AX200 WiFi not working
Hi :slight_smile:
I recently installed Manjaro KDE on my Beelink SER8 mini PC. I’m having a few hiccups but am fighting my way through them.
My biggest hurdle at the moment is that WiFi is not working on my Intel AX200 card.
Here are some konsole outputs that I have seen often requested when searching the forums:
If I am interpreting it correctly, the following look incorrect to me.
inxi -Fazy Device-2: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
journalctl -b’ Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0: probe with driver iwlwifi failed with error -110
I have tried using both the linux6.10,13-3 and the linux6.6.54-2 kernels, but no luck on either of them. I am back running 6.11.2-4 as seen in the inxi -Fazy output.
Hopefully that is enough info, I tried to include what seemed to be commonly requested in the threads that I searched.
inxi -Fazy:
  Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=61992ddc-4c45-4fd6-87f1-313868e5556f rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
  Type: Mini-pc Mobo: AZW model: SER8 v: V10 serial: <superuser required>
    part-nu: 75 uuid: <superuser required> UEFI: American Megatrends LLC.
    v: SER8_P5C8V29 date: 08/14/2024
  Info: model: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705205
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1098 min/max: 400/5137 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1098 2: 1098 3: 1098
    4: 1098 5: 1098 6: 1098 7: 1098 8: 1098 9: 1098 10: 1098 11: 1098 12: 1098
    13: 1098 14: 1098 15: 1098 16: 1098 bogomips: 121420
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 driver: amdgpu v: kernel
    arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, DP-4,
    DP-5, DP-6, HDMI-A-1, Writeback-1 bus-ID: c4:00.0 chip-ID: 1002:1900
    class-ID: 0300 temp: 26.0 C
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: DP-1 model: Gigabyte AORUS CV27F serial: <filter> built: 2019
    res: 1920x1080 dpi: 82 gamma: 1.2 size: 595x336mm (23.43x13.23")
    diag: 683mm (26.9") ratio: 16:9 modes: max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.0.1
    gfx1103_r1 LLVM 18.1.8 DRM 3.59 6.11.2-4-MANJARO) device-ID: 1002:1900
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV GFX1103_R1) driver: mesa radv v: 24.2.4-arch1.0.1
    device-ID: 1002:1900 surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: c4:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c4:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    bus-ID: c4:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: HP HyperX Cloud III Wireless
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-1.1.2:6 chip-ID: 03f0:05b7 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-3: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.4:5 chip-ID: 0b95:1790
    class-ID: 0a00 serial: <filter>
  IF: eth0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 931.51 GiB used: 18.5 GiB (2.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 23.9 C
    scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 18.5 GiB (2.0%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 30.0 C mobo: 27.2 C gpu: amdgpu temp: 26.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 28 GiB available: 27.19 GiB used: 2.71 GiB (10.0%)
  Processes: 387 Power: uptime: 0m states: freeze,mem,disk suspend: s2idle
    image: 10.86 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1225 pm: pacman pkgs: 1211 libs: 331 tools: pamac,yay pm: flatpak
    pkgs: 14 Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
journalctl -b.txt:
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0: CSR_RESET = 0x10
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0: Host monitor block 0x0 vector 0x0
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 0]: 0x3f7f8c30
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 1]: 0x3f7f8430
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 2]: 0x3f7f0c30
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 3]: 0x3f7f0430
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 4]: 0x3f7f0030
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 5]: 0x3f7f8830
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 6]: 0x3f7f8830
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 7]: 0x3f7f8830
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 8]: 0x3f7f8030
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 9]: 0x3f7f0830
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 10]: 0x3f7f8c30
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 11]: 0x3f7f8430
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 12]: 0x3f7f8c30
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 13]: 0x3f7f8430
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 14]: 0x3f7f0430
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0: Host monitor block 0x0 vector 0x1
