[solved] Soundcard not detected anymore (after recent stable update?)
Hello forum.
I recently noticed my sound not working anymore. I’ve been using i3wm with alsa (no pulseaudio). Alsamixer shows only “Loopback” as soundcard for any reason.
Here some infos:
inxi -Fxxxx
System:    Host: XXX Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: i3 4.18.2 info: i3bar
           dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: XPS 13 9370 v: N/A serial: <superuser/root required> Chassis: type: 10
           Mobo: Dell model: 0F6P3V v: A00 serial: <superuser/root required> UEFI: Dell v: 1.6.3 date: 11/04/2018
Battery:   ID-1: BAT0 charge: 49.4 Wh condition: 49.4/52.0 Wh (95%) volts: 8.4/7.6 model: SMP DELL G8VCF6C type: Li-poly
           serial: 711 status: Full
CPU:       Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 8192 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32012
           Speed: 2870 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 2870 2: 2987 3: 2937 4: 2920 5: 2977 6: 2963 7: 2750
           8: 2977
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
           Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-5:3 chip ID: 0bda:58f4
           serial: 200901010001
           Display: x11 server: X.Org 1.20.9 compositor: picom v: git-2c9e7 driver: intel resolution: 1920x1080~60Hz s-dpi: 96
           OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_soc_skl v: kernel bus ID: 00:1f.3
           chip ID: 8086:9d71
           Sound Server: ALSA v: k5.4.67-1-MANJARO
Network:   Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
           vendor: Bigfoot Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel port: f040 bus ID: 02:00.0
           chip ID: 168c:003e
           IF: wlp2s0 state: up mac: 9c:b6:d0:8c:a8:27
Drives:    Local Storage: total: 476.94 GiB used: 391.57 GiB (82.1%)
           ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC401 NVMe 512GB size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
           serial: EJ85N47651180581B rev: 80003E00 scheme: GPT
Partition: ID-1: / size: 39.12 GiB used: 22.31 GiB (57.0%) fs: ext4 dev: /dev/nvme0n1p3
           ID-2: /home size: 328.06 GiB used: 286.43 GiB (87.3%) fs: ext4 dev: /dev/nvme0n1p4
Swap:      ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A
Info:      Processes: 246 Uptime: 30m Memory: 15.36 GiB used: 1.85 GiB (12.0%) Init: systemd v: 246 Compilers: gcc: 10.2.0
           clang: 10.0.1 Packages: pacman: 1661 Shell: Bash v: 5.0.18 running in: terminator inxi: 3.1.05
sudo alsa-info.sh
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Sun Oct 18 16:41:32 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      Dell Inc.
Product Name:      XPS 13 9370
Product Version:
Firmware Version:  1.6.3
Board Vendor:      Dell Inc.
Board Name:        0F6P3V
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 	 15
/sys/bus/acpi/devices/ACPI000C:00/status 	 15
/sys/bus/acpi/devices/DELL07E6:00/status 	 15
/sys/bus/acpi/devices/DLLK07E6:00/status 	 15
/sys/bus/acpi/devices/INT0E0C:00/status 	 15
/sys/bus/acpi/devices/INT33A1:00/status 	 15
/sys/bus/acpi/devices/INT33D5:00/status 	 15
/sys/bus/acpi/devices/INT3400:00/status 	 15
/sys/bus/acpi/devices/INT3403:00/status 	 15
/sys/bus/acpi/devices/INT3403:01/status 	 15
/sys/bus/acpi/devices/INT3403:02/status 	 15
/sys/bus/acpi/devices/INT3403:03/status 	 15
/sys/bus/acpi/devices/INT3403:04/status 	 15
/sys/bus/acpi/devices/INT3403:05/status 	 15
/sys/bus/acpi/devices/INT340E:00/status 	 15
/sys/bus/acpi/devices/INT344B:00/status 	 15
/sys/bus/acpi/devices/INT3F0D:00/status 	 15
/sys/bus/acpi/devices/LNXPOWER:00/status 	 1
/sys/bus/acpi/devices/MSFT0101:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:03/status 	 3
/sys/bus/acpi/devices/PNP0C02:05/status 	 3
/sys/bus/acpi/devices/PNP0C09:00/status 	 15
/sys/bus/acpi/devices/PNP0C0A:00/status 	 31
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/USBC000:00/status 	 15
/sys/bus/acpi/devices/device:09/status 	 15
/sys/bus/acpi/devices/device:66/status 	 15
/sys/bus/acpi/devices/device:77/status 	 11
!!Kernel Information
Kernel release:    5.4.67-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.4.67-1-MANJARO
Library version:    1.2.3.2
Utilities version:  1.2.3
!!Loaded ALSA modules
snd_aloop
!!Sound Servers on this system
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [Loopback       ]: Loopback - Loopback
                      Loopback 1
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d71] (rev 21) (prog-if 80)
	Subsystem: Dell Device [1028:07e6]
!!Modprobe options (Sound related)
snd_mia: index=-2
snd_hda_intel: index=0
!!Loaded sound module options
!!Module: snd_aloop
	enable : Y,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	pcm_notify : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	pcm_substreams : 8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8
!!ALSA Device nodes
crw-rw----+ 1 root audio 116,  6 Oct 18 18:38 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  3 Oct 18 18:38 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116,  2 Oct 18 18:38 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116,  5 Oct 18 18:38 /dev/snd/pcmC0D1c
crw-rw----+ 1 root audio 116,  4 Oct 18 18:38 /dev/snd/pcmC0D1p
crw-rw----+ 1 root audio 116,  1 Oct 18 18:38 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Oct 18 18:38 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Oct 18 18:38 .
