I have a dual boot with windows.
Sometimes I get very slow shutdown with some unmounting related text at the end.
Output of journalctl -b -1 | grep -A999 "System is rebooting.\|System is powering down."
I guess you mean the snaps? Remove snapd and install these apps with an official package or with AUR. And this will gone…
pamac remove --unneeded snapd
pamac install bitwarden
pamac build spotify zoom
Thanks, it seemed okay for a while, but still a bit slow and sometimes it still takes a while to shutdown
Mar 29 23:37:11 ww-81fv dbus-daemon[623]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Mar 29 23:37:11 ww-81fv NetworkManager[624]: <info> [1617075431.5325] modem-manager: ModemManager no longer available
Mar 29 23:37:31 ww-81fv kwin_x11[1048]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
I’m a bit confused how to read this output. Which process is causing the lage? NetworkManager or kwin_x11 or neither?
Mar 29 23:37:06 ww-81fv systemd-logind[635]: System is powering down.
Mar 29 23:37:06 ww-81fv sddm[687]: Authentication error: "Process crashed"
Mar 29 23:37:06 ww-81fv sddm[687]: Auth: sddm-helper crashed (exit code 15)
Mar 29 23:37:06 ww-81fv sddm[687]: Auth: sddm-helper exited with 15
Mar 29 23:37:06 ww-81fv sddm[687]: Socket server stopping...
Mar 29 23:37:06 ww-81fv sddm[687]: Socket server stopped.
Mar 29 23:37:06 ww-81fv sddm[687]: Display server stopping...
Mar 29 23:37:06 ww-81fv klauncher[1032]: The X11 connection broke (error 1). Did the X11 server die?
Mar 29 23:37:06 ww-81fv kded5[1044]: bluedevil: Destroyed
Mar 29 23:37:06 ww-81fv kded5[1044]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Mar 29 23:37:06 ww-81fv kglobalaccel5[1065]: The X11 connection broke (error 1). Did the X11 server die?
Mar 29 23:37:06 ww-81fv at-spi-bus-launcher[2525]: X connection to :0 broken (explicit kill or server shutdown).
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Session 2 of user ww.
Mar 29 23:37:06 ww-81fv baloorunner[1581]: The X11 connection broke (error 1). Did the X11 server die?
Mar 29 23:37:06 ww-81fv telegram-desktop[2479]: The X11 connection broke (error 1). Did the X11 server die?
Mar 29 23:37:06 ww-81fv systemd[1]: Removed slice system-getty.slice.
Mar 29 23:37:06 ww-81fv systemd[1]: Removed slice system-modprobe.slice.
Mar 29 23:37:06 ww-81fv systemd[1]: Removed slice system-systemd\x2dcoredump.slice.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped target Bluetooth.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped target Graphical Interface.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped target Sound Card.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped target Timers.
Mar 29 23:37:06 ww-81fv systemd[1]: logrotate.timer: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[991]: plasma-kglobalaccel.service: Main process exited, code=exited, status=1/FAILURE
Mar 29 23:37:06 ww-81fv systemd[991]: plasma-kglobalaccel.service: Failed with result 'exit-code'.
Mar 29 23:37:06 ww-81fv at-spi-bus-launcher[2523]: dbus-daemon[2523]: Activating service name='org.a11y.atspi.Registry' requested by ':1.12' (uid=1000 pid=1068 comm="/usr/lib/kactivitymanagerd ")
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Daily rotation of log files.
Mar 29 23:37:06 ww-81fv systemd[1]: man-db.timer: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Daily man-db regeneration.
Mar 29 23:37:06 ww-81fv systemd[1]: pamac-cleancache.timer: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Monthly clean packages cache.
Mar 29 23:37:06 ww-81fv systemd[1]: pamac-mirrorlist.timer: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Generate mirrorlist weekly.
Mar 29 23:37:06 ww-81fv systemd[1]: shadow.timer: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Daily verification of password and group files.
Mar 29 23:37:06 ww-81fv systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Mar 29 23:37:06 ww-81fv systemd[1]: lvm2-lvmpolld.socket: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Closed LVM2 poll daemon socket.
Mar 29 23:37:06 ww-81fv systemd[1]: systemd-rfkill.socket: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mar 29 23:37:06 ww-81fv bluetoothd[621]: Terminating
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Bluetooth service...
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping CUPS Scheduler...
Mar 29 23:37:06 ww-81fv systemd[1]: Starting Generate shutdown-ramfs...
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Simple Desktop Display Manager...
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Load/Save Random Seed...
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping TLP system startup/shutdown...
Mar 29 23:37:06 ww-81fv systemd[991]: plasma-baloorunner.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Disk Manager...