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 0]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 1]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 2]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 3]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 4]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 5]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 6]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 7]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 8]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 9]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 10]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 11]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 12]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 13]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 14]: 0x044466c2
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0: Host monitor block 0x0 vector 0x6
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 0]: 0xf00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 1]: 0xe00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 2]: 0xe00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 3]: 0xa00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 4]: 0xa00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 5]: 0xf00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 6]: 0xb00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 7]: 0xb00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 8]: 0xb00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 9]: 0xf00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 10]: 0xe00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 11]: 0xa00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 12]: 0xa00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 13]: 0xa00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 14]: 0xa00c4471
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0: Host monitor block 0x22 vector 0x0
Oct 11 17:54:33 ser8 kernel: iwlwifi 0000:02:00.0:     value [iter 0]: 0x00000000
mhwd -lh -d
06: PCI 300.0: 0108 Non-Volatile memory controller (NVM Express)
  SysFS ID: /devices/pci0000:00/0000:00:02.4/0000:03:00.0
  SysFS BusID: 0000:03:00.0
  Hardware Class: storage
  Model: "Micron Non-Volatile memory controller"
  Vendor: pci 0x1344 "Micron Technology Inc"
  Device: pci 0x5416
  SubVendor: pci 0x1344 "Micron Technology Inc"
  SubDevice: pci 0x1100
  Revision: 0x01
  Driver: "nvme"
  Driver Modules: "nvme"
  Memory Range: 0xdca00000-0xdca03fff (rw,non-prefetchable)
  IRQ: 50 (no events)
  Module Alias: "pci:v00001344d00005416sv00001344sd00001100bc01sc08i02"
  Driver Info #0:
    Driver Status: nvme is active
    Driver Activation Cmd: "modprobe nvme"
  Attached to: #33 (PCI bridge)
07: PCI 03.1: 0604 PCI bridge (Normal decode)
  SysFS ID: /devices/pci0000:00/0000:00:03.1
  SysFS BusID: 0000:00:03.1
  Hardware Class: bridge
  Model: "AMD PCI bridge"
  Vendor: pci 0x1022 "AMD"
  Device: pci 0x14ef
  SubVendor: pci 0x1022 "AMD"
  SubDevice: pci 0x1453
  Driver: "pcieport"
  IRQ: 41 (no events)
  Module Alias: "pci:v00001022d000014EFsv00001022sd00001453bc06sc04i00"
08: PCI 08.0: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:08.0
  SysFS BusID: 0000:00:08.0
  Model: "AMD Host bridge"
  Device: pci 0x14ea
  Module Alias: "pci:v00001022d000014EAsv00000000sd00000000bc06sc00i00"
09: PCI 18.3: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:18.3
  SysFS BusID: 0000:00:18.3
  Device: pci 0x14f3
  Driver: "k10temp"
  Driver Modules: "k10temp"
  Module Alias: "pci:v00001022d000014F3sv00000000sd00000000bc06sc00i00"
  Driver Info #0:
    Driver Status: k10temp is active
    Driver Activation Cmd: "modprobe k10temp"
10: PCI c400.5: 0480 Multimedia controller
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.5
  SysFS BusID: 0000:c4:00.5
  Hardware Class: unknown
  Model: "AMD Raven/Raven2/FireFlight/Renoir Audio Processor"
  Device: pci 0x15e2 "Raven/Raven2/FireFlight/Renoir Audio Processor"
  SubDevice: pci 0x15e2
  Revision: 0x63
  Driver: "snd_pci_ps"
  Driver Modules: "snd_pci_ps"
  Memory Range: 0xdc580000-0xdc5bffff (rw,non-prefetchable)
  Memory Range: 0x7c10000000-0x7c107fffff (ro,non-prefetchable)
  IRQ: 106 (no events)
  Module Alias: "pci:v00001022d000015E2sv00001022sd000015E2bc04sc80i00"
  Driver Info #0:
    Driver Status: snd_pci_acp3x is active
    Driver Activation Cmd: "modprobe snd_pci_acp3x"
  Driver Info #1:
    Driver Status: snd_rn_pci_acp3x is active
    Driver Activation Cmd: "modprobe snd_rn_pci_acp3x"
  Driver Info #2:
    Driver Status: snd_pci_acp5x is active
    Driver Activation Cmd: "modprobe snd_pci_acp5x"
  Driver Info #3:
    Driver Status: snd_pci_acp6x is active
    Driver Activation Cmd: "modprobe snd_pci_acp6x"
  Driver Info #4:
    Driver Status: snd_acp_pci is active
    Driver Activation Cmd: "modprobe snd_acp_pci"
  Driver Info #5:
    Driver Status: snd_rpl_pci_acp6x is active
    Driver Activation Cmd: "modprobe snd_rpl_pci_acp6x"
  Driver Info #6:
    Driver Status: snd_pci_ps is active
    Driver Activation Cmd: "modprobe snd_pci_ps"
  Driver Info #7:
    Driver Status: snd_sof_amd_renoir is active
    Driver Activation Cmd: "modprobe snd_sof_amd_renoir"
  Driver Info #8:
    Driver Status: snd_sof_amd_rembrandt is active
    Driver Activation Cmd: "modprobe snd_sof_amd_rembrandt"
  Driver Info #9:
    Driver Status: snd_sof_amd_vangogh is active
    Driver Activation Cmd: "modprobe snd_sof_amd_vangogh"
  Driver Info #10:
    Driver Status: snd_sof_amd_acp63 is active
    Driver Activation Cmd: "modprobe snd_sof_amd_acp63"
  Attached to: #26 (PCI bridge)
11: PCI c500.1: 1180 Signal processing controller
  SysFS ID: /devices/pci0000:00/0000:00:08.2/0000:c5:00.1
  SysFS BusID: 0000:c5:00.1
  Model: "AMD Signal processing controller"
  Device: pci 0x1502
  SubDevice: pci 0x1502
  Memory Range: 0xdc900000-0xdc97ffff (rw,non-prefetchable,disabled)
  Memory Range: 0xdc9c0000-0xdc9c1fff (rw,non-prefetchable,disabled)
  Memory Range: 0x7c10900000-0x7c1093ffff (ro,non-prefetchable,disabled)
  Memory Range: 0xdc980000-0xdc9bffff (rw,non-prefetchable,disabled)
  IRQ: 255 (no events)
  Module Alias: "pci:v00001022d00001502sv00001022sd00001502bc11sc80i00"
  Attached to: #45 (PCI bridge)
12: PCI 18.1: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:18.1
  SysFS BusID: 0000:00:18.1
  Device: pci 0x14f1
  Module Alias: "pci:v00001022d000014F1sv00000000sd00000000bc06sc00i00"
13: PCI 200.0: 0280 Network controller
  SysFS ID: /devices/pci0000:00/0000:00:02.2/0000:02:00.0
  SysFS BusID: 0000:02:00.0
  Hardware Class: network
  Model: "Intel Wi-Fi 6 AX200NGW"
  Vendor: pci 0x8086 "Intel Corporation"
  Device: pci 0x2723 "Wi-Fi 6 AX200"
  SubVendor: pci 0x8086 "Intel Corporation"
  SubDevice: pci 0x0084 "Wi-Fi 6 AX200NGW"
  Revision: 0x1a
  Memory Range: 0xdcb00000-0xdcb03fff (rw,non-prefetchable)
  IRQ: 52 (no events)
  Module Alias: "pci:v00008086d00002723sv00008086sd00000084bc02sc80i00"
  Driver Info #0:
    Driver Status: iwlwifi is active
    Driver Activation Cmd: "modprobe iwlwifi"
  Attached to: #38 (PCI bridge)
14: PCI 01.0: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:01.0
  SysFS BusID: 0000:00:01.0
  Device: pci 0x14ea
15: PCI c400.3: 0c03 USB Controller (XHCI)
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3
  SysFS BusID: 0000:c4:00.3
  Hardware Class: usb controller
  Model: "AMD USB Controller"
  Device: pci 0x15b9
  SubDevice: pci 0x15b9
  Driver: "xhci_hcd"
  Driver Modules: "xhci_pci"
  Memory Range: 0xdc300000-0xdc3fffff (rw,non-prefetchable)
  IRQ: 46 (no events)
  Module Alias: "pci:v00001022d000015B9sv00001022sd000015B9bc0Csc03i30"
  Driver Info #0:
    Driver Status: xhci_pci is active
    Driver Activation Cmd: "modprobe xhci_pci"
16: PCI c600.6: 0c03 USB Controller (USB4 Host Interface)
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.6
  SysFS BusID: 0000:c6:00.6
  Device: pci 0x1669
  SubDevice: pci 0x1669
  Driver: "thunderbolt"
  Driver Modules: "thunderbolt"
  Memory Range: 0xdc800000-0xdc87ffff (rw,non-prefetchable)
  IRQ: 102 (no events)
  Module Alias: "pci:v00001022d00001669sv00001022sd00001669bc0Csc03i40"
  Driver Info #0:
    Driver Status: thunderbolt is active
    Driver Activation Cmd: "modprobe thunderbolt"
  Attached to: #23 (PCI bridge)
17: PCI 04.0: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:04.0
  SysFS BusID: 0000:00:04.0
  Device: pci 0x14ea
18: PCI 14.3: 0601 ISA bridge
  SysFS ID: /devices/pci0000:00/0000:00:14.3
  SysFS BusID: 0000:00:14.3
  Model: "AMD FCH LPC Bridge"
  Device: pci 0x790e "FCH LPC Bridge"
  SubDevice: pci 0x790e
  Revision: 0x51
  Module Alias: "pci:v00001022d0000790Esv00001022sd0000790Ebc06sc01i00"
19: PCI c400.1: 0403 Audio device
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.1
  SysFS BusID: 0000:c4:00.1
  Hardware Class: sound
  Model: "ATI Audio device"
  Vendor: pci 0x1002 "ATI Technologies Inc"
  Device: pci 0x1640
  SubVendor: pci 0x1002 "ATI Technologies Inc"
  SubDevice: pci 0x1640
  Driver: "snd_hda_intel"
  Driver Modules: "snd_hda_intel"
  Memory Range: 0xdc5c8000-0xdc5cbfff (rw,non-prefetchable)
  IRQ: 110 (326 events)
  Module Alias: "pci:v00001002d00001640sv00001002sd00001640bc04sc03i00"
  Driver Info #0:
    Driver Status: snd_hda_intel is active
    Driver Activation Cmd: "modprobe snd_hda_intel"
20: PCI 100.0: 0200 Ethernet controller
  SysFS ID: /devices/pci0000:00/0000:00:01.4/0000:01:00.0
  SysFS BusID: 0000:01:00.0
  Model: "Realtek RTL8125 2.5GbE Controller"
  Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
  Device: pci 0x8125 "RTL8125 2.5GbE Controller"
  SubVendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
  SubDevice: pci 0x0123
  Revision: 0x05
  Driver: "r8169"
  Driver Modules: "r8169"
  Device File: enp1s0
  I/O Ports: 0xf000-0xf0ff (rw)
  Memory Range: 0xdcc00000-0xdcc0ffff (rw,non-prefetchable)
  Memory Range: 0xdcc10000-0xdcc13fff (rw,non-prefetchable)
  IRQ: 73 (no events)
  HW Address: 70:70:fc:07:34:45
  Permanent HW Address: 70:70:fc:07:34:45
  Link detected: yes
  Module Alias: "pci:v000010ECd00008125sv000010ECsd00000123bc02sc00i00"
  Driver Info #0:
    Driver Status: r8169 is active
    Driver Activation Cmd: "modprobe r8169"
  Attached to: #47 (PCI bridge)
21: PCI c600.4: 0c03 USB Controller (XHCI)
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.4
  SysFS BusID: 0000:c6:00.4
  Device: pci 0x15c1
  SubDevice: pci 0x15c1
  Driver: "xhci_hcd"
  Memory Range: 0xdc600000-0xdc6fffff (rw,non-prefetchable)
  IRQ: 54 (no events)
  Module Alias: "pci:v00001022d000015C1sv00001022sd000015C1bc0Csc03i30"
  Driver Info #0:
22: PCI 00.2: 0806 IOMMU
  SysFS ID: /devices/pci0000:00/0000:00:00.2
  SysFS BusID: 0000:00:00.2
  Model: "AMD IOMMU"
  Device: pci 0x14e9
  SubDevice: pci 0x14e9
  IRQ: 25 (no events)
  Module Alias: "pci:v00001022d000014E9sv00001022sd000014E9bc08sc06i00"
23: PCI 08.3: 0604 PCI bridge (Normal decode)
  SysFS BusID: 0000:00:08.3
  Device: pci 0x14eb
  SubDevice: pci 0x14eb
  Driver: "pcieport"
  IRQ: 45 (no events)
  Module Alias: "pci:v00001022d000014EBsv00001022sd000014EBbc06sc04i00"
24: PCI 18.6: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:18.6
  SysFS BusID: 0000:00:18.6
  Device: pci 0x14f6
  Module Alias: "pci:v00001022d000014F6sv00000000sd00000000bc06sc00i00"
25: PCI 00.0: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:00.0
  SysFS BusID: 0000:00:00.0
  Device: pci 0x14e8
  SubDevice: pci 0x14e8
  Module Alias: "pci:v00001022d000014E8sv00001022sd000014E8bc06sc00i00"
26: PCI 08.1: 0604 PCI bridge (Normal decode)
  SysFS BusID: 0000:00:08.1
  Device: pci 0x14eb
  Driver: "pcieport"
  IRQ: 43 (5 events)
27: PCI 18.4: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:18.4
  SysFS BusID: 0000:00:18.4
  Device: pci 0x14f4
  Module Alias: "pci:v00001022d000014F4sv00000000sd00000000bc06sc00i00"
28: PCI c600.0: 1300 Non-Essential Instrumentation
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.0
  SysFS BusID: 0000:c6:00.0
  Model: "AMD Non-Essential Instrumentation"
  Device: pci 0x14ec
  SubDevice: pci 0x14ec
  Module Alias: "pci:v00001022d000014ECsv00001022sd000014ECbc13sc00i00"
29: PCI 03.0: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:03.0
  SysFS BusID: 0000:00:03.0
  Device: pci 0x14ea
30: PCI c400.6: 0403 Audio device
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.6
  SysFS BusID: 0000:c4:00.6
  Device Name: "Realtek ALC256"
  Model: "AMD Family 17h (Models 10h-1fh) HD Audio Controller"
  Device: pci 0x15e3 "Family 17h (Models 10h-1fh) HD Audio Controller"
  SubVendor: pci 0x1f66
  SubDevice: pci 0x0202
  Memory Range: 0xdc5c0000-0xdc5c7fff (rw,non-prefetchable)
  IRQ: 113 (2411 events)
  Module Alias: "pci:v00001022d000015E3sv00001F66sd00000202bc04sc03i00"
  Driver Info #0:
31: PCI 18.2: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:18.2
  SysFS BusID: 0000:00:18.2
  Device: pci 0x14f2
  Module Alias: "pci:v00001022d000014F2sv00000000sd00000000bc06sc00i00"
32: PCI c400.4: 0c03 USB Controller (XHCI)
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.4
  SysFS BusID: 0000:c4:00.4
  Device: pci 0x15ba
  Driver: "xhci_hcd"
  Memory Range: 0xdc200000-0xdc2fffff (rw,non-prefetchable)
  IRQ: 48 (no events)
  Module Alias: "pci:v00001022d000015BAsv00001022sd000015B9bc0Csc03i30"
  Driver Info #0:
33: PCI 02.4: 0604 PCI bridge (Normal decode)
  SysFS BusID: 0000:00:02.4
  Device: pci 0x14ee
  Driver: "pcieport"
  IRQ: 40 (no events)
  Module Alias: "pci:v00001022d000014EEsv00001022sd00001453bc06sc04i00"
34: PCI c500.0: 1300 Non-Essential Instrumentation
  SysFS ID: /devices/pci0000:00/0000:00:08.2/0000:c5:00.0
  SysFS BusID: 0000:c5:00.0
  Device: pci 0x14ec
35: PCI 18.0: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:18.0
  SysFS BusID: 0000:00:18.0
  Device: pci 0x14f0
  Module Alias: "pci:v00001022d000014F0sv00000000sd00000000bc06sc00i00"
36: PCI 04.1: 0604 PCI bridge (Normal decode)
  SysFS ID: /devices/pci0000:00/0000:00:04.1
  SysFS BusID: 0000:00:04.1
  Device: pci 0x14ef
  Driver: "pcieport"
  IRQ: 42 (no events)
37: PCI c400.2: 1080 Encryption controller
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.2
  SysFS BusID: 0000:c4:00.2
  Model: "AMD Encryption controller"
  Device: pci 0x15c7
  SubDevice: pci 0x15c7
  Driver: "ccp"
  Driver Modules: "ccp"
  Memory Range: 0xdc400000-0xdc4fffff (rw,non-prefetchable)
  Memory Range: 0xdc5cc000-0xdc5cdfff (rw,non-prefetchable)
  IRQ: 73 (no events)
  Module Alias: "pci:v00001022d000015C7sv00001022sd000015C7bc10sc80i00"
  Driver Info #0:
    Driver Status: ccp is active
    Driver Activation Cmd: "modprobe ccp"
38: PCI 02.2: 0604 PCI bridge (Normal decode)
  SysFS BusID: 0000:00:02.2
  Device: pci 0x14ee
  Driver: "pcieport"
  IRQ: 39 (no events)
39: PCI c600.5: 0c03 USB Controller (USB4 Host Interface)
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.5
  SysFS BusID: 0000:c6:00.5
  Device: pci 0x1668
  SubDevice: pci 0x1668
  Memory Range: 0xdc880000-0xdc8fffff (rw,non-prefetchable)
  IRQ: 76 (no events)
  Module Alias: "pci:v00001022d00001668sv00001022sd00001668bc0Csc03i40"
  Driver Info #0:
40: PCI c400.0: 0300 VGA compatible controller (VGA)
