it just happened again, this time every process froze 1 by 1 until the system became completely unresponsive. Happened on 6.6.19 kernel, latest nvidia driver but with hybrid mode (nvidia gpu not being used). Here is the journalctl
мар 07 20:38:55 ~-P1G6 kernel: _raw_spin_lock+0x29/0x30
мар 07 20:38:55 ~-P1G6 kernel: ? native_queued_spin_lock_slowpath+0x6e/0x2e0
мар 07 20:38:55 ~-P1G6 kernel: ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
мар 07 20:38:55 ~-P1G6 kernel: <TASK>
мар 07 20:38:55 ~-P1G6 kernel: </IRQ>
мар 07 20:38:55 ~-P1G6 kernel: ? sysvec_apic_timer_interrupt+0x6d/0x90
мар 07 20:38:55 ~-P1G6 kernel: ? __sysvec_apic_timer_interrupt+0x4d/0x140
мар 07 20:38:55 ~-P1G6 kernel: ? hrtimer_interrupt+0xf8/0x230
мар 07 20:38:55 ~-P1G6 kernel: ? __hrtimer_run_queues+0x10f/0x2b0
мар 07 20:38:55 ~-P1G6 kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
мар 07 20:38:55 ~-P1G6 kernel: ? watchdog_timer_fn+0x1b8/0x220
мар 07 20:38:55 ~-P1G6 kernel: <IRQ>
мар 07 20:38:55 ~-P1G6 kernel: Call Trace:
мар 07 20:38:55 ~-P1G6 kernel: PKRU: 55555554
мар 07 20:38:55 ~-P1G6 kernel: CR2: 0000557d03724588 CR3: 000000027cf32000 CR4: 0000000000f50ee0
мар 07 20:38:55 ~-P1G6 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
мар 07 20:38:55 ~-P1G6 kernel: FS: 00007fa0ae0fb6c0(0000) GS:ffff88901f400000(0000) knlGS:0000000000000000
мар 07 20:38:55 ~-P1G6 kernel: R13: 03ffffffffffffff R14: ffff888101fcda90 R15: 0000000000000000
мар 07 20:38:55 ~-P1G6 kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000184155
мар 07 20:38:55 ~-P1G6 kernel: RBP: ffff888101fcda98 R08: ffffea000da69d00 R09: 000000000000000a
мар 07 20:38:55 ~-P1G6 kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff888101fcda98
мар 07 20:38:55 ~-P1G6 kernel: RAX: 0000000000000001 RBX: ffff888101fcda98 RCX: 0000000000000003
мар 07 20:38:55 ~-P1G6 kernel: RSP: 0000:ffffc9000b8e3bb0 EFLAGS: 00000202
мар 07 20:38:55 ~-P1G6 kernel: Code: 77 7f f0 0f ba 2b 08 0f 92 c2 8b 03 0f b6 d2 c1 e2 08 30 e4 09 d0 3d ff 00 00 00 77 5b 85 c0 74 10 0f b6 03 84 c0 74 09 f>
мар 07 20:38:55 ~-P1G6 kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x6e/0x2e0
мар 07 20:38:55 ~-P1G6 kernel: Hardware name: LENOVO 21FVCTO1WW/21FVCTO1WW, BIOS N3ZET21W (1.08 ) 07/07/2023
мар 07 20:38:55 ~-P1G6 kernel: CPU: 8 PID: 15441 Comm: Thread (pooled) Tainted: P B D W OEL 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e>
мар 07 20:38:55 ~-P1G6 kernel: int3403_thermal i2c_hid_acpi int340x_thermal_zone serial_multi_instantiate i2c_hid int3400_thermal wmi acpi_thermal_rel acpi_t>
мар 07 20:38:55 ~-P1G6 kernel: crct10dif_pclmul snd_hda_codec_hdmi snd_compress crc32_pclmul ac97_bus mac80211 polyval_clmulni snd_pcm_dmaengine polyval_gene>
мар 07 20:38:55 ~-P1G6 kernel: Modules linked in: snd_usb_audio snd_usbmidi_lib snd_ump snd_rawmidi snd_seq_device usbhid tls ccm rfcomm nvidia_uvm(POE) nvidi>
мар 07 20:38:55 ~-P1G6 kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 52s! [Thread (pooled):15441]
мар 07 20:38:27 ~-P1G6 kernel: </TASK>
мар 07 20:38:27 ~-P1G6 kernel: R13: 0000557d03774cd0 R14: 00007fff71ba68a0 R15: 00007fa0ad8fb000
мар 07 20:38:27 ~-P1G6 kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 0000557d035c3070
мар 07 20:38:27 ~-P1G6 kernel: RBP: 0000557d03724588 R08: 0000000000000011 R09: 0000000000000000
мар 07 20:38:27 ~-P1G6 kernel: RDX: 0000000000000001 RSI: 0000000000000000 RDI: 0000557d03724588
мар 07 20:38:27 ~-P1G6 kernel: RAX: 0000000000000000 RBX: 0000557d03724530 RCX: 0000000000000000
мар 07 20:38:27 ~-P1G6 kernel: RSP: 002b:00007fa0ae0fad08 EFLAGS: 00010246
мар 07 20:38:27 ~-P1G6 kernel: Code: 41 0f 94 c4 4c 89 ef e8 43 d8 fe ff 48 83 c4 08 44 89 e0 5b 5d 41 5c 41 5d c3 90 0f 1f 40 00 f3 0f 1e fa 31 c0 ba 01 00 0>
мар 07 20:38:27 ~-P1G6 kernel: RIP: 0033:0x7fa0b3ae72cb
мар 07 20:38:27 ~-P1G6 kernel: asm_exc_page_fault+0x26/0x30
мар 07 20:38:27 ~-P1G6 kernel: exc_page_fault+0x7f/0x180
мар 07 20:38:27 ~-P1G6 kernel: do_user_addr_fault+0x15b/0x660
мар 07 20:38:27 ~-P1G6 kernel: handle_mm_fault+0x17f/0x360
мар 07 20:38:27 ~-P1G6 kernel: __handle_mm_fault+0x7fb/0xd90
мар 07 20:38:27 ~-P1G6 kernel: ? __pte_offset_map+0x1b/0x180
мар 07 20:38:27 ~-P1G6 kernel: ? __pfx_hrtimer_wakeup+0x10/0x10
мар 07 20:38:27 ~-P1G6 kernel: do_swap_page+0x1b8/0xd30
мар 07 20:38:27 ~-P1G6 kernel: swapin_readahead+0x464/0x4e0
мар 07 20:38:27 ~-P1G6 kernel: swap_readpage+0x81/0x460
мар 07 20:38:27 ~-P1G6 kernel: ? __mod_memcg_lruvec_state+0x4e/0xa0
мар 07 20:38:27 ~-P1G6 kernel: zswap_load+0x9c/0x490
мар 07 20:38:27 ~-P1G6 kernel: _raw_spin_lock+0x29/0x30
мар 07 20:38:27 ~-P1G6 kernel: ? native_queued_spin_lock_slowpath+0x6e/0x2e0
мар 07 20:38:27 ~-P1G6 kernel: ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
мар 07 20:38:27 ~-P1G6 kernel: <TASK>
мар 07 20:38:27 ~-P1G6 kernel: </IRQ>
мар 07 20:38:27 ~-P1G6 kernel: ? sysvec_apic_timer_interrupt+0x6d/0x90
мар 07 20:38:27 ~-P1G6 kernel: ? __sysvec_apic_timer_interrupt+0x4d/0x140
мар 07 20:38:27 ~-P1G6 kernel: ? hrtimer_interrupt+0xf8/0x230
мар 07 20:38:27 ~-P1G6 kernel: ? __hrtimer_run_queues+0x10f/0x2b0
мар 07 20:38:27 ~-P1G6 kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
мар 07 20:38:27 ~-P1G6 kernel: ? watchdog_timer_fn+0x1b8/0x220
мар 07 20:38:27 ~-P1G6 kernel: <IRQ>
мар 07 20:38:27 ~-P1G6 kernel: Call Trace:
мар 07 20:38:27 ~-P1G6 kernel: PKRU: 55555554
мар 07 20:38:27 ~-P1G6 kernel: CR2: 0000557d03724588 CR3: 000000027cf32000 CR4: 0000000000f50ee0
мар 07 20:38:27 ~-P1G6 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
мар 07 20:38:27 ~-P1G6 kernel: FS: 00007fa0ae0fb6c0(0000) GS:ffff88901f400000(0000) knlGS:0000000000000000
мар 07 20:38:27 ~-P1G6 kernel: R13: 03ffffffffffffff R14: ffff888101fcda90 R15: 0000000000000000
мар 07 20:38:27 ~-P1G6 kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000184155
мар 07 20:38:27 ~-P1G6 kernel: RBP: ffff888101fcda98 R08: ffffea000da69d00 R09: 000000000000000a
мар 07 20:38:27 ~-P1G6 kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff888101fcda98
мар 07 20:38:27 ~-P1G6 kernel: RAX: 0000000000000001 RBX: ffff888101fcda98 RCX: 0000000000000003
мар 07 20:38:27 ~-P1G6 kernel: RSP: 0000:ffffc9000b8e3bb0 EFLAGS: 00000202
мар 07 20:38:27 ~-P1G6 kernel: Code: 77 7f f0 0f ba 2b 08 0f 92 c2 8b 03 0f b6 d2 c1 e2 08 30 e4 09 d0 3d ff 00 00 00 77 5b 85 c0 74 10 0f b6 03 84 c0 74 09 f>
мар 07 20:38:27 ~-P1G6 kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x6e/0x2e0
мар 07 20:38:27 ~-P1G6 kernel: Hardware name: LENOVO 21FVCTO1WW/21FVCTO1WW, BIOS N3ZET21W (1.08 ) 07/07/2023
мар 07 20:38:27 ~-P1G6 kernel: CPU: 8 PID: 15441 Comm: Thread (pooled) Tainted: P B D W OE 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e>
мар 07 20:38:27 ~-P1G6 kernel: int3403_thermal i2c_hid_acpi int340x_thermal_zone serial_multi_instantiate i2c_hid int3400_thermal wmi acpi_thermal_rel acpi_t>
мар 07 20:38:27 ~-P1G6 kernel: crct10dif_pclmul snd_hda_codec_hdmi snd_compress crc32_pclmul ac97_bus mac80211 polyval_clmulni snd_pcm_dmaengine polyval_gene>
мар 07 20:38:27 ~-P1G6 kernel: Modules linked in: snd_usb_audio snd_usbmidi_lib snd_ump snd_rawmidi snd_seq_device usbhid tls ccm rfcomm nvidia_uvm(POE) nvidi>
мар 07 20:38:27 ~-P1G6 kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 26s! [Thread (pooled):15441]
мар 07 20:37:32 ~-P1G6 kernel: ---[ end trace 0000000000000000 ]---
мар 07 20:37:32 ~-P1G6 kernel: </TASK>
мар 07 20:37:32 ~-P1G6 kernel: R13: 00007fff71ba6750 R14: 0000000000000058 R15: 00007f60b2acb000
мар 07 20:37:32 ~-P1G6 kernel: R10: 0000000000000004 R11: 0000000000000001 R12: 0000000000000000
мар 07 20:37:32 ~-P1G6 kernel: RBP: 0000000000000000 R08: 00007fff71ba6290 R09: 0000000000000000
мар 07 20:37:32 ~-P1G6 kernel: RDX: 0000000000000000 RSI: 00007f60b2acb000 RDI: 0000000000000000
мар 07 20:37:32 ~-P1G6 kernel: RAX: 0000000000000003 RBX: 00007fff71ba6370 RCX: 0000000000000004
мар 07 20:37:32 ~-P1G6 kernel: RSP: 002b:00007fff71ba6280 EFLAGS: 00010246
мар 07 20:37:32 ~-P1G6 kernel: Code: c2 0f b7 c9 c1 e2 10 09 ca 89 53 40 31 d2 48 89 74 c3 48 66 89 94 43 48 01 00 00 40 f6 c5 01 0f 85 1d 01 00 00 4c 8b 7c 2>
мар 07 20:37:32 ~-P1G6 kernel: RIP: 0033:0x7fa0b2bf2258
мар 07 20:37:32 ~-P1G6 kernel: rewind_stack_and_make_dead+0x17/0x20
мар 07 20:37:32 ~-P1G6 kernel: make_task_dead+0x81/0x170
мар 07 20:37:32 ~-P1G6 kernel: ? do_exit+0x70/0xb20
мар 07 20:37:32 ~-P1G6 kernel: ? do_exit+0x8e9/0xb20