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Daemon for power management...
Mar 29 23:37:06 ww-81fv systemd[991]: run-media-ww-9270B63170B61BC3.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[991]: run-media-ww-CEB24C78B24C66D5.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[991]: run-media-ww-A03229043228E0D0.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: run-media-ww-9270B63170B61BC3.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Unmounted /run/media/ww/9270B63170B61BC3.
Mar 29 23:37:06 ww-81fv systemd[1]: run-media-ww-CEB24C78B24C66D5.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Unmounted /run/media/ww/CEB24C78B24C66D5.
Mar 29 23:37:06 ww-81fv systemd[1]: run-media-ww-A03229043228E0D0.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Unmounted /run/media/ww/A03229043228E0D0.
Mar 29 23:37:06 ww-81fv systemd[1]: cups.service: Succeeded.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped CUPS Scheduler.
Mar 29 23:37:06 ww-81fv systemd[1]: rtkit-daemon.service: Succeeded.
Mar 29 23:37:06 ww-81fv ntfs-3g[1182]: Unmounting /dev/nvme0n1p3 ()
Mar 29 23:37:06 ww-81fv kernel: audit: type=1131 audit(1617075426.489:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv ntfs-3g[1410]: Unmounting /dev/sda3 ()
Mar 29 23:37:06 ww-81fv ntfs-3g[1412]: Unmounting /dev/sda2 ()
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Mar 29 23:37:06 ww-81fv kernel: audit: type=1131 audit(1617075426.492:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[991]: home-ww-pCloudDrive.mount: Succeeded.
Mar 29 23:37:06 ww-81fv dbus-daemon[1014]: [session uid=1000 pid=1014] Activating via systemd: service name='org.kde.kglobalaccel' unit='plasma-kglobalaccel.service' requested by ':1.8' (uid=1000 pid=1048 comm="/usr/bin/kwin_x11 ")
Mar 29 23:37:06 ww-81fv kded5[1044]: The X11 connection broke: I/O error (code 1)
Mar 29 23:37:06 ww-81fv udisksd[955]: udisks daemon version 2.9.2 exiting
Mar 29 23:37:06 ww-81fv systemd[1]: home-ww-pCloudDrive.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Unmounted /home/ww/pCloudDrive.
Mar 29 23:37:06 ww-81fv systemd[1]: upower.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Daemon for power management.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[1]: systemd-random-seed.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Load/Save Random Seed.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv kernel: audit: type=1131 audit(1617075426.512:157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv kernel: audit: type=1131 audit(1617075426.512:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[1]: udisks2.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Disk Manager.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd-logind[635]: Session 2 logged out. Waiting for processes to exit.
Mar 29 23:37:06 ww-81fv kernel: audit: type=1131 audit(1617075426.515:159): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5221] device (wlp7s0): state change: activated -> deactivating (reason 'connection-removed', sys-iface-state: 'managed')
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5224] manager: NetworkManager state is now DISCONNECTING
Mar 29 23:37:06 ww-81fv mkinitcpio[173038]: ==> Starting build: none
Mar 29 23:37:06 ww-81fv dbus-daemon[623]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=624 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 29 23:37:06 ww-81fv mkinitcpio[173038]: -> Running build hook: [sd-shutdown]
Mar 29 23:37:06 ww-81fv dbus-daemon[623]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Mar 29 23:37:06 ww-81fv audit: BPF prog-id=13 op=UNLOAD
Mar 29 23:37:06 ww-81fv audit: BPF prog-id=12 op=UNLOAD
Mar 29 23:37:06 ww-81fv kernel: audit: type=1334 audit(1617075426.529:160): prog-id=13 op=UNLOAD
Mar 29 23:37:06 ww-81fv kernel: audit: type=1334 audit(1617075426.529:161): prog-id=12 op=UNLOAD
Mar 29 23:37:06 ww-81fv kernel: wlp7s0: deauthenticating from 68:ff:7b:e4:9d:44 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 29 23:37:06 ww-81fv wpa_supplicant[784]: wlp7s0: CTRL-EVENT-DISCONNECTED bssid=68:ff:7b:e4:9d:44 reason=3 locally_generated=1
Mar 29 23:37:06 ww-81fv wpa_supplicant[784]: wlp7s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=0 noise=9999 txrate=0
Mar 29 23:37:06 ww-81fv bluetoothd[621]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc
Mar 29 23:37:06 ww-81fv bluetoothd[621]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5477] device (wlp7s0): supplicant interface state: completed -> disconnected
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5478] device (p2p-dev-wlp7s0): supplicant management interface state: completed -> disconnected
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5479] device (wlp7s0): state change: deactivating -> disconnected (reason 'connection-removed', sys-iface-state: 'managed')
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Withdrawing address record for fe80::d69e:becf:7777:f262 on wlp7s0.