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.0
  SysFS BusID: 0000:c4:00.0
  Hardware Class: graphics card
  Model: "ATI VGA compatible controller"
  Device: pci 0x1900
  SubDevice: pci 0x0031
  Revision: 0xc5
  Driver: "amdgpu"
  Driver Modules: "amdgpu"
  Memory Range: 0x7c00000000-0x7c0fffffff (ro,non-prefetchable)
  Memory Range: 0xdc000000-0xdc1fffff (ro,non-prefetchable)
  I/O Ports: 0xe000-0xe0ff (rw)
  Memory Range: 0xdc500000-0xdc57ffff (rw,non-prefetchable)
  IRQ: 48 (no events)
  Module Alias: "pci:v00001002d00001900sv00001F66sd00000031bc03sc00i00"
  Driver Info #0:
    Driver Status: amdgpu is active
    Driver Activation Cmd: "modprobe amdgpu"
41: PCI 02.0: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:02.0
  SysFS BusID: 0000:00:02.0
  Device: pci 0x14ea
42: PCI 18.7: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:18.7
  SysFS BusID: 0000:00:18.7
  Device: pci 0x14f7
  Module Alias: "pci:v00001022d000014F7sv00000000sd00000000bc06sc00i00"
43: PCI c600.3: 0c03 USB Controller (XHCI)
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.3
  SysFS BusID: 0000:c6:00.3
  Device: pci 0x15c0
  SubDevice: pci 0x15c0
  Driver: "xhci_hcd"
  Memory Range: 0xdc700000-0xdc7fffff (rw,non-prefetchable)
  IRQ: 52 (no events)
  Module Alias: "pci:v00001022d000015C0sv00001022sd000015C0bc0Csc03i30"
  Driver Info #0:
44: PCI 14.0: 0c05 SMBus
  SysFS ID: /devices/pci0000:00/0000:00:14.0
  SysFS BusID: 0000:00:14.0
  Model: "AMD FCH SMBus Controller"
  Device: pci 0x790b "FCH SMBus Controller"
  SubDevice: pci 0x790b
  Revision: 0x71
  Driver: "piix4_smbus"
  Driver Modules: "i2c_piix4"
  Module Alias: "pci:v00001022d0000790Bsv00001022sd0000790Bbc0Csc05i00"
  Driver Info #0:
    Driver Status: i2c_piix4 is active
    Driver Activation Cmd: "modprobe i2c_piix4"
  Driver Info #1:
    Driver Status: sp5100_tco is active
    Driver Activation Cmd: "modprobe sp5100_tco"
45: PCI 08.2: 0604 PCI bridge (Normal decode)
  SysFS BusID: 0000:00:08.2
  Device: pci 0x14eb
  Driver: "pcieport"
  IRQ: 44 (no events)
46: PCI 18.5: 0600 Host bridge
  SysFS ID: /devices/pci0000:00/0000:00:18.5
  SysFS BusID: 0000:00:18.5
  Device: pci 0x14f5
  Module Alias: "pci:v00001022d000014F5sv00000000sd00000000bc06sc00i00"
47: PCI 01.4: 0604 PCI bridge (Normal decode)
  SysFS BusID: 0000:00:01.4
  Device: pci 0x14ee
  Driver: "pcieport"
  IRQ: 38 (no events)
02: SCSI 00.1: 10600 Disk
  SysFS ID: /class/block/sdb
  SysFS BusID: 0:0:0:1
  SysFS Device Link: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb2/2-1/2-1.2/2-1.2:1.0/host0/target0:0:0/0:0:0:1
  Hardware Class: disk
  Model: "Generic MassStorageClass"
  Vendor: usb 0x05e3 "Generic"
  Device: usb 0x0749 "MassStorageClass"
  Revision: "1536"
  Serial ID: "000000001536"
  Driver: "usb-storage", "sd"
  Driver Modules: "usb_storage"
  Device File: /dev/sdb (/dev/sg1)
  Device Files: /dev/sdb, /dev/disk/by-path/pci-0000:c4:00.3-usb-0:1.2:1.0-scsi-0:0:0:1, /dev/disk/by-path/pci-0000:c4:00.3-usbv3-0:1.2:1.0-scsi-0:0:0:1, /dev/disk/by-diskseq/5, /dev/disk/by-id/usb-Generic_MassStorageClass_000000001536-0:1
  Device Number: block 8:16-8:31 (char 21:1)
  Module Alias: "usb:v05E3p0749d1535dc00dsc00dp00ic08isc06ip50in00"
  Driver Info #0:
    Driver Status: uas is active
    Driver Activation Cmd: "modprobe uas"
  Driver Info #1:
    Driver Status: usb_storage is active
    Driver Activation Cmd: "modprobe usb_storage"
  Drive status: no medium
03: SCSI 00.0: 10600 Disk
  SysFS ID: /class/block/sda
  SysFS BusID: 0:0:0:0
  SysFS Device Link: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb2/2-1/2-1.2/2-1.2:1.0/host0/target0:0:0/0:0:0:0
  Revision: "1536"
  Device File: /dev/sda (/dev/sg0)
  Device Files: /dev/sda, /dev/disk/by-path/pci-0000:c4:00.3-usbv3-0:1.2:1.0-scsi-0:0:0:0, /dev/disk/by-id/usb-Generic_MassStorageClass_000000001536-0:0, /dev/disk/by-path/pci-0000:c4:00.3-usb-0:1.2:1.0-scsi-0:0:0:0, /dev/disk/by-diskseq/4
  Device Number: block 8:0-8:15 (char 21:0)
04: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.3/usb6/6-0:1.0
  SysFS BusID: 6-0:1.0
  Hardware Class: hub
  Model: "Linux Foundation 3.0 root hub"
  Hotplug: USB
  Vendor: usb 0x1d6b "Linux Foundation"
  Device: usb 0x0003 "3.0 root hub"
  Revision: "6.11"
  Serial ID: "0000:c6:00.3"
  Driver: "hub"
  Module Alias: "usb:v1D6Bp0003d0611dc09dsc00dp03ic09isc00ip00in00"
05: USB 00.2: 0401 Multimedia audio controller
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.2
  SysFS BusID: 1-1.1.2:1.2
  Model: "HP HyperX Cloud III Wireless"
  Hotplug: USB
  Vendor: usb 0x03f0 "HP"
  Device: usb 0x05b7 "HyperX Cloud III Wireless"
  Revision: "41.09"
  Serial ID: "0000000000000000"
  Driver: "snd-usb-audio"
  Driver Modules: "snd_usb_audio"
  Speed: 12 Mbps
  Module Alias: "usb:v03F0p05B7d4109dc00dsc00dp00ic01isc02ip00in02"
  Attached to: #12 (Hub)
06: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb2/2-1/2-1:1.0
  SysFS BusID: 2-1:1.0
  Hardware Class: hub
  Model: "Genesys Logic USB3.1 Hub"
  Hotplug: USB
  Vendor: usb 0x05e3 "Genesys Logic, Inc."