мар 07 20:37:32 ~-P1G6 kernel: ? asm_exc_invalid_op+0x1a/0x20
мар 07 20:37:32 ~-P1G6 kernel: ? exc_invalid_op+0x17/0x70
мар 07 20:37:32 ~-P1G6 kernel: ? handle_bug+0x3c/0x80
мар 07 20:37:32 ~-P1G6 kernel: ? report_bug+0x171/0x1a0
мар 07 20:37:32 ~-P1G6 kernel: ? __warn+0x81/0x130
мар 07 20:37:32 ~-P1G6 kernel: <TASK>
мар 07 20:37:32 ~-P1G6 kernel: Call Trace:
мар 07 20:37:32 ~-P1G6 kernel: PKRU: 55555554
мар 07 20:37:32 ~-P1G6 kernel: CR2: 00000000000033dd CR3: 000000027cf32000 CR4: 0000000000f50ee0
мар 07 20:37:32 ~-P1G6 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
мар 07 20:37:32 ~-P1G6 kernel: FS: 00007fa0b240f880(0000) GS:ffff88901f3c0000(0000) knlGS:0000000000000000
мар 07 20:37:32 ~-P1G6 kernel: R13: ffff888154daa940 R14: 0000000000000000 R15: 0000000000000000
мар 07 20:37:32 ~-P1G6 kernel: R10: 0000000000000003 R11: ffff88905f7a4c28 R12: 0000000000000009
мар 07 20:37:32 ~-P1G6 kernel: RBP: ffff888104508900 R08: 0000000000000000 R09: ffffc9000554fdd8
мар 07 20:37:32 ~-P1G6 kernel: RDX: 0000000000000001 RSI: 0000000000002710 RDI: ffff888154daa940
мар 07 20:37:32 ~-P1G6 kernel: RAX: 0000000000000000 RBX: ffff888242fe8000 RCX: 0000000080000000
мар 07 20:37:32 ~-P1G6 kernel: RSP: 0000:ffffc9000554fed8 EFLAGS: 00010286
мар 07 20:37:32 ~-P1G6 kernel: Code: e9 35 f8 ff ff 48 8b bb 00 06 00 00 31 f6 e8 3e d9 ff ff e9 bd fd ff ff 4c 89 e6 bf 05 06 00 00 e8 2c 1b 01 00 e9 5f f8 f>
мар 07 20:37:32 ~-P1G6 kernel: RIP: 0010:do_exit+0x8e9/0xb20
мар 07 20:37:32 ~-P1G6 kernel: Hardware name: LENOVO 21FVCTO1WW/21FVCTO1WW, BIOS N3ZET21W (1.08 ) 07/07/2023
мар 07 20:37:32 ~-P1G6 kernel: CPU: 7 PID: 5283 Comm: baloo_file Tainted: P B D OE 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e1c
мар 07 20:37:32 ~-P1G6 kernel: int3403_thermal i2c_hid_acpi int340x_thermal_zone serial_multi_instantiate i2c_hid int3400_thermal wmi acpi_thermal_rel acpi_t>
мар 07 20:37:32 ~-P1G6 kernel: crct10dif_pclmul snd_hda_codec_hdmi snd_compress crc32_pclmul ac97_bus mac80211 polyval_clmulni snd_pcm_dmaengine polyval_gene>
мар 07 20:37:32 ~-P1G6 kernel: Modules linked in: snd_usb_audio snd_usbmidi_lib snd_ump snd_rawmidi snd_seq_device usbhid tls ccm rfcomm nvidia_uvm(POE) nvidi>
мар 07 20:37:32 ~-P1G6 kernel: WARNING: CPU: 7 PID: 5283 at kernel/exit.c:818 do_exit+0x8e9/0xb20
мар 07 20:37:32 ~-P1G6 kernel: ------------[ cut here ]------------
мар 07 20:37:32 ~-P1G6 kernel: note: baloo_file[5283] exited with preempt_count 1
мар 07 20:37:32 ~-P1G6 kernel: note: baloo_file[5283] exited with irqs disabled
мар 07 20:37:32 ~-P1G6 kernel: R13: 0000000000000001 R14: ffff8881f0a61b40 R15: ffff88901f3f0840
мар 07 20:37:32 ~-P1G6 kernel: R10: 0000000000000000 R11: 0000000000000107 R12: 0000000000000206
мар 07 20:37:32 ~-P1G6 kernel: RBP: 00000000000033dd R08: ffff888101fcda90 R09: 0000000000000011
мар 07 20:37:32 ~-P1G6 kernel: RDX: ffff888242fe8000 RSI: 00000000000005bf RDI: ffff88901f3f0840
мар 07 20:37:32 ~-P1G6 kernel: RAX: 0000000000000001 RBX: 00000000000005bf RCX: ffff888142b30a00
мар 07 20:37:32 ~-P1G6 kernel: RSP: 0000:ffffc9000554f780 EFLAGS: 00010002
мар 07 20:37:32 ~-P1G6 kernel: Code: c7 40 08 03 00 65 4c 03 3d 9e f0 83 4c 49 8b 47 10 48 39 f8 0f 84 9c 00 00 00 4c 89 ff e8 69 f2 ff ff 49 89 c6 e8 a1 22 d>
мар 07 20:37:32 ~-P1G6 kernel: RIP: 0010:refill_obj_stock+0x4f/0x180
мар 07 20:37:32 ~-P1G6 kernel: asm_exc_page_fault+0x26/0x30
мар 07 20:37:32 ~-P1G6 kernel: irqentry_exit_to_user_mode+0x9/0x30
мар 07 20:37:32 ~-P1G6 kernel: exit_to_user_mode_prepare+0x160/0x1f0
мар 07 20:37:32 ~-P1G6 kernel: mem_cgroup_handle_over_high+0xa8/0x2a0
мар 07 20:37:32 ~-P1G6 kernel: reclaim_high+0xb1/0x100
мар 07 20:37:32 ~-P1G6 kernel: try_to_free_mem_cgroup_pages+0x10b/0x230
мар 07 20:37:32 ~-P1G6 kernel: do_try_to_free_pages+0xe7/0x5b0
мар 07 20:37:32 ~-P1G6 kernel: shrink_node+0x2ae/0xbc0
мар 07 20:37:32 ~-P1G6 kernel: ? mem_cgroup_iter+0xec/0x2a0
мар 07 20:37:32 ~-P1G6 kernel: ? folio_add_file_rmap_range+0x116/0x190
мар 07 20:37:32 ~-P1G6 kernel: ? blk_mq_flush_plug_list.part.0+0x597/0x5c0
мар 07 20:37:32 ~-P1G6 kernel: shrink_lruvec+0x160/0xdd0
мар 07 20:37:32 ~-P1G6 kernel: try_to_shrink_lruvec+0x19e/0x290
мар 07 20:37:32 ~-P1G6 kernel: evict_folios+0x27e/0x600
мар 07 20:37:32 ~-P1G6 kernel: shrink_folio_list+0x5f7/0xc60
мар 07 20:37:32 ~-P1G6 kernel: pageout+0xc5/0x240
мар 07 20:37:32 ~-P1G6 kernel: swap_writepage+0x33/0xb0
мар 07 20:37:32 ~-P1G6 kernel: ? try_to_unmap_one+0x19a/0xd50
мар 07 20:37:32 ~-P1G6 kernel: zswap_store+0x24c/0x9b0
мар 07 20:37:32 ~-P1G6 kernel: zswap_free_entry+0x1b/0x140
мар 07 20:37:32 ~-P1G6 kernel: obj_cgroup_uncharge_zswap+0x1d/0x60
мар 07 20:37:32 ~-P1G6 kernel: ? refill_obj_stock+0x4f/0x180
мар 07 20:37:32 ~-P1G6 kernel: ? asm_exc_page_fault+0x26/0x30
мар 07 20:37:32 ~-P1G6 kernel: ? exc_page_fault+0x7f/0x180
мар 07 20:37:32 ~-P1G6 kernel: ? page_fault_oops+0x171/0x4e0
мар 07 20:37:32 ~-P1G6 kernel: ? __die+0x23/0x70
мар 07 20:37:32 ~-P1G6 kernel: CPU: 7 PID: 5283 Comm: baloo_file Tainted: P B OE 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e1c
мар 07 20:37:32 ~-P1G6 kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
мар 07 20:37:32 ~-P1G6 kernel: PGD 0 P4D 0
мар 07 20:37:32 ~-P1G6 kernel: #PF: error_code(0x0000) - not-present page
мар 07 20:37:32 ~-P1G6 kernel: #PF: supervisor read access in kernel mode
мар 07 20:37:32 ~-P1G6 kernel: BUG: unable to handle page fault for address: 00000000000033dd
мар 07 20:37:13 ~-P1G6 Discord[5486]: blackbox: 2024-03-08T01:37:13.817Z 22 window.close win2
мар 07 20:36:42 ~-P1G6 nmbd[1181]: This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мар 07 20:36:42 ~-P1G6 nmbd[1181]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.15 for name WORKGROUP<1d>.
мар 07 20:36:42 ~-P1G6 nmbd[1181]: [2024/03/07 20:36:42.075659, 0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мар 07 20:36:13 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203613.367352:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Cannot access contents of url "https>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.800166:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794889:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794863:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794773:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794739:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794702:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794681:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794643:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794632:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794598:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794588:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794580:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794569:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794535:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.794519:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.576146:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570843:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570832:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570809:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570786:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570778:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570744:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570736:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570725:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570718:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570707:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570699:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570687:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570680:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:09 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203609.570656:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.327698:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320515:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320452:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320441:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320423:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320411:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320393:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320382:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320364:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320353:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320333:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320321:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320279:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320231:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:07 