(solved) Plasmashell 5.20.4 continuously increases ram memory usage
Hi,
i am using manjaro stable, kde plasma.
plasmashell is 5.20.4.
I did not install any widgets, other dm’s, fancy stuff or services except cups.
Immediatly after logging in, plasmashell continously increases its size. on my 4 core CPU, there is also considerable cpu use (5-20%,variable ) on a totally idle machine by plasmashell.
I already found year-old problems of plasmashell 5.x with a memory leak, that is said to have been patched in 5.18, but this reminds me of it.
I found others that reported transparent layouts to be the problem, I started with adwaita dark, also tested breeze-dark and switched to breeze (non-transparent), and also tried to disable animations and optic effects, but all that didn’t help.
I furthermore found baloo hoarding memory, thus I disabled the file index service, which stopped that, but plasmashell keeps on eating ram.
During googling around I found some topics that could be related, however I’m unsure whether they are.
https://bugs.kde.org/show_bug.cgi?id=429593
thank you for ideas on how to tackle this.
here are some starting points
in order to quantify this I used smem, to print out the memory usage of the largest task. one line every 10 minutes, and I had the machine sit totally idle without any activity for a few hours.
(the blank line marks me starting up firefox to google this bug, so after the blank line I am actively using a web browser) for 20-30min, and then let it sit idle again.
 $ date; smem | head -n1; while true; do smem | tail -n 1 ; sleep 600; done
Mo 14. Dez 09:19:32 CET 2020
  PID User     Command                         Swap      USS      PSS      RSS
 1185 n8xpress /usr/bin/plasmashell               0   732280   744589   820708
 1185 n8xpress /usr/bin/plasmashell             552   794284   804700   881244
 1185 n8xpress /usr/bin/plasmashell             552   860092   870508   947052
 1185 n8xpress /usr/bin/plasmashell             552   924840   935239  1011728
 1185 n8xpress /usr/bin/plasmashell            1304   988468   998736  1074736
 1185 n8xpress /usr/bin/plasmashell            1960  1051248  1061481  1137132
 1185 n8xpress /usr/bin/plasmashell            2024  1114380  1124401  1198716
 1185 n8xpress /usr/bin/plasmashell            2036  1176300  1185418  1256488
 1185 n8xpress /usr/bin/plasmashell            2080  1238884  1247798  1318404
 1185 n8xpress /usr/bin/plasmashell            5652  1296488  1304921  1373580
 1185 n8xpress /usr/bin/plasmashell            6620  1359208  1367011  1431896
 1185 n8xpress /usr/bin/plasmashell           29808  1396440  1403732  1465772
 1185 n8xpress /usr/bin/plasmashell           39188  1446796  1453458  1512380
 1185 n8xpress /usr/bin/plasmashell           58904  1487048  1493250  1547924
 1185 n8xpress /usr/bin/plasmashell           62992  1542256  1548047  1598648
 1185 n8xpress /usr/bin/plasmashell           64612  1599464  1604987  1650944
 1185 n8xpress /usr/bin/plasmashell           64672  1658040  1662282  1699016
 1185 n8xpress /usr/bin/plasmashell           65436  1714796  1718303  1750184
 1185 n8xpress /usr/bin/plasmashell           66176  1772032  1775198  1804712
 1185 n8xpress /usr/bin/plasmashell           67404  1828260  1831178  1858812
 1185 n8xpress /usr/bin/plasmashell           67800  1884568  1887339  1914036
 1185 n8xpress /usr/bin/plasmashell           68412  1940784  1943453  1967140
 1185 n8xpress /usr/bin/plasmashell           70084  1996248  1998631  2017536
 1185 n8xpress /usr/bin/plasmashell           70456  2051144  2053527  2072116
 1185 n8xpress /usr/bin/plasmashell           74712  2101792  2104056  2121904
 1185 n8xpress /usr/bin/plasmashell           80264  2150296  2152242  2167540
 1185 n8xpress /usr/bin/plasmashell           89212  2197940  2199836  2214308
 1185 n8xpress /usr/bin/plasmashell           97500  2242984  2244863  2258476
 1185 n8xpress /usr/bin/plasmashell          126884  2266236  2268071  2280928
 1185 n8xpress /usr/bin/plasmashell          135688  2310332  2312114  2324856
 1185 n8xpress /usr/bin/plasmashell          147196  2350308  2352034  2364668
 1185 n8xpress /usr/bin/plasmashell          154044  2395080  2396974  2408552
 1185 n8xpress /usr/bin/plasmashell          403308  2170436  2171653  2175132
 1185 n8xpress /usr/bin/plasmashell          773008  1801424  1802031  1804832
 1185 n8xpress /usr/bin/plasmashell          525528  2076808  2078255  2081868
 1185 n8xpress /usr/bin/plasmashell          497616  2106384  2109003  2114768
 1185 n8xpress /usr/bin/plasmashell          374672  2253536  2256536  2263796
 1185 n8xpress /usr/bin/plasmashell          355516  2315056  2317691  2323644
 1185 n8xpress /usr/bin/plasmashell          514520  2194488  2196503  2201760
 1185 n8xpress /usr/bin/plasmashell          575044  2153568  2156110  2161520
 1185 n8xpress /usr/bin/plasmashell          335532  2400456  2402757  2408188
 1185 n8xpress /usr/bin/plasmashell          355540  2403872  2407087  2413280