  Device: usb 0x0626 "USB3.1 Hub"
  Revision: "6.63"
  Driver: "hub"
  Module Alias: "usb:v05E3p0626d0663dc09dsc00dp03ic09isc00ip00in00"
  Attached to: #27 (Hub)
08: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.4/usb3/3-0:1.0
  SysFS BusID: 3-0:1.0
  Hardware Class: hub
  Model: "Linux Foundation 2.0 root hub"
  Hotplug: USB
  Device: usb 0x0002 "2.0 root hub"
  Revision: "6.11"
  Serial ID: "0000:c4:00.4"
  Driver: "hub"
  Speed: 480 Mbps
  Module Alias: "usb:v1D6Bp0002d0611dc09dsc00dp01ic09isc00ip00in00"
10: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.4/usb7/7-0:1.0
  SysFS BusID: 7-0:1.0
  Hardware Class: hub
  Hotplug: USB
  Revision: "6.11"
  Serial ID: "0000:c6:00.4"
  Driver: "hub"
  Speed: 480 Mbps
11: USB 00.1: 10503 USB Mouse
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.3/1-1.3:1.1
  SysFS BusID: 1-1.3:1.1
  Hardware Class: mouse
  Model: "Cypress HID Keyboard"
  Hotplug: USB
  Vendor: usb 0x04b4 "Cypress Semiconductor Corp."
  Device: usb 0x0510 "HID Keyboard"
  Revision: "2.01"
  Compatible to: int 0x0200 0x0001 "Generic USB Mouse"
  Driver: "usbhid"
  Driver Modules: "usbhid"
  Device File: /dev/input/event3
  Device Files: /dev/input/event3, /dev/input/by-path/pci-0000:c4:00.3-usb-0:1.3:1.1-event-kbd, /dev/input/by-path/pci-0000:c4:00.3-usbv2-0:1.3:1.1-event-kbd, /dev/input/by-id/usb-HID_Keyboard_HID_Keyboard-if01-event-kbd
  Device Number: char 13:67
  Speed: 1.5 Mbps
  Module Alias: "usb:v04B4p0510d0201dc00dsc00dp00ic03isc01ip02in01"
  Driver Info #0:
    XFree86 Protocol: explorerps/2
    GPM Protocol: exps2
  Attached to: #26 (Hub)
12: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.1/1-1.1:1.0
  SysFS BusID: 1-1.1:1.0
  Hardware Class: hub
  Model: "Genesys Logic Hub"
  Hotplug: USB
  Device: usb 0x0610 "Hub"
  Revision: "6.63"
  Driver: "hub"
  Speed: 480 Mbps
  Module Alias: "usb:v05E3p0610d0663dc09dsc00dp01ic09isc00ip00in00"
13: USB 00.1: 11500 Bluetooth Device
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-5/1-5:1.1
  SysFS BusID: 1-5:1.1
  Hardware Class: bluetooth
  Model: "Intel AX200 Bluetooth"
  Hotplug: USB
  Vendor: usb 0x8087 "Intel Corp."
  Device: usb 0x0029 "AX200 Bluetooth"
  Revision: "0.01"
  Driver: "btusb"
  Driver Modules: "btusb"
  Speed: 12 Mbps
  Module Alias: "usb:v8087p0029d0001dcE0dsc01dp01icE0isc01ip01in01"
  Driver Info #0:
    Driver Status: btusb is active
    Driver Activation Cmd: "modprobe btusb"
  Attached to: #20 (Hub)
14: USB 00.2: 0000 Unclassified device
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.2
  SysFS BusID: 1-1.1.3:1.2
  Model: "Logitech USB Receiver"
  Hotplug: USB
  Vendor: usb 0x046d "Logitech, Inc."
  Device: usb 0xc547 "USB Receiver"
  Revision: "4.02"
  Driver: "usbhid"
  Speed: 12 Mbps
  Module Alias: "usb:v046DpC547d0402dc00dsc00dp00ic03isc00ip00in02"
  Driver Info #0:
    Driver Status: usbhid is active
    Driver Activation Cmd: "modprobe usbhid"
15: USB 00.0: 0200 Ethernet controller
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb2/2-1/2-1.4/2-1.4:2.0
  SysFS BusID: 2-1.4:2.0
  Model: "ASIX Electronics AX88179 Gigabit Ethernet"
  Hotplug: USB
  Vendor: usb 0x0b95 "ASIX Electronics Corp."