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203607.320203:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.088381:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083864:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083858:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083823:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083714:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083704:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083674:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083668:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083657:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083649:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083638:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083631:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083617:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083604:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:36:00 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203600.083514:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.343159:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.334172:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.334154:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.334143:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.334115:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.334066:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333956:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333937:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333917:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333899:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333888:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333866:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333813:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333801:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:59 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203559.333766:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.608205:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601826:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601818:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601813:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601805:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601800:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601791:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601767:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601761:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601753:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601747:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601738:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601731:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601717:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:58 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203558.601598:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.022811:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019912:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019872:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019837:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019820:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019808:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019789:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019775:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019754:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019623:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019610:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019593:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019582:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019551:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:57 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203557.019520:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@6.service: Deactivated successfully.
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.128310:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123169:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123140:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123122:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123112:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123095:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123084:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123064:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123029:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.123018:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.122999:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.122988:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.122969:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.122957:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:55 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/203555.122928:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:35:50 ~-P1G6 kwin_x11[5296]: kwin_core: XCB error: 3 (BadWindow), sequence: 57044, resource id: 14823990, major code: 129 (SHAPE), minor code: 6 (In>
мар 07 20:35:43 ~-P1G6 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@6.service.
мар 07 20:35:38 ~-P1G6 rtkit-daemon[1417]: Supervising 1 threads of 1 processes of 1 users.
мар 07 20:35:38 ~-P1G6 rtkit-daemon[1417]: Successfully made thread 15577 of process 5567 owned by '1000' RT at priority 5.
мар 07 20:35:38 ~-P1G6 rtkit-daemon[1417]: Supervising 0 threads of 0 processes of 0 users.
мар 07 20:35:38 ~-P1G6 systemd[1340]: Reached target Sound Card.
мар 07 20:35:38 ~-P1G6 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
мар 07 20:35:38 ~-P1G6 mtp-probe[15566]: bus: 1, device: 5 was not an MTP device
мар 07 20:35:38 ~-P1G6 mtp-probe[15566]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
мар 07 20:35:38 ~-P1G6 kernel: usbcore: registered new interface driver snd-usb-audio
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: [10] FU [iFi (by AMR) HD USB Audio Playback Volume] ch = 1, val = -32512/0/1
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: Warning! Unlikely big volume range (=32512), cval->res is probably wrong.
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: [10] FU [iFi (by AMR) HD USB Audio Playback Volume] ch = 2, val = -32512/0/1
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: 1:4 : unsupported format bits 0x100000000
мар 07 20:35:38 ~-P1G6 kernel: usbhid: USB HID core driver
мар 07 20:35:38 ~-P1G6 kernel: usbcore: registered new interface driver usbhid
мар 07 20:35:38 ~-P1G6 kernel: hid-generic 0003:20B1:3008.0002: hiddev96,hidraw1: USB HID v1.10 Device [iFi (by AMR) iFi (by AMR) HD USB Audio] on usb-0000:00>
мар 07 20:35:38 ~-P1G6 mtp-probe[15535]: bus: 1, device: 5 was not an MTP device
мар 07 20:35:38 ~-P1G6 mtp-probe[15535]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: SerialNumber: 0003
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: Manufacturer: iFi (by AMR)
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: Product: iFi (by AMR) HD USB Audio
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=2
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: New USB device found, idVendor=20b1, idProduct=3008, bcdDevice= 7.40
мар 07 20:35:38 ~-P1G6 kernel: usb 1-1: new high-speed USB device number 5 using xhci_hcd
мар 07 20:31:46 ~-P1G6 nmbd[1181]: This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мар 07 20:31:46 ~-P1G6 nmbd[1181]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.15 for name WORKGROUP<1d>.
мар 07 20:31:46 ~-P1G6 nmbd[1181]: [2024/03/07 20:31:46.167105, 0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мар 07 20:26:46 ~-P1G6 nmbd[1181]: This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мар 07 20:26:46 ~-P1G6 nmbd[1181]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.15 for name WORKGROUP<1d>.
