Getting more frequent "A stop job is running" notices than before
Ever since the KDE 5.21 and kernel 5.11 landed in testing, I’ve noticed that I’m getting “A stop job is running” notices a lot more often at shutdown and reboot. Getting a snappy shutdown/reboot seems more of an anomaly now.
Usually it’s for Session 2, but sometimes UID 1000 as well.
inxi -Fxza
System:    Kernel: 5.11.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=c28c9ba1-1ab9-48ed-a6c3-a5cf6794acea ro apparmor=1
           security=apparmor udev.log_priority=3 sysrq_always_enabled=1
           Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0 serial: <filter>
           UEFI: American Megatrends LLC. v: 2.C0 date: 02/01/2021
CPU:       Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
           microcode: 800820D L2 cache: 4 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118432
           Speed: 1862 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 1862 2: 2075 3: 2104 4: 4009 5: 1887
           6: 1887 7: 1887 8: 1893 9: 2617 10: 3499 11: 2197 12: 2198 13: 2199 14: 2201 15: 2523 16: 2137
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm
           bus ID: 26:00.0 chip ID: 10de:1b06 class ID: 0300
           Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia display ID: :0 screens: 1
           Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5") s-diag: 692mm (27.3")
           Monitor-1: DP-0 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
           OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56 direct render: Yes
Audio:     Device-1: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 26:00.1
           chip ID: 10de:10ef class ID: 0403
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus ID: 28:00.3 chip ID: 1022:1457 class ID: 0403
           Device-3: GYROCOM C&C UAC1 DAC type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-10:2 chip ID: 1852:5110
           class ID: 0102
           Sound Server: ALSA v: k5.11.5-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
           port: e000 bus ID: 22:00.0 chip ID: 10ec:8168 class ID: 0200
           IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
RAID:      Supported mdraid levels: raid0
           Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active size: 744.74 GiB
           Info: report: N/A blocks: 780914688 chunk size: 512k super blocks: 1.2
           Components: Online:
           0: sdb maj-min: 8:16 size: 186.31 GiB
           1: sdc maj-min: 8:32 size: 186.31 GiB
           2: sdd maj-min: 8:48 size: 186.31 GiB
           3: sde maj-min: 8:64 size: 186.31 GiB
Drives:    Local Storage: total: raw: 1.18 TiB usable: 1.18 TiB used: 440.84 GiB (36.4%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 4B6Q scheme: GPT
           ID-2: /dev/sdb maj-min: 8:16 model: SSD 910 200GB size: 186.31 GiB block size: physical: 4096 B logical: 512 B
           rotation: SSD serial: N/A rev: a424
           ID-3: /dev/sdc maj-min: 8:32 model: SSD 910 200GB size: 186.31 GiB block size: physical: 4096 B logical: 512 B
           ID-4: /dev/sdd maj-min: 8:48 model: SSD 910 200GB size: 186.31 GiB block size: physical: 4096 B logical: 512 B
           ID-5: /dev/sde maj-min: 8:64 model: SSD 910 200GB size: 186.31 GiB block size: physical: 4096 B logical: 512 B
Partition: ID-1: / raw size: 465.26 GiB size: 456.96 GiB (98.22%) used: 193.62 GiB (42.4%) fs: ext4 dev: /dev/sda2
           maj-min: 8:2
           ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%) used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 47.6 C mobo: 41.0 C gpu: nvidia temp: 47 C
           Fan Speeds (RPM): fan-1: 0 fan-2: 1335 fan-3: 1011 fan-4: 637 fan-5: 867 gpu: nvidia fan: 39%
Info:      Processes: 312 Uptime: 9m wakeups: 0 Memory: 31.35 GiB used: 2.76 GiB (8.8%) Init: systemd v: 247 Compilers:
           gcc: 10.2.0 Packages: pacman: 1377 lib: 424 Shell: Zsh v: 5.8 running in: yakuake inxi: 3.3.01
journalctl from my last boot where I got Session 2 notice, from logout prompt to shutdown
maalis 10 18:53:09 jp-gentoo dbus-daemon[1106]: [session uid=1000 pid=1106] Activating service name='org.kde.LogoutPrompt' requested by ':1.15' (uid=1000 pid=1221 comm="/usr/bin/ksmserver ")
maalis 10 18:53:10 jp-gentoo dbus-daemon[1106]: [session uid=1000 pid=1106] Successfully activated service 'org.kde.LogoutPrompt'
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
maalis 10 18:53:10 jp-gentoo ksmserver-logout-greeter[3756]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/components/UserDelegate.qml:31: ReferenceError: model is not defined
maalis 10 18:53:12 jp-gentoo dbus-daemon[1106]: [session uid=1000 pid=1106] Activating service name='org.kde.Shutdown' requested by ':1.62' (uid=1000 pid=3756 comm="/usr/lib/ksmserver-logout-greeter ")
maalis 10 18:53:12 jp-gentoo dbus-daemon[1106]: [session uid=1000 pid=1106] Successfully activated service 'org.kde.Shutdown'
maalis 10 18:53:12 jp-gentoo polkit-kde-authentication-agent-1[1235]: Destroying listener
maalis 10 18:53:12 jp-gentoo polkit-kde-authentication-agent-1[1235]: Removing listener  PolkitQt1::Agent::Listener(0x557bdd18bd50)
maalis 10 18:53:12 jp-gentoo msm_kde_notifier[1265]: Shutting down MSM Notifier...
