Hello,
recently i’m having some problem with keyboard.
Suddenly some particular keys
e.g. “s” , “w” , “x” and “2”
these keys doesn’t work. But If i press them for too long then all of them starts to work properly. But after a little time they don’t work again.
I’m using:
5.15.38-1 LTS kernel
I tried 5.10 and 5.15.36rt but nothing helps
Pleae Help !
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=71f51a91-f49b-4cf8-a93c-399aa59b177b rw quiet
resume=UUID=2d56ae24-4e22-42ef-9901-2bd813914904 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 2324A82 v: ThinkPad X230
Mobo: LENOVO model: 2324A82 serial: <superuser required> UEFI: LENOVO
v: G2ET90WW (2.50 ) date: 12/20/2012
ID-1: BAT0 charge: 25.6 Wh (54.6%) condition: 46.9/64.0 Wh (73.3%)
volts: 11.1 min: 10.8 model: SANYO 45N1023 type: Li-ion serial: <filter>
status: discharging
Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1758 high: 2371 min/max: 1200/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1483 2: 1693 3: 1487
4: 2371 bogomips: 20761
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel ports: active: LVDS-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-1.6:4 chip-ID: 04f2:b2eb class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x02d8 built: 2012 res: 1366x768
hz: 60 dpi: 125 gamma: 1.2 size: 277x156mm (10.91x6.14") diag: 318mm (12.5")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 22.0.3
compat-v: 3.1 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.51 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0085 class-ID: 0280
Device-1: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad] type: USB driver: btusb
v: 0.8 bus-ID: 1-1.4:3 chip-ID: 0a5c:21e6 class-ID: fe01 serial: <filter>
Local Storage: total: 111.79 GiB used: 35.58 GiB (31.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD SSD 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0A0 scheme: GPT
ID-1: / raw-size: 102.69 GiB size: 100.52 GiB (97.89%)
used: 35.58 GiB (35.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 67.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 4341
Processes: 228 Uptime: 6m wakeups: 2 Memory: 7.59 GiB used: 2.1 GiB (27.7%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1381 lib: 377 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.15
those are not the latest kernels you are using… did you run the latest update from few days ago?
Yes!!! I had…Do I need to change the kernel?
when did you run the update? did you rebooted after the update? those are old kernels youre running, not the latest from the update
I dont remember properly but maybe around a week or two ago
but the latest kernels are:
5.15.41-1
and youre running 5.15.38-1
so you dont have the latest kernels
run this command: pamac update
recently i have changed fonts of my system.
can it be related to my problem?
go to system setting/kernel and post the screenshot
changing fonts could be the problem, so try to set them to defaults, then reboot and test
changed and rebooted but no change
you are running old kernels, so i dont know if you didnt reboot after the last stable update, or you dont have updated your system yet…
I’m Running the latest lts verion…that’ hy the kernel didn’t updated
no you are not running the latest LTS …
post formated output from:
inxi -Fazy
and also install the 5.10 and 5.17 and try with them
status: discharging
Type: l1tf
screens: 1
class-ID: 0403
if you run this:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
0.184 Bangladesh : http://mirror.xeonbd.com/manjaro/
::INFO Writing mirror list
::Bangladesh : http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core 169.4 KiB 552 KiB/s 00:00 [####################################################] 100%
extra 1884.0 KiB 1208 KiB/s 00:02 [####################################################] 100%
community 7.0 MiB 1775 KiB/s 00:04 [####################################################] 100%
multilib 178.9 KiB 877 KiB/s 00:00 [####################################################] 100%
there is nothing to do
i have no idea why youre using old kernels… so try yo switch to the 5.10 and 5.17 and try with them
I tried 5.10
now installing 5.17
omano
29 May 2022 09:51
21
Obviously his single mirror from his custom mirror pool is not synced yet.
from the file at http://mirror.xeonbd.com/manjaro/state
### BoxIt global state file
# Unique hash code representing current repository state.
# This hash code changes in a frequent interval.
state=58de39efd2a6b3ca8b28c41fb17ed6f1b088720f
# Date and time of the last state update.
date=2022-05-15T04:56:47Z
Execute the following command to switch to Global mirrors (CDN)
sudo pacman-mirrors -c Global && sudo pacman -Syyu