мар 07 20:26:46 ~-P1G6 nmbd[1181]: [2024/03/07 20:26:46.047089, 0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мар 07 20:23:55 ~-P1G6 kwin_x11[5296]: kwin_core: XCB error: 3 (BadWindow), sequence: 40911, resource id: 14821823, major code: 129 (SHAPE), minor code: 6 (In>
мар 07 20:23:53 ~-P1G6 Discord[5486]: blackbox: 2024-03-08T01:23:53.936Z 21 window.close win2
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608866:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608841:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608830:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608808:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608619:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608584:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608487:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608465:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608451:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608364:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608353:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608326:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608319:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:41 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202341.608301:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:40 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202340.780223:ERROR:CONSOLE(242)] "<webview>: Script cannot be injected into content until the pag>
мар 07 20:23:40 ~-P1G6 Discord[15234]: Opening in existing browser session.
мар 07 20:23:40 ~-P1G6 systemd[1340]: Started Vivaldi - Web Browser.
мар 07 20:23:16 ~-P1G6 kglobalaccel5[6859]: [6899:6899:0307/202316.020145:ERROR:shared_image_manager.cc(221)] SharedImageManager::ProduceSkia: Trying to Produ>
мар 07 20:23:16 ~-P1G6 kglobalaccel5[6859]: [6899:6899:0307/202316.019208:ERROR:shared_image_manager.cc(221)] SharedImageManager::ProduceSkia: Trying to Produ>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.324335:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319973:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319948:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319924:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319917:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319908:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319903:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319894:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319888:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319877:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319868:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319860:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319850:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319801:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319736:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:12 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202312.319612:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818532:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818512:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818494:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818483:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818466:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818455:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818438:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818427:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818410:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818379:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818353:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818201:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818188:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818157:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:23:08 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/202308.818119:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 20:21:51 ~-P1G6 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
мар 07 20:21:42 ~-P1G6 NetworkManager[904]: <info> [1709860902.4235] dhcp6 (wlp0s20f3): state changed new lease
мар 07 20:21:42 ~-P1G6 NetworkManager[904]: <info> [1709860902.4064] policy: set 'NETGEAR79-5G' (wlp0s20f3) as default for IPv6 routing and DNS
мар 07 20:21:42 ~-P1G6 NetworkManager[904]: <info> [1709860902.4052] dhcp6 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
мар 07 20:21:42 ~-P1G6 NetworkManager[904]: <info> [1709860902.0331] manager: NetworkManager state is now CONNECTED_GLOBAL
мар 07 20:21:41 ~-P1G6 plasmashell[5328]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5561783d7f20) QQmlContext(0x5561746125d0) QUrl("file:///usr/s>
мар 07 20:21:41 ~-P1G6 NetworkManager[904]: <info> [1709860901.6709] device (wlp0s20f3): Activation: successful, device activated.
мар 07 20:21:41 ~-P1G6 NetworkManager[904]: <info> [1709860901.6695] manager: NetworkManager state is now CONNECTED_SITE
мар 07 20:21:41 ~-P1G6 NetworkManager[904]: <info> [1709860901.6689] device (wlp0s20f3): state change: secondaries -> activated (reason 'none', sys-iface-sta>
мар 07 20:21:41 ~-P1G6 NetworkManager[904]: <info> [1709860901.6685] device (wlp0s20f3): state change: ip-check -> secondaries (reason 'none', sys-iface-stat>
мар 07 20:21:41 ~-P1G6 systemd[1]: Started Network Manager Script Dispatcher Service.
мар 07 20:21:41 ~-P1G6 systemd[1]: Starting Network Manager Script Dispatcher Service...
мар 07 20:21:41 ~-P1G6 NetworkManager[904]: <info> [1709860901.6122] device (wlp0s20f3): state change: ip-config -> ip-check (reason 'none', sys-iface-state:>
мар 07 20:21:41 ~-P1G6 NetworkManager[904]: <info> [1709860901.5790] policy: set 'NETGEAR79-5G' (wlp0s20f3) as default for IPv4 routing and DNS
мар 07 20:21:41 ~-P1G6 NetworkManager[904]: <info> [1709860901.5783] dhcp4 (wlp0s20f3): state changed new lease, address=192.168.0.15
мар 07 20:21:41 ~-P1G6 NetworkManager[904]: <info> [1709860901.3920] dhcp4 (wlp0s20f3): state changed new lease, address=192.168.0.15, acd pending
мар 07 20:21:40 ~-P1G6 ModemManager[941]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any >
мар 07 20:21:40 ~-P1G6 kernel: </TASK>
мар 07 20:21:40 ~-P1G6 kernel: R13: 0000000000000000 R14: 00007fe4665f6680 R15: 00007fe4665f7fc0
мар 07 20:21:40 ~-P1G6 kernel: R10: 00005622ea1f0200 R11: 0000000000000206 R12: 0000000000000000
мар 07 20:21:40 ~-P1G6 kernel: RBP: 0000000000000b68 R08: 0000000000000ce0 R09: 0000000000000000
мар 07 20:21:40 ~-P1G6 kernel: RDX: 00000000000000e7 RSI: ffffffffffffff08 RDI: 0000000000000000
мар 07 20:21:40 ~-P1G6 kernel: RAX: ffffffffffffffda RBX: 00007fe4665f7fa8 RCX: 00007fe4664f366d
мар 07 20:21:40 ~-P1G6 kernel: RSP: 002b:00007ffc907e3ce8 EFLAGS: 00000206 ORIG_RAX: 00000000000000e7
мар 07 20:21:40 ~-P1G6 kernel: Code: Unable to access opcode bytes at 0x7fe4664f3643.
мар 07 20:21:40 ~-P1G6 kernel: RIP: 0033:0x7fe4664f366d
мар 07 20:21:40 ~-P1G6 kernel: entry_SYSCALL_64_after_hwframe+0x6e/0xd8
мар 07 20:21:40 ~-P1G6 kernel: ? exc_page_fault+0x7f/0x180
мар 07 20:21:40 ~-P1G6 kernel: ? do_user_addr_fault+0x30f/0x660
мар 07 20:21:40 ~-P1G6 kernel: ? handle_mm_fault+0xa2/0x360
мар 07 20:21:40 ~-P1G6 kernel: ? count_memcg_events.constprop.0+0x1a/0x30
мар 07 20:21:40 ~-P1G6 kernel: ? __count_memcg_events+0x42/0x90
мар 07 20:21:40 ~-P1G6 kernel: do_syscall_64+0x5d/0x90
мар 07 20:21:40 ~-P1G6 kernel: __x64_sys_exit_group+0x18/0x20
мар 07 20:21:40 ~-P1G6 kernel: do_group_exit+0x31/0x80
мар 07 20:21:40 ~-P1G6 kernel: do_exit+0x31c/0xb20
мар 07 20:21:40 ~-P1G6 kernel: __mmput+0x3e/0x130
мар 07 20:21:40 ~-P1G6 kernel: exit_mmap+0xec/0x340
мар 07 20:21:40 ~-P1G6 kernel: unmap_vmas+0xb5/0x190
мар 07 20:21:40 ~-P1G6 kernel: unmap_page_range+0x507/0x1120
мар 07 20:21:40 ~-P1G6 kernel: vm_normal_page+0xbe/0xd0
мар 07 20:21:40 ~-P1G6 kernel: print_bad_pte+0x1b9/0x280
мар 07 20:21:40 ~-P1G6 kernel: dump_stack_lvl+0x47/0x60
мар 07 20:21:40 ~-P1G6 kernel: <TASK>
мар 07 20:21:40 ~-P1G6 kernel: Call Trace:
мар 07 20:21:40 ~-P1G6 kernel: Hardware name: LENOVO 21FVCTO1WW/21FVCTO1WW, BIOS N3ZET21W (1.08 ) 07/07/2023
мар 07 20:21:40 ~-P1G6 kernel: CPU: 11 PID: 14110 Comm: kscreenlocker_g Tainted: P B OE 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746>
мар 07 20:21:40 ~-P1G6 kernel: file:(null) fault:0x0 mmap:0x0 read_folio:0x0
мар 07 20:21:40 ~-P1G6 kernel: addr:00007fe404bfd000 vm_flags:08100073 anon_vma:ffff888354add680 mapping:0000000000000000 index:7fe404bfd
мар 07 20:21:40 ~-P1G6 kernel: BUG: Bad page map in process kscreenlocker_g pte:40000000000339d pmd:18306a067
мар 07 20:21:40 ~-P1G6 kernel: R13: 00007fe450001460 R14: 0000000000000000 R15: 00007fe450001610
мар 07 20:21:40 ~-P1G6 kernel: R10: 00007fe46898a0b8 R11: 0000000000000246 R12: 00007fe450016370
мар 07 20:21:40 ~-P1G6 kernel: RBP: 0000000000000000 R08: 00007fe4613b3cd0 R09: 00007fe45b89f6c0
мар 07 20:21:40 ~-P1G6 kernel: RDX: 00007fe45be60010 RSI: 00007fe45b89e180 RDI: 00007fe45be5d04a
мар 07 20:21:40 ~-P1G6 kernel: RAX: ffffffffffffffda RBX: 0000000040000020 RCX: 00007fe4664f423b
мар 07 20:21:40 ~-P1G6 kernel: RSP: 002b:00007fe45b89e168 EFLAGS: 00000246 ORIG_RAX: 000000000000003b
мар 07 20:21:40 ~-P1G6 kernel: Code: Unable to access opcode bytes at 0x7fe4664f4211.
