SMplayer stopped working and crashes
It worked until it suddenly stopped. Mpv and mplayer make it very confusing for me and I don’t know where to even start troubleshooting this.
The video was choppy, I played with the settings (performance, cores, hardware acceleration, video output driver), reinstalled, SMplayer, mpv and mplayer. But nothing. Now it crashes at start up. VLC work alright.
How do I go about it?
Hi @lee_mdk,
I just tested smplayer and it work :100: so I’m presuming mplayer would as well.
I guess that first step to diagnosing it would be to launch it from the terminal and see if it provides any hint as to why it’s being naughty:
smplayer
Just open a terminal emulator window and run that. See if it provides you with any hints as to why it’s misbehaving. Feel free to p rovide the output here.
Edit:
:bangbang: Tip: :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Thank you for replying!
[lee@leenux ~]$ smplayer
This is SMPlayer v. 22.7.0 (revision 10091) running on Linux
Nothing out of the ordinary.
When I choose mpv as multimedia engine, it takes about 30 seconds to start up.
If I choose mplayer as multimedia engine, it opens instantly.
I tried to play a video, and got this error in SMplayer:
/usr/bin/mplayer -noquiet -slave -identify -nofs -vc ffh264vdpau,ffmpeg12vdpau,ffwmv3vdpau,ffvc1vdpau,ffodivxvdpau,ffhevcvdpau, -lavdopts threads=8 -sub-fuzziness 1 -vo vdpau, -ao pulse, -nodr -double -nomouseinput -input nodefault-bindings:conf=/dev/null -nokeepaspect -wid 211812649 -monitorpixelaspect 1 -osdlevel 0 -subfont-osd-scale 3 -progbar-align 80 -ass -embeddedfonts -ass-line-spacing 0 -ass-font-scale 1 -noflip-hebrew -ass-styles /home/lee/.config/smplayer/styles.ass -subcp ISO-8859-1 -alang eng -slang gre -subpos 100 -volume 26 -noslices -af-add scaletempo -softvol -softvol-max 110 /home/lee/Downloads/Movies/A.Man.Called.Otto.2022.1080p.WEB-DL.DDP5.1.Atmos.H.264-CM.mkv
MPlayer SVN-r38407 (C) 2000-2022 MPlayer Team
226 audio & 469 video codecs
do_connect: could not connect to socket
connect: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /home/lee/Downloads/Movies/A.Man.Called.Otto.2022.1080p.WEB-DL.DDP5.1.Atmos.H.264-CM.mkv.
libavformat version 59.27.100 (external)
libavformat file format detected.
ID_CHAPTER_ID=0
ID_CHAPTER_0_START=0
ID_CHAPTER_0_END=528445
ID_CHAPTER_0_NAME=Chapter 01
ID_CHAPTER_ID=1
ID_CHAPTER_1_START=528445
ID_CHAPTER_1_END=990115
ID_CHAPTER_1_NAME=Chapter 02
ID_CHAPTER_ID=2
ID_CHAPTER_2_START=990115
ID_CHAPTER_2_END=1412203
ID_CHAPTER_2_NAME=Chapter 03
ID_CHAPTER_ID=3
ID_CHAPTER_3_START=1412203
ID_CHAPTER_3_END=1987654
ID_CHAPTER_3_NAME=Chapter 04
ID_CHAPTER_ID=4
ID_CHAPTER_4_START=1987654
ID_CHAPTER_4_END=2429262
ID_CHAPTER_4_NAME=Chapter 05
ID_CHAPTER_ID=5
ID_CHAPTER_5_START=2429262
ID_CHAPTER_5_END=2957207
ID_CHAPTER_5_NAME=Chapter 06
ID_CHAPTER_ID=6
ID_CHAPTER_6_START=2957207
ID_CHAPTER_6_END=3353436
ID_CHAPTER_6_NAME=Chapter 07
ID_CHAPTER_ID=7
ID_CHAPTER_7_START=3353436
ID_CHAPTER_7_END=3847847