drwxr-xr-x 3 root root 200 Oct 18 18:38 ..
lrwxrwxrwx 1 root root  12 Oct 18 18:38 platform-snd_aloop.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 0: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
  Subdevices: 8/8
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 8/8
  Subdevices: 8/8
!!Amixer output
!!-------Mixer controls for card Loopback
Card hw:0 'Loopback'/'Loopback 1'
  Mixer name	: 'Loopback Mixer'
  Components	: ''
  Controls      : 98
  Simple ctrls  : 2
Simple mixer control 'PCM',0
  Capabilities: pvolume
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 0 [0%] [-51.00dB]
  Front Right: Playback 0 [0%] [-51.00dB]
Simple mixer control 'Digital',0
  Capabilities: cvolume
  Limits: Capture 0 - 120
  Front Left: Capture 60 [50%] [0.00dB]
  Front Right: Capture 60 [50%] [0.00dB]
!!Alsactl output
--startcollapse--
state.Loopback {
	control.1 {
		iface PCM
		name 'PCM Rate Shift 100000'
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '80000 - 120000 (step 1)'
	control.2 {
		iface PCM
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.3 {
		iface PCM
		name 'PCM Slave Active'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.4 {
		iface PCM
		name 'PCM Slave Format'
		value 2
		comment {
			access read
			type INTEGER
			count 1
			range '0 - 52 (step 1)'
	control.5 {
		iface PCM
		name 'PCM Slave Rate'
		value 48000
		comment {
			access read
			type INTEGER
			count 1
			range '0 - 192000 (step 1)'
	control.6 {
		iface PCM
		name 'PCM Slave Channels'
		value 2
		comment {
			access read
			type INTEGER
			count 1
			range '1 - 1024 (step 1)'
	control.7 {
		iface PCM
		subdevice 1
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.8 {
		iface PCM
		subdevice 1
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface PCM
		subdevice 1
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.10 {
		iface PCM
		subdevice 1
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.11 {
		iface PCM
		subdevice 1
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.12 {
		iface PCM
		subdevice 1
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.13 {
		iface PCM
		subdevice 2
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.14 {
		iface PCM
		subdevice 2
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.15 {
		iface PCM
		subdevice 2
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.16 {
		iface PCM
		subdevice 2
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.17 {
		iface PCM
		subdevice 2
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.18 {
		iface PCM
		subdevice 2
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.19 {
		iface PCM
		subdevice 3
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.20 {
		iface PCM
		subdevice 3
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.21 {
		iface PCM
		subdevice 3
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.22 {
		iface PCM
		subdevice 3
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.23 {
		iface PCM
		subdevice 3
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.24 {
		iface PCM
		subdevice 3
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.25 {
		iface PCM
		subdevice 4
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.26 {
		iface PCM
		subdevice 4
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.27 {
		iface PCM
		subdevice 4
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.28 {
		iface PCM
		subdevice 4
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.29 {
		iface PCM
		subdevice 4
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.30 {
		iface PCM
		subdevice 4
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.31 {
		iface PCM
		subdevice 5
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.32 {
		iface PCM
		subdevice 5
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.33 {
		iface PCM
		subdevice 5
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.34 {
		iface PCM
		subdevice 5
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.35 {
		iface PCM
		subdevice 5
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.36 {
		iface PCM
		subdevice 5
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.37 {
		iface PCM
		subdevice 6
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.38 {
		iface PCM
		subdevice 6
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.39 {
		iface PCM
		subdevice 6
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.40 {
		iface PCM
		subdevice 6
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.41 {
		iface PCM
		subdevice 6
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.42 {
		iface PCM
		subdevice 6
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.43 {
		iface PCM
		subdevice 7
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.44 {
		iface PCM