мар 07 20:21:40 ~-P1G6 kernel: RIP: 0033:0x7fe4664f423b
мар 07 20:21:40 ~-P1G6 kernel: ? do_syscall_64+0x6c/0x90
мар 07 20:21:40 ~-P1G6 kernel: ? syscall_exit_to_user_mode+0x2b/0x40
мар 07 20:21:40 ~-P1G6 kernel: __x64_sys_execve+0x36/0x40
мар 07 20:21:40 ~-P1G6 kernel: do_execveat_common.isra.0+0x1ad/0x250
мар 07 20:21:40 ~-P1G6 kernel: bprm_execve+0x284/0x670
мар 07 20:21:40 ~-P1G6 kernel: ? __kernel_read+0x1b4/0x2e0
мар 07 20:21:40 ~-P1G6 kernel: load_elf_binary+0x2cc/0x1740
мар 07 20:21:40 ~-P1G6 kernel: begin_new_exec+0x4df/0xb20
мар 07 20:21:40 ~-P1G6 kernel: CPU: 8 PID: 14755 Comm: QThread Tainted: P B OE 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e1c
мар 07 20:21:40 ~-P1G6 kernel: addr:00007fe404bfd000 vm_flags:08100073 anon_vma:ffff88825f8e4af8 mapping:0000000000000000 index:7fe404bfd
мар 07 20:21:40 ~-P1G6 kernel: BUG: Bad page map in process QThread pte:40000000000339d pmd:24e0cd067
мар 07 20:21:40 ~-P1G6 kernel: R13: 00007fe450001460 R14: 00007fe45b89e070 R15: 00007fe450001610
мар 07 20:21:40 ~-P1G6 kernel: R10: 00007fe45b89f990 R11: 0000000000000246 R12: 0000000000000000
мар 07 20:21:40 ~-P1G6 kernel: RBP: 0000000000000001 R08: 0000000000000000 R09: 0000000000000001
мар 07 20:21:40 ~-P1G6 kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000001200011
мар 07 20:21:40 ~-P1G6 kernel: RAX: ffffffffffffffda RBX: 0000000000000002 RCX: 00007fe4664f35f7
мар 07 20:21:40 ~-P1G6 kernel: RSP: 002b:00007fe45b89e068 EFLAGS: 00000246 ORIG_RAX: 0000000000000038
мар 07 20:21:40 ~-P1G6 kernel: Code: 00 00 00 f3 0f 1e fa 64 48 8b 04 25 10 00 00 00 45 31 c0 31 d2 31 f6 bf 11 00 20 01 4c 8d 90 d0 02 00 00 b8 38 00 00 00 0>
мар 07 20:21:40 ~-P1G6 kernel: RIP: 0033:0x7fe4664f35f7
мар 07 20:21:40 ~-P1G6 kernel: __do_sys_clone+0x66/0x90
мар 07 20:21:40 ~-P1G6 kernel: kernel_clone+0xc0/0x430
мар 07 20:21:40 ~-P1G6 kernel: copy_process+0x1b98/0x1c70
мар 07 20:21:40 ~-P1G6 kernel: dup_mmap+0x580/0x6f0
мар 07 20:21:40 ~-P1G6 kernel: ? mas_wr_store_entry.isra.0+0xf5/0x4b0
мар 07 20:21:40 ~-P1G6 kernel: copy_page_range+0x784/0x1580
мар 07 20:21:40 ~-P1G6 kernel: ? __pte_offset_map+0x1b/0x180
мар 07 20:21:40 ~-P1G6 kernel: CPU: 11 PID: 14123 Comm: QThread Tainted: P B OE 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e1c
мар 07 20:21:40 ~-P1G6 kernel: BUG: Bad page map in process QThread pte:40000000000339d pmd:18306a067
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.3389] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.3380] device (wlp0s20f3): state change: config -> ip-config (reason 'none', sys-iface-state: '>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.3378] device (p2p-dev-wlp0s20f3): supplicant management interface state: 4way_handshake -> com>
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-41 noise=9999 txrate=234000
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.3377] device (wlp0s20f3): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Conne>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.3377] device (wlp0s20f3): supplicant interface state: 4way_handshake -> completed
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: CTRL-EVENT-CONNECTED - Connection to 44:a5:6e:01:0b:94 completed [id=0 id_str=]
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: WPA: Key negotiation completed with 44:a5:6e:01:0b:94 [PTK=CCMP GTK=CCMP]
мар 07 20:21:40 ~-P1G6 kernel: wlp0s20f3: Limiting TX power to 30 (30 - 0) dBm as advertised by 44:a5:6e:01:0b:94
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.2424] device (p2p-dev-wlp0s20f3): supplicant management interface state: associating -> 4way_h>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.2423] device (wlp0s20f3): supplicant interface state: associating -> 4way_handshake
мар 07 20:21:40 ~-P1G6 kernel: wlp0s20f3: associated
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: Associated with 44:a5:6e:01:0b:94
мар 07 20:21:40 ~-P1G6 kernel: wlp0s20f3: RX AssocResp from 44:a5:6e:01:0b:94 (capab=0x1011 status=0 aid=1)
мар 07 20:21:40 ~-P1G6 kernel: wlp0s20f3: associate with 44:a5:6e:01:0b:94 (try 1/3)
мар 07 20:21:40 ~-P1G6 kernel: wlp0s20f3: authenticated
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.2171] device (p2p-dev-wlp0s20f3): supplicant management interface state: authenticating -> ass>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.2171] device (wlp0s20f3): supplicant interface state: authenticating -> associating
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: Trying to associate with 44:a5:6e:01:0b:94 (SSID='NETGEAR79-5G' freq=5765 MHz)
мар 07 20:21:40 ~-P1G6 kernel: wlp0s20f3: send auth to 44:a5:6e:01:0b:94 (try 1/3)
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1843] device (p2p-dev-wlp0s20f3): supplicant management interface state: scanning -> authentic>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1843] device (wlp0s20f3): supplicant interface state: scanning -> authenticating
мар 07 20:21:40 ~-P1G6 kernel: wlp0s20f3: authenticate with 44:a5:6e:01:0b:94
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: SME: Trying to authenticate with 44:a5:6e:01:0b:94 (SSID='NETGEAR79-5G' freq=5765 MHz)
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1374] Config: added 'psk' value '<hidden>'
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1374] Config: added 'auth_alg' value 'OPEN'
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1373] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1373] Config: added 'bgscan' value 'simple:30:-70:86400'
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1373] Config: added 'scan_ssid' value '1'
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1373] Config: added 'ssid' value 'NETGEAR79-5G'
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1373] device (wlp0s20f3): Activation: (wifi) connection 'NETGEAR79-5G' has security, and secre>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1371] device (wlp0s20f3): state change: prepare -> config (reason 'none', sys-iface-state: 'ma>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1367] device (wlp0s20f3): state change: need-auth -> prepare (reason 'none', sys-iface-state: >
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: WPS-CANCEL
мар 07 20:21:40 ~-P1G6 kded5[5295]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "V>
мар 07 20:21:40 ~-P1G6 plasmashell[5328]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled prope>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1210] device (p2p-dev-wlp0s20f3): supplicant management interface state: inactive -> scanning
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1209] device (wlp0s20f3): supplicant interface state: inactive -> scanning
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: WPS-PBC-ACTIVE
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1148] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> inact>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1147] device (wlp0s20f3): supplicant interface state: disconnected -> inactive
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1138] sup-iface[78fa74ae6fec5bf4,1,wlp0s20f3]: wps: type pbc start...