ID_CHAPTER_7_NAME=Chapter 08
ID_CHAPTER_ID=8
ID_CHAPTER_8_START=3847847
ID_CHAPTER_8_END=4311561
ID_CHAPTER_8_NAME=Chapter 09
ID_CHAPTER_ID=9
ID_CHAPTER_9_START=4311561
ID_CHAPTER_9_END=4829204
ID_CHAPTER_9_NAME=Chapter 10
ID_CHAPTER_ID=10
ID_CHAPTER_10_START=4829204
ID_CHAPTER_10_END=5314773
ID_CHAPTER_10_NAME=Chapter 11
ID_CHAPTER_ID=11
ID_CHAPTER_11_START=5314773
ID_CHAPTER_11_END=5768601
ID_CHAPTER_11_NAME=Chapter 12
ID_CHAPTER_ID=12
ID_CHAPTER_12_START=5768601
ID_CHAPTER_12_END=6262887
ID_CHAPTER_12_NAME=Chapter 13
ID_CHAPTER_ID=13
ID_CHAPTER_13_START=6262887
ID_CHAPTER_13_END=6757298
ID_CHAPTER_13_NAME=Chapter 14
ID_CHAPTER_ID=14
ID_CHAPTER_14_START=6757298
ID_CHAPTER_14_END=7036619
ID_CHAPTER_14_NAME=Chapter 15
ID_CHAPTER_ID=15
ID_CHAPTER_15_START=7036619
ID_CHAPTER_15_END=7568864
ID_CHAPTER_15_NAME=Chapter 16
ID_VIDEO_ID=0
[lavf] stream 0: video (h264), -vid 0
ID_AUDIO_ID=0
ID_AID_0_LANG=eng
[lavf] stream 1: audio (eac3), -aid 0, -alang eng
ID_SUBTITLE_ID=0
ID_SID_0_LANG=eng
ID_SID_0_NAME=SDH
[lavf] stream 2: subtitle (srt), -sid 0, -slang eng, SDH
ID_SUBTITLE_ID=1
ID_SID_1_LANG=eng
[lavf] stream 3: subtitle (srt), -sid 1, -slang eng
ID_SUBTITLE_ID=2
ID_SID_2_LANG=eng
ID_SID_2_NAME=British SDH
[lavf] stream 4: subtitle (srt), -sid 2, -slang eng, British SDH
ID_SUBTITLE_ID=3
ID_SID_3_LANG=eng
ID_SID_3_NAME=British
[lavf] stream 5: subtitle (srt), -sid 3, -slang eng, British
ID_SUBTITLE_ID=4
ID_SID_4_LANG=dan
[lavf] stream 6: subtitle (srt), -sid 4, -slang dan
ID_SUBTITLE_ID=5
ID_SID_5_LANG=ger
[lavf] stream 7: subtitle (srt), -sid 5, -slang ger
ID_SUBTITLE_ID=6
ID_SID_6_LANG=spa
[lavf] stream 8: subtitle (srt), -sid 6, -slang spa
ID_SUBTITLE_ID=7
ID_SID_7_LANG=spa
ID_SID_7_NAME=Latin American
[lavf] stream 9: subtitle (srt), -sid 7, -slang spa, Latin American
ID_SUBTITLE_ID=8
ID_SID_8_LANG=fin
[lavf] stream 10: subtitle (srt), -sid 8, -slang fin
ID_SUBTITLE_ID=9
ID_SID_9_LANG=fre
[lavf] stream 11: subtitle (srt), -sid 9, -slang fre
ID_SUBTITLE_ID=10
ID_SID_10_LANG=ind
[lavf] stream 12: subtitle (srt), -sid 10, -slang ind
ID_SUBTITLE_ID=11
ID_SID_11_LANG=kor
[lavf] stream 13: subtitle (srt), -sid 11, -slang kor
ID_SUBTITLE_ID=12
ID_SID_12_LANG=dut
[lavf] stream 14: subtitle (srt), -sid 12, -slang dut
ID_SUBTITLE_ID=13
ID_SID_13_LANG=nor
[lavf] stream 15: subtitle (srt), -sid 13, -slang nor
ID_SUBTITLE_ID=14
ID_SID_14_LANG=por
ID_SID_14_NAME=Brazilian
[lavf] stream 16: subtitle (srt), -sid 14, -slang por, Brazilian
ID_SUBTITLE_ID=15
ID_SID_15_LANG=swe
[lavf] stream 17: subtitle (srt), -sid 15, -slang swe
ID_SUBTITLE_ID=16
ID_SID_16_LANG=chi
ID_SID_16_NAME=Traditional
[lavf] stream 18: subtitle (srt), -sid 16, -slang chi, Traditional
ID_SUBTITLE_ID=17
ID_SID_17_LANG=chi
ID_SID_17_NAME=Mandarin Chinese Traditional
[lavf] stream 19: subtitle (srt), -sid 17, -slang chi, Mandarin Chinese Traditional
VIDEO:  [H264]  1920x1036  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
[ass] Track has custom format line(s). 'ScaledBorderAndShadow' will default to 'yes'.
