[Solved] Fresh installation has poor performance
Hello. I have installed Manjaro on my desktop alongside win10 and it has low performance in some apps:
  • Firefox scrolling is very slow; when scrolling a web-page in Firefox, htop sometimes shows up to 80% load of a core;
  • Sometimes SMPlayer freeze system including GUI while sound is still playing;
  • Qt Creator quiet slow but compiling simple app seems fast;
  • Sometimes xfce4-terminal opens with 0.5-1 sec delay;
  • Sublime Text 3 scrolls very slow.
During installation Microsoft EFI partition was of unknown type so I created additional partition and edited efibootmgr to have Manjaro bootloader first, partitions are:
/dev/sda1 - MS reserved partition
/dev/sda2 - Win10
/dev/sda3 - EFI partition created with “boot” flag and mounted in /boot/efi
/dev/sda4 - /
/dev/sda5 - /home
<<< inxi -Fza
System:    Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=8b9fb7be-8931-4c9a-93ef-d351e7854fb6 ro quiet apparmor=1
           Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASRock model: B450 Steel Legend serial: <filter> UEFI: American Megatrends v: P3.20
           date: 11/27/2019
CPU:       Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
           stepping: N/A microcode: 8701013 L2 cache: 3 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86269
           Speed: 2795 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2795 2: 1862 3: 2788 4: 1858 5: 1862
           6: 1862 7: 2795 8: 1861 9: 2792 10: 1858 11: 1857 12: 1860
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics:  Device-1: NVIDIA GK107 [GeForce GTX 650] vendor: Gigabyte driver: nvidia v: 460.32.03
           alternate: nouveau,nvidia_drm bus ID: 09:00.0 chip ID: 10de:0fc6
           Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia display ID: :0.0 screens: 1
           Screen-1: 0 s-res: 3360x1080 s-dpi: 96 s-size: 889x286mm (35.0x11.3") s-diag: 934mm (36.8")
           Monitor-1: VGA-0 res: 1440x900 hz: 60 dpi: 85 size: 428x255mm (16.9x10.0") diag: 498mm (19.6")
           Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 305 size: 160x90mm (6.3x3.5") diag: 184mm (7.2")
           OpenGL: renderer: GeForce GTX 650/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03 direct render: Yes
Audio:     Device-1: NVIDIA GK107 HDMI Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 09:00.1
           chip ID: 10de:0e1b
           Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
           bus ID: 0b:00.4 chip ID: 1022:1487
           Sound Server: ALSA v: k5.9.16-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel port: d000
           bus ID: 08:00.0 chip ID: 10ec:8168
           IF: enp8s0 state: down mac: <filter>
           Device-2: ASUSTek WL-167G v3 802.11n Adapter [Realtek RTL8188SU] type: USB driver: r8712u bus ID: 3-2:3
           chip ID: 0b05:1791 serial: <filter>
           IF: wlp11s0f3u2 state: up mac: <filter>
Drives:    Local Storage: total: 3.86 TiB used: 1.52 TiB (39.4%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37240G size: 223.57 GiB block size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 37R5
           ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB block size:
           physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: SDM1
           ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD20PURZ-85GU6Y0 size: 1.82 TiB block size:
           physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 0A80
           ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB block size:
           physical: 512 B logical: 512 B serial: <filter> rev: 0419
Partition: ID-1: / raw size: 53.71 GiB size: 52.62 GiB (97.96%) used: 10.54 GiB (20.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
           ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%) used: 328 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
           ID-3: /home raw size: 61.92 GiB size: 60.7 GiB (98.02%) used: 45.26 GiB (74.6%) fs: ext4 dev: /dev/sda5
           maj-min: 8:5
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 47.1 C mobo: N/A gpu: nvidia temp: 33 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 48%
Info:      Processes: 281 Uptime: 19h 13m wakeups: 0 Memory: 15.56 GiB used: 2.44 GiB (15.7%) Init: systemd v: 247 Compilers:
           gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1193 lib: 395 flatpak: 0 Shell: Bash v: 5.1.0
           running in: xfce4-terminal inxi: 3.2.02
Hello @mankoon :wink:
This could be related to the gpu driver (acceleration) or you have not much RAM. In case you have not much RAM no swap is there:
That results in slow scrolling and system freezes if the RAM is full. However 16GB RAM should be enough…
It is always good to have at least a swapfile active with some space (about 512MB, 16GB*1.5=24GB are recommend).
What says?
free -h
Also Kernel 5.9 is EOL and already dropped. Switch to 5.10 or stay on 5.4. https://www.kernel.org/
Hi,
I updated kernel to 5.10.7-3, but problems persisted.
free -h
              total        used        free      shared  buff/cache   available
Mem:           15Gi       1,0Gi        13Gi       101Mi       845Mi        14Gi
Swap:            0B          0B          0B
I’m not loading my RAM with anything.
How can I check GPU driver?
@mankoon
I guess it is this problem with older GPUs:
Seems to persist in 460xx according to your experience.
Thanks!
I switched to nouveau and it’s become much better.