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1136] device (wlp0s20f3): state change: config -> need-auth (reason 'none', sys-iface-state: '>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1136] device (wlp0s20f3): Activation: (wifi) access point 'NETGEAR79-5G' has security, but sec>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1132] device (wlp0s20f3): state change: prepare -> config (reason 'none', sys-iface-state: 'ma>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.1114] device (wlp0s20f3): set-hw-addr: reset MAC address to C0:A5:E8:74:30:4C (preserve)
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.0921] manager: NetworkManager state is now CONNECTING
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.0918] device (wlp0s20f3): state change: disconnected -> prepare (reason 'none', sys-iface-stat>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.0917] device (wlp0s20f3): Activation: starting connection 'NETGEAR79-5G' (2aab970e-531d-45cd-8>
мар 07 20:21:40 ~-P1G6 NetworkManager[904]: <info> [1709860900.0912] policy: auto-activating connection 'NETGEAR79-5G' (2aab970e-531d-45cd-8082-75816baff132)
мар 07 20:21:40 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
мар 07 20:21:38 ~-P1G6 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
мар 07 20:21:37 ~-P1G6 kernel: </TASK>
мар 07 20:21:37 ~-P1G6 kernel: R13: 00007fe450001460 R14: 0000000000000000 R15: 00007fe450001610
мар 07 20:21:37 ~-P1G6 kernel: R10: 00007fe46898a0b8 R11: 0000000000000246 R12: 0000000000000000
мар 07 20:21:37 ~-P1G6 kernel: RBP: 0000000000000000 R08: 00007fe4613b3cd0 R09: 00007fe45b89f6c0
мар 07 20:21:37 ~-P1G6 kernel: RDX: 00007fe45be60010 RSI: 00007fe45b89e4f0 RDI: 00007fe45be5d04a
мар 07 20:21:37 ~-P1G6 kernel: RAX: ffffffffffffffda RBX: 0000000040000020 RCX: 00007fe4664f423b
мар 07 20:21:37 ~-P1G6 kernel: RSP: 002b:00007fe45b89e4d8 EFLAGS: 00000246 ORIG_RAX: 000000000000003b
мар 07 20:21:37 ~-P1G6 kernel: Code: Unable to access opcode bytes at 0x7fe4664f4211.
мар 07 20:21:37 ~-P1G6 kernel: RIP: 0033:0x7fe4664f423b
мар 07 20:21:37 ~-P1G6 kernel: entry_SYSCALL_64_after_hwframe+0x6e/0xd8
мар 07 20:21:37 ~-P1G6 kernel: ? exc_page_fault+0x7f/0x180
мар 07 20:21:37 ~-P1G6 kernel: ? do_syscall_64+0x6c/0x90
мар 07 20:21:37 ~-P1G6 kernel: ? syscall_exit_to_user_mode+0x2b/0x40
мар 07 20:21:37 ~-P1G6 kernel: ? exit_to_user_mode_prepare+0x17d/0x1f0
мар 07 20:21:37 ~-P1G6 kernel: do_syscall_64+0x5d/0x90
мар 07 20:21:37 ~-P1G6 kernel: __x64_sys_execve+0x36/0x40
мар 07 20:21:37 ~-P1G6 kernel: do_execveat_common.isra.0+0x1ad/0x250
мар 07 20:21:37 ~-P1G6 kernel: bprm_execve+0x284/0x670
мар 07 20:21:37 ~-P1G6 kernel: ? __kernel_read+0x1b4/0x2e0
мар 07 20:21:37 ~-P1G6 kernel: load_elf_binary+0x2cc/0x1740
мар 07 20:21:37 ~-P1G6 kernel: begin_new_exec+0x4df/0xb20
мар 07 20:21:37 ~-P1G6 kernel: __mmput+0x3e/0x130
мар 07 20:21:37 ~-P1G6 kernel: exit_mmap+0xec/0x340
мар 07 20:21:37 ~-P1G6 kernel: unmap_vmas+0xb5/0x190
мар 07 20:21:37 ~-P1G6 kernel: unmap_page_range+0x507/0x1120
мар 07 20:21:37 ~-P1G6 kernel: vm_normal_page+0xbe/0xd0
мар 07 20:21:37 ~-P1G6 kernel: print_bad_pte+0x1b9/0x280
мар 07 20:21:37 ~-P1G6 kernel: dump_stack_lvl+0x47/0x60
мар 07 20:21:37 ~-P1G6 kernel: <TASK>
мар 07 20:21:37 ~-P1G6 kernel: Call Trace:
мар 07 20:21:37 ~-P1G6 kernel: Hardware name: LENOVO 21FVCTO1WW/21FVCTO1WW, BIOS N3ZET21W (1.08 ) 07/07/2023
мар 07 20:21:37 ~-P1G6 kernel: CPU: 8 PID: 14733 Comm: QThread Tainted: P B OE 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e1c
мар 07 20:21:37 ~-P1G6 kernel: file:(null) fault:0x0 mmap:0x0 read_folio:0x0
мар 07 20:21:37 ~-P1G6 kernel: addr:00007fe404bfd000 vm_flags:08100073 anon_vma:ffff8881fccf1e38 mapping:0000000000000000 index:7fe404bfd
мар 07 20:21:37 ~-P1G6 kernel: BUG: Bad page map in process QThread pte:40000000000339d pmd:264cd1067
мар 07 20:21:37 ~-P1G6 kernel: R13: 00007fe450001460 R14: 00007fe45b89e3e0 R15: 00007fe450001610
мар 07 20:21:37 ~-P1G6 kernel: R10: 00007fe45b89f990 R11: 0000000000000246 R12: 0000000000000000
мар 07 20:21:37 ~-P1G6 kernel: RBP: 0000000000000001 R08: 0000000000000000 R09: 0000000000000007
мар 07 20:21:37 ~-P1G6 kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000001200011
мар 07 20:21:37 ~-P1G6 kernel: RAX: ffffffffffffffda RBX: 0000000000000002 RCX: 00007fe4664f35f7
мар 07 20:21:37 ~-P1G6 kernel: RSP: 002b:00007fe45b89e3d8 EFLAGS: 00000246 ORIG_RAX: 0000000000000038
мар 07 20:21:37 ~-P1G6 kernel: Code: 00 00 00 f3 0f 1e fa 64 48 8b 04 25 10 00 00 00 45 31 c0 31 d2 31 f6 bf 11 00 20 01 4c 8d 90 d0 02 00 00 b8 38 00 00 00 0>
мар 07 20:21:37 ~-P1G6 kernel: RIP: 0033:0x7fe4664f35f7
мар 07 20:21:37 ~-P1G6 kernel: __do_sys_clone+0x66/0x90
мар 07 20:21:37 ~-P1G6 kernel: ? alloc_fd+0xb5/0x170
мар 07 20:21:37 ~-P1G6 kernel: kernel_clone+0xc0/0x430
мар 07 20:21:37 ~-P1G6 kernel: copy_process+0x1b98/0x1c70
мар 07 20:21:37 ~-P1G6 kernel: dup_mmap+0x580/0x6f0
мар 07 20:21:37 ~-P1G6 kernel: ? mas_wr_store_entry.isra.0+0xf5/0x4b0
мар 07 20:21:37 ~-P1G6 kernel: copy_page_range+0x784/0x1580
мар 07 20:21:37 ~-P1G6 kernel: ? __pte_offset_map+0x1b/0x180
мар 07 20:21:37 ~-P1G6 kernel: CPU: 11 PID: 14123 Comm: QThread Tainted: P OE 6.6.19-1-MANJARO #1 76c482e512047110118a77981ac42e42c9746e1c
мар 07 20:21:37 ~-P1G6 kernel: addr:00007fe404bfd000 vm_flags:08100073 anon_vma:ffff888354add680 mapping:0000000000000000 index:7fe404bfd
мар 07 20:21:37 ~-P1G6 kernel: BUG: Bad page map in process QThread pte:000033dd pmd:18306a067
мар 07 20:21:37 ~-P1G6 NetworkManager[904]: <info> [1709860897.0543] device (p2p-dev-wlp0s20f3): state change: unavailable -> disconnected (reason 'none', sy>
мар 07 20:21:37 ~-P1G6 NetworkManager[904]: <info> [1709860897.0538] device (wlp0s20f3): state change: unavailable -> disconnected (reason 'supplicant-availa>
мар 07 20:21:37 ~-P1G6 NetworkManager[904]: <info> [1709860897.0533] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sy>
мар 07 20:21:37 ~-P1G6 NetworkManager[904]: <info> [1709860897.0531] manager: (p2p-dev-wlp0s20f3): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManag>
мар 07 20:21:37 ~-P1G6 NetworkManager[904]: <info> [1709860897.0528] Wi-Fi P2P device controlled by interface wlp0s20f3 created
мар 07 20:21:37 ~-P1G6 NetworkManager[904]: <info> [1709860897.0523] device (p2p-dev-wlp0s20f3): state change: unavailable -> unmanaged (reason 'removed', sy>
мар 07 20:21:37 ~-P1G6 NetworkManager[904]: <info> [1709860897.0522] device (wlp0s20f3): supplicant interface state: internal-starting -> disconnected
мар 07 20:21:36 ~-P1G6 NetworkManager[904]: <info> [1709860896.9933] manager: NetworkManager state is now DISCONNECTED
мар 07 20:21:36 ~-P1G6 NetworkManager[904]: <info> [1709860896.9930] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sy>
мар 07 20:21:36 ~-P1G6 kcminit[14716]: kcm_touchpad: Using X11 backend
мар 07 20:21:36 ~-P1G6 kcminit[14716]: Initializing "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
мар 07 20:21:36 ~-P1G6 kcminit[14716]: Initializing "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
мар 07 20:21:36 ~-P1G6 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
мар 07 20:21:36 ~-P1G6 kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
мар 07 20:21:36 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
мар 07 20:21:36 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
мар 07 20:21:36 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
мар 07 20:21:36 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
мар 07 20:21:36 ~-P1G6 ModemManager[941]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:16.3': Device support check >
мар 07 20:21:36 ~-P1G6 NetworkManager[904]: <info> [1709860896.7141] device (wlp0s20f3): set-hw-addr: set MAC address to D6:9B:36:C1:8B:F7 (scanning)
мар 07 20:21:36 ~-P1G6 kdeconnectd[5508]: Error sending UDP packet: QAbstractSocket::NetworkError
мар 07 20:21:36 ~-P1G6 NetworkManager[904]: <info> [1709860896.6680] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface->
мар 07 20:21:36 ~-P1G6 NetworkManager[904]: <info> [1709860896.6678] manager: sleep: wake requested (sleeping: yes enabled: yes)
мар 07 20:21:36 ~-P1G6 ModemManager[941]: <msg> [sleep-monitor-systemd] system is resuming
мар 07 20:21:36 ~-P1G6 systemd[1]: Stopped target Suspend.