		subdevice 7
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.45 {
		iface PCM
		subdevice 7
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.46 {
		iface PCM
		subdevice 7
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.47 {
		iface PCM
		subdevice 7
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.48 {
		iface PCM
		subdevice 7
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.49 {
		iface PCM
		device 1
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.50 {
		iface PCM
		device 1
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.51 {
		iface PCM
		device 1
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.52 {
		iface PCM
		device 1
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.53 {
		iface PCM
		device 1
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.54 {
		iface PCM
		device 1
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.55 {
		iface PCM
		device 1
		subdevice 1
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.56 {
		iface PCM
		device 1
		subdevice 1
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.57 {
		iface PCM
		device 1
		subdevice 1
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.58 {
		iface PCM
		device 1
		subdevice 1
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.59 {
		iface PCM
		device 1
		subdevice 1
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.60 {
		iface PCM
		device 1
		subdevice 1
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.61 {
		iface PCM
		device 1
		subdevice 2
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.62 {
		iface PCM
		device 1
		subdevice 2
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.63 {
		iface PCM
		device 1
		subdevice 2
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.64 {
		iface PCM
		device 1
		subdevice 2
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.65 {
		iface PCM
		device 1
		subdevice 2
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.66 {
		iface PCM
		device 1
		subdevice 2
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.67 {
		iface PCM
		device 1
		subdevice 3
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.68 {
		iface PCM
		device 1
		subdevice 3
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.69 {
		iface PCM
		device 1
		subdevice 3
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.70 {
		iface PCM
		device 1
		subdevice 3
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.71 {
		iface PCM
		device 1
		subdevice 3
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.72 {
		iface PCM
		device 1
		subdevice 3
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.73 {
		iface PCM
		device 1
		subdevice 4
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.74 {
		iface PCM
		device 1
		subdevice 4
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.75 {
		iface PCM
		device 1
		subdevice 4
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.76 {
		iface PCM
		device 1
		subdevice 4
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.77 {
		iface PCM
		device 1
		subdevice 4
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.78 {
		iface PCM
		device 1
		subdevice 4
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.79 {
		iface PCM
		device 1
		subdevice 5
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.80 {
		iface PCM
		device 1
		subdevice 5
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.81 {
		iface PCM
		device 1
		subdevice 5
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.82 {
		iface PCM
		device 1
		subdevice 5
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.83 {
		iface PCM
		device 1
		subdevice 5
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.84 {
		iface PCM
		device 1
		subdevice 5
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.85 {
		iface PCM
		device 1
		subdevice 6
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.86 {
		iface PCM
		device 1
		subdevice 6
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.87 {
		iface PCM
		device 1
		subdevice 6
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.88 {
		iface PCM
		device 1
		subdevice 6
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.89 {
		iface PCM
		device 1
		subdevice 6
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.90 {
		iface PCM
		device 1
		subdevice 6
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.91 {
		iface PCM
		device 1
		subdevice 7
		value 100000
		comment {
			access 'read write'
			type INTEGER
			count 1
	control.92 {
		iface PCM
		device 1
		subdevice 7
		name 'PCM Notify'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.93 {
		iface PCM
		device 1
		subdevice 7
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.94 {
		iface PCM
		device 1
		subdevice 7
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.95 {