Opening video filter: [ass auto=1]
Couldn't open video filter 'ass'.
ASS: cannot add video filter
[ass] libass API version: 0x1700000
[ass] libass source: commit: 0.17.0-0-gbef4b43ef1882b77f789f611d9cd24271ccdd65b-dirty
[ass] Shaper: FriBidi 1.0.12 (SIMPLE) HarfBuzz-ng 7.0.0 (COMPLEX)
[ass] Using font provider fontconfig
Forced video codec: ffh264vdpau
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 59.37.100 (external)
Selected video codec: [ffh264vdpau] vfm: ffmpeg (FFmpeg H.264 (VDPAU))
ID_VIDEO_CODEC=ffh264vdpau
Clip info:
 encoder: libebml v1.4.2 + libmatroska v1.6.4
ID_CLIP_INFO_NAME0=encoder
ID_CLIP_INFO_VALUE0=libebml v1.4.2 + libmatroska v1.6.4
ID_CLIP_INFO_N=1
Load subtitles in /home/lee/Downloads/Movies/
ID_FILENAME=/home/lee/Downloads/Movies/A.Man.Called.Otto.2022.1080p.WEB-DL.DDP5.1.Atmos.H.264-CM.mkv
ID_DEMUXER=lavfpref
ID_VIDEO_FORMAT=H264
ID_VIDEO_BITRATE=0
ID_VIDEO_WIDTH=1920
ID_VIDEO_HEIGHT=1036
ID_VIDEO_FPS=23.976
ID_VIDEO_ASPECT=0.0000
ID_AUDIO_FORMAT=EAC3
ID_AUDIO_BITRATE=768000
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=6
ID_START_TIME=0.00
ID_LENGTH=7568.86
ID_SEEKABLE=1
ID_CHAPTERS=16
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, floatle, 768.0 kbit/25.00% (ratio: 96000->384000)
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=2
Selected audio codec: [ffeac3] afm: ffmpeg (FFmpeg E-AC-3)
AO: [pulse] 48000Hz 2ch floatle (4 bytes per sample)
ID_AUDIO_CODEC=ffeac3
[Mixer] No hardware mixing, inserting volume filter.
Starting playback...
Movie-Aspect is 1.85:1 - prescaling to correct movie aspect.
ID_VIDEO_ASPECT=1.8533
VO: [vdpau] 1920x1036 => 1920x1036 H.264 VDPAU acceleration
MPlayer interrupted by signal 11 in module: decode video
ID_SIGNAL=11
- MPlayer crashed by bad usage of CPU/FPU/RAM.
  Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
  disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
  gcc version. If you think it's MPlayer's fault, please read
  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
  won't help unless you provide this information when reporting a possible bug.
I'm an idiot, I didn't mean this
This :point_down:
I actually meant this :point_down:
Makes me suspect it has something to do with all the GPU codecs and stuff that’s been going on lately. I’m also, because of that, certain I can’t help, reallly.
So with that in mind, I salute you :saluting_face: and thanks for all the fish.
This might shed some light somewhere:
https://wiki.archlinux.org/title/Hardware_video_acceleration
Thank you very much!
I managed to get it running (I don’t know exactly what worked, I tried tones of stuff).
However, one problem persists, SMplayer takes about 30 seconds to startup.
If I run it with sudo it starts immediately.