  Device: usb 0x1790 "AX88179 Gigabit Ethernet"
  Revision: "2.00"
  Serial ID: "000000000041BF"
  Driver: "cdc_ncm"
  Driver Modules: "cdc_ncm"
  Device File: eth0
  HW Address: 6c:1f:f7:04:c9:d3
  Permanent HW Address: 6c:1f:f7:04:c9:d3
  Link detected: no
  Module Alias: "usb:v0B95p1790d0200dc00dsc00dp00ic02isc0Dip00in00"
  Driver Info #0:
    Driver Status: cdc_ncm is active
    Driver Activation Cmd: "modprobe cdc_ncm"
  Driver Info #1:
    Driver Status: cdc_mbim is active
    Driver Activation Cmd: "modprobe cdc_mbim"
  Attached to: #6 (Hub)
16: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.4/usb4/4-0:1.0
  SysFS BusID: 4-0:1.0
  Hardware Class: hub
  Hotplug: USB
  Revision: "6.11"
  Driver: "hub"
17: USB 00.0: 10503 USB Mouse
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0
  SysFS BusID: 1-1.1.3:1.0
  Hotplug: USB
  Revision: "4.02"
  Compatible to: int 0x0210 0x0048
  Driver: "usbhid"
  Device File: /dev/input/mice (/dev/input/mouse0)
  Device Files: /dev/input/mice, /dev/input/mouse0, /dev/input/event7, /dev/input/by-path/pci-0000:c4:00.3-usb-0:1.1.3:1.0-event-mouse, /dev/input/by-id/usb-Logitech_USB_Receiver-event-mouse, /dev/input/by-path/pci-0000:c4:00.3-usbv2-0:1.1.3:1.0-event-mouse, /dev/input/by-path/pci-0000:c4:00.3-usbv2-0:1.1.3:1.0-mouse, /dev/input/by-path/pci-0000:c4:00.3-usb-0:1.1.3:1.0-mouse, /dev/input/by-id/usb-Logitech_USB_Receiver-mouse
  Device Number: char 13:63 (char 13:32)
  Speed: 12 Mbps
  Module Alias: "usb:v046DpC547d0402dc00dsc00dp00ic03isc01ip02in00"
  Driver Info #0:
    Buttons: 8
    Wheels: 4
    GPM Protocol: exps2
18: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.4/usb8/8-0:1.0
  SysFS BusID: 8-0:1.0
  Hardware Class: hub
  Hotplug: USB
  Revision: "6.11"
  Driver: "hub"
19: USB 00.3: 0000 Unclassified device
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.3
  SysFS BusID: 1-1.1.2:1.3
  Hotplug: USB
  Revision: "41.09"
  Driver: "usbhid"
  Device File: /dev/input/event5
  Device Number: char 13:69
  Speed: 12 Mbps
  Module Alias: "usb:v03F0p05B7d4109dc00dsc00dp00ic03isc00ip00in03"
  Driver Info #0:
20: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-0:1.0
  SysFS BusID: 1-0:1.0
  Hardware Class: hub
  Hotplug: USB
  Revision: "6.11"
  Serial ID: "0000:c4:00.3"
  Driver: "hub"
  Speed: 480 Mbps
22: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.3/0000:c6:00.3/usb5/5-0:1.0
  SysFS BusID: 5-0:1.0
  Hardware Class: hub
  Hotplug: USB
  Revision: "6.11"
  Driver: "hub"
  Speed: 480 Mbps
23: USB 00.0: 0000 Unclassified device
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.1/1-1.1.4/1-1.1.4:1.0
  SysFS BusID: 1-1.1.4:1.0
  Model: "Integrated Technology Express ITE BillBoard"
  Hotplug: USB
  Vendor: usb 0x048d "Integrated Technology Express, Inc."
  Device: usb 0x5212 "ITE BillBoard"
  Revision: "0.01"
  Driver: "usbhid"
  Speed: 12 Mbps
  Module Alias: "usb:v048Dp5212d0001dc00dsc00dp00ic03isc00ip00in00"
  Driver Info #0:
25: USB 00.0: 10800 Keyboard
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.3/1-1.3:1.0
  SysFS BusID: 1-1.3:1.0
  Hardware Class: keyboard
  Hotplug: USB
  Revision: "2.01"
  Driver: "usbhid"
  Device File: /dev/input/event2
  Device Files: /dev/input/event2, /dev/input/by-path/pci-0000:c4:00.3-usbv2-0:1.3:1.0-event-kbd, /dev/input/by-id/usb-HID_Keyboard_HID_Keyboard-event-kbd, /dev/input/by-path/pci-0000:c4:00.3-usb-0:1.3:1.0-event-kbd
  Device Number: char 13:66
  Speed: 1.5 Mbps
  Module Alias: "usb:v04B4p0510d0201dc00dsc00dp00ic03isc01ip01in00"
  Driver Info #0:
    XkbRules: xfree86
    XkbModel: pc104
26: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1:1.0
  SysFS BusID: 1-1:1.0
  Hardware Class: hub
  Hotplug: USB
  Revision: "6.63"
  Driver: "hub"
  Speed: 480 Mbps
27: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb2/2-0:1.0
  SysFS BusID: 2-0:1.0
  Hardware Class: hub
  Hotplug: USB
  Revision: "6.11"
  Driver: "hub"
28: USB 00.0: 10a00 Hub
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb2/2-1/2-1.1/2-1.1:1.0
  SysFS BusID: 2-1.1:1.0
  Hardware Class: hub
  Hotplug: USB
  Revision: "6.63"
  Driver: "hub"
30: USB 00.1: 10800 Keyboard
  SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:c4:00.3/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.1
  SysFS BusID: 1-1.1.3:1.1
  Hotplug: USB
  Revision: "4.02"
  Driver: "usbhid"
  Device File: /dev/input/event8
  Device Files: /dev/input/event8, /dev/input/by-path/pci-0000:c4:00.3-usb-0:1.1.3:1.1-event-kbd, /dev/input/by-path/pci-0000:c4:00.3-usbv2-0:1.1.3:1.1-event-kbd, /dev/input/by-id/usb-Logitech_USB_Receiver-if01-event-kbd
  Device Number: char 13:72
  Speed: 12 Mbps
  Module Alias: "usb:v046DpC547d0402dc00dsc00dp00ic03isc01ip01in01"
  Driver Info #0:
    XkbRules: xfree86
    XkbModel: pc104
I wondered if this was some sort of dual-boot with windoze issue.
