So i will say that i am still relatively new to using linux, but every distro i have downloaded to this laptop has had this issue.
All that’s happening is any time the accelerometer tries to trigger the screen rotation even with rotation and touch screen off. It disables any “unneccesary” devices and drivers which just so happens to my bluetooth, wifi, and also any keyboards or mouses external or internal.
So I basically have had to use my laptop as a Desktop computer on a flat surface as to not risk disconnecting everything, cutting off downloads etc… just because i decided to pick up my laptop and put it somewhere else, and at this point its just gotten kind of irritating and redundant so i finally came for help.
ruziel
February 20, 2023, 8:24am
2
Hi there. What does a search for turning off the accelerometer on your specific notebook come up with? It could be a hardware issue. I hope you find a solution soon. R
Well over the past few months i have searched up everything i could regarding the issue.
From what i know it has to do with the fact that whatever device is in control of disconnecting my mousepad and integrated keyboard when the keyboard rotates just disconnects all the devices connected to the computer that aren’t essential to function.
Frenchy
February 21, 2023, 4:26am
4
Ever thought it could be just(…) some sort of internal earthing issue? Look around the battery parhaps, it could be a connectivity problem. In any case fingers crossed
Ben
February 21, 2023, 8:23am
6
Try uninstalling your Pinball Wizard
root=UUID=2a06fd87-998e-43b5-9656-b035a6d21ca4 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Convertible System: HP product: HP ENVY x360 Convertible 15m-ed0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: HP model: 875B v: 09.40 serial: <filter> UEFI: Insyde v: F.21
date: 12/28/2020
ID-1: BAT1 charge: 44.5 Wh (100.0%) condition: 44.5/51.0 Wh (87.1%)
volts: 12.6 min: 11.6 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Device-1: hid-0018:04F3:2B0E.0001-battery model: ELAN2514:00 04F3:2B0E
serial: N/A charge: N/A status: N/A
RAM: total: 11.48 GiB used: 3.93 GiB (34.3%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
manufacturer: Micron part-no: 8ATF1G64HZ-3G2J1 serial: <filter>
Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
size: 4 GiB speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64
total: 64 manufacturer: Micron part-no: 4ATF51264HZ-3G2J1 serial: <filter>
Info: model: Intel Core i7-1065G7 socket: U3E1 bits: 64 type: MT MCP
arch: Ice Lake gen: core 10 level: v4 note: check built: 2019-21
process: Intel 10nm family: 6 model-id: 0x7E (126) stepping: 5
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1136 high: 1200 min/max: 400/3900 base/boost: 1200/8300
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 1124 2: 1168 3: 1133 4: 1095 5: 1113 6: 1120
7: 1138 8: 1200 bogomips: 23968
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Iris Plus Graphics G7 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 3-5:3 chip-ID: 04f2:b6b6 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1184x380mm (46.61x14.96")
s-diag: 1243mm (48.96")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: left model: M43Q6-J04
serial: <filter> built: 2020 res: 2560x1440 hz: 60 dpi: 59 gamma: 1.2
size: 1096x616mm (43.15x24.25") diag: 1630mm (64.2") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
Monitor-2: eDP-1 pos: primary,right model: BOE Display 0x08a8 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Iris Plus Graphics
(ICL GT2) direct-render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0401
Sound API: ALSA v: k5.15.93-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 3060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 504.19 GiB used: 31.7 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Intel model: HBRPEKNX0202AH
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: HPS2 temp: 28.9 C scheme: GPT
SMART: yes health: PASSED on: 294d 10h cycles: 466
read-units: 5,139,551 [2.63 TB] written-units: 12,630,933 [6.46 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202AHO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: HPS3 temp: 30.9 C
SMART: yes health: PASSED on: 310d 16h cycles: 467
read-units: 7,100,496 [3.63 TB] written-units: 8,106,301 [4.15 TB]
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 31.7 GiB (6.8%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:3 label: N/A
uuid: 2a06fd87-998e-43b5-9656-b035a6d21ca4
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:2 label: N/A uuid: 5389-5E95
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: MosArt 2.4G INPUT DEVICE type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 062a:4180 class-ID: 0301
Device-2: 3-5:3 info: Chicony HP Wide Vision HD Camera type: Video
Device-3: 3-6:4 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c4c class-ID: 0000
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 244 Uptime: 10h 35m wakeups: 5 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1181 pm: pacman pkgs: 1163 libs: 323 tools: pamac pm: flatpak
pkgs: 18 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25```
Alright here you go hope this helps.
Nah ive tested it, it is perfectly in sync with the rotation of the screen. Linux Mint is the only linux distro that i didn’t have this problem with and this is OS number like 6. Yet like i said i worked on linux mint and it worked on windows also.
What happens when i tilt the laptop to the side it tries to go into upright orientation and only enable the touch screen.
Disabling screen rotation doesn’t do the trick, and i cant seem to find a dedicated device in this computer that acts as an accelerometer. I was more less wondering if there was a way i could from the operating system level just stop it from accepting any accelerometer outputs.