Any idea why?
I got this SMPlayer log that shows where the delay for the startup is. Is it related to audio? Before it started I was messing around with remove pipewire to use pulseaudio.
22:10:31:647] BaseGuiPlus::updateSendToScreen
[22:10:31:647] BaseGuiPlus::updateSendAudioMenu
[22:10:31:647] PlayerID::Player: player_bin: "/usr/bin/mpv" filename: "mpv"
[22:10:31:647] DeviceInfo::mpvAudioDevices
[22:11:01:677] WARNING: QProcess: Destroyed while process ("/usr/bin/mpv") is still running.
[22:11:01:679] GlobalShortcuts::GlobalShortcuts
[22:11:01:680] GlobalShortcuts::setEnabled: false
Full log:
[22:10:31:521] global_init
[22:10:31:521] global_init: config file: '/home/lee/.config/smplayer/smplayer.ini'
[22:10:31:521] Preferences::load
[22:10:31:521] AssStyles::load
[22:10:31:522] Preferences::load: config_version: 5, CURRENT_CONFIG_VERSION: 5
[22:10:31:522] Translator::loadCatalog: can't load "qt_en_US" from "/usr/share/smplayer/translations"
[22:10:31:522] Translator::loadCatalog: successfully loaded "qt_en_US" from "/usr/share/qt/translations"
[22:10:31:522] Translator::loadCatalog: can't load "qtbase_en_US" from "/usr/share/smplayer/translations"
[22:10:31:522] Translator::loadCatalog: successfully loaded "qtbase_en_US" from "/usr/share/qt/translations"
[22:10:31:522] Translator::loadCatalog: successfully loaded "smplayer_en_US" from "/usr/share/smplayer/translations"
[22:10:31:522] This is SMPlayer v. 22.7.0 (revision 10091) running on Linux
[22:10:31:522] Compiled with Qt v. 5.15.7, using 5.15.8
[22:10:31:522]  * application path: "/usr/bin"
[22:10:31:522]  * data path: "/usr/share/smplayer"
[22:10:31:522]  * translation path: "/usr/share/smplayer/translations"
[22:10:31:522]  * doc path: "/usr/share/doc/smplayer"
[22:10:31:522]  * themes path: "/usr/share/smplayer/themes"
[22:10:31:522]  * shortcuts path: "/usr/share/smplayer/shortcuts"
[22:10:31:522]  * config path: "/home/lee/.config/smplayer"
[22:10:31:522]  * ini path: "/home/lee/.config/smplayer"
[22:10:31:522]  * file for subtitles' styles: "/home/lee/.config/smplayer/styles.ass"
[22:10:31:522]  * current path: "/home/lee"
[22:10:31:522] main: hdpi_config_path: "/home/lee/.config/smplayer"
[22:10:31:522] SMPlayer::processArgs: arguments: 1
[22:10:31:522] SMPlayer::processArgs: 0 = smplayer
[22:10:31:522] SMPlayer::processArgs: files_to_play: count: 0
[22:10:31:522] SMPlayer::gui: changed working directory to app path
[22:10:31:522] SMPlayer::gui: current directory: /usr/bin
[22:10:31:522] ScreenHelper::setAutoHideCursor: 0
[22:10:31:522] Images::setThemesPath: "/usr/share/smplayer/themes"
[22:10:31:522] Images::resourceFilename: "/usr/share/smplayer/themes/ePapirus/ePapirus.rcc"
[22:10:31:522] Images::setTheme: loading "/usr/share/smplayer/themes/ePapirus/ePapirus.rcc"
[22:10:31:522] Images::setTheme: has_rcc: true
[22:10:31:527] MediaSettings::reset
[22:10:31:527] Core::changeFileSettingsMethod: hash
[22:10:31:527] PlayerID::Player: player_bin: "/usr/bin/mpv" filename: "mpv"
[22:10:31:527] PlayerProcess::createPlayerProcess: creating MPVProcess
[22:10:31:527] MyProcess::MyProcess: bin_path: "/home/lee/bin"
[22:10:31:527] MyProcess::MyProcess: PATH: "/home/lee/.local/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl"
[22:10:31:527] MyProcess::MyProcess: paths: ("/home/lee/.local/bin", "/usr/local/bin", "/usr/bin", "/usr/local/sbin", "/usr/lib/jvm/default/bin", "/usr/bin/site_perl", "/usr/bin/vendor_perl", "/usr/bin/core_perl")
[22:10:31:527] MyProcess::MyProcess: PATH: "/home/lee/bin:/home/lee/.local/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl"
[22:10:31:527] MPVProcess::initializeOptionVars
[22:10:31:527] MPVProcess::MPVProcess: socket_name: "/tmp/smplayer-mpv-1335"
[22:10:31:527] VideoLayer::setRepaintBackground: 1
[22:10:31:527] Preferences::monitor_aspect_double
[22:10:31:527]  warning: monitor_aspect couldn't be parsed!