But your output would suggest this is the sole system on the machine.
Sadly … that does not discount the possibility that windoze was not fully shutdown and has held the card hostage. This related arch thread solution included re-installing windoze!
( In order to disable ‘fast-startup’ - a cmd to properly shut down could also suffice )
https://bbs.archlinux.org/viewtopic.php?id=290632
Gaah, I knew that I was forgetting to include info about Windows!
Manjaro is the only OS installed on my drive and I have disabled fastboot in the BIOS.
I will read your link and see what comes of it.
Please take a look through the linked thread.
BIOS ‘Fastboot’ and windoze ‘fast-start’ are not the same.
The proposed problem source is the desktop option ‘fast start’ … which is the default microsoft configuration. And it means the system does not fully shut down, but instead enters a hibernation.
This can cause all sorts of problems with other systems.
( And if the other thread is to be believed … can even persist beyond replacing the operating system. )
I have no firsthand experience of this situation.
Though I am familiar with the ‘false shutdown’ issue in general - its usually something concerning an active dual-boot scenario.
The wifi card in question should be fully compatible and working out of the box.
After reading that thread, I powered off my PC AND pulled the power plug. Grabbed myself a tasty beverage, came back to my PC, and PRESTO!
Thanks!!!
Ah the full power pull and bit of a wait was a good idea!
And much preferable to having to reinstall. :innocent:
Just as a comparison to help with troubleshooting, this is the inxi -Fazy network output for my Beelink SER5, which uses the same wifi adapter as the SER8:
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
    bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
One thing I have found, and this is a fairly recent occurrence (the past few months or so), is that my SER5’s wifi connects with successful authentication to the router, but doesn’t send or receive traffic. Switching the wifi off & back on via the Network icon in the system tray, allowing the wifi to autoconnect again to the router, often fixes that problem. Not an issue for me though, as I use Ethernet 99.9% of the time.
Edit: I see that, while I was typing this, the issue has been resolved by doing a full power-off. A full power-off can force a firmware reload, especially after a system update. Switching it off and back on seems to be as applicable today as it was when I got my first PC in 2001.
Yeah, not just a full power off, but a full power disconnect by pulling it out of the wall. This also solved my issue of the PC not powering off properly (it would hang at a black screen when attempting to power off/reboot). Never would have guessed that killing the 120VAC to the PC was the solution.
Also, unless you have a specific reason for running Plasma on an X11 session, you might be better off switching to a Wayland session. Wayland works very well with AMD devices.
I am not sure what either of those are. :sweat_smile: I’ll take a look into it, thanks.
Wayland is a much more modern display manager than X11. It is what KDE Plasma defaults to nowadays. The main reason why Manjaro set Plasma to default to X11 is that there were/are issues with Nvidia GPUs that caused problems starting the desktop. As you don’t have an Nvidia GPU, your system may actually work better on Wayland.
To change to Wayland just log out of your Plasma session and at the login screen select Plasma Wayland instead of Plasma X11 (the option should be at the bottom left of the login screen).
If you use autologin to skip the login screen, then open System Settings => Colors & Themes => Login Screen (SDDM) & select the Behavior button at the top. Change the autologin session to Plasma (Wayland).
On a related note …
I run Folding At Home overnight, and in the past six months I would check only to find my wifi was disconnected. Frustrating as all get out. Finally, I ran into thread regarding creation of the file wifi-powersave-off under NetworkManager.
I suspect it was a remnant of the above discussion of dual boot, since the trouble did start about the last time I brought up Windows. I further suspect that while folding larger molecules, the wifi would have no transmitting activity long enough to put it into sleep mode.
Various powersave options can be disabled including the following…
  • NetworkManager
    As noted above;
# /etc/NetworkManager/conf.d/wifi-powersave-off.conf
[connection]
# Values are 0 (use default), 1 (ignore/don't touch), 2 (disable) or 3 (enable).
wifi.powersave = 2
  • Various module-specific options. In the case of modern intel chips using iwlwifi its own powersaving should be disabled by default. But another module iwlmvm may actually have it enabled.
# /etc/modprobe.d/iwlmvm.conf
options iwlmvm power_scheme=1
Also here is this:
https://wiki.archlinux.org/title/Network_configuration/Wireless#Intel
Holy sh*t, we both encounter the 100% same problem. I am using Beek-link SER8 too, I just bought it two days ago. And I spent a whole day try to solve this problem. But nothing help…