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5483] dhcp4 (wlp7s0): canceled DHCP transaction
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Leaving mDNS multicast group on interface wlp7s0.IPv6 with address fe80::d69e:becf:7777:f262.
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5483] dhcp4 (wlp7s0): state changed extended -> done
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Interface wlp7s0.IPv6 no longer relevant for mDNS.
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5498] device (wlp7s0): set-hw-addr: set MAC address to 66:28:DC:E6:B5:4F (scanning)
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Interface wlp7s0.IPv4 no longer relevant for mDNS.
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Leaving mDNS multicast group on interface wlp7s0.IPv4 with address 192.168.0.168.
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Withdrawing address record for 192.168.0.168 on wlp7s0.
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Joining mDNS multicast group on interface wlp7s0.IPv4 with address 192.168.0.168.
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: New relevant interface wlp7s0.IPv4 for mDNS.
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Registering new address record for 192.168.0.168 on wlp7s0.IPv4.
Mar 29 23:37:06 ww-81fv NetworkManager[624]: <info> [1617075426.5528] manager: NetworkManager state is now DISCONNECTED
Mar 29 23:37:06 ww-81fv systemd[991]: pulseaudio.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[991]: tmp-.mount_pcloud5cevEf.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: tmp-.mount_pcloud5cevEf.mount: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Unmounted /tmp/.mount_pcloud5cevEf.
Mar 29 23:37:06 ww-81fv systemd[991]: app-telegramdesktop-b917c56ce5624311b1013e1b8ed2f4de.scope: Succeeded.
Mar 29 23:37:06 ww-81fv audit[173047]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=173047 comm="pcloud" exe="/pcloud" sig=5 res=1
Mar 29 23:37:06 ww-81fv kernel: traps: pcloud[173047] trap int3 ip:330ddc1 sp:7ffc7dc7ab98 error:0 in pcloud[1011000+3c09000]
Mar 29 23:37:06 ww-81fv kernel: audit: type=1701 audit(1617075426.575:162): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=173047 comm="pcloud" exe="/pcloud" sig=5 res=1
Mar 29 23:37:06 ww-81fv systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-coredump@1-173135-0.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Mar 29 23:37:06 ww-81fv systemd[1]: systemd-coredump.socket: Failed to queue service startup job (Maybe the service file is missing or not a non-template unit?): Transaction for systemd-coredump@1-173135-0.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Mar 29 23:37:06 ww-81fv systemd[1]: systemd-coredump.socket: Failed with result 'resources'.
Mar 29 23:37:06 ww-81fv systemd[991]: app-pcloud-925172dd97954727a60c9689dde897dc.scope: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[991]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 1.
Mar 29 23:37:06 ww-81fv systemd[991]: Stopped KDE Global Shortcuts Server.
Mar 29 23:37:06 ww-81fv systemd[991]: Starting KDE Global Shortcuts Server...
Mar 29 23:37:06 ww-81fv mkinitcpio[173038]: ==> Build complete.
Mar 29 23:37:06 ww-81fv systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Finished Generate shutdown-ramfs.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv kernel: audit: type=1130 audit(1617075426.602:163): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv bluetoothd[621]: Stopping SDP server
Mar 29 23:37:06 ww-81fv bluetoothd[621]: Exit
Mar 29 23:37:06 ww-81fv systemd[1]: bluetooth.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Bluetooth service.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv tlp[173041]: Applying power save settings...done.
Mar 29 23:37:06 ww-81fv systemd[1]: tlp.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped TLP system startup/shutdown.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped target Multi-User System.
Mar 29 23:37:06 ww-81fv systemd[1]: pkgfile-update.timer: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped pkgfile database update timer.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped target Login Prompts.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped target System Time Synchronized.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped target System Time Set.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Modem Manager...
Mar 29 23:37:06 ww-81fv ModemManager[692]: <info> caught signal, shutting down...
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Got SIGTERM, quitting.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Periodic Command Scheduler...
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Logitech Configuration Daemon...
Mar 29 23:37:06 ww-81fv ModemManager[692]: <info> ModemManager is shut down
Mar 29 23:37:06 ww-81fv systemd[1]: ModemManager.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Modem Manager.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv dbus-daemon[623]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.364' (uid=1000 pid=155281 comm="/usr/lib/gvfsd-dnssd --spawner :1.31 /org/gtk/gvfs")
Mar 29 23:37:06 ww-81fv systemd[1]: Stopping Authorization Manager...
