here’s latest xorg.0.log:
[ 23.590] (--) Log file renamed from "/var/log/Xorg.pid-1972.log" to "/var/log/Xorg.0.log"
[ 23.590]
X.Org X Server 1.20.10
[ 23.590] Build Operating System: Linux Manjaro Linux
[ 23.590] Current Operating System: Linux Razinal-NB 5.11.0-1-MANJARO #1 SMP PREEMPT Mon Jan 4 05:04:59 UTC 2021 x86_64
[ 23.590] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.11-x86_64 root=UUID=f6749f9b-1222-4b2c-bfe1-fe7173bb2fd9 ro rootflags=subvol=@ quiet udev.log_priority=3 resume=/dev/disk/by-uuid/6cb04bf1-ed5f-4c06-979f-e7c8b710f4b1
[ 23.590] Build Date: 16 December 2020 10:33:32PM
[ 23.590]
[ 23.590] Current version of pixman: 0.40.0
[ 23.590] Before reporting problems, check http://wiki.x.org
[ 23.590] Markers: (--) probed, (**) from config file, (==) default setting,
[ 23.590] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 10 07:59:21 2021
[ 23.591] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 23.591] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 23.591] (==) ServerLayout "layout"
[ 23.591] (**) |-->Screen "nvidia" (0)
[ 23.591] (**) | |-->Monitor "<default monitor>"
[ 23.591] (**) | |-->Device "nvidia"
[ 23.591] (==) No monitor specified for screen "nvidia".
[ 23.591] (==) Automatically adding devices
[ 23.591] (==) Automatically enabling devices
[ 23.591] (==) Automatically adding GPU devices
[ 23.591] (==) Automatically binding GPU devices
[ 23.591] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 23.591] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 23.591] Entry deleted from font path.
[ 23.591] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 23.591] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 23.591] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 23.591] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 23.591] (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/nvidia"
[ 23.591] (II) The server relies on udev to provide the list of input devices.
[ 23.591] (II) Module ABI versions:
[ 23.591] X.Org ANSI C Emulation: 0.4
[ 23.591] X.Org Video Driver: 24.1
[ 23.591] X.Org XInput driver : 24.1
[ 23.591] X.Org Server Extension : 10.0
[ 23.592] (++) using VT number 1
[ 23.592] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 23.592] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 23.602] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 23.603] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/nvidia"
[ 23.603] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/nvidia"
[ 23.757] (--) PCI:*(0@0:2:0) 8086:1616:1025:098a rev 9, Mem @ 0xc2000000/16777216, 0xd0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 23.757] (--) PCI: (4@0:0:0) 10de:1347:1025:098c rev 162, Mem @ 0xc3000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x00003000/128
[ 23.757] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 23.757] (II) LoadModule: "glx"
[ 23.757] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 23.758] (II) Module glx: vendor="X.Org Foundation"
[ 23.758] compiled for 1.20.10, module version = 1.0.0
[ 23.758] ABI class: X.Org Server Extension, version 10.0
[ 23.758] (II) LoadModule: "nvidia"
[ 23.758] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 23.759] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 23.759] compiled for 1.6.99.901, module version = 1.0.0
[ 23.759] Module class: X.Org Video Driver
[ 23.759] (II) NVIDIA dlloader X Driver 460.32.03 Sun Dec 27 18:56:00 UTC 2020
[ 23.759] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 23.759] (II) Loading sub module "fb"
[ 23.759] (II) LoadModule: "fb"
[ 23.759] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 23.759] (II) Module fb: vendor="X.Org Foundation"
[ 23.759] compiled for 1.20.10, module version = 1.0.0
[ 23.759] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.759] (II) Loading sub module "wfb"
[ 23.759] (II) LoadModule: "wfb"
[ 23.759] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 23.759] (II) Module wfb: vendor="X.Org Foundation"
[ 23.760] (II) Loading sub module "ramdac"
[ 23.760] (II) LoadModule: "ramdac"
[ 23.760] (II) Module "ramdac" already built-in
[ 23.760] (EE) No devices detected.
[ 23.760] (EE)
Fatal server error:
[ 23.760] (EE) no screens found(EE)
[ 23.760] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 23.760] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 23.760] (EE)
[ 23.760] (EE) Server terminated with error (1). Closing log file.