 1185 n8xpress /usr/bin/plasmashell          436408  2329732  2332018  2336860
 1185 n8xpress /usr/bin/plasmashell          391076  2375128  2377769  2383000
 1185 n8xpress /usr/bin/plasmashell          398204  2369812  2371829  2376336
 1185 n8xpress /usr/bin/plasmashell          566808  2207036  2211607  2220328
 1185 n8xpress /usr/bin/plasmashell          455880  2322696  2325720  2331392
 1185 n8xpress /usr/bin/plasmashell          510936  2271712  2273896  2278268
 1185 n8xpress /usr/bin/plasmashell          608472  2173868  2176559  2182160
 1185 n8xpress /usr/bin/plasmashell          669312  2108152  2109236  2112340
 1185 n8xpress /usr/bin/plasmashell          475932  2316432  2318483  2322960
 1185 n8xpress /usr/bin/plasmashell          680760  2103232  2105973  2112124
 1185 n8xpress /usr/bin/plasmashell          656568  2128128  2129866  2133968
some system info:
$ inxi -Fazy
  Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.9-x86_64
  root=UUID=7fd670dc-55d9-4eb8-a8c6-cf1532e72a8a rw rootflags=subvol=@
  cryptdevice=UUID=ad8b45b8-7db3-4a4f-9e87-c0904db4375c:cryptroot quiet
  udev.log_priority=3
  Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: Hewlett-Packard product: HP Spectre x2 Pro
  v: 097B110400405F00000130003 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: Hewlett-Packard model: 2152 v: 23.29 serial: <filter> UEFI: Insyde
  v: F.1B date: 04/02/2014
  ID-1: BAT0 charge: 27.4 Wh condition: 27.4/27.4 Wh (100%) volts: 12.5/11.1
  model: 13-1B LR03033X type: Li-ion serial: <filter> status: Full
  ID-2: BAT1 charge: 10.1 Wh condition: 10.1/10.1 Wh (100%) volts: 12.5/11.1
  model: 13-17 IEP001 type: Li-ion serial: <filter> status: Full
  Info: Dual Core model: Intel Core i5-4202Y bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
  L2 cache: 3072 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 12774
  Speed: 1696 MHz min/max: 600/2000 MHz Core speeds (MHz): 1: 1696 2: 1696
  3: 1712 4: 1718
  Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: Intel vendor: Hewlett-Packard driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:0a1e
  Device-2: Suyin HP TrueVision Full HD type: USB driver: uvcvideo
  bus ID: 1-1.7:6 chip ID: 064e:c352 serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel
  unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7")
  diag: 336mm (13.2")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4200 (HSW GT2)
  v: 4.5 Mesa 20.2.3 compat-v: 3.0 direct render: Yes
  Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
  Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
  Sound Server: ALSA v: k5.9.11-3-MANJARO
  Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: 4040
  bus ID: 07:00.0 chip ID: 8086:08b1
  IF: wlp7s0 state: up mac: <filter>
  Local Storage: total: 238.47 GiB used: 198.45 GiB (83.2%)
  ID-1: /dev/sda vendor: LITE-ON IT model: LMT-256M6M-HP size: 238.47 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 701 scheme: GPT
  ID-1: / raw size: 238.41 GiB size: 238.41 GiB (100.00%)
  used: 198.45 GiB (83.2%) fs: btrfs dev: /dev/dm-0
  ID-2: /home raw size: 238.41 GiB size: 238.41 GiB (100.00%)
  ID-1: swap-1 type: file size: 5.00 GiB used: 2.84 GiB (56.9%) priority: -2
  file: /swap/file
  System Temperatures: cpu: 56.0 C mobo: N/A
  Processes: 219 Uptime: 6h 52m Memory: 3.77 GiB used: 3.25 GiB (86.1%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1338 lib: 385
  flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
my env:
SHELL=/bin/bash
SESSION_MANAGER=local/gunship:@/tmp/.ICE-unix/1151,unix/gunship:/tmp/.ICE-unix/1151
WINDOWID=52428807
COLORTERM=truecolor
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session1
LANGUAGE=
LC_ADDRESS=de_DE.UTF-8
SHELL_SESSION_ID=55a453695713471e866290125b4b970b
LIBVA_DRIVER_NAME=i965
DESKTOP_SESSION=/usr/share/xsessions/plasma
LC_MONETARY=de_DE.UTF-8
GTK_RC_FILES=/etc/gtk/gtkrc:/home/n8xpress/.gtkrc:/home/n8xpress/.config/gtkrc
XCURSOR_SIZE=24
EDITOR=/usr/bin/nano
GTK_MODULES=canberra-gtk-module
XDG_SEAT=seat0
PWD=/home/n8xpress
XDG_SESSION_DESKTOP=KDE
LOGNAME=n8xpress
XDG_SESSION_TYPE=x11
XAUTHORITY=/home/n8xpress/.Xauthority
MOTD_SHOWN=pam
GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/home/n8xpress/.gtkrc-2.0:/home/n8xpress/.config/gtkrc-2.0
HOME=/home/n8xpress
LC_PAPER=de_DE.UTF-8
LANG=de_DE.UTF-8
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.pdf=00;32:*.ps=00;32:*.txt=00;32:*.patch=00;32:*.diff=00;32:*.log=00;32:*.tex=00;32:*.doc=00;32:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:
XDG_CURRENT_DESKTOP=KDE
KONSOLE_DBUS_SERVICE=:1.38
VDPAU_DRIVER_NAME=va_gl
KONSOLE_DBUS_SESSION=/Sessions/1
PROFILEHOME=
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
KONSOLE_VERSION=200803
KDE_SESSION_UID=1000
XDG_SESSION_CLASS=user
TERM=xterm-256color
USER=n8xpress
COLORFGBG=15;0
KDE_SESSION_VERSION=5
PAM_KWALLET5_LOGIN=/run/user/1000/kwallet5.socket
DISPLAY=:0
SHLVL=1
LC_MESSAGES=de_DE.UTF-8
LC_MEASUREMENT=de_DE.UTF-8
XDG_VTNR=1
XDG_SESSION_ID=2
QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