[22:10:31:527]  monitor_aspect set to 0
[22:10:31:529] PowerSaving::PowerSaving: interface is valid
[22:10:31:572] Playlist::setModified: 0
[22:10:31:572] Playlist::updateWindowTitle: "Untitled playlist"
[22:10:31:605] Recents::addItem: 'http://smplayer.info/sample.m3u8'
[22:10:31:605] Playlist::setConfigPath: "/home/lee/.config/smplayer"
[22:10:31:605] Playlist::setConfigPath: ini file: "/home/lee/.config/smplayer/playlist.ini"
[22:10:31:605] Playlist::loadSettings
[22:10:31:605] Helper::qtVersion: 6508
[22:10:31:605] Playlist::updateWindowTitle: "Untitled playlist"
[22:10:31:605] Playlist::setModified: 0
[22:10:31:607] BaseGui::BaseGui: default_style: ""
[22:10:31:608] Favorites::load
[22:10:31:608] TVList::parse_channels_conf
[22:10:31:608] VList::parse_channels_conf: /home/lee/.mplayer/channels.conf.ter doesn't exist
[22:10:31:608] TVList::parse_channels_conf: can't open /home/lee/.mplayer/channels.conf
[22:10:31:609] BaseGui::initializeMenus
[22:10:31:609] BaseGui::updateBookmarks
[22:10:31:613] BaseGui::initializeMenus
[22:10:31:613] BaseGui::updateBookmarks
[22:10:31:613] BaseGui::updateRecents
[22:10:31:613] BaseGui::updateWidgets
[22:10:31:613] Core::changeUseCustomSubStyle: 1
[22:10:31:613] Core::changeSubVisilibity: 1
[22:10:31:613] Core::displayMessage
[22:10:31:613] PlayerID::Player: player_bin: "/usr/bin/mpv" filename: "mpv"
[22:10:31:613] BaseGui::setupNetworkProxy
[22:10:31:613] BaseGui::setupNetworkProxy: no proxy
[22:10:31:613] BaseGui::setStayOnTop: 0
[22:10:31:613] BaseGui::setStayOnTop: nothing to do
[22:10:31:614] BaseGui::updateRecents
[22:10:31:614] UpdateChecker::UpdateChecker: enabled: true
[22:10:31:614] UpdateChecker::UpdateChecker: days_to_check: 7
[22:10:31:614] UpdateChecker::UpdateChecker: days since last check: 0
[22:10:31:647] BaseGuiPlus::updateSendToScreen
[22:11:01:683] Chromecast::loadSettings
[22:11:01:685] BaseGui::initializeMenus
[22:11:01:685] BaseGui::updateBookmarks
[22:11:01:685] BaseGui::updateRecents
[22:11:01:685] BaseGuiPlus::updateWidgets
[22:11:01:685] BaseGui::updateWidgets
[22:11:01:685] PlayerID::Player: player_bin: "/usr/bin/mpv" filename: "mpv"
[22:11:01:685] BaseGuiPlus::loadConfig
[22:11:01:685] DefaultGui::createStatusBar
[22:11:01:686] StateWidget::StateWidget: supported formats for QMovie: ("gif", "mng", "webp")
[22:11:01:686] DefaultGui::createActions
[22:11:01:687] DefaultGui::createControlWidget
[22:11:01:687] DefaultGui::createControlWidgetMini
[22:11:01:687] AutohideWidget::installFilter: child name: ""
[22:11:01:687] AutohideWidget::installFilter: child name: "mplayerwindowlogo"
[22:11:01:687] DefaultGui::adjustFloatingControlSize
[22:11:01:687] DefaultGui::populateMainMenu
[22:11:01:687] BaseGuiPlus::populateMainMenu
[22:11:01:687] BaseGui::populateMainMenu
[22:11:01:687] BaseGuiPlus::initializeSystrayMenu
[22:11:01:695] BaseGui::initializeMenus
[22:11:01:695] BaseGui::updateBookmarks