maalis 10 18:53:12 jp-gentoo polkitd[721]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.35, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29565, resource id: 25165830, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29569, resource id: 44040197, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29575, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29579, resource id: 37748741, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo kded5[1168]: Service  ":1.33" unregistered
maalis 10 18:53:12 jp-gentoo kded5[1168]: Service  ":1.32" unregistered
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29583, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29593, resource id: 62914585, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29599, resource id: 35651589, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo sddm[1110]: kwalletd5: Checking for pam module
maalis 10 18:53:12 jp-gentoo sddm[1110]: kwalletd5: Got pam-login param
maalis 10 18:53:12 jp-gentoo sddm[1110]: kwalletd5: Waiting for hash on 7-
maalis 10 18:53:12 jp-gentoo sddm[1110]: kwalletd5: waitingForEnvironment on: 8
maalis 10 18:53:12 jp-gentoo sddm[1110]: kwalletd5: client connected
maalis 10 18:53:12 jp-gentoo sddm[1110]: kwalletd5: client disconnected
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29603, resource id: 27262981, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29607, resource id: 46137376, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:31: TypeError: Cannot read property 'formFactor' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:103: TypeError: Cannot read property 'editMode' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:48: TypeError: Cannot read property 'editMode' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:37: TypeError: Cannot read property 'editMode' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: trying to show an empty dialog
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:30: TypeError: Cannot read property 'enabledBorders' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardindicator/contents/ui/main.qml:20: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: libkcups: Cancel-Subscription last error: 0 successful-ok
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/main.qml:38: TypeError: Cannot read property 'formFactor' of null
maalis 10 18:53:12 jp-gentoo dbus-daemon[1106]: [session uid=1000 pid=1106] Activating service name='org.kde.kdeconnect' requested by ':1.24' (uid=1000 pid=1241 comm="/usr/bin/plasmashell ")
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/main.qml:149: TypeError: Cannot read property 'nativeInterface' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:79:5: Unable to assign [undefined] to QObject*
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:176: TypeError: Cannot read property 'nativeInterface' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:37: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:241: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:247: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:253: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:261: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:40: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: qrc:/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:82: TypeError: Cannot read property 'expanded' of null
maalis 10 18:53:12 jp-gentoo kded5[1168]: Service  "org.kde.StatusNotifierHost-1241" unregistered
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:109: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:110: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:101: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:37: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:83: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:72: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:98: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:76: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:53: TypeError: Cannot read property 'compactRepresentationItem' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:222: TypeError: Cannot read property 'globalAction' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:211: TypeError: Cannot read property 'action' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:205: TypeError: Cannot read property 'action' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:33: TypeError: Cannot read property 'editMode' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:46: TypeError: Cannot read property 'editMode' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:47: TypeError: Cannot read property 'editMode' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75: TypeError: Cannot read property 'pluginName' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:77: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:78: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:79: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:80: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:32: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:33: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:34: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:35: TypeError: Cannot read property 'configuration' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: QObject::disconnect: Unexpected nullptr parameter
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:121: TypeError: Cannot read property 'x' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:135: TypeError: Cannot read property 'y' of null
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-Yoyodyne_Consulting_UAC1_DAC-01.analog-stereo.monitor"
maalis 10 18:53:12 jp-gentoo plasmashell[1241]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-Yoyodyne_Consulting_UAC1_DAC-01.analog-stereo"
maalis 10 18:53:12 jp-gentoo kwin_x11[1172]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29744, resource id: 23068680, major code: 18 (ChangeProperty), minor code: 0
maalis 10 18:53:12 jp-gentoo systemd-logind[735]: System is rebooting.
maalis 10 18:53:12 jp-gentoo kded5[1168]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
maalis 10 18:53:12 jp-gentoo sddm[791]: Authentication error: "Process crashed"
maalis 10 18:53:12 jp-gentoo sddm[791]: Auth: sddm-helper crashed (exit code 15)
maalis 10 18:53:12 jp-gentoo sddm[791]: Auth: sddm-helper exited with 15
maalis 10 18:53:12 jp-gentoo sddm[791]: Socket server stopping...
maalis 10 18:53:12 jp-gentoo sddm[791]: Socket server stopped.
maalis 10 18:53:12 jp-gentoo sddm[791]: Display server stopping...
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Session 2 of user jp.
maalis 10 18:53:12 jp-gentoo xdg-desktop-portal-kde[1457]: The X11 connection broke (error 1). Did the X11 server die?
maalis 10 18:53:12 jp-gentoo systemd[1]: Removed slice system-getty.slice.
maalis 10 18:53:12 jp-gentoo systemd[1]: Removed slice system-modprobe.slice.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped target Graphical Interface.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped target Sound Card.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped target Timers.
maalis 10 18:53:12 jp-gentoo systemd[1]: fstrim.timer: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Discard unused blocks once a week.
maalis 10 18:53:12 jp-gentoo kactivitymanagerd[1193]: The X11 connection broke (error 1). Did the X11 server die?
maalis 10 18:53:12 jp-gentoo systemd[1]: logrotate.timer: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Daily rotation of log files.
maalis 10 18:53:12 jp-gentoo systemd[1]: man-db.timer: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Daily man-db regeneration.
maalis 10 18:53:12 jp-gentoo systemd[1]: pamac-cleancache.timer: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Monthly clean packages cache.
maalis 10 18:53:12 jp-gentoo systemd[1]: pamac-mirrorlist.timer: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Generate mirrorlist weekly.
maalis 10 18:53:12 jp-gentoo systemd[1]: shadow.timer: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Daily verification of password and group files.
maalis 10 18:53:12 jp-gentoo systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
maalis 10 18:53:12 jp-gentoo kglobalaccel5[1218]: The X11 connection broke (error 1). Did the X11 server die?
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Daily Cleanup of Temporary Directories.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped target System Time Synchronized.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped target System Time Set.
maalis 10 18:53:12 jp-gentoo systemd[1]: lvm2-lvmpolld.socket: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Closed LVM2 poll daemon socket.
maalis 10 18:53:12 jp-gentoo systemd[1]: systemd-rfkill.socket: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
maalis 10 18:53:12 jp-gentoo at-spi-bus-launcher[1423]: X connection to :0 broken (explicit kill or server shutdown).
maalis 10 18:53:12 jp-gentoo kscreen_backend_launcher[1365]: The X11 connection broke (error 1). Did the X11 server die?
maalis 10 18:53:12 jp-gentoo dbus-daemon[1106]: [session uid=1000 pid=1106] Activating via systemd: service name='org.kde.kglobalaccel' unit='plasma-kglobalaccel.service' requested by ':1.11' (uid=1000 pid=1172 comm="/usr/b>
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Save/Restore Sound Card State...