XDG_RUNTIME_DIR=/run/user/1000
LC_TIME=de_DE.UTF-8
QT_AUTO_SCREEN_SCALE_FACTOR=0
XCURSOR_THEME=breeze_cursors
XDG_DATA_DIRS=/home/n8xpress/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop
KDE_FULL_SESSION=true
BROWSER=/usr/bin/firefox
PATH=/home/n8xpress/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
KDE_APPLICATIONS_AS_SCOPE=1
HG=/usr/bin/hg
MAIL=/var/spool/mail/n8xpress
_=/usr/bin/env
on dmesg there was one ata bus error, quite some time ago. the uptime is 25242 during googling and 37354 during reporting, but just in case this could be related:
 sudo dmesg -l emerg,alert,crit,err,warn
[    0.106630] x86/cpu: VMX (outside TXT) disabled by BIOS
[    0.112238] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.112500]  #2 #3
[    0.119652] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.292225] ACPI Error: No handler for Region [RAM_] (00000000dd9f77bf) [EmbeddedControl] (20200717/evregion-127)
[    0.292230] ACPI Error: Region EmbeddedControl (ID=3) has no handler (20200717/exfldio-261)
[    0.292236] ACPI Error: Aborting method \_SB.PCI0.XHC._PSW due to previous error (AE_NOT_EXIST) (20200717/psparse-529)
[    0.292242] ACPI: _PSW execution failed
[    1.757444] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[   12.183270] wmi_bus wmi_bus-PNP0C14:00: WQBJ data block query control method not found
[   12.190980] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[   12.678784] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   15.592477] kauditd_printk_skb: 30 callbacks suppressed
[   15.895427] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[   20.694833] kauditd_printk_skb: 9 callbacks suppressed
[   30.403181] kauditd_printk_skb: 7 callbacks suppressed
[11594.350276] ata1.00: exception Emask 0x50 SAct 0x4000 SErr 0x40c0800 action 0xe frozen
[11594.350279] ata1.00: irq_stat 0x00000040, connection status changed
[11594.350282] ata1: SError: { HostInt CommWake 10B8B DevExch }
[11594.350286] ata1.00: failed command: READ FPDMA QUEUED
[11594.350291] ata1.00: cmd 60/20:70:c0:75:ec/00:00:18:00:00/40 tag 14 ncq dma 16384 in
                        res 40/00:74:c0:75:ec/00:00:18:00:00/40 Emask 0x50 (ATA bus error)
[11594.350292] ata1.00: status: { DRDY }
[15402.406275] ata1.00: exception Emask 0x50 SAct 0x70000007 SErr 0x40c0800 action 0xe frozen
[15402.406280] ata1.00: irq_stat 0x00000040, connection status changed
[15402.406284] ata1: SError: { HostInt CommWake 10B8B DevExch }
[15402.406288] ata1.00: failed command: WRITE FPDMA QUEUED
[15402.406309] ata1.00: cmd 61/08:00:c0:5a:4b/00:00:02:00:00/40 tag 0 ncq dma 4096 out
                        res 40/00:14:a0:5b:4b/00:00:02:00:00/40 Emask 0x50 (ATA bus error)
[15402.406311] ata1.00: status: { DRDY }
[15402.406314] ata1.00: failed command: WRITE FPDMA QUEUED
[15402.406321] ata1.00: cmd 61/08:08:58:5b:4b/00:00:02:00:00/40 tag 1 ncq dma 4096 out
[15402.406323] ata1.00: status: { DRDY }
[15402.406325] ata1.00: failed command: WRITE FPDMA QUEUED
[15402.406332] ata1.00: cmd 61/08:10:a0:5b:4b/00:00:02:00:00/40 tag 2 ncq dma 4096 out
[15402.406334] ata1.00: status: { DRDY }
[15402.406337] ata1.00: failed command: WRITE FPDMA QUEUED
[15402.406344] ata1.00: cmd 61/08:e0:f8:59:4b/00:00:02:00:00/40 tag 28 ncq dma 4096 out
[15402.406346] ata1.00: status: { DRDY }
[15402.406348] ata1.00: failed command: WRITE FPDMA QUEUED
[15402.406355] ata1.00: cmd 61/08:e8:58:5a:4b/00:00:02:00:00/40 tag 29 ncq dma 4096 out
[15402.406356] ata1.00: status: { DRDY }
[15402.406359] ata1.00: failed command: WRITE FPDMA QUEUED
[15402.406365] ata1.00: cmd 61/08:f0:b0:5a:4b/00:00:02:00:00/40 tag 30 ncq dma 4096 out
[15402.406367] ata1.00: status: { DRDY }
and here some infos from Xorg.0.log - I don’t see anything suspicous (but the stalling at the end), but I’m not an expert.
$ grep -e \(EE\) -e WW -e Dri -e DRI  -nC1 /var/log/Xorg.0.log
14-     (++) from command line, (!!) notice, (II) informational,
15:     (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
16-[    15.124] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 14 07:51:42 2020
29-[    15.126] (==) Max clients allowed: 256, resource mask: 0x1fffff
30:[    15.126] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
31-[    15.126]         Entry deleted from font path.
32-[    15.126]         (Run 'mkfontdir' on "/usr/share/fonts/misc").
33:[    15.126] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
34-[    15.126]         Entry deleted from font path.
35-[    15.126]         (Run 'mkfontdir' on "/usr/share/fonts/TTF").
36:[    15.126] (WW) The directory "/usr/share/fonts/OTF" does not exist.
37-[    15.126]         Entry deleted from font path.
38:[    15.126] (WW) The directory "/usr/share/fonts/Type1" does not exist.
39-[    15.126]         Entry deleted from font path.
40:[    15.126] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
41-[    15.126]         Entry deleted from font path.
42:[    15.126] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
43-[    15.126]         Entry deleted from font path.
