[solved] Problems to configure second screen with NVIDIA drivers
Hello, I installed this new HP Omen 15 notebook with Manjaro Gnome. Everything seems working fine from the first installation, until I tried to connect it to a second screen by HDMI. In gnome-control-center detects the external monitor, but when I tried to apply Join Displays, it returns to Single display.
I tried with noueveau drivers, but I need nvidia GPU for blender and other apps that didn’t detect the card with Noueveau. I tried to uninstall hybrid drivers and only use nvidia ones, and then works for the external monitor, but not for the internal screen.
So maybe it’s only a configuration that I can’t found. This is the result of inxi command:
  Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=679102ee-fd58-49d7-a9df-9b37b3eac85c rw quiet splash apparmor=1
  security=apparmor resume=UUID=79bb137d-2f6a-48e6-bc60-a430e1031785
  udev.log_priority=3 acpi_backlight=native
  Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 3.38.2.1
  Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8786 v: 22.26 serial: <filter> UEFI: AMI v: F.02
  date: 05/11/2020
  ID-1: BAT0 charge: 66.5 Wh (98.8%) condition: 67.3/67.3 Wh (100.0%)
  volts: 13.2 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
  serial: N/A status: Charging cycles: 605
  RAM: total: 7.2 GiB used: 2.06 GiB (28.6%)
  Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600103 cache: L2: 4 MiB bogomips: 92661
  Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1397 3: 1400 4: 1396 5: 1397 6: 1397 7: 1398 8: 1397 9: 1397
  10: 1397 11: 1397 12: 1397 13: 1397 14: 1397 15: 1400 16: 1397
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
  lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
  nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
  pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
  skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
  svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
  vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
  driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:2191 class-ID: 0300
  Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
  type: USB driver: uvcvideo bus-ID: 3-3:2 chip-ID: 05c8:03df class-ID: 0e02
  Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
  loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
  alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.26-1-MANJARO LLVM 11.1.0)
  v: 4.6 Mesa 21.0.1 direct render: Yes
  Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
  alternate: snd_pci_acp3x bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-2: AMD Family 17h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.24 running: no
  vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000
  bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
  Message: No LVM data was found.
  Local Storage: total: 476.94 GiB used: 16.34 GiB (3.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000H1
  lanes: 4 rotation: SSD serial: <filter> rev: HPS0NEXF temp: 35.9 C
  scheme: GPT
  ID-1: / raw-size: 333.99 GiB size: 327.68 GiB (98.11%)
  used: 16.28 GiB (5.0%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  label: N/A uuid: 679102ee-fd58-49d7-a9df-9b37b3eac85c
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 62 MiB (24.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM uuid: 06E5-0131
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
  uuid: 79bb137d-2f6a-48e6-bc60-a430e1031785
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 134.34 GiB fs: ntfs label: Windows
  uuid: D8AE0643AE061B20
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 541 MiB fs: ntfs label: N/A
  uuid: 6C62965A6296293A
  Hub-1: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-3:2
  info: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
  type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
  power: 500mA chip-ID: 05c8:03df class-ID: 0e02
  Device-2: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Hub-2: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
  chip-ID: 046d:c53d class-ID: 0300
  Device-2: 5-2:3 info: Holtek Wireless keyboard and mouse
  type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 1.5 Mb/s power: 98mA chip-ID: 1a81:1006 class-ID: 0301
  Hub-4: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 62.8 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Processes: 375 Uptime: 5m wakeups: 2 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 Packages: pacman: 1322 lib: 418 flatpak: 0 Shell: Zsh
  v: 5.8 running-in: gnome-terminal inxi: 3.3.03
Thanks for any directions!
I have a hybrid nvidia and intel, when I connect via hdmi it switches on the nvidia driver and uses the intel on my laptop. Seems to me that you may want to have nvidia drivers installed so that one screens uses the nvidia and the other the amd gpu. Else the hdmi will appear black.
I have absolutely no experience with AMD. Maybe you need to install the correct driver for that gpu? Nvidia seems ok with 460x. As I recall amd maybe integrated in the kernel.
I would check whether this amd gpu is supported by your current kernel or needs a newer or perhaps older lts.
Edit: manjaro has a easy gui tool to try/install another kernel. Needs a reboot after install though. I also like to mention that I often saw problems on linux forum with HP and their dual gpu, something with the vendor bios that makes our life a bit more difficult on linux…
Edit2: saw that you posted on this thread
Did you try install the dual gpu driver as mentioned there via terminal?
This is know issue. As per NVIDIA documentation:
The NVIDIA driver currently cannot be used as an output sink when the output source driver is xf86-video-amdgpu.
See this thread for more information.
