Some audio players don't work right
When I test the audio in sound settings, and I click on left speaker, right speaker, it works.
But some audio players are not working right.
Audacious doesn’t access the sound tracks, and now Strawberry doesn’t put out sound. VLC still works.
inxi -F         ✔
  Host: shmuel-manjaro Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.6 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 2208
    date: 07/09/2021
  ID-1: hidpp_battery_0 charge: 80% condition: N/A
  Info: 8-core model: Intel Core i7-9700 bits: 64 type: MCP cache: L2: 2 MiB
  Speed (MHz): avg: 1625 min/max: 800/4700 cores: 1: 800 2: 800 3: 800
    4: 3000 5: 800 6: 3000 7: 800 8: 3000
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
  Device-2: USB C Video Adaptor driver: N/A type: USB
  Device-3: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
    type: USB
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_wayland driver: X: loaded: modesetting dri: iris gpu: i915
    resolution: 1: 1920x1080 2: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2)
  Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
  Device-2: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
    type: USB
  API: ALSA v: k6.4.6-1-MANJARO status: kernel-api
  Server-1: PulseAudio v: 16.1 status: active
    driver: r8169
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: a8:5e:45:e2:87:3c
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
  IF: enp0s20f0u3u1 state: down mac: 00:e0:4c:68:51:92
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    type: USB
  Local Storage: total: 2.26 TiB used: 751.92 GiB (32.5%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
  ID-2: /dev/sdb vendor: Toshiba model: HDWD120 size: 1.82 TiB
  ID-1: / size: 63.33 GiB used: 16.24 GiB (25.6%) fs: ext4 dev: /dev/sda6
  ID-2: /boot/efi size: 96 MiB used: 25.6 MiB (26.7%) fs: vfat
    dev: /dev/sda1
  System Temperatures: cpu: 38.0 C mobo: N/A
  Processes: 248 Uptime: 18m Memory: total: 16 GiB available: 15.49 GiB
  used: 3.06 GiB (19.7%) Shell: Zsh inxi: 3.3.28
  1. You should add a swap partition or file.
  2. Can you post /etc/pulse/daemon.conf ?
Perhaps you don’t have the required gstreamer codecs installed. VLC provides its own codecs.
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out.  Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
which package do i want to install for the codecs?
EDIT: I have kcodecs installed.
I installed manjaro-pipewire and after a reboot, all is well.