50-[    15.126]         X.Org ANSI C Emulation: 0.4
51:[    15.126]         X.Org Video Driver: 24.1
52-[    15.126]         X.Org XInput driver : 24.1
58-[    15.144] (--) PCI:*(0@0:2:0) 8086:0a1e:103c:2152 rev 11, Mem @ 0xb2000000/4194304, 0xa0000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
59:[    15.144] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
60-[    15.144] (II) LoadModule: "glx"
73-[    15.172]         compiled for 1.20.9, module version = 2.99.917
74:[    15.172]         Module class: X.Org Video Driver
75:[    15.172]         ABI class: X.Org Video Driver, version 24.1
76-[    15.172] (II) LoadModule: "modesetting"
79-[    15.179]         compiled for 1.20.10, module version = 1.20.10
80:[    15.179]         Module class: X.Org Video Driver
81:[    15.179]         ABI class: X.Org Video Driver, version 24.1
82-[    15.179] (II) LoadModule: "fbdev"
83:[    15.179] (WW) Warning, couldn't open module fbdev
84:[    15.179] (EE) Failed to load module "fbdev" (module does not exist, 0)
85-[    15.179] (II) LoadModule: "vesa"
86:[    15.179] (WW) Warning, couldn't open module vesa
87:[    15.179] (EE) Failed to load module "vesa" (module does not exist, 0)
88:[    15.179] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
89-     i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
92-     GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
93:[    15.180] (II) intel: Driver for Intel(R) HD Graphics
94:[    15.180] (II) intel: Driver for Intel(R) Iris(TM) Graphics
95:[    15.180] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
96:[    15.180] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
97-[    15.180] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200715
98-[    15.180] (II) intel(0): SNA compiled from 2.99.917-913-g9236c582
99:[    15.180] (WW) Falling back to old probe method for modesetting
100-[    15.180] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4200
135-[    15.183] (==) intel(0): Display hotplug detection enabled
136:[    15.183] (II) intel(0): [DRI2] Setup complete
137:[    15.183] (II) intel(0): [DRI2]   DRI driver: i965
138:[    15.183] (II) intel(0): [DRI2]   VDPAU driver: va_gl
139:[    15.183] (II) intel(0): direct rendering: DRI2 DRI3 enabled
140-[    15.183] (II) intel(0): hardware support for Present enabled
160-[    15.186] (II) Initializing extension Present
161:[    15.186] (II) Initializing extension DRI3
162-[    15.186] (II) Initializing extension X-Resource
166-[    15.274] (II) AIGLX: Loaded and initialized i965
167:[    15.274] (II) GLX: Initialized DRI2 GL provider for screen 0
168-[    15.274] (II) Initializing extension XFree86-VidModeExtension
169-[    15.275] (II) Initializing extension XFree86-DGA
170:[    15.275] (II) Initializing extension XFree86-DRI
171:[    15.275] (II) Initializing extension DRI2
172-[    15.288] (II) intel(0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
181-[    15.460]        compiled for 1.20.8, module version = 0.30.0
182:[    15.460]        Module class: X.Org XInput Driver
183-[    15.460]        ABI class: X.Org XInput driver, version 24.1
292-[    16.001] (II) mouse1  - not using input device '/dev/input/mouse1'.
293:[    16.001] (EE) libinput: Synaptics s3203: Failed to create a device for /dev/input/mouse1
294:[    16.001] (EE) PreInit returned 2 for "Synaptics s3203"
295-[    16.002] (II) UnloadModule: "libinput"
385-[    16.262] (II) mouse1  - not using input device '/dev/input/mouse1'.
386:[    16.262] (EE) libinput: Synaptics s3203: Failed to create a device for /dev/input/mouse1
387:[    16.262] (EE) PreInit returned 2 for "Synaptics s3203"
388-[    16.262] (II) UnloadModule: "libinput"
458-[    17.184] (II) intel(0): Modeline "1920x1080"x0.0   94.00  1920 1936 1952 2104  1080 1083 1097 1116 -hsync -vsync (44.7 kHz e)
459:[ 24274.918] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 14ms, your system is too slow
460:[ 24395.624] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 59ms, your system is too slow
461:[ 24418.963] (EE) event2  - AT Translated Set 2 keyboard: client bug: event processing lagging behind by 53ms, your system is too slow
462:[ 24438.801] (EE) event2  - AT Translated Set 2 keyboard: client bug: event processing lagging behind by 97ms, your system is too slow
463:[ 24450.778] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 11ms, your system is too slow
464:[ 24450.802] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
465:[ 24468.608] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 28ms, your system is too slow
466:[ 24507.907] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 28ms, your system is too slow
467:[ 24508.206] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
468:[ 24817.801] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-84ms), your system is too slow
469:[ 24817.972] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-476ms), your system is too slow
470:[ 24817.972] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-489ms), your system is too slow
471:[ 24851.324] (EE) event4  - Synaptics s3203: client bug: event processing lagging behind by 14ms, your system is too slow
472:[ 25095.890] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-554ms), your system is too slow
473-[ 25096.189] (II) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): SYN_DROPPED event - some input events have been lost.
474:[ 25096.189] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-29ms), your system is too slow
475:[ 25096.189] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-42ms), your system is too slow
476:[ 25201.582] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-31ms), your system is too slow
477:[ 25201.843] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-187ms), your system is too slow
478:[ 25201.843] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-200ms), your system is too slow
479:[ 25219.822] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-46ms), your system is too slow
480:[ 25219.824] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-69ms), your system is too slow
481-[ 25282.180] (II) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): SYN_DROPPED event - some input events have been lost.
482:[ 25550.818] (EE) event2  - AT Translated Set 2 keyboard: client bug: event processing lagging behind by 14ms, your system is too slow
483:[ 25586.730] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-1478ms), your system is too slow
484:[ 25586.920] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-872ms), your system is too slow
485:[ 25586.920] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-885ms), your system is too slow
486:[ 25614.762] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-186ms), your system is too slow
487:[ 25614.792] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-228ms), your system is too slow
488:[ 25788.351] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-42ms), your system is too slow
489-[ 25967.947] (II) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): SYN_DROPPED event - some input events have been lost.
490:[ 26173.803] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-11ms), your system is too slow
491-[ 26215.638] (II) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): SYN_DROPPED event - some input events have been lost.