[22:11:01:695] BaseGui::updateRecents
[22:11:01:695] DefaultGui::updateWidgets
[22:11:01:695] BaseGuiPlus::updateWidgets
[22:11:01:695] BaseGui::updateWidgets
[22:11:01:695] PlayerID::Player: player_bin: "/usr/bin/mpv" filename: "mpv"
[22:11:01:696] DefaultGui::loadConfig
[22:11:01:696] DesktopInfo::isInsideScreen: center point of window: QPoint(2164,270)
[22:11:01:696] DesktopInfo::isInsideScreen: virtual geometry: QRect(0,0 4480x1440)
[22:11:01:696] ToolbarEditor::load: 'toolbar1'
[22:11:01:696] ToolbarEditor::load: loading action open_file
[22:11:01:696] ToolbarEditor::load: loading action open_url
[22:11:01:696] ToolbarEditor::load: loading action favorites_menu
[22:11:01:696] ToolbarEditor::load: loading action separator
[22:11:01:696] ToolbarEditor::load: adding separator
[22:11:01:696] ToolbarEditor::load: loading action screenshot
[22:11:01:696] ToolbarEditor::load: loading action show_file_properties
[22:11:01:696] ToolbarEditor::load: loading action show_playlist
[22:11:01:696] ToolbarEditor::load: loading action show_tube_browser
[22:11:01:696] ToolbarEditor::load: loading action show_preferences
[22:11:01:696] ToolbarEditor::load: loading action play_prev
[22:11:01:696] ToolbarEditor::load: loading action play_next
[22:11:01:696] ToolbarEditor::load: loading action audiotrack_menu
[22:11:01:696] ToolbarEditor::load: loading action subtitlestrack_menu
[22:11:01:696] ToolbarEditor::load: 'controlwidget'
[22:11:01:696] ToolbarEditor::load: loading action play_or_pause
[22:11:01:696] ToolbarEditor::load: loading action stop
[22:11:01:697] ToolbarEditor::load: loading action mute
[22:11:01:697] ToolbarEditor::load: loading action volumeslider_action
[22:11:01:697] ToolbarEditor::load: loading action separator
[22:11:01:697] ToolbarEditor::load: adding separator
[22:11:01:697] ToolbarEditor::load: loading action rewind1
[22:11:01:697] ToolbarEditor::load: loading action timeslider_action
[22:11:01:697] TimeSlider::setDragDelay: 100
[22:11:01:697] ToolbarEditor::load: loading action forward1
[22:11:01:697] ToolbarEditor::load: loading action fullscreen
[22:11:01:697] ToolbarEditor::load: 'controlwidget_mini'
[22:11:01:697] ToolbarEditor::load: loading action play_or_pause
[22:11:01:697] ToolbarEditor::load: loading action stop
[22:11:01:697] ToolbarEditor::load: 'floating_control'
[22:11:01:697] ToolbarEditor::load: loading action current_timelabel_action
[22:11:01:697] ToolbarEditor::load: loading action total_timelabel_action
[22:11:01:698] ToolbarEditor::load: adding separator
[22:11:01:698] ToolbarEditor::load: loading action fullscreen
[22:11:01:698] Helper::qtVersion: 6508
[22:11:01:699] DefaultGui::updateWidgets
[22:11:01:699] BaseGuiPlus::updateWidgets
[22:11:01:699] BaseGui::updateWidgets
[22:11:01:699] PlayerID::Player: player_bin: "/usr/bin/mpv" filename: "mpv"
[22:11:01:699] BaseGui::applyStyles