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping CUPS Scheduler...
maalis 10 18:53:12 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Starting Generate shutdown-ramfs...
maalis 10 18:53:12 jp-gentoo systemd[1095]: Starting KDE Global Shortcuts Server...
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Simple Desktop Display Manager...
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Load/Save Random Seed...
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping TLP system startup/shutdown...
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Disk Manager...
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Daemon for power management...
maalis 10 18:53:12 jp-gentoo kded5[1168]: The X11 connection broke: I/O error (code 1)
maalis 10 18:53:12 jp-gentoo systemd[1]: cups.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1095]: plasma-kactivitymanagerd.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped CUPS Scheduler.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo systemd[1]: upower.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Daemon for power management.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo udisksd[1035]: udisks daemon version 2.9.2 exiting
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1131 audit(1615395192.491:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? term>
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1131 audit(1615395192.491:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? te>
maalis 10 18:53:12 jp-gentoo systemd[1]: rtkit-daemon.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo systemd[1]: alsa-restore.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Save/Restore Sound Card State.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1131 audit(1615395192.494:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? add>
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1131 audit(1615395192.494:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? add>
maalis 10 18:53:12 jp-gentoo systemd[1]: systemd-random-seed.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Load/Save Random Seed.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=su>
maalis 10 18:53:12 jp-gentoo systemd-logind[735]: Session 2 logged out. Waiting for processes to exit.
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1131 audit(1615395192.497:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostnam>
maalis 10 18:53:12 jp-gentoo mkinitcpio[3776]: ==> Starting build: none
maalis 10 18:53:12 jp-gentoo systemd[1]: udisks2.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Disk Manager.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo mkinitcpio[3776]:   -> Running build hook: [sd-shutdown]
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1131 audit(1615395192.507:93): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? t>
maalis 10 18:53:12 jp-gentoo audit: BPF prog-id=13 op=UNLOAD
maalis 10 18:53:12 jp-gentoo audit: BPF prog-id=12 op=UNLOAD
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1334 audit(1615395192.527:94): prog-id=13 op=UNLOAD
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1334 audit(1615395192.527:95): prog-id=12 op=UNLOAD
maalis 10 18:53:12 jp-gentoo systemd[1095]: pulseaudio.service: Succeeded.
maalis 10 18:53:12 jp-gentoo mkinitcpio[3776]: ==> Build complete.
maalis 10 18:53:12 jp-gentoo systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Finished Generate shutdown-ramfs.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? t>
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? te>
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1130 audit(1615395192.587:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/s>
maalis 10 18:53:12 jp-gentoo kernel: audit: type=1131 audit(1615395192.587:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/s>
maalis 10 18:53:12 jp-gentoo tlp[3780]: Applying power save settings...done.
maalis 10 18:53:12 jp-gentoo systemd[1]: tlp.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped TLP system startup/shutdown.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped target Multi-User System.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped target Login Prompts.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Modem Manager...
maalis 10 18:53:12 jp-gentoo ModemManager[799]: <info>  caught signal, shutting down...
maalis 10 18:53:12 jp-gentoo avahi-daemon[711]: Got SIGTERM, quitting.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
maalis 10 18:53:12 jp-gentoo avahi-daemon[711]: Leaving mDNS multicast group on interface enp34s0.IPv6 with address 2001:14ba:a4ed:9201:d0f7:aee6:d661:1821.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Periodic Command Scheduler...
maalis 10 18:53:12 jp-gentoo avahi-daemon[711]: Leaving mDNS multicast group on interface enp34s0.IPv4 with address 192.168.0.103.
maalis 10 18:53:12 jp-gentoo avahi-daemon[711]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
maalis 10 18:53:12 jp-gentoo avahi-daemon[711]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
maalis 10 18:53:12 jp-gentoo NetworkManager[714]: <info>  [1615395192.7035] modem-manager: ModemManager no longer available
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Initialize hardware monitoring sensors...
maalis 10 18:53:12 jp-gentoo ModemManager[799]: <info>  ModemManager is shut down
maalis 10 18:53:12 jp-gentoo systemd[1]: ModemManager.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Modem Manager.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopping Authorization Manager...
maalis 10 18:53:12 jp-gentoo crond[712]: (CRON) INFO (Shutting down)
maalis 10 18:53:12 jp-gentoo avahi-daemon[711]: avahi-daemon 0.8 exiting.
maalis 10 18:53:12 jp-gentoo systemd[1]: cronie.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Periodic Command Scheduler.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo systemd[1]: avahi-daemon.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo systemd[1]: polkit.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Authorization Manager.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:12 jp-gentoo systemd[1]: lm_sensors.service: Succeeded.
maalis 10 18:53:12 jp-gentoo systemd[1]: Stopped Initialize hardware monitoring sensors.
maalis 10 18:53:12 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lm_sensors comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:13 jp-gentoo kglobalaccel5[3777]: qt.qpa.xcb: could not connect to display :0
maalis 10 18:53:13 jp-gentoo audit[3777]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=3777 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
maalis 10 18:53:13 jp-gentoo kglobalaccel5[3777]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
maalis 10 18:53:13 jp-gentoo kglobalaccel5[3777]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                  Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
maalis 10 18:53:13 jp-gentoo sddm[791]: Display server stopped.
maalis 10 18:53:13 jp-gentoo sddm[791]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
maalis 10 18:53:13 jp-gentoo sddm[791]: Removing display ":0" ...
maalis 10 18:53:13 jp-gentoo sddm[791]: Adding new display on vt 1 ...
maalis 10 18:53:13 jp-gentoo sddm[791]: Loading theme configuration from ""
maalis 10 18:53:13 jp-gentoo sddm[791]: Display server starting...