Mar 29 23:37:06 ww-81fv dbus-daemon[623]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Refusing activation, D-Bus is shutting down.
Mar 29 23:37:06 ww-81fv crond[622]: (CRON) INFO (Shutting down)
Mar 29 23:37:06 ww-81fv avahi-daemon[620]: avahi-daemon 0.8 exiting.
Mar 29 23:37:06 ww-81fv systemd[1]: cronie.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Periodic Command Scheduler.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[1]: avahi-daemon.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[1]: polkit.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Authorization Manager.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:06 ww-81fv systemd[1]: logid.service: Succeeded.
Mar 29 23:37:06 ww-81fv systemd[1]: Stopped Logitech Configuration Daemon.
Mar 29 23:37:06 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logid comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:07 ww-81fv at-spi2-registr[173035]: Could not open X display
Mar 29 23:37:07 ww-81fv audit[173165]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=173165 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
Mar 29 23:37:07 ww-81fv kglobalaccel5[173165]: qt.qpa.xcb: could not connect to display :0
Mar 29 23:37:07 ww-81fv kglobalaccel5[173165]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Mar 29 23:37:07 ww-81fv kglobalaccel5[173165]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Mar 29 23:37:07 ww-81fv at-spi-bus-launcher[2523]: dbus-daemon[2523]: Successfully activated service 'org.a11y.atspi.Registry'
Mar 29 23:37:07 ww-81fv at-spi2-registr[173035]: AT-SPI: Cannot open default display
Mar 29 23:37:07 ww-81fv at-spi-bus-launcher[173035]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Mar 29 23:37:07 ww-81fv kscreen_backend_launcher[1206]: The X11 connection broke (error 1). Did the X11 server die?
Mar 29 23:37:07 ww-81fv xdg-desktop-portal-kde[2504]: The X11 connection broke (error 1). Did the X11 server die?
Mar 29 23:37:07 ww-81fv kactivitymanagerd[1068]: The X11 connection broke (error 1). Did the X11 server die?
Mar 29 23:37:07 ww-81fv systemd-coredump[173290]: Failed to connect to coredump service: Connection refused
Mar 29 23:37:07 ww-81fv systemd[991]: plasma-kglobalaccel.service: Main process exited, code=dumped, status=6/ABRT
Mar 29 23:37:07 ww-81fv systemd[991]: plasma-kglobalaccel.service: Failed with result 'core-dump'.
Mar 29 23:37:07 ww-81fv systemd[991]: Failed to start KDE Global Shortcuts Server.
Mar 29 23:37:07 ww-81fv sddm[687]: Display server stopped.
Mar 29 23:37:07 ww-81fv sddm[687]: Running display stop script "/usr/share/sddm/scripts/Xstop"
Mar 29 23:37:07 ww-81fv sddm[687]: Removing display ":0" ...
Mar 29 23:37:07 ww-81fv sddm[687]: Adding new display on vt 1 ...
Mar 29 23:37:07 ww-81fv sddm[687]: Loading theme configuration from ""
Mar 29 23:37:07 ww-81fv sddm[687]: Display server starting...
Mar 29 23:37:07 ww-81fv sddm[687]: Adding cookie to "/var/run/sddm/{10fd7db0-349c-4540-8c40-3e05789a1302}"
Mar 29 23:37:07 ww-81fv sddm[687]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{10fd7db0-349c-4540-8c40-3e05789a1302} -noreset -displayfd 18
Mar 29 23:37:07 ww-81fv systemd[991]: plasma-kactivitymanagerd.service: Succeeded.
Mar 29 23:37:07 ww-81fv systemd[991]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 2.
Mar 29 23:37:07 ww-81fv systemd[991]: Stopped KDE Global Shortcuts Server.
Mar 29 23:37:07 ww-81fv systemd[991]: Starting KDE Global Shortcuts Server...
Mar 29 23:37:08 ww-81fv kernel: nvidia 0000:01:00.0: Enabling HDA controller
Mar 29 23:37:09 ww-81fv sddm[687]: Setting default cursor
Mar 29 23:37:10 ww-81fv kglobalaccel5[173296]: qt.qpa.xcb: could not connect to display :0
Mar 29 23:37:10 ww-81fv audit[173296]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=173296 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
Mar 29 23:37:10 ww-81fv kglobalaccel5[173296]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Mar 29 23:37:10 ww-81fv kglobalaccel5[173296]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Mar 29 23:37:10 ww-81fv sddm[687]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
Mar 29 23:37:10 ww-81fv sddm[687]: Display server started.
Mar 29 23:37:10 ww-81fv kglobalaccel5[173296]: Invalid MIT-MAGIC-COOKIE-1 key
Mar 29 23:37:10 ww-81fv sddm[687]: Socket server starting...