мар 07 20:21:36 ~-P1G6 systemd-logind[911]: Operation 'suspend' finished.
мар 07 20:21:36 ~-P1G6 systemd[1]: Reached target Suspend.
мар 07 20:21:36 ~-P1G6 systemd[1]: Stopped target Sleep.
мар 07 20:21:36 ~-P1G6 systemd[1]: Finished System Suspend.
мар 07 20:21:36 ~-P1G6 systemd[1]: systemd-suspend.service: Deactivated successfully.
мар 07 20:21:36 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: spk-prot: C:\Working\Project\LCH3\2023-03-15-SZ\LS\17AA2316_20230113_V0_A0.bin
мар 07 20:21:36 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-17aa2316-spkid0-r0.bin: v0.43.1
мар 07 20:21:36 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: Firmware: 400a4 vendor: 0x2 v0.43.1, 2 algorithms
мар 07 20:21:36 ~-P1G6 systemd-sleep[14353]: [7] INFO: Post-resume hook completed successfully.
мар 07 20:21:36 ~-P1G6 systemd-sleep[14353]: [7] INFO: Writing state {'type': 'done', 'switch_id': '20240307T172008', 'current_mode': 'hybrid'}
мар 07 20:21:36 ~-P1G6 systemd-sleep[14353]: [7] INFO: Nothing to do
мар 07 20:21:36 ~-P1G6 systemd-sleep[14353]: [6] INFO: Previous state was: {'type': 'pending_post_resume', 'switch_id': '20240307T172008', 'current_mode': 'hy>
мар 07 20:21:36 ~-P1G6 systemd-sleep[14353]: [6] INFO: # Post-resume hook
мар 07 20:21:35 ~-P1G6 kernel: PM: suspend exit
мар 07 20:21:35 ~-P1G6 systemd-sleep[14152]: System returned from sleep operation 'suspend'.
мар 07 20:21:35 ~-P1G6 nmbd[1181]: Packet send failed to 10.250.133.255(138) ERRNO=Network is unreachable
мар 07 20:21:35 ~-P1G6 nmbd[1181]: [2024/03/07 20:21:35.904353, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
мар 07 20:21:35 ~-P1G6 nmbd[1181]: [2024/03/07 20:21:35.904241, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Demoted 10 threads.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 1529 of process 1526.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 1523 of process 1523.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 1532 of process 1523.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 5567 of process 5567.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 5731 of process 5567.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 5733 of process 5567.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 5739 of process 5567.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 5756 of process 5567.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 5758 of process 5567.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Successfully demoted thread 5761 of process 5567.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: Demoting known real-time threads.
мар 07 20:21:35 ~-P1G6 systemd-logind[911]: Lid opened.
мар 07 20:21:35 ~-P1G6 rtkit-daemon[1417]: The canary thread is apparently starving. Taking action.
мар 07 20:21:35 ~-P1G6 kernel: random: crng reseeded on system resumption
мар 07 20:21:35 ~-P1G6 kernel: Restarting tasks ... done.
мар 07 20:21:35 ~-P1G6 kernel: OOM killer enabled.
мар 07 20:21:35 ~-P1G6 kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
мар 07 20:21:35 ~-P1G6 kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
мар 07 20:21:35 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: spk-prot: C:\Working\Project\LCH3\2023-03-15-SZ\LS\17AA2316_20230113_V0_A1.bin
мар 07 20:21:35 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-17aa2316-spkid0-l0.bin: v0.43.1
мар 07 20:21:35 ~-P1G6 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
мар 07 20:21:35 ~-P1G6 kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
мар 07 20:21:35 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
мар 07 20:21:35 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
мар 07 20:21:35 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
мар 07 20:21:35 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: Firmware: 400a4 vendor: 0x2 v0.43.1, 2 algorithms
мар 07 20:21:35 ~-P1G6 kernel: i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
мар 07 20:21:35 ~-P1G6 kernel: i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
мар 07 20:21:35 ~-P1G6 kernel: i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
мар 07 20:21:35 ~-P1G6 kernel: i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
мар 07 20:21:35 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
мар 07 20:21:35 ~-P1G6 kernel: i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
мар 07 20:21:35 ~-P1G6 kernel: i915 0000:00:02.0: [drm] GT0: GuC firmware i915/adlp_guc_70.bin version 70.20.0
мар 07 20:21:35 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: cirrus/cs35l41-dsp1-spk-prot-17aa2316.wmfw: Fri 27 Aug 2021 14:58:19 W. Europe >
мар 07 20:21:35 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: Firmware version: 3
мар 07 20:21:35 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: cirrus/cs35l41-dsp1-spk-prot-17aa2316.wmfw: Fri 27 Aug 2021 14:58:19 W. Europe >
мар 07 20:21:35 ~-P1G6 kernel: cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: Firmware version: 3
мар 07 20:21:35 ~-P1G6 kernel: nvme nvme0: 20/0/0 default/read/poll queues
мар 07 20:21:35 ~-P1G6 kernel: nvme nvme0: Shutdown timeout set to 10 seconds
мар 07 20:21:35 ~-P1G6 kernel: usb usb4: root hub lost power or was reset
мар 07 20:21:35 ~-P1G6 kernel: usb usb3: root hub lost power or was reset
мар 07 20:21:35 ~-P1G6 kernel: xhci_hcd 0000:48:00.0: xHC error in resume, USBSTS 0x401, Reinit
мар 07 20:21:35 ~-P1G6 kernel: ACPI: EC: interrupt unblocked
мар 07 20:21:35 ~-P1G6 kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
мар 07 20:21:35 ~-P1G6 kernel: typec port0-partner: PM: parent port0 should not be sleeping
мар 07 20:21:35 ~-P1G6 kernel: ACPI: EC: interrupt blocked
мар 07 20:21:35 ~-P1G6 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
мар 07 20:21:35 ~-P1G6 kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
мар 07 20:21:35 ~-P1G6 kernel: OOM killer disabled.
мар 07 20:21:35 ~-P1G6 kernel: Freezing user space processes completed (elapsed 0.002 seconds)
мар 07 19:32:37 ~-P1G6 kernel: Filesystems sync: 0.015 seconds
мар 07 19:32:37 ~-P1G6 kernel: PM: suspend entry (s2idle)
мар 07 19:32:37 ~-P1G6 systemd-sleep[14152]: Performing sleep operation 'suspend'...
мар 07 19:32:37 ~-P1G6 systemd-sleep[14175]: [8] INFO: Pre-suspend hook completed successfully.
мар 07 19:32:37 ~-P1G6 systemd-sleep[14175]: [8] INFO: Writing state {'type': 'pending_post_resume', 'switch_id': '20240307T172008', 'current_mode': 'hybrid'}
мар 07 19:32:37 ~-P1G6 systemd-sleep[14175]: [8] INFO: Nothing to do
мар 07 19:32:37 ~-P1G6 systemd-sleep[14175]: [8] INFO: Switching option: none
мар 07 19:32:37 ~-P1G6 systemd-sleep[14175]: [7] INFO: Previous state was: {'type': 'done', 'switch_id': '20240307T172008', 'current_mode': 'hybrid'}
мар 07 19:32:37 ~-P1G6 systemd-sleep[14175]: [7] INFO: # Pre-suspend hook
мар 07 19:32:37 ~-P1G6 wpa_supplicant[1109]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
мар 07 19:32:37 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
мар 07 19:32:37 ~-P1G6 systemd[1]: Starting System Suspend...