maalis 10 18:53:13 jp-gentoo sddm[791]: Adding cookie to "/var/run/sddm/{16070ac3-6798-4911-a367-cf723909b87a}"
maalis 10 18:53:13 jp-gentoo sddm[791]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{16070ac3-6798-4911-a367-cf723909b87a} -noreset -displayfd 18
maalis 10 18:53:13 jp-gentoo systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-coredump@0-4054-0.service/start is destructive (tmp.mount has 'stop' job queued, but 'start' is included in t>
maalis 10 18:53:13 jp-gentoo systemd[1]: systemd-coredump.socket: Failed to queue service startup job (Maybe the service file is missing or not a non-template unit?): Transaction for systemd-coredump@0-4054-0.service/start >
maalis 10 18:53:13 jp-gentoo systemd[1]: systemd-coredump.socket: Failed with result 'resources'.
maalis 10 18:53:13 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Main process exited, code=dumped, status=6/ABRT
maalis 10 18:53:13 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Failed with result 'core-dump'.
maalis 10 18:53:13 jp-gentoo systemd[1095]: Failed to start KDE Global Shortcuts Server.
maalis 10 18:53:13 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 1.
maalis 10 18:53:13 jp-gentoo systemd[1095]: Stopped KDE Global Shortcuts Server.
maalis 10 18:53:13 jp-gentoo systemd[1095]: Starting KDE Global Shortcuts Server...
maalis 10 18:53:13 jp-gentoo kdeconnectd[3769]: Qt: Session management error: Could not open network socket
maalis 10 18:53:13 jp-gentoo dbus-daemon[1106]: [session uid=1000 pid=1106] Successfully activated service 'org.kde.kdeconnect'
maalis 10 18:53:13 jp-gentoo kdeconnectd[3769]: The X11 connection broke (error 1). Did the X11 server die?
maalis 10 18:53:13 jp-gentoo dbus-daemon[1106]: [session uid=1000 pid=1106] Activating service name='org.freedesktop.Notifications' requested by ':1.64' (uid=1000 pid=3769 comm="/usr/lib/kdeconnectd ")
maalis 10 18:53:13 jp-gentoo sddm[791]: Setting default cursor
maalis 10 18:53:13 jp-gentoo kglobalaccel5[4062]: qt.qpa.xcb: could not connect to display :0
maalis 10 18:53:13 jp-gentoo audit[4062]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=4062 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
maalis 10 18:53:13 jp-gentoo kglobalaccel5[4062]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
maalis 10 18:53:13 jp-gentoo kglobalaccel5[4062]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
maalis 10 18:53:13 jp-gentoo sddm[791]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
maalis 10 18:53:13 jp-gentoo sddm[791]: Display server started.
maalis 10 18:53:13 jp-gentoo sddm[791]: Socket server starting...
maalis 10 18:53:13 jp-gentoo sddm[791]: Socket server started.
maalis 10 18:53:13 jp-gentoo sddm[791]: Loading theme configuration from "/usr/share/sddm/themes/breath2/theme.conf"
maalis 10 18:53:13 jp-gentoo sddm[791]: Greeter starting...
maalis 10 18:53:13 jp-gentoo sddm[791]: Signal received: SIGTERM
maalis 10 18:53:13 jp-gentoo sddm[791]: Socket server stopping...
maalis 10 18:53:13 jp-gentoo sddm[791]: Socket server stopped.
maalis 10 18:53:13 jp-gentoo sddm[791]: Display server stopping...
maalis 10 18:53:13 jp-gentoo systemd-coredump[4071]: Failed to connect to coredump service: Connection refused
maalis 10 18:53:13 jp-gentoo kglobalaccel5[4062]: Invalid MIT-MAGIC-COOKIE-1 key
maalis 10 18:53:13 jp-gentoo sddm-helper[4075]: [PAM] Starting...
maalis 10 18:53:13 jp-gentoo audit[4075]: USER_AUTH pid=4075 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=?>
maalis 10 18:53:13 jp-gentoo audit[4075]: USER_ACCT pid=4075 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? ter>
maalis 10 18:53:13 jp-gentoo sddm-helper[4075]: [PAM] Authenticating...
maalis 10 18:53:13 jp-gentoo sddm-helper[4075]: [PAM] returning.
maalis 10 18:53:14 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 2.
maalis 10 18:53:14 jp-gentoo systemd[1095]: Stopped KDE Global Shortcuts Server.
maalis 10 18:53:14 jp-gentoo systemd[1095]: Starting KDE Global Shortcuts Server...
maalis 10 18:53:14 jp-gentoo kglobalaccel5[4076]: qt.qpa.xcb: could not connect to display :0
maalis 10 18:53:14 jp-gentoo audit[4076]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=4076 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
maalis 10 18:53:14 jp-gentoo kglobalaccel5[4076]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
maalis 10 18:53:14 jp-gentoo kglobalaccel5[4076]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
maalis 10 18:53:14 jp-gentoo sddm[791]: Display server stopped.
maalis 10 18:53:14 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:14 jp-gentoo sddm[791]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
maalis 10 18:53:14 jp-gentoo sddm[791]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
maalis 10 18:53:14 jp-gentoo systemd[1]: sddm.service: Succeeded.
maalis 10 18:53:14 jp-gentoo systemd[1]: Stopped Simple Desktop Display Manager.
maalis 10 18:53:14 jp-gentoo systemd-coredump[4077]: Failed to connect to coredump service: Connection refused
maalis 10 18:53:14 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Main process exited, code=dumped, status=6/ABRT
maalis 10 18:53:14 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Failed with result 'core-dump'.
maalis 10 18:53:14 jp-gentoo systemd[1095]: Failed to start KDE Global Shortcuts Server.
maalis 10 18:53:15 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 3.
maalis 10 18:53:15 jp-gentoo systemd[1095]: Stopped KDE Global Shortcuts Server.
maalis 10 18:53:15 jp-gentoo systemd[1095]: Starting KDE Global Shortcuts Server...