Mar 29 23:37:10 ww-81fv sddm[687]: Socket server started.
Mar 29 23:37:10 ww-81fv sddm[687]: Loading theme configuration from "/usr/share/sddm/themes/breath2/theme.conf"
Mar 29 23:37:10 ww-81fv systemd-coredump[173311]: Failed to connect to coredump service: Connection refused
Mar 29 23:37:10 ww-81fv sddm[687]: Greeter starting...
Mar 29 23:37:10 ww-81fv sddm[687]: Signal received: SIGTERM
Mar 29 23:37:10 ww-81fv sddm[687]: Socket server stopping...
Mar 29 23:37:10 ww-81fv sddm[687]: Socket server stopped.
Mar 29 23:37:10 ww-81fv sddm[687]: Display server stopping...
Mar 29 23:37:10 ww-81fv systemd[991]: plasma-kglobalaccel.service: Main process exited, code=dumped, status=6/ABRT
Mar 29 23:37:10 ww-81fv systemd[991]: plasma-kglobalaccel.service: Failed with result 'core-dump'.
Mar 29 23:37:10 ww-81fv audit[173315]: USER_AUTH pid=173315 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:10 ww-81fv audit[173315]: USER_ACCT pid=173315 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:10 ww-81fv systemd[991]: Failed to start KDE Global Shortcuts Server.
Mar 29 23:37:10 ww-81fv sddm-helper[173315]: [PAM] Starting...
Mar 29 23:37:10 ww-81fv sddm-helper[173315]: [PAM] Authenticating...
Mar 29 23:37:10 ww-81fv sddm-helper[173315]: [PAM] returning.
Mar 29 23:37:10 ww-81fv systemd[991]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 3.
Mar 29 23:37:10 ww-81fv systemd[991]: Stopped KDE Global Shortcuts Server.
Mar 29 23:37:10 ww-81fv systemd[991]: Starting KDE Global Shortcuts Server...
Mar 29 23:37:10 ww-81fv audit[173316]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=173316 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
Mar 29 23:37:10 ww-81fv kglobalaccel5[173316]: qt.qpa.xcb: could not connect to display :0
Mar 29 23:37:10 ww-81fv kglobalaccel5[173316]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Mar 29 23:37:10 ww-81fv kglobalaccel5[173316]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Mar 29 23:37:10 ww-81fv systemd-coredump[173318]: Failed to connect to coredump service: Connection refused
Mar 29 23:37:10 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:10 ww-81fv sddm[687]: Display server stopped.
Mar 29 23:37:10 ww-81fv sddm[687]: Running display stop script "/usr/share/sddm/scripts/Xstop"
Mar 29 23:37:10 ww-81fv sddm[687]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Mar 29 23:37:10 ww-81fv systemd[1]: sddm.service: Succeeded.
Mar 29 23:37:10 ww-81fv systemd[1]: Stopped Simple Desktop Display Manager.
Mar 29 23:37:10 ww-81fv systemd[991]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 4.
Mar 29 23:37:10 ww-81fv kglobalaccel5[173322]: qt.qpa.xcb: could not connect to display :0
Mar 29 23:37:10 ww-81fv audit[173322]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=173322 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
Mar 29 23:37:10 ww-81fv kglobalaccel5[173322]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Mar 29 23:37:10 ww-81fv kglobalaccel5[173322]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Mar 29 23:37:10 ww-81fv systemd-coredump[173323]: Failed to connect to coredump service: Connection refused
Mar 29 23:37:11 ww-81fv systemd[991]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 5.
Mar 29 23:37:11 ww-81fv systemd[991]: Stopped KDE Global Shortcuts Server.
Mar 29 23:37:11 ww-81fv systemd[991]: Starting KDE Global Shortcuts Server...
Mar 29 23:37:11 ww-81fv kglobalaccel5[173326]: qt.qpa.xcb: could not connect to display :0
Mar 29 23:37:11 ww-81fv audit[173326]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=173326 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
Mar 29 23:37:11 ww-81fv kglobalaccel5[173326]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Mar 29 23:37:11 ww-81fv kglobalaccel5[173326]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Mar 29 23:37:11 ww-81fv systemd-coredump[173327]: Failed to connect to coredump service: Connection refused
Mar 29 23:37:11 ww-81fv systemd[991]: plasma-kglobalaccel.service: Main process exited, code=dumped, status=6/ABRT
Mar 29 23:37:11 ww-81fv systemd[991]: plasma-kglobalaccel.service: Failed with result 'core-dump'.
