Pcwolf
16 December 2024 18:56
1
Intel AX200 wifi card issue that is undeniable any longer.
I can reproduce at will.
Two desktop systems working under continuous moderate load running F@H 24x7, the wifi connections are trouble free for approximately one day before locking up with red exclamation mark by the taskbar icon. Disconnect and reconnect do nothing; requires a reboot to restore wifi.
This ONLY happens with kernels 6.11 and 6.12. When I boot with kernel 6.6 LTS the wifi will run days/weeks without issue.
I would gladly provide logs or diagnostic data if someone wiser than I would point me in the direction of where to look and what to ask the systems.
Thanks in advance
Rest assured, you’re not the only one experiencing some difficulty with the AX200.
Please monitor the following threads for information that may be relevant:
cscs
17 December 2024 00:19
3
If you dual-boot as in the other thread, then make sure windoze is fully shut down (fast start off).
Otherwise, as usualy, some system info makes sense
inxi -Farz
Pcwolf
17 December 2024 14:49
4
I do have Win11 installed on separate drive. Boot mainly to update anymore, perhaps one or two times a year. Then I ensure a true shutdown and poweroff. But the AX200 Windows power/shutdown issue doesn’t argue against why the problem does not occur while in Manjaro 6.6 boot.
(Thanks to soundofthunder’s first link, I tossed a quick donation to the Manjaro dev team.)
Here is output of inxi -Farz
Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=128a3360-e16a-4c49-a3f3-5b0e910e8385 rw udev.log_priority=3
fbdev=1
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASRock model: B550 Taichi serial: <superuser required>
UEFI: American Megatrends LLC. v: L3.46 date: 08/20/2024
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2200 min/max: 2200/5083 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200 28: 2200
29: 2200 30: 2200 31: 2200 32: 2200 bogomips: 217279
affected
Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: PNY driver: nvidia
v: 550.135 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 ports: active: none off: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 10de:2782
class-ID: 0300
Device-2: NVIDIA AD106 [GeForce RTX 4060 Ti] driver: nvidia v: 550.135
ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 0c:00.0
chip-ID: 10de:2803 class-ID: 0300
Device-3: Alpha Imaging Amcrest AWC5100 USB Webcam
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-3.2.4:14 chip-ID: 114d:8437 class-ID: 0102
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.64x15.43")
s-diag: 804mm (31.65")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: Dell U3219Q
serial: <filter> built: 2020 res: 3840x2160 hz: 60 dpi: 140 gamma: 1.2
size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: nvidia device: 4 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
x11: drv: nvidia inactive: wayland,device-2,device-3
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
memory: 11.71 GiB
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti driver: N/A device-ID: 10de:2782 surfaces: xcb,xlib
device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 4060 Ti driver: N/A
device-ID: 10de:2803 surfaces: N/A
Device-1: NVIDIA AD104 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:22bc class-ID: 0403
Device-2: NVIDIA AD106M High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 0c:00.1
chip-ID: 10de:22bd class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Alpha Imaging Amcrest AWC5100 USB Webcam
API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Info: services: NetworkManager, nfsd, systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:11 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 4.63 TiB used: 117.7 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
model: T-FORCE TM8FP7001T size: 931.51 GiB block-size: physical: 512 B
fw-rev: EGFM13.0 temp: 52.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 46.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD1003FZEX-00MK2A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: TeamGroup model: T-FORCE 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: Portable SSD T5
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 model: N/A size: 58.59 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 3.00 scheme: MBR
ID-1: / raw-size: 64 GiB size: 62.69 GiB (97.96%) used: 40.05 GiB (63.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 308 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 200 GiB size: 195.8 GiB (97.90%)
used: 77.65 GiB (39.7%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 41.5 C mobo: 44.0 C gpu: nvidia temp: 81 C
Fan Speeds (rpm): case-1: 1184 case-2: 2016 fan-1: 0 fan-2: 0 fan-3: 0
fan-4: 0 fan-5: 0 fan-6: 0 fan-7: 0 gpu: nvidia fan: 86%
Power: 12v: 1.84 5v: N/A 3.3v: N/A vbat: 3.28
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1517 libs: 393 tools: pamac,yay
1: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
7: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
8: http://mirror.fcix.net/manjaro/stable/$repo/$arch
Memory: total: 16 GiB available: 15.54 GiB used: 14.51 GiB (93.4%)
Processes: 537 Power: uptime: 23h 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: Bash v: 5.2.37
running-in: yakuake inxi: 3.3.36
While any donations are no doubt appreciated, both thread links given contained possibly relevant information regarding the AX200 Wifi – I hope you scrolled down to find it.