maalis 10 18:53:15 jp-gentoo kglobalaccel5[4081]: qt.qpa.xcb: could not connect to display :0
maalis 10 18:53:15 jp-gentoo audit[4081]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=4081 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
maalis 10 18:53:15 jp-gentoo kglobalaccel5[4081]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
maalis 10 18:53:15 jp-gentoo kglobalaccel5[4081]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
maalis 10 18:53:15 jp-gentoo systemd-coredump[4082]: Failed to connect to coredump service: Connection refused
maalis 10 18:53:15 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Main process exited, code=dumped, status=6/ABRT
maalis 10 18:53:15 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Failed with result 'core-dump'.
maalis 10 18:53:15 jp-gentoo systemd[1095]: Failed to start KDE Global Shortcuts Server.
maalis 10 18:53:15 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 4.
maalis 10 18:53:15 jp-gentoo kglobalaccel5[4085]: qt.qpa.xcb: could not connect to display :0
maalis 10 18:53:15 jp-gentoo audit[4085]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=4085 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
maalis 10 18:53:15 jp-gentoo kglobalaccel5[4085]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
maalis 10 18:53:15 jp-gentoo kglobalaccel5[4085]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
maalis 10 18:53:15 jp-gentoo systemd-coredump[4086]: Failed to connect to coredump service: Connection refused
maalis 10 18:53:15 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Scheduled restart job, restart counter is at 5.
maalis 10 18:53:15 jp-gentoo systemd[1095]: plasma-kglobalaccel.service: Start request repeated too quickly.
maalis 10 18:53:37 jp-gentoo kwin_x11[1172]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote appl>
maalis 10 18:53:37 jp-gentoo systemd[1]: session-2.scope: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Session 2 of user jp.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping User Login Management...
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping User Manager for UID 1000...
maalis 10 18:53:37 jp-gentoo systemd[1095]: Removed slice User Background Tasks Slice.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped target Main User Target.
maalis 10 18:53:37 jp-gentoo gamemoded[1103]: ERROR: Failure when processing the bus: Connection reset by peer
maalis 10 18:53:37 jp-gentoo gamemoded[1103]: v1.6.1
maalis 10 18:53:37 jp-gentoo gamemoded[1103]: Successfully initialised bus with name [com.feralinteractive.GameMode]...
maalis 10 18:53:37 jp-gentoo gvfsd[1319]: A connection to the bus can't be made
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopping Accessibility services bus...
maalis 10 18:53:37 jp-gentoo systemd-logind[735]: Removed session 2.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopping D-Bus User Message Bus...
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopping gamemoded...
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopping Virtual filesystem service...
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopping Multimedia Service...
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopping Portal service...
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopping flatpak document portal service...
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopping sandboxed app permission store...
maalis 10 18:53:37 jp-gentoo systemd[1095]: xdg-permission-store.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped sandboxed app permission store.
maalis 10 18:53:37 jp-gentoo systemd[1095]: pipewire.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped Multimedia Service.
maalis 10 18:53:37 jp-gentoo systemd[1]: run-user-1000-doc.mount: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounted /run/user/1000/doc.
maalis 10 18:53:37 jp-gentoo systemd[1095]: run-user-1000-doc.mount: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: run-user-1000-gvfs.mount: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounted /run/user/1000/gvfs.
maalis 10 18:53:37 jp-gentoo systemd[1095]: run-user-1000-gvfs.mount: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: xdg-document-portal.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped flatpak document portal service.
maalis 10 18:53:37 jp-gentoo systemd[1095]: gvfs-daemon.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped Virtual filesystem service.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Removed slice User Core Session Slice.
maalis 10 18:53:37 jp-gentoo systemd[1095]: gamemoded.service: Main process exited, code=exited, status=1/FAILURE
maalis 10 18:53:37 jp-gentoo systemd[1095]: gamemoded.service: Failed with result 'exit-code'.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped gamemoded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: dbus.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped D-Bus User Message Bus.
maalis 10 18:53:37 jp-gentoo systemd[1095]: xdg-desktop-portal.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped Portal service.
maalis 10 18:53:37 jp-gentoo systemd[1095]: at-spi-dbus-bus.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped Accessibility services bus.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped target Basic System.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped target Paths.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped target Sockets.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Stopped target Timers.
maalis 10 18:53:37 jp-gentoo systemd[1095]: dbus.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed D-Bus User Message Bus Socket.
maalis 10 18:53:37 jp-gentoo systemd[1095]: dirmngr.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed GnuPG network certificate management daemon.
maalis 10 18:53:37 jp-gentoo systemd[1095]: gpg-agent-browser.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
maalis 10 18:53:37 jp-gentoo systemd[1095]: gpg-agent-extra.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
maalis 10 18:53:37 jp-gentoo systemd[1095]: gpg-agent-ssh.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed GnuPG cryptographic agent (ssh-agent emulation).
maalis 10 18:53:37 jp-gentoo systemd[1095]: gpg-agent.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed GnuPG cryptographic agent and passphrase cache.
maalis 10 18:53:37 jp-gentoo systemd[1095]: p11-kit-server.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed p11-kit server.
maalis 10 18:53:37 jp-gentoo systemd[1095]: pipewire.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed Multimedia System.
maalis 10 18:53:37 jp-gentoo systemd[1095]: pulseaudio.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Closed Sound System.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Removed slice User Application Slice.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Reached target Shutdown.
maalis 10 18:53:37 jp-gentoo systemd[1095]: systemd-exit.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Finished Exit the Session.
maalis 10 18:53:37 jp-gentoo systemd[1095]: Reached target Exit the Session.
maalis 10 18:53:37 jp-gentoo systemd[1096]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[jp] ruser=[<unknown>] rhost=[<unknown>]
maalis 10 18:53:37 jp-gentoo systemd[1]: user@1000.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped User Manager for UID 1000.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping User Runtime Directory /run/user/1000...
maalis 10 18:53:37 jp-gentoo kernel: kauditd_printk_skb: 14 callbacks suppressed
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1131 audit(1615395217.594:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=>
maalis 10 18:53:37 jp-gentoo systemd[1]: run-user-1000.mount: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounted /run/user/1000.
maalis 10 18:53:37 jp-gentoo systemd[1]: user-runtime-dir@1000.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped User Runtime Directory /run/user/1000.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=>
maalis 10 18:53:37 jp-gentoo systemd[1]: Removed slice User Slice of UID 1000.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping Permit User Sessions...