мар 07 19:32:37 ~-P1G6 kscreenlocker_greet[14110]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvi>
мар 07 19:32:37 ~-P1G6 systemd[1]: Reached target Sleep.
мар 07 19:32:37 ~-P1G6 wpa_supplicant[1109]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0
мар 07 19:32:37 ~-P1G6 wpa_supplicant[1109]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all
мар 07 19:32:37 ~-P1G6 NetworkManager[904]: <info> [1709857957.0686] device (wlp0s20f3): set-hw-addr: reset MAC address to C0:A5:E8:74:30:4C (unmanage)
мар 07 19:32:37 ~-P1G6 kscreenlocker_greet[14110]: kf.kirigami: Failed to find a Kirigami platform plugin
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.9183] device (wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-ifac>
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED a8:bd:27:42:c4:82 0
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.8190] device (wlp0s20f3): set-hw-addr: set MAC address to CE:1B:D7:1E:A8:D6 (scanning)
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED f0:61:c0:01:4e:73 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED f0:61:c0:00:3e:93 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED a8:bd:27:42:c4:c2 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED a8:bd:27:42:c4:d2 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED f0:61:c0:00:3e:83 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED 20:9c:b4:01:a0:83 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED 20:9c:b4:02:3c:e3 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED 20:9c:b4:01:a0:93 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED 20:9c:b4:02:3c:f3 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED dc:b7:ac:a2:aa:d3 0
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-REMOVED dc:b7:ac:a2:aa:c3 0
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.7827] dhcp4 (wlp0s20f3): state changed no lease
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.7827] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.7827] dhcp4 (wlp0s20f3): canceled DHCP transaction
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.7820] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping', sys-i>
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.7816] device (wlp0s20f3): supplicant interface state: completed -> disconnected
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
мар 07 19:32:36 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=dc:b7:ac:a2:aa:c3 reason=3 locally_generated=1
мар 07 19:32:36 ~-P1G6 kscreenlocker_greet[14110]: Could not create scene graph context for backend 'opengl' - check that plugins are installed correctly in />
мар 07 19:32:36 ~-P1G6 kscreenlocker_greet[14110]: Qt: Session management error: networkIdsList argument is NULL
мар 07 19:32:36 ~-P1G6 kernel: wlp0s20f3: deauthenticating from dc:b7:ac:a2:aa:c3 by local choice (Reason: 3=DEAUTH_LEAVING)
мар 07 19:32:36 ~-P1G6 systemd[1]: Started Network Manager Script Dispatcher Service.
мар 07 19:32:36 ~-P1G6 systemd[1]: Starting Network Manager Script Dispatcher Service...
мар 07 19:32:36 ~-P1G6 kded5[5295]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.6678] device (wlp0s20f3): state change: activated -> deactivating (reason 'sleeping', sys-ifac>
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.6673] manager: NetworkManager state is now ASLEEP
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.6665] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', >
мар 07 19:32:36 ~-P1G6 ModemManager[941]: <msg> [sleep-monitor-systemd] system is about to suspend
мар 07 19:32:36 ~-P1G6 NetworkManager[904]: <info> [1709857956.6663] manager: sleep: sleep requested (sleeping: no enabled: yes)
мар 07 19:32:36 ~-P1G6 systemd-logind[911]: The system will suspend now!
мар 07 19:32:36 ~-P1G6 systemd-logind[911]: Lid closed.
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.111594:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095222:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095214:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095201:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095191:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095138:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095117:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095106:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095100:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095090:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095080:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095067:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095057:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095039:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.095016:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:32:14 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/193214.094956:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:31:58 ~-P1G6 Discord[5486]: blackbox: 2024-03-08T00:31:58.908Z 20 window.close win2
мар 07 19:28:37 ~-P1G6 wpa_supplicant[1109]: wlp0s20f3: PMKSA-CACHE-ADDED a8:bd:27:42:c4:82 0
мар 07 19:25:39 ~-P1G6 systemd[1340]: Started Dolphin - File Manager.
мар 07 19:25:39 ~-P1G6 kstart5[13737]: Omitting both --window and --windowclass arguments is not recommended
мар 07 19:25:24 ~-P1G6 plasmashell[5328]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemMultiGridView.qml:109: TypeError: Cannot re>
мар 07 19:25:22 ~-P1G6 baloorunner[7368]: QFSFileEngine::open: No file name specified
мар 07 19:25:22 ~-P1G6 plasmashell[5328]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemGridDelegate.qml:69:5: QML Label: Binding l>
мар 07 19:25:22 ~-P1G6 plasmashell[5328]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
мар 07 19:25:22 ~-P1G6 plasmashell[5328]: libpng warning: profile matches sRGB but writing iCCP instead
мар 07 19:25:22 ~-P1G6 plasmashell[5328]: libpng warning: known incorrect sRGB profile
мар 07 19:25:22 ~-P1G6 plasmashell[5328]: libpng warning: iCCP: known incorrect sRGB profile
мар 07 19:25:22 ~-P1G6 plasmashell[5328]: libpng warning: iCCP: cHRM chunk does not match sRGB
мар 07 19:24:31 ~-P1G6 kglobalaccel5[6859]: Fontconfig error: Cannot load default config file: No such file: (null)
мар 07 19:24:29 ~-P1G6 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
мар 07 19:24:24 ~-P1G6 kglobalaccel5[6859]: [6899:6899:0307/192424.261957:ERROR:shared_image_manager.cc(221)] SharedImageManager::ProduceSkia: Trying to Produ>
мар 07 19:24:24 ~-P1G6 kglobalaccel5[6859]: [6899:6899:0307/192424.261504:ERROR:shared_image_manager.cc(221)] SharedImageManager::ProduceSkia: Trying to Produ>
мар 07 19:24:19 ~-P1G6 systemd[1]: Started Network Manager Script Dispatcher Service.
мар 07 19:24:19 ~-P1G6 systemd[1]: Starting Network Manager Script Dispatcher Service...
мар 07 19:24:19 ~-P1G6 NetworkManager[904]: <info> [1709857459.5186] dhcp4 (wlp0s20f3): state changed new lease, address=10.250.133.4
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615728:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615341:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615335:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615321:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615316:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615309:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615304:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615295:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615290:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615281:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615276:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615267:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615262:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615252:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:06 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/192206.615241:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:22:00 ~-P1G6 Discord[5486]: legacyModuleUpdater: update-check-finished
мар 07 19:22:00 ~-P1G6 Discord[5486]: 2024-03-08T00:22:00.627Z [Modules] No module updates available.
мар 07 19:22:00 ~-P1G6 Discord[5486]: 2024-03-08T00:22:00.606Z [Modules] Checking for module updates at https://discord.com/api/modules/stable/versions.json
мар 07 19:22:00 ~-P1G6 Discord[5486]: 2024-03-08T00:22:00.606Z [Modules] Host is up to date.
мар 07 19:22:00 ~-P1G6 Discord[5486]: 2024-03-08T00:22:00.546Z [Modules] Checking for host updates.
мар 07 19:22:00 ~-P1G6 Discord[5486]: mainScreen.UpdaterEvents: CHECK_FOR_UPDATES UPDATE_NOT_AVAILABLE
мар 07 19:21:58 ~-P1G6 kglobalaccel5[6859]: Fontconfig error: Cannot load default config file: No such file: (null)
мар 07 19:21:52 ~-P1G6 Discord[5486]: blackbox: 2024-03-08T00:21:52.406Z 19 window.close win2
мар 07 19:21:46 ~-P1G6 pamac-tray-plas[5553]: updates_checker.vala:100: 0 updates found
мар 07 19:21:44 ~-P1G6 pamac-tray-plas[5553]: updates_checker.vala:70: check updates
мар 07 19:21:24 ~-P1G6 plasmashell[5328]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.chromium.instance6855" has an invalid URL for the mpris:artUrl entry o>
мар 07 19:21:20 ~-P1G6 plasmashell[5328]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.chromium.instance6855" has an invalid URL for the mpris:artUrl entry o>
мар 07 19:20:45 ~-P1G6 plasmashell[5328]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.chromium.instance6855" has an invalid URL for the mpris:artUrl entry o>
мар 07 19:18:39 ~-P1G6 plasmashell[5328]: kde.dataengine.mpris: "org.mpris.MediaPlayer2.chromium.instance6855" has an invalid URL for the mpris:artUrl entry o>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.627187:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.623158:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.623152:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.623144:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.623139:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.623131:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.623125:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.623115:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
мар 07 19:18:15 ~-P1G6 kglobalaccel5[6859]: [6855:6855:0307/191815.623094:ERROR:extension_host.cc(429)] Received EventAck for extension jffbochibkahlbbmanpmnd>
I can’t see anything useful here other than the system having a complete heart attack for no apparent reason.
I did memtest86 earlier today, passed without errors.