[22:11:01:699] BaseGui::applyStyles: stylesheet: "ePapirus"
[22:11:01:699] BaseGui::changeStyleSheet: "ePapirus"
[22:11:01:699] BaseGui::loadQss: :/default-theme/style.qss
[22:11:01:699] Images::setThemesPath: "/usr/share/smplayer/themes"
[22:11:01:699] Images::setTheme: unloading "/usr/share/smplayer/themes/ePapirus/ePapirus.rcc"
[22:11:01:699] Images::resourceFilename: "/usr/share/smplayer/themes/ePapirus/ePapirus.rcc"
[22:11:01:699] Images::setTheme: loading "/usr/share/smplayer/themes/ePapirus/ePapirus.rcc"
[22:11:01:699] Images::setTheme: has_rcc: true
[22:11:01:708] BaseGui::applyStyles: style: "Adwaita-Dark"
[22:11:01:743] BaseGui::showEvent
[22:11:01:747] BaseGui::loadActions
[22:11:01:747] ActionsEditor::loadFromConfig
[22:11:01:748] BaseGui::checkReminder
[22:11:01:753] BaseGui::initializeMenus
[22:11:01:753] BaseGui::updateBookmarks
[22:11:01:753] BaseGui::updateRecents
[22:11:01:753] DefaultGui::updateWidgets
[22:11:01:753] BaseGuiPlus::updateWidgets
[22:11:01:753] BaseGui::updateWidgets
[22:11:01:753] PlayerID::Player: player_bin: "/usr/bin/mpv" filename: "mpv"
[22:11:01:884] BaseGuiPlus::updateShortcutsContext
[22:11:06:024] BaseGuiPlus::showPreferencesDialog
[22:11:06:024] GlobalShortcuts::setEnabled: false
[22:11:06:024] BaseGui::showPreferencesDialog
[22:11:06:032] InfoReader::setPlayerBin: mplayerbin: "/usr/bin/mpv"
[22:11:06:032] InfoReader::getInfo: sname: "mpv_4bfa5cba7906babb"
[22:11:06:033] InfoReader::getInfo: loaded info from "/home/lee/.config/smplayer/player_info.ini"
[22:11:06:033] DeviceInfo::xvAdaptors
[22:11:06:035] DeviceInfo::xvAdaptors: could not start xvinfo, error 0
[22:11:06:045] PrefGeneral::player_combo_changed: 0
[22:11:06:045] PrefGeneral::player_combo_changed: -1
[22:11:06:045] PrefGeneral::vo_combo_changed: 0
[22:11:06:045] PrefGeneral::ao_combo_changed: 0
[22:11:06:046] PrefGeneral::ao_combo_changed: 0
[22:11:06:057] PrefDrives::updateDriveCombos: detect_cd_devices: 0
[22:11:06:112] PrefInterface::PrefInterface: icon_dir: "/home/lee/.config/smplayer/themes"
[22:11:06:112] PrefInterface::PrefInterface: icon_dir: "/usr/share/smplayer/themes"
[22:11:06:239] PrefGeneral::player_combo_changed: 2
[22:11:06:240] PrefGeneral::vo_combo_changed: 2
[22:11:06:240] PrefGeneral::ao_combo_changed: 2
[22:11:06:240] PrefSubtitles:on_freetype_check_toggled: 1
[22:11:06:241] Chromecast::localAddresses: "127.0.0.1"
[22:11:06:241] Chromecast::localAddresses: "::1"
[22:11:06:241] Chromecast::localAddresses: "192.168.2.7"
[22:11:06:241] Chromecast::localAddresses: "2a02:85f:e61c:a900:44f5:d631:8200:f9da"
[22:11:06:241] Chromecast::localAddresses: "fe80::a389:f707:9e:8bdd%wlp1s0"
[22:11:11:026] BaseGui::showLog
[22:11:45:910] BaseGui::hideEvent
[22:13:26:324] BaseGui::showEvent
I use SMPlayer daily and it runs flawless… maybe switch between the engines?
Options>Preference>General>Multimedia Engine>MPV or Mplayer.