		iface PCM
		device 1
		subdevice 7
		value 48000
		comment {
			access read
			type INTEGER
			count 1
	control.96 {
		iface PCM
		device 1
		subdevice 7
		value 2
		comment {
			access read
			type INTEGER
			count 1
	control.97 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 -5100
			dbvalue.1 -5100
	control.98 {
		iface MIXER
		name 'Digital Capture Volume'
		value.0 60
		value.1 60
		comment {
			type INTEGER
			count 2
			range '0 - 120'
			tlv '0000000100000008fffff44800000032'
			dbmin -3000
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac
ac97_bus
acpi_thermal_rel
aesni_intel
agpgart
ath
ath10k_core
ath10k_pci
atkbd
battery
bluetooth
btbcm
btintel
btrtl
btusb
ccm
cdc_acm
cdrom
cfg80211
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
dcdbas
dell_laptop
dell_smbios
dell_wmi
dell_wmi_descriptor
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_i801
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
input_leds
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_hid
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
intel_wmi_thunderbolt
intel_xhci_usb_role_switch
ip6_tables
ip6t_REJECT
ip6t_rt
ip6table_filter
ip_tables
ipt_REJECT
iptable_filter
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libcrc32c
libps2
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mei_wdt
memstick
mmc_core
mousedev
nf_conntrack
nf_conntrack_broadcast
nf_conntrack_ftp
nf_conntrack_netbios_ns
nf_defrag_ipv4
nf_defrag_ipv6
nf_log_common
nf_log_ipv4
nf_log_ipv6
nf_nat
nf_nat_ftp
nf_reject_ipv4
nf_reject_ipv6
nls_cp437
nls_iso8859_1
pcspkr
processor_thermal_device
psmouse
rapl
rfkill
rng_core
roles
rtsx_pci
rtsx_pci_ms
rtsx_pci_sdmmc
scsi_mod
serio
serio_raw
sg
snd
snd_aloop
snd_compress
snd_hda_codec
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_nhlt
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hdmi
snd_soc_skl
snd_soc_skl_hda_dsp
snd_soc_skl_ssp_clk
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_timer
soundcore
sparse_keymap
sr_mod
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_displayport
typec_ucsi
ucsi_acpi
usb_storage
usbhid
uvcvideo
v4l2loopback_dc
vboxdrv
vboxnetadp
vboxnetflt
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
xt_LOG
xt_addrtype
xt_conntrack
xt_hl
xt_limit
xt_tcpudp
!!ALSA/HDA dmesg
[    0.195290] ACPI: Added _OSI(Linux-Dell-Video)
[    0.195290] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.195290] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    7.172189] AES CTR mode by8 optimization enabled
[    7.173486] snd_hda_intel 0000:00:1f.3: cannot find the slot for index 0 (range 0-0), error: -16
[    7.173487] snd_hda_intel 0000:00:1f.3: Error creating card!
[    7.173490] snd_hda_intel: probe of 0000:00:1f.3 failed with error -16
[    7.272968] usb 1-10: New USB device found, idVendor=27c6, idProduct=5385, bcdDevice= 1.00
[    7.412130] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
[    7.542205] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[    7.542211] snd_soc_skl 0000:00:1f.3: enabling device (0000 -> 0002)
[    7.547539] ath10k_pci 0000:02:00.0: enabling device (0000 -> 0002)
[    7.739212] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10
[    7.739395] snd_soc_skl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    7.748016] i2c_hid i2c-DELL07E6:00: i2c-DELL07E6:00 supply vdd not found, using dummy regulator
[    7.771048] fbcon: i915drmfb (fb0) is primary device
[    7.785213] HDMI HDA Codec ehdaudio0D2: Max dais supported: 3
[    7.807915] ath10k_pci 0000:02:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 1a56:143a`
sudo dmesg | grep snd
Any suggestions? Thanks in advance for any help.
Regards,
z0id
Have you tried - at least temporarily - removing these options?
see this
Audio driver snd_mia is for Echo Mia pci audio card and does not relate to this system
This is probably from Archwiki Advanced Linux Sound Architecture - Configuring the index order via kernel module options
suggest remove option for snd_mia
and change option for snd_hda_intel to ensure audio device is the first card (index 0) ahead of loopback
options snd slots=snd_hda_intel,
based on this from kernel documentation
Advanced Linux Sound Architecture - Driver Configuration guide — The Linux Kernel documentation
Alternative (and new) way to fixate the slot assignment is to use slots option of snd module. In the case above, specify like the following:
options snd slots=snd-interwave,snd-ens1371
Then, the first slot (#0) is reserved for snd-interwave driver, and the second (#1) for snd-ens1371. You can omit index option in each driver if slots option is used
Making these changes in /etc/modprobe.d/alsa-base.conf solved the problem. Thanks to all of you for your support.
