Just wanted to ask if you did find out yet? Still stuck at updates? Already collecting Chicken Dinners? Or was this just a joke? My guess is that it was a joke (I’m not around here long enough to know about the teams kind of humor) 'cause even if the game would run without Google services I just can’t imagine you can get playable framerates with the PinePhones hardware.
Does it really matter where I ask? Is this not an official account? But if you really wanna know I asked here because I never use twitter actively, just passively as a sort of news aggregator.
We tested a lot of things via Waydroid on the Pinephone. Some might work, some not. We managed to get thru updates with the lite edition from uptodown store. However could never login to the servers. We might see if it works or not. Everything is in early stages as of now.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