492:[ 26245.820] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-1300ms), your system is too slow
493:[ 26245.908] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-1275ms), your system is too slow
494:[ 26245.908] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-1288ms), your system is too slow
495:[ 26624.132] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
496:[ 36903.726] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 106ms, your system is too slow
497:[ 36983.994] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 12ms, your system is too slow
498:[ 37000.168] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 218ms, your system is too slow
499:[ 37036.802] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 20ms, your system is too slow
500:[ 37057.835] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-4ms), your system is too slow
501:[ 37057.836] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
502:[ 37192.112] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-37ms), your system is too slow
503:[ 37192.190] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-148ms), your system is too slow
504:[ 37293.983] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): client bug: event processing lagging behind by 876ms, your system is too slow
505:[ 37293.990] (EE) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
506:[ 37323.572] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-13ms), your system is too slow
507:[ 37323.581] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-35ms), your system is too slow
508:[ 37779.771] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-91ms), your system is too slow
509:[ 37779.825] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-34ms), your system is too slow
510:[ 37779.825] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-47ms), your system is too slow
511:[ 37832.134] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-4ms), your system is too slow
512:[ 37832.135] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-125ms), your system is too slow
513:[ 38001.198] (EE) event4  - Synaptics s3203: client bug: event processing lagging behind by 24ms, your system is too slow
514:[ 38014.853] (EE) event4  - Synaptics s3203: client bug: event processing lagging behind by 55ms, your system is too slow
515:[ 38025.431] (EE) event4  - Synaptics s3203: client bug: event processing lagging behind by 11ms, your system is too slow
516:[ 38182.107] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-3ms), your system is too slow
517:[ 38182.112] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-22ms), your system is too slow
518-[ 38219.409] (II) event3  - Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): SYN_DROPPED event - some input events have been lost.
519:[ 38363.741] (EE) event4  - Synaptics s3203: client bug: event processing lagging behind by 15ms, your system is too slow
520:[ 38364.346] (EE) event4  - Synaptics s3203: client bug: event processing lagging behind by 64ms, your system is too slow
521:[ 38364.346] (EE) event4  - Synaptics s3203: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
522-[ 38390.717] (II) event4  - Synaptics s3203: SYN_DROPPED event - some input events have been lost.
in my journalctl log file, there are approximately one million log lines of the last ten hours.
I tried to filter out what was duplicate and for sure useless (Networkmanager etc), now this remains:
-- Logs begin at Thu 2020-12-03 14:31:48 CET, end at Mon 2020-12-14 18:38:06 CET. --
Dez 14 09:10:34 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:10:34 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
    (many of these two)
Dez 14 09:10:39 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:10:39 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
Dez 14 09:10:40 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 09:10:40 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33017, resource id: 14690896, major code: 20 (GetProperty), minor code: 0
Dez 14 09:10:41 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:10:41 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
Dez 14 09:10:42 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:10:42 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
Dez 14 09:10:42 gunship plasmashell[1185]: Using QByteRef with an index pointing outside the valid range of a QByteArray. The corresponding behavior is deprecated, and will be changed in a future version of Qt.
Dez 14 09:10:42 gunship plasmashell[1185]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Dez 14 09:10:43 gunship plasmashell[1185]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
Dez 14 09:10:43 gunship plasmashell[1185]: Using QByteRef with an index pointing outside the valid range of a QByteArray. The corresponding behavior is deprecated, and will be changed in a future version of Qt.
Dez 14 09:10:43 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33971, resource id: 48235013, major code: 18 (ChangeProperty), minor code: 0
Dez 14 09:10:43 gunship systemd[1056]: Started Konsole - Terminal.
Dez 14 09:10:43 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:10:43 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
   (many of these two)
Dez 14 09:12:13 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:12:13 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
Dez 14 09:12:14 gunship rtkit-daemon[1369]: Supervising 4 threads of 2 processes of 1 users.
Dez 14 09:12:14 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:12:14 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
   (many of these two)
Dez 14 09:12:39 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:12:39 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
Dez 14 09:12:40 gunship rtkit-daemon[1369]: Supervising 4 threads of 2 processes of 1 users.
Dez 14 09:12:40 gunship kdeinit5[1437]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Dez 14 09:12:40 gunship kdeinit5[1437]: kf.kio.slaves.tags: "tags:/" list() invalid url
    and so on, I will no longer list more rtkit or kio.slaves.tags....
Dez 14 09:15:10 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 09:15:10 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53385, resource id: 14690945, major code: 20 (GetProperty), minor code: 0
Dez 14 09:17:43 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 09:17:43 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58254, resource id: 14693467, major code: 20 (GetProperty), minor code: 0
Dez 14 09:17:49 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 09:17:50 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59849, resource id: 14693584, major code: 20 (GetProperty), minor code: 0
Dez 14 09:23:19 gunship kscreen_backend_launcher[1196]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
Dez 14 09:23:19 gunship kscreen_backend_launcher[1196]: kscreen.xcb.helper:         Output:  67
Dez 14 09:23:19 gunship kscreen_backend_launcher[1196]: kscreen.xcb.helper:         Property:  Backlight
Dez 14 09:23:19 gunship kscreen_backend_launcher[1196]: kscreen.xcb.helper:         State (newValue, Deleted):  0
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/home/n8xpress/.local/share/wallpapers" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Autumn" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Breath2" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/BytheWater" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Canopee" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Cascade" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Cluster" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/ColdRipple" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/ColorfulCups" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/DarkestHour" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Elarun" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/EveningGlow" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/FallenLeaf" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Flow" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/FlyingKonqui" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Grey" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/IceCold" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Kite" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Kokkini" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Next" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/OneStandsOut" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Opal" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/PastelHills" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Path" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/SafeLanding" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/summer_1am" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Volna" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/manjaro-wallpapers-18.0" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/wallpapers-2018" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/wallpapers-juhraya" is a directory. Use addDir!