Mar 29 23:37:11 ww-81fv systemd[991]: Failed to start KDE Global Shortcuts Server.
Mar 29 23:37:11 ww-81fv systemd[991]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 6.
Mar 29 23:37:11 ww-81fv systemd[991]: plasma-kglobalaccel.service: Start request repeated too quickly.
Mar 29 23:37:11 ww-81fv dbus-daemon[623]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=624 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 29 23:37:31 ww-81fv systemd[1]: session-2.scope: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Session 2 of user ww.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping User Login Management...
Mar 29 23:37:31 ww-81fv pipewire[2509]: Asked to handle disabled watch: 0x555a2b270140 21
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping User Manager for UID 1000...
Mar 29 23:37:31 ww-81fv systemd-logind[635]: Removed session 2.
Mar 29 23:37:31 ww-81fv systemd[991]: Removed slice User Background Tasks Slice.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped target Main User Target.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping AppImageLauncher daemon...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Accessibility services bus...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping D-Bus User Message Bus...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping User preferences database...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Virtual filesystem service - Apple File Conduit monitor...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Virtual filesystem service...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Virtual filesystem service - digital camera monitor...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Virtual filesystem service - disk device monitor...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Bluetooth OBEX service...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Multimedia Service...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping Portal service...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping flatpak document portal service...
Mar 29 23:37:31 ww-81fv systemd[991]: Stopping sandboxed app permission store...
Mar 29 23:37:31 ww-81fv systemd[991]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Mar 29 23:37:31 ww-81fv systemd[991]: xdg-permission-store.service: Failed with result 'exit-code'.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped sandboxed app permission store.
Mar 29 23:37:31 ww-81fv systemd[991]: gvfs-mtp-volume-monitor.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Mar 29 23:37:31 ww-81fv systemd[991]: dconf.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped User preferences database.
Mar 29 23:37:31 ww-81fv systemd[991]: obex.service: Main process exited, code=exited, status=1/FAILURE
Mar 29 23:37:31 ww-81fv systemd[991]: obex.service: Failed with result 'exit-code'.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Bluetooth OBEX service.
Mar 29 23:37:31 ww-81fv systemd[991]: pipewire.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Multimedia Service.
Mar 29 23:37:31 ww-81fv systemd[991]: gvfs-gphoto2-volume-monitor.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Virtual filesystem service - digital camera monitor.
Mar 29 23:37:31 ww-81fv systemd[991]: Removed slice User Core Session Slice.
Mar 29 23:37:31 ww-81fv systemd[1]: run-user-1000-doc.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: run-user-1000-doc.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounted /run/user/1000/doc.
Mar 29 23:37:31 ww-81fv systemd[991]: xdg-document-portal.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped flatpak document portal service.
Mar 29 23:37:31 ww-81fv systemd[1]: run-user-1000-gvfs.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounted /run/user/1000/gvfs.
Mar 29 23:37:31 ww-81fv systemd[991]: run-user-1000-gvfs.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: appimagelauncherd.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped AppImageLauncher daemon.
Mar 29 23:37:31 ww-81fv systemd[991]: at-spi-dbus-bus.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Accessibility services bus.
Mar 29 23:37:31 ww-81fv systemd[991]: dbus.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped D-Bus User Message Bus.
Mar 29 23:37:31 ww-81fv systemd[991]: xdg-desktop-portal.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Portal service.
Mar 29 23:37:31 ww-81fv systemd[991]: gvfs-udisks2-volume-monitor.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Virtual filesystem service - disk device monitor.
Mar 29 23:37:31 ww-81fv systemd[991]: gvfs-afc-volume-monitor.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Mar 29 23:37:31 ww-81fv systemd[991]: gvfs-daemon.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped Virtual filesystem service.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped target Basic System.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped target Paths.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped target Sockets.
Mar 29 23:37:31 ww-81fv systemd[991]: Stopped target Timers.
Mar 29 23:37:31 ww-81fv systemd[991]: dbus.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed D-Bus User Message Bus Socket.
Mar 29 23:37:31 ww-81fv systemd[991]: dirmngr.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed GnuPG network certificate management daemon.
Mar 29 23:37:31 ww-81fv systemd[991]: gpg-agent-browser.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 29 23:37:31 ww-81fv systemd[991]: gpg-agent-extra.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Mar 29 23:37:31 ww-81fv systemd[991]: gpg-agent-ssh.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Mar 29 23:37:31 ww-81fv systemd[991]: gpg-agent.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed GnuPG cryptographic agent and passphrase cache.
Mar 29 23:37:31 ww-81fv systemd[991]: p11-kit-server.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed p11-kit server.