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1131 audit(1615395217.601:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" host>
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-user-sessions.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Permit User Sessions.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=>
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Network.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Remote File Systems.
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1131 audit(1615395217.604:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" host>
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping Network Manager...
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6101] caught SIGTERM, shutting down normally.
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6365] dhcp4 (enp34s0): canceled DHCP transaction
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6365] dhcp4 (enp34s0): state changed bound -> done
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6365] device (enp34s0): DHCPv4: trying to acquire a new lease within 90 seconds
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6368] dhcp6 (enp34s0): canceled DHCP transaction
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6368] dhcp6 (enp34s0): state changed bound -> done
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6369] dhcp6 (enp34s0): canceled DHCP transaction
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6372] manager: NetworkManager state is now CONNECTED_SITE
maalis 10 18:53:37 jp-gentoo dbus-daemon[713]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=714 comm="/usr/bi>
maalis 10 18:53:37 jp-gentoo dbus-daemon[713]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
maalis 10 18:53:37 jp-gentoo NetworkManager[714]: <info>  [1615395217.6447] exiting (success)
maalis 10 18:53:37 jp-gentoo systemd[1]: NetworkManager.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Network Manager.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-logind.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped User Login Management.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1131 audit(1615395217.674:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? >
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1131 audit(1615395217.674:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? >
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping D-Bus System Message Bus...
maalis 10 18:53:37 jp-gentoo systemd[1]: dbus.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped D-Bus System Message Bus.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Basic System.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Paths.
maalis 10 18:53:37 jp-gentoo systemd[1]: cups.path: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped CUPS Scheduler.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Slices.
maalis 10 18:53:37 jp-gentoo systemd[1]: Removed slice User and Session Slice.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Sockets.
maalis 10 18:53:37 jp-gentoo systemd[1]: avahi-daemon.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1131 audit(1615395217.684:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? ter>
maalis 10 18:53:37 jp-gentoo systemd[1]: cups.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Closed CUPS Scheduler.
maalis 10 18:53:37 jp-gentoo systemd[1]: dbus.socket: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Closed D-Bus System Message Bus Socket.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target System Initialization.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Local Encrypted Volumes.
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-ask-password-console.path: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-ask-password-wall.path: Succeeded.
maalis 10 18:53:37 jp-gentoo audit: BPF prog-id=8 op=UNLOAD
maalis 10 18:53:37 jp-gentoo audit: BPF prog-id=7 op=UNLOAD
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1334 audit(1615395217.691:118): prog-id=8 op=UNLOAD
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1334 audit(1615395217.691:119): prog-id=7 op=UNLOAD
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping Set Up Additional Binary Formats...
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-sysctl.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Apply Kernel Variables.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-modules-load.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Load Kernel Modules.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=s>
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping Network Time Synchronization...
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1131 audit(1615395217.704:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? >
maalis 10 18:53:37 jp-gentoo kernel: audit: type=1131 audit(1615395217.704:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostn>
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-binfmt.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Set Up Additional Binary Formats.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:37 jp-gentoo audit[4113]: SYSTEM_SHUTDOWN pid=4113 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal>
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-update-utmp.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=su>
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-timesyncd.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Network Time Synchronization.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succ>
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Create Volatile Files and Directories.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res>
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Local File Systems.
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounting /boot/efi...
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounting /mnt/faaast...
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounting /tmp...
maalis 10 18:53:37 jp-gentoo systemd[1]: mnt-faaast.mount: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounted /mnt/faaast.
maalis 10 18:53:37 jp-gentoo systemd[1]: tmp.mount: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounted /tmp.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Swap.
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-fsck@dev-disk-by\x2duuid-9477a9d1\x2d47fc\x2d4f4b\x2da05f\x2d24cd2755ab8e.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped File System Check on /dev/disk/by-uuid/9477a9d1-47fc-4f4b-a05f-24cd2755ab8e.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-9477a9d1\x2d47fc\x2d4f4b\x2da05f\x2d24cd2755ab8e comm="systemd" exe=>
maalis 10 18:53:37 jp-gentoo systemd[1]: boot-efi.mount: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Unmounted /boot/efi.
maalis 10 18:53:37 jp-gentoo systemd[1]: Reached target Unmount All Filesystems.
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-fsck@dev-disk-by\x2duuid-B5D2\x2d5542.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped File System Check on /dev/disk/by-uuid/B5D2-5542.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-B5D2\x2d5542 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=>
maalis 10 18:53:37 jp-gentoo systemd[1]: Removed slice system-systemd\x2dfsck.slice.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped target Local File Systems (Pre).
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-remount-fs.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Remount Root and Kernel File Systems.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-fsck-root.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped File System Check on Root Device.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succ>
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Create Static Device Nodes in /dev.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
maalis 10 18:53:37 jp-gentoo systemd[1]: lvm2-monitor.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:37 jp-gentoo systemd[1]: Reached target Shutdown.
maalis 10 18:53:37 jp-gentoo systemd[1]: Reached target Final Step.
maalis 10 18:53:37 jp-gentoo systemd[1]: systemd-reboot.service: Succeeded.
maalis 10 18:53:37 jp-gentoo systemd[1]: Finished Reboot.