Dez 14 09:25:51 gunship kscreenlocker_greet[17945]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "de_DE" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Dez 14 09:48:41 gunship plasmashell[1185]: libkcups: Renew-Subscription last error: 0 successful-ok
Dez 14 10:00:01 gunship CROND[27866]: (root) CMD (timeshift --check --scripted)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT ((process:27866): GLib-GIO-CRITICAL **: 10:00:02.031: g_file_get_path: assertion 'G_IS_FILE (file)' failed)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT ()
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (** (process:27866): CRITICAL **: 10:00:02.031: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (** (process:27866): CRITICAL **: 10:00:02.031: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Using system disk as snapshot device for creating snapshots in BTRFS mode)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (/dev/dm-0 is mounted at: /run/timeshift/backup, options: rw,relatime,compress=zstd:3,ssd,space_cache,commit=120,subvolid=5,subvol=/)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Boot snapshots are enabled)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Last boot snapshot is 1 hours old)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Daily snapshots are enabled)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Last daily snapshot is 12 hours old)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Weekly snapshots are enabled)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Last weekly snapshot is 1 days old)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Monthly snapshot are enabled)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (Last monthly snapshot is 9 days old)
Dez 14 10:00:02 gunship CROND[27865]: (root) CMDOUT (------------------------------------------------------------------------------)
Dez 14 10:00:02 gunship crontab[27923]: (root) LIST (root)
Dez 14 10:00:02 gunship crontab[27924]: (root) LIST (root)
Dez 14 11:04:42 gunship kernel: ata1.00: exception Emask 0x50 SAct 0x4000 SErr 0x40c0800 action 0xe frozen
Dez 14 11:04:42 gunship kernel: ata1.00: irq_stat 0x00000040, connection status changed
Dez 14 11:04:42 gunship kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
Dez 14 11:04:42 gunship kernel: ata1.00: failed command: READ FPDMA QUEUED
Dez 14 11:04:42 gunship kernel: ata1.00: cmd 60/20:70:c0:75:ec/00:00:18:00:00/40 tag 14 ncq dma 16384 in
Dez 14 11:04:42 gunship kernel: ata1.00: status: { DRDY }
Dez 14 11:04:42 gunship kernel: ata1: hard resetting link
Dez 14 11:04:42 gunship kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dez 14 11:04:42 gunship kernel: ata1.00: configured for UDMA/133
Dez 14 11:04:42 gunship kernel: ahci 0000:00:1f.2: port does not support device sleep
Dez 14 11:04:42 gunship kernel: ata1: EH complete
Dez 14 11:45:21 gunship plasmashell[1185]: libkcups: Renew-Subscription last error: 0 successful-ok
Dez 14 12:08:10 gunship kernel: ata1.00: exception Emask 0x50 SAct 0x70000007 SErr 0x40c0800 action 0xe frozen
Dez 14 12:08:10 gunship kernel: ata1.00: irq_stat 0x00000040, connection status changed
Dez 14 12:08:10 gunship kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
Dez 14 12:08:10 gunship kernel: ata1.00: failed command: WRITE FPDMA QUEUED
Dez 14 12:08:10 gunship kernel: ata1.00: cmd 61/08:00:c0:5a:4b/00:00:02:00:00/40 tag 0 ncq dma 4096 out
Dez 14 12:08:10 gunship kernel: ata1.00: status: { DRDY }
Dez 14 12:08:10 gunship kernel: ata1.00: cmd 61/08:08:58:5b:4b/00:00:02:00:00/40 tag 1 ncq dma 4096 out
Dez 14 12:08:10 gunship kernel: ata1.00: cmd 61/08:10:a0:5b:4b/00:00:02:00:00/40 tag 2 ncq dma 4096 out
Dez 14 12:08:10 gunship kernel: ata1.00: cmd 61/08:e0:f8:59:4b/00:00:02:00:00/40 tag 28 ncq dma 4096 out
Dez 14 12:08:10 gunship kernel: ata1.00: cmd 61/08:e8:58:5a:4b/00:00:02:00:00/40 tag 29 ncq dma 4096 out
Dez 14 12:08:10 gunship kernel: ata1.00: cmd 61/08:f0:b0:5a:4b/00:00:02:00:00/40 tag 30 ncq dma 4096 out
Dez 14 12:08:10 gunship kernel: ata1: hard resetting link
Dez 14 12:08:10 gunship kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dez 14 12:08:10 gunship kernel: ata1.00: configured for UDMA/133
Dez 14 12:08:10 gunship kernel: ahci 0000:00:1f.2: port does not support device sleep
Dez 14 12:08:10 gunship kernel: ata1: EH complete
Dez 14 14:00:01 gunship CROND[97697]: (root) CMD (timeshift --check --scripted)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT ((process:97697): GLib-GIO-CRITICAL **: 14:00:01.626: g_file_get_path: assertion 'G_IS_FILE (file)' failed)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT ()
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (** (process:97697): CRITICAL **: 14:00:01.627: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (** (process:97697): CRITICAL **: 14:00:01.627: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Using system disk as snapshot device for creating snapshots in BTRFS mode)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (/dev/dm-0 is mounted at: /run/timeshift/backup, options: rw,relatime,compress=zstd:3,ssd,space_cache,commit=120,subvolid=5,subvol=/)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Boot snapshots are enabled)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Last boot snapshot is 5 hours old)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Daily snapshots are enabled)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Last daily snapshot is 15 hours old)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Weekly snapshots are enabled)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Last weekly snapshot is 1 days old)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Monthly snapshot are enabled)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (Last monthly snapshot is 10 days old)
Dez 14 14:00:01 gunship CROND[97696]: (root) CMDOUT (------------------------------------------------------------------------------)
Dez 14 14:00:02 gunship crontab[97754]: (root) LIST (root)
Dez 14 14:00:02 gunship crontab[97755]: (root) LIST (root)
Dez 14 14:01:01 gunship CROND[98043]: (root) CMD (run-parts /etc/cron.hourly)
Dez 14 14:33:11 gunship kscreen_backend_launcher[1196]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
Dez 14 14:33:11 gunship kscreen_backend_launcher[1196]: kscreen.xcb.helper:         Output:  67
Dez 14 14:33:11 gunship kscreen_backend_launcher[1196]: kscreen.xcb.helper:         Property:  Backlight
Dez 14 14:33:11 gunship kscreen_backend_launcher[1196]: kscreen.xcb.helper:         State (newValue, Deleted):  0
(multiple)
Dez 14 14:33:15 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39498, resource id: 85983276, major code: 18 (ChangeProperty), minor code: 0
Dez 14 14:35:04 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 14:35:05 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59388, resource id: 14694829, major code: 20 (GetProperty), minor code: 0
Dez 14 14:39:21 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 14:40:21 gunship plasmashell[1185]: libkcups: Renew-Subscription last error: 0 successful-ok
Dez 14 14:43:09 gunship systemmonitor[110656]: QProcess: Destroyed while process ("/usr/lib/ksysguard/ksgrd_network_helper") is still running.