Mar 29 23:37:31 ww-81fv systemd[991]: pipewire.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed Multimedia System.
Mar 29 23:37:31 ww-81fv systemd[991]: pulseaudio.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Closed Sound System.
Mar 29 23:37:31 ww-81fv systemd[991]: Removed slice User Application Slice.
Mar 29 23:37:31 ww-81fv systemd[991]: Reached target Shutdown.
Mar 29 23:37:31 ww-81fv systemd[991]: systemd-exit.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[991]: Finished Exit the Session.
Mar 29 23:37:31 ww-81fv systemd[991]: Reached target Exit the Session.
Mar 29 23:37:31 ww-81fv systemd[992]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[ww] ruser=[<unknown>] rhost=[<unknown>]
Mar 29 23:37:31 ww-81fv systemd[1]: user@1000.service: Succeeded.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped User Manager for UID 1000.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping User Runtime Directory /run/user/1000...
Mar 29 23:37:31 ww-81fv kernel: kauditd_printk_skb: 16 callbacks suppressed
Mar 29 23:37:31 ww-81fv kernel: audit: type=1131 audit(1617075451.529:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: run-user-1000.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounted /run/user/1000.
Mar 29 23:37:31 ww-81fv systemd[1]: user-runtime-dir@1000.service: Succeeded.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped User Runtime Directory /run/user/1000.
Mar 29 23:37:31 ww-81fv systemd[1]: Removed slice User Slice of UID 1000.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping Permit User Sessions...
Mar 29 23:37:31 ww-81fv kernel: audit: type=1131 audit(1617075451.535:181): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-logind.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped User Login Management.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-user-sessions.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Permit User Sessions.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Network.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Remote File Systems.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping Network Manager...
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping WPA supplicant...
Mar 29 23:37:31 ww-81fv NetworkManager[624]: <info> [1617075451.5441] caught SIGTERM, shutting down normally.
Mar 29 23:37:31 ww-81fv wpa_supplicant[784]: nl80211: deinit ifname=p2p-dev-wlp7s0 disabled_11b_rates=0
Mar 29 23:37:31 ww-81fv NetworkManager[624]: <info> [1617075451.5449] device (wlp7s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Mar 29 23:37:31 ww-81fv kernel: audit: type=1131 audit(1617075451.539:182): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv kernel: audit: type=1131 audit(1617075451.539:183): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv NetworkManager[624]: <info> [1617075451.5459] device (wlp7s0): set-hw-addr: reset MAC address to 34:E1:2D:B8:FF:38 (unmanage)
Mar 29 23:37:31 ww-81fv audit: BPF prog-id=8 op=UNLOAD
Mar 29 23:37:31 ww-81fv audit: BPF prog-id=7 op=UNLOAD
Mar 29 23:37:31 ww-81fv NetworkManager[624]: <info> [1617075451.5654] device (p2p-dev-wlp7s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 29 23:37:31 ww-81fv dbus-daemon[623]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=624 comm="/usr/bin/NetworkManager --no-daemon ")
Mar 29 23:37:31 ww-81fv dbus-daemon[623]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Mar 29 23:37:31 ww-81fv kernel: audit: type=1334 audit(1617075451.562:184): prog-id=8 op=UNLOAD
Mar 29 23:37:31 ww-81fv kernel: audit: type=1334 audit(1617075451.562:185): prog-id=7 op=UNLOAD
Mar 29 23:37:31 ww-81fv wpa_supplicant[784]: p2p-dev-wlp7s0: CTRL-EVENT-TERMINATING
Mar 29 23:37:31 ww-81fv NetworkManager[624]: <info> [1617075451.6537] exiting (success)
Mar 29 23:37:31 ww-81fv systemd[1]: NetworkManager.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Network Manager.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv kernel: audit: type=1131 audit(1617075451.665:186): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv wpa_supplicant[784]: nl80211: deinit ifname=wlp7s0 disabled_11b_rates=0
Mar 29 23:37:31 ww-81fv wpa_supplicant[784]: wlp7s0: CTRL-EVENT-TERMINATING
Mar 29 23:37:31 ww-81fv systemd[1]: wpa_supplicant.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped WPA supplicant.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv kernel: audit: type=1131 audit(1617075451.745:187): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping D-Bus System Message Bus...
Mar 29 23:37:31 ww-81fv systemd[1]: dbus.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped D-Bus System Message Bus.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Basic System.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Paths.
Mar 29 23:37:31 ww-81fv systemd[1]: cups.path: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped CUPS Scheduler.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Slices.
Mar 29 23:37:31 ww-81fv kernel: audit: type=1131 audit(1617075451.759:188): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Removed slice User and Session Slice.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Sockets.