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes>
maalis 10 18:53:37 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
maalis 10 18:53:37 jp-gentoo systemd[1]: Reached target Reboot.
maalis 10 18:53:37 jp-gentoo systemd[1]: Shutting down.
maalis 10 18:53:37 jp-gentoo audit: BPF prog-id=4 op=UNLOAD
maalis 10 18:53:37 jp-gentoo audit: BPF prog-id=3 op=UNLOAD
maalis 10 18:53:37 jp-gentoo audit: BPF prog-id=6 op=UNLOAD
maalis 10 18:53:37 jp-gentoo audit: BPF prog-id=5 op=UNLOAD
maalis 10 18:53:37 jp-gentoo systemd[1]: Using hardware watchdog 'SP5100 TCO timer', version 0, device /dev/watchdog
maalis 10 18:53:37 jp-gentoo systemd[1]: Set hardware watchdog to 10min.
maalis 10 18:53:37 jp-gentoo kernel: watchdog: watchdog0: watchdog did not stop!
maalis 10 18:53:37 jp-gentoo systemd-shutdown[1]: Syncing filesystems and block devices.
maalis 10 18:53:37 jp-gentoo systemd-shutdown[1]: Sending SIGTERM to remaining processes...
maalis 10 18:53:37 jp-gentoo systemd-journald[383]: Journal stopped
Edit:
journalctl -b-1 -p3 -x, for more focus
maalis 10 18:25:50 jp-gentoo kernel: mpt2sas_cm0: overriding NVDATA EEDPTagMode setting
maalis 10 18:26:26 jp-gentoo pulseaudio[1275]: GetManagedObjects() failed: org.freedesktop.DBu>
maalis 10 18:53:13 jp-gentoo kglobalaccel5[3777]: This application failed to start because no >
                                                  Available platform plugins are: eglfs, linux>
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 212 and the job result is failed.
maalis 10 18:53:13 jp-gentoo kglobalaccel5[4062]: This application failed to start because no >
maalis 10 18:53:13 jp-gentoo systemd-coredump[4071]: Failed to connect to coredump service: Co>
░░ The job identifier is 230 and the job result is failed.
maalis 10 18:53:14 jp-gentoo kglobalaccel5[4076]: This application failed to start because no >
maalis 10 18:53:14 jp-gentoo systemd-coredump[4077]: Failed to connect to coredump service: Co>
░░ The job identifier is 248 and the job result is failed.
maalis 10 18:53:15 jp-gentoo kglobalaccel5[4081]: This application failed to start because no >
maalis 10 18:53:15 jp-gentoo systemd-coredump[4082]: Failed to connect to coredump service: Co>
░░ The job identifier is 266 and the job result is failed.
maalis 10 18:53:15 jp-gentoo kglobalaccel5[4085]: This application failed to start because no >
maalis 10 18:53:15 jp-gentoo systemd-coredump[4086]: Failed to connect to coredump service: Co>
░░ The job identifier is 284 and the job result is failed.
░░ The job identifier is 302 and the job result is failed.
maalis 10 18:53:37 jp-gentoo kwin_x11[1172]: Couldn't start kglobalaccel from org.kde.kglobala>
Edit: Seems to be related this this.
Same problem here, same logs.
The kglobalaccel problems appear to have been fixed, but now there seems to be new issue(s) holding shutdown and reboot back…
journal entries from start of shutdown sequence to the end of journal
huhti 19 15:15:46 jp-gentoo dbus-daemon[1107]: [session uid=1000 pid=1107] Activating service name='org.kde.Shutdown' requested by ':1.15' (uid=1000 pid=1222 comm="/usr/bin/ksmserver ")
huhti 19 15:15:46 jp-gentoo dbus-daemon[1107]: [session uid=1000 pid=1107] Successfully activated service 'org.kde.Shutdown'
huhti 19 15:15:46 jp-gentoo msm_kde_notifier[1267]: Shutting down MSM Notifier...
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48874, resource id: 10485766, major code: 18 (ChangeProperty), minor code: 0
huhti 19 15:15:46 jp-gentoo polkit-kde-authentication-agent-1[1235]: Destroying listener
huhti 19 15:15:46 jp-gentoo polkit-kde-authentication-agent-1[1235]: Removing listener  PolkitQt1::Agent::Listener(0x55ef90cbb480)
huhti 19 15:15:46 jp-gentoo kded5[1169]: Service  ":1.29" unregistered
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48878, resource id: 46137349, major code: 18 (ChangeProperty), minor code: 0
huhti 19 15:15:46 jp-gentoo kded5[1169]: Service  ":1.34" unregistered
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48882, resource id: 39845893, major code: 18 (ChangeProperty), minor code: 0
huhti 19 15:15:46 jp-gentoo polkitd[620]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.34, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48886, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48890, resource id: 25165829, major code: 18 (ChangeProperty), minor code: 0
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48894, resource id: 44040202, major code: 18 (ChangeProperty), minor code: 0
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48898, resource id: 35651589, major code: 18 (ChangeProperty), minor code: 0
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48902, resource id: 29360133, major code: 18 (ChangeProperty), minor code: 0
huhti 19 15:15:46 jp-gentoo sddm[1111]: kwalletd5: Checking for pam module
huhti 19 15:15:46 jp-gentoo sddm[1111]: kwalletd5: Got pam-login param
huhti 19 15:15:46 jp-gentoo sddm[1111]: kwalletd5: Waiting for hash on 7-
huhti 19 15:15:46 jp-gentoo sddm[1111]: kwalletd5: waitingForEnvironment on: 8
huhti 19 15:15:46 jp-gentoo sddm[1111]: kwalletd5: client connected
huhti 19 15:15:46 jp-gentoo sddm[1111]: kwalletd5: client disconnected
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:31: TypeError: Cannot read property 'formFactor' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:103: TypeError: Cannot read property 'editMode' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:48: TypeError: Cannot read property 'editMode' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.paneltoolbox/contents/ui/main.qml:37: TypeError: Cannot read property 'editMode' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: trying to show an empty dialog
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:30: TypeError: Cannot read property 'enabledBorders' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardindicator/contents/ui/main.qml:20: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: libkcups: Cancel-Subscription last error: 0 successful-ok
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/main.qml:38: TypeError: Cannot read property 'formFactor' of null
huhti 19 15:15:46 jp-gentoo dbus-daemon[1107]: [session uid=1000 pid=1107] Activating service name='org.kde.kdeconnect' requested by ':1.20' (uid=1000 pid=1237 comm="/usr/bin/plasmashell ")
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/main.qml:149: TypeError: Cannot read property 'nativeInterface' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:79:5: Unable to assign [undefined] to QObject*
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:176: TypeError: Cannot read property 'nativeInterface' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:37: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:241: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:247: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:253: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:261: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:40: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: qrc:/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:82: TypeError: Cannot read property 'expanded' of null
huhti 19 15:15:46 jp-gentoo kded5[1169]: Service  "org.kde.StatusNotifierHost-1237" unregistered
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:109: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:110: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:101: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:37: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:83: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:72: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:98: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:76: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/main.qml:53: TypeError: Cannot read property 'compactRepresentationItem' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:222: TypeError: Cannot read property 'globalAction' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:211: TypeError: Cannot read property 'action' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:205: TypeError: Cannot read property 'action' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:33: TypeError: Cannot read property 'editMode' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:46: TypeError: Cannot read property 'editMode' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/packages/org.kde.desktoptoolbox/contents/ui/ToolBoxButton.qml:47: TypeError: Cannot read property 'editMode' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75: TypeError: Cannot read property 'pluginName' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:77: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:78: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:79: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:80: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:32: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:33: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:34: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:35: TypeError: Cannot read property 'configuration' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: QObject::disconnect: Unexpected nullptr parameter
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:121: TypeError: Cannot read property 'x' of null
huhti 19 15:15:46 jp-gentoo plasmashell[1237]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:135: TypeError: Cannot read property 'y' of null
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48987, resource id: 33554446, major code: 15 (QueryTree), minor code: 0
huhti 19 15:15:46 jp-gentoo systemd-logind[621]: System is rebooting.