Dez 14 14:43:09 gunship systemmonitor[110656]: org.kde.ksysguard.plugin.network: Helper process terminated abnormally!
Dez 14 14:43:09 gunship systemmonitor[110656]: org.kde.ksysguard.plugin.network: ""
Dez 14 14:43:10 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4307, resource id: 88080442, major code: 18 (ChangeProperty), minor code: 0
Dez 14 14:43:10 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4352, resource id: 14730713, major code: 3 (GetWindowAttributes), minor code: 0
Dez 14 14:43:10 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4353, resource id: 14730713, major code: 14 (GetGeometry), minor code: 0
Dez 14 14:43:10 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4363, resource id: 14730713, major code: 2 (ChangeWindowAttributes), minor code: 0
Dez 14 14:44:06 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 14:44:23 gunship polkitd[478]: Registered Authentication Agent for unix-process:111609:2477589 (system bus name :1.1526 [/sbin/flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Dez 14 14:44:24 gunship polkitd[478]: Unregistered Authentication Agent for unix-process:111609:2477589 (system bus name :1.1526, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Dez 14 14:44:45 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 14:45:20 gunship dbus-daemon[1078]: [session uid=1000 pid=1078] Activating service name='org.kde.krunner' requested by ':1.79' (uid=1000 pid=111925 comm="dbus-send --type=method_call --dest=org.kde.krunne")
Dez 14 14:45:22 gunship dbus-daemon[1078]: [session uid=1000 pid=1078] Successfully activated service 'org.kde.krunner'
Dez 14 14:45:23 gunship krunner[111933]: Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
Dez 14 14:45:24 gunship krunner[111933]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 14:45:24 gunship krunner[111933]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/runcommand/RunCommand.qml:41:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 15:08:36 gunship plasmashell[1185]: Using QByteRef with an index pointing outside the valid range of a QByteArray. The corresponding behavior is deprecated, and will be changed in a future version of Qt.
Dez 14 15:08:57 gunship dolphin[120210]: kf.kio.core: "Could not enter folder tags:/."
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1886680168
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 791624307
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1970433894
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1634545261
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1918986862
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1919889007
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 796143463
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1986817907
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1882023013
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1836278124
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1701344097
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1630366828
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 2016240750
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 761754223
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1751607656
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1970299693
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 1634956589
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 875521383
Dez 14 15:09:37 gunship plasmashell[1185]: qt.qpa.xcb: atomName: bad atom 943207216
Dez 14 15:09:58 gunship plasmashell[1185]: Using QByteRef with an index pointing outside the valid range of a QByteArray. The corresponding behavior is deprecated, and will be changed in a future version of Qt.
Dez 14 15:10:00 gunship systemd[1056]: Started Dolphin - Dateiverwaltung.
Dez 14 15:12:02 gunship audit[121408]: USER_AUTH pid=121408 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="n8xpress" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:02 gunship kernel: audit: type=1100 audit(1607955122.862:118): pid=121408 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="n8xpress" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:02 gunship dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.2144' (uid=0 pid=121408 comm="sudo dmesg -l emerg,alert,crit,err,warn ")
Dez 14 15:12:02 gunship dbus-daemon[473]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Dez 14 15:12:02 gunship sudo[121408]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Dez 14 15:12:03 gunship kernel: audit: type=1101 audit(1607955122.952:119): pid=121408 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="n8xpress" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:03 gunship kernel: audit: type=1110 audit(1607955122.952:120): pid=121408 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:03 gunship kernel: audit: type=1105 audit(1607955122.962:121): pid=121408 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:02 gunship audit[121408]: USER_ACCT pid=121408 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="n8xpress" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:02 gunship audit[121408]: CRED_REFR pid=121408 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:02 gunship audit[121408]: USER_START pid=121408 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:02 gunship sudo[121408]: n8xpress : TTY=pts/7 ; PWD=/home/n8xpress ; USER=root ; COMMAND=/usr/bin/dmesg -l emerg,alert,crit,err,warn
Dez 14 15:12:02 gunship sudo[121408]: pam_unix(sudo:session): session opened for user root(uid=0) by n8xpress(uid=0)
Dez 14 15:12:03 gunship sudo[121408]: pam_unix(sudo:session): session closed for user root
Dez 14 15:12:03 gunship audit[121408]: USER_END pid=121408 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:03 gunship audit[121408]: CRED_DISP pid=121408 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:03 gunship kernel: audit: type=1106 audit(1607955123.102:122): pid=121408 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:03 gunship kernel: audit: type=1104 audit(1607955123.102:123): pid=121408 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.2148' (uid=0 pid=121553 comm="sudo dmesg ")
Dez 14 15:12:24 gunship dbus-daemon[473]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Dez 14 15:12:24 gunship sudo[121553]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Dez 14 15:12:24 gunship kernel: audit: type=1101 audit(1607955144.569:124): pid=121553 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="n8xpress" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship kernel: audit: type=1110 audit(1607955144.572:125): pid=121553 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship kernel: audit: type=1105 audit(1607955144.575:126): pid=121553 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship kernel: audit: type=1106 audit(1607955144.625:127): pid=121553 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship kernel: audit: type=1104 audit(1607955144.625:128): pid=121553 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship audit[121553]: USER_ACCT pid=121553 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="n8xpress" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship audit[121553]: CRED_REFR pid=121553 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship audit[121553]: USER_START pid=121553 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship audit[121553]: USER_END pid=121553 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship audit[121553]: CRED_DISP pid=121553 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/7 res=success'
Dez 14 15:12:24 gunship sudo[121553]: n8xpress : TTY=pts/7 ; PWD=/home/n8xpress ; USER=root ; COMMAND=/usr/bin/dmesg
Dez 14 15:12:24 gunship sudo[121553]: pam_unix(sudo:session): session opened for user root(uid=0) by n8xpress(uid=0)
Dez 14 15:12:24 gunship sudo[121553]: pam_unix(sudo:session): session closed for user root
Dez 14 15:14:09 gunship kwin_x11[1138]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 15:14:11 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13053, resource id: 14723814, major code: 20 (GetProperty), minor code: 0
Dez 14 18:05:56 gunship audit[179943]: USER_AUTH pid=179943 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="n8xpress" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Dez 14 18:05:56 gunship kernel: audit: type=1100 audit(1607965556.002:141): pid=179943 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="n8xpress" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Dez 14 18:05:56 gunship kscreenlocker_greet[124342]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property 'width' of null
Dez 14 18:05:56 gunship kwin_x11[1138]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19836, resource id: 92274732, major code: 18 (ChangeProperty), minor code: 0
Dez 14 18:08:35 gunship dbus-daemon[1078]: [session uid=1000 pid=1078] Activating service name='org.kde.runners.baloo' requested by ':1.80' (uid=1000 pid=111933 comm="/usr/bin/krunner ")
Dez 14 18:08:35 gunship krunner[111933]: QObject::connect: Cannot queue arguments of type 'Consumer::ServiceStatus'
                                         (Make sure 'Consumer::ServiceStatus' is registered using qRegisterMetaType().)