Mar 29 23:37:31 ww-81fv systemd[1]: avahi-daemon.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Mar 29 23:37:31 ww-81fv systemd[1]: cups.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Closed CUPS Scheduler.
Mar 29 23:37:31 ww-81fv systemd[1]: dbus.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Closed D-Bus System Message Bus Socket.
Mar 29 23:37:31 ww-81fv systemd[1]: snapd.socket: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Closed Socket activation for snappy daemon.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target System Initialization.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Local Encrypted Volumes.
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-ask-password-console.path: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-ask-password-wall.path: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping Set Up Additional Binary Formats...
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-sysctl.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Apply Kernel Variables.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-modules-load.service: Succeeded.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Load Kernel Modules.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping Network Time Synchronization...
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-update-done.service: Succeeded.
Mar 29 23:37:31 ww-81fv kernel: audit: type=1131 audit(1617075451.779:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Update is Completed.
Mar 29 23:37:31 ww-81fv systemd[1]: ldconfig.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-journal-catalog-update.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Rebuild Journal Catalog.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-backlight@backlight:intel_backlight.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-binfmt.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Set Up Additional Binary Formats.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-timesyncd.service: Succeeded.
Mar 29 23:37:31 ww-81fv audit[173350]: SYSTEM_SHUTDOWN pid=173350 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Network Time Synchronization.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Removed slice system-systemd\x2dbacklight.slice.
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-update-utmp.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Create Volatile Files and Directories.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Local File Systems.
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounting /boot/efi...
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounting /run/media/ww/EE5C-6E50...
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounting /run/timeshift/backup...
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounting Temporary Directory (/tmp)...
Mar 29 23:37:31 ww-81fv systemd[1]: run-media-ww-EE5C\x2d6E50.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounted /run/media/ww/EE5C-6E50.
Mar 29 23:37:31 ww-81fv systemd[1]: run-timeshift-backup.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounted /run/timeshift/backup.
Mar 29 23:37:31 ww-81fv systemd[1]: boot-efi.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounted /boot/efi.
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-fsck@dev-disk-by\x2duuid-0227\x2dCDD9.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped File System Check on /dev/disk/by-uuid/0227-CDD9.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-0227\x2dCDD9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Removed slice system-systemd\x2dfsck.slice.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Local File Systems (Pre).
Mar 29 23:37:31 ww-81fv systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Create Static Device Nodes in /dev.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-sysusers.service: Succeeded.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Create System Users.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-remount-fs.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Remount Root and Kernel File Systems.
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-fsck-root.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped File System Check on Root Device.
Mar 29 23:37:31 ww-81fv systemd[1]: tmp.mount: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Unmounted Temporary Directory (/tmp).
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped target Swap.
Mar 29 23:37:31 ww-81fv systemd[1]: Reached target Unmount All Filesystems.
Mar 29 23:37:31 ww-81fv systemd[1]: lvm2-monitor.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Reached target Shutdown.
Mar 29 23:37:31 ww-81fv systemd[1]: Reached target Final Step.
Mar 29 23:37:31 ww-81fv systemd[1]: systemd-poweroff.service: Succeeded.
Mar 29 23:37:31 ww-81fv systemd[1]: Finished Power-Off.
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-poweroff comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-poweroff comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 29 23:37:31 ww-81fv systemd[1]: Reached target Power-Off.
Mar 29 23:37:31 ww-81fv systemd[1]: Shutting down.
Mar 29 23:37:31 ww-81fv audit: BPF prog-id=6 op=UNLOAD
Mar 29 23:37:31 ww-81fv audit: BPF prog-id=5 op=UNLOAD
Mar 29 23:37:31 ww-81fv audit: BPF prog-id=4 op=UNLOAD
Mar 29 23:37:31 ww-81fv audit: BPF prog-id=3 op=UNLOAD
Mar 29 23:37:32 ww-81fv systemd-shutdown[1]: Syncing filesystems and block devices.
Mar 29 23:37:32 ww-81fv systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Mar 29 23:37:32 ww-81fv systemd-journald[277]: Journal stopped
@heavenhaeven Well, under 30sec for a shutdown is not really long. I would rather expect, that this is a HDD and not a SSD. Is that correct?
inxi -Dazy
If so, then nothing can be done there. Under 30sec is for a full featured Desktop on a HDD not long.
Local Storage: total: 1.36 TiB used: 1.06 TiB (77.8%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 2B2QEXM7 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: LCM2 scheme: MBR
It’s 970 Evo+, so I assumed it should be fast enough.
Looks like yet another instance of this problem:
which is this KDE bug.
