB "-DTRANSLATION_DOMAIN=\"lightly_style_config\"" -D_GNU_SOURCE -D_LARGEFILE64_SOURCE -Dkstyle_lightly_config_EXPORTS -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/config -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/animations -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/debug -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/liblightlycommon -I/home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/liblightlycommon -I/home/meck/anaconda3/include/qt -I/home/meck/anaconda3/include/qt/QtCore -I/home/meck/anaconda3/mkspecs/linux-g++ -I/usr/include/qt -I/usr/include/qt/QtGui -I/usr/include/qt/QtWidgets -I/usr/include/qt/QtDBus -I/usr/include/KF5/KConfigCore -I/usr/include/KF5 -I/usr/include/KF5/KConfigWidgets -I/usr/include/KF5/KCodecs -I/usr/include/KF5/KWidgetsAddons -I/usr/include/KF5/KConfigGui -I/usr/include/qt/QtXml -I/usr/include/KF5/KAuth -I/usr/include/KF5/KCoreAddons -I/usr/include/KF5/KI18n -I/usr/include/c++/10.2.0 -I/usr/include/c++/10.2.0/x86_64-pc-linux-gnu -I/usr/include/c++/10.2.0/backward -I/usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/include -I/usr/local/include -I/usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/include-fixed -I/usr/include --include /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config/kstyle_lightly_config_autogen/moc_predefs.h --output-dep-file -o /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/build/kstyle/config/kstyle_lightly_config_autogen/EWIEGA46WW/moc_lightlystyleconfigmodule.cpp /home/meck/.cache/yay/lightly-qt/src/Lightly-0.4/kstyle/config/lightlystyleconfigmodule.h
> Output
> make[2]: *** [kstyle/config/CMakeFiles/kstyle_lightly_config_autogen.dir/build.make:77: kstyle/config/CMakeFiles/kstyle_lightly_config_autogen] Error 1
> make[1]: *** [CMakeFiles/Makefile2:954: kstyle/config/CMakeFiles/kstyle_lightly_config_autogen.dir/all] Error 2
> make[1]: *** Waiting for unfinished jobs....
> [ 4%] Built target kde4lightly_autogen
> [ 4%] Built target lightlycommon5_autogen
> [ 4%] Built target lightly-settings5_autogen
> make: *** [Makefile:149: all] Error 2
> ==> ERROR: A failure occurred in build().
> Aborting...
> error making: lightly-qt