Dez 14 18:08:36 gunship dbus-daemon[1078]: [session uid=1000 pid=1078] Activated service 'org.kde.runners.baloo' failed: Process org.kde.runners.baloo exited with status 255
Dez 14 18:08:36 gunship krunner[111933]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 18:08:36 gunship krunner[111933]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship krunner[111933]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
Dez 14 18:08:36 gunship dbus-daemon[1078]: [session uid=1000 pid=1078] Activating service name='org.kde.runners.baloo' requested by ':1.80' (uid=1000 pid=111933 comm="/usr/bin/krunner ")
#sed -e “s/$HOSTNAME/HOST/gI” -e “s/$USER/USER/gI” < plasmashell-error-report >plasmashell-error_report
Yes, there was and indeed for that particular case has been fixed. What you have to find out is if it’s really a leak and the leak is in plasmashell. I had one report that’s actually in the graphics card driver, but I can only see plasmashell because it’s the one utilizing the driver.
To be sure, is it keep increasing to the point you’re out of RAM and it starts swapping? Or it’s going up and down accordingly? Remember that plasma does caching for speed reason. It’s hard to get the free RAM value you have on start vs after you open and work on several apps then close them all. Plasma won’t just free the memory those apps have used. I don’t know if this behavior is user controllable, but what I know is it’s the default.
For the kde-dev/git issue of my linked post could pretty quickly be seen from something like this:
pacman -Qqs '\-git'
If you see a lot of kde related packages that are git versions (ex - plasma-workspace-git) then thats the same issue and you should use the mentioned script.
I confirm the problem is still there for me.
I think it could be a good idea if there was a daemon which supervised hourly if plasmashell memory has increased abnormally, and reset it if it was the case.
The commands for restart are:
killall plasmashell; plasmashell > /dev/null 2>&1 & disown
it definetly goes that far up to swapping, filling lots of swap space.
I have
$ pacman -Qqs '\-git'
attica-git
karchive-git
kauth-git
kbookmarks-git
kcodecs-git
kcompletion-git
kconfig-git
kconfigwidgets-git
kcoreaddons-git
kcrash-git
kdbusaddons-git
kglobalaccel-git
kguiaddons-git
ki18n-git
kiconthemes-git
kio-git
kitemviews-git
kjobwidgets-git
knotifications-git
kservice-git
ktextwidgets-git
kwallet-git
kwidgetsaddons-git
kwindowsystem-git
kxmlgui-git
solid-git
sonnet-git
user-manager-git
Then you should follow the suggestions and use the script at the bottom of the first post of the nibia thread.
instead of sending plasmashell output to nirvana, I had the idea to run plasmashell in a shell (no pun intended, but nice… :slight_smile: )
$ plasmashell
kf.plasma.quick: Applet preload policy set to 1
trying to show an empty dialog
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
kf.coreaddons: KDirWatch: "/home/_USER_/.local/share/wallpapers" is a directory. Use addDir!
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Both point size and pixel size set. Using pixel size.
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:302:13: QML PropertyChanges: Cannot assign to non-existent property "font.minimumPixelSize"
Entry is not valid "kontact.desktop" QSharedPointer(0x556e0960f070)
Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x556e0963d7a0)
Entry is not valid "org.kde.discover" QSharedPointer(0x556e0960f0c0)
Entry is not valid "kontact.desktop" QSharedPointer(0x556e0963da40)
Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x556e0960ecd0)
Entry is not valid "org.kde.discover" QSharedPointer(0x556e0960ed20)
file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumHeight"
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:73:5: QML Binding: Not restoring previous value because restoreMode has not been set.
This behavior is deprecated.
You have to import QtQml 2.15 after any QtQuick imports and set
the restoreMode of the binding to fix this warning.
In Qt < 6.0 the default is Binding.RestoreBinding.
In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:89:5: QML Binding: Not restoring previous value because restoreMode has not been set.
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:66:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Error: cannot change the containment to AppletsLayout
Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader
libkcups: CUPS-Get-Printers last error: 0 successful-ok
libkcups: Get-Jobs last error: 0 successful-ok
libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
file:///usr/lib/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:53:5: Unable to assign [undefined] to int
Plasma Shell startup completed
libkcups: 3 "Leer-Kyocera-FS-920"
libkcups: 0
libkcups: 0
file:///usr/lib/qt/qml/org/kde/plasma/components.3/ComboBox.qml:74:9: Unable to assign [undefined] to QQmlComponent*
thank you very much! that fixed it for me.
That also fixed a problem of a flickering start menu that seemed to reload so quickly that I could not start a submenu entry.