huhti 19 15:15:46 jp-gentoo kded5[1169]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
huhti 19 15:15:46 jp-gentoo sddm[640]: Authentication error: "Process crashed"
huhti 19 15:15:46 jp-gentoo sddm[640]: Auth: sddm-helper crashed (exit code 15)
huhti 19 15:15:46 jp-gentoo sddm[640]: Auth: sddm-helper exited with 15
huhti 19 15:15:46 jp-gentoo sddm[640]: Socket server stopping...
huhti 19 15:15:46 jp-gentoo sddm[640]: Socket server stopped.
huhti 19 15:15:46 jp-gentoo sddm[640]: Display server stopping...
huhti 19 15:15:46 jp-gentoo xdg-desktop-portal-kde[1466]: The X11 connection broke (error 1). Did the X11 server die?
huhti 19 15:15:46 jp-gentoo kwin_x11[1173]: The X11 connection broke: I/O error (code 1)
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Session 2 of user jp.
huhti 19 15:15:46 jp-gentoo systemd[1]: Removed slice system-getty.slice.
huhti 19 15:15:46 jp-gentoo systemd[1]: Removed slice system-modprobe.slice.
huhti 19 15:15:46 jp-gentoo kglobalaccel5[1213]: The X11 connection broke (error 1). Did the X11 server die?
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped target Graphical Interface.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped target Sound Card.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped target Timers.
huhti 19 15:15:46 jp-gentoo systemd[1]: fstrim.timer: Succeeded.
huhti 19 15:15:46 jp-gentoo kactivitymanagerd[1212]: The X11 connection broke (error 1). Did the X11 server die?
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Discard unused blocks once a week.
huhti 19 15:15:46 jp-gentoo systemd[1]: logrotate.timer: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Daily rotation of log files.
huhti 19 15:15:46 jp-gentoo kscreen_backend_launcher[1365]: The X11 connection broke (error 1). Did the X11 server die?
huhti 19 15:15:46 jp-gentoo systemd[1]: man-db.timer: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Daily man-db regeneration.
huhti 19 15:15:46 jp-gentoo systemd[1]: pamac-cleancache.timer: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Monthly clean packages cache.
huhti 19 15:15:46 jp-gentoo systemd[1]: pamac-mirrorlist.timer: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Generate mirrorlist weekly.
huhti 19 15:15:46 jp-gentoo at-spi-bus-launcher[1420]: X connection to :0 broken (explicit kill or server shutdown).
huhti 19 15:15:46 jp-gentoo systemd[1]: shadow.timer: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Daily verification of password and group files.
huhti 19 15:15:46 jp-gentoo systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Daily Cleanup of Temporary Directories.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped target System Time Synchronized.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped target System Time Set.
huhti 19 15:15:46 jp-gentoo systemd[1]: lvm2-lvmpolld.socket: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Closed LVM2 poll daemon socket.
huhti 19 15:15:46 jp-gentoo systemd[1]: systemd-rfkill.socket: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
huhti 19 15:15:46 jp-gentoo systemd[1097]: plasma-kglobalaccel.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Save/Restore Sound Card State...
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping CUPS Scheduler...
huhti 19 15:15:46 jp-gentoo kded5[1169]: The X11 connection broke: I/O error (code 1)
huhti 19 15:15:46 jp-gentoo systemd[1]: Starting Generate shutdown-ramfs...
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
huhti 19 15:15:46 jp-gentoo systemd[1097]: plasma-kactivitymanagerd.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Simple Desktop Display Manager...
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Load/Save Random Seed...
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping TLP system startup/shutdown...
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Disk Manager...
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Daemon for power management...
huhti 19 15:15:46 jp-gentoo systemd[1]: cups.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped CUPS Scheduler.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: upower.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Daemon for power management.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1131 audit(1618834546.398:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1131 audit(1618834546.398:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: rtkit-daemon.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: alsa-restore.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Save/Restore Sound Card State.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1131 audit(1618834546.402:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1131 audit(1618834546.402:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: systemd-random-seed.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Load/Save Random Seed.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo udisksd[1038]: udisks daemon version 2.9.2 exiting
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1131 audit(1618834546.405:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo mkinitcpio[1785]: ==> Starting build: none
huhti 19 15:15:46 jp-gentoo mkinitcpio[1785]:   -> Running build hook: [sd-shutdown]
huhti 19 15:15:46 jp-gentoo systemd-logind[621]: Session 2 logged out. Waiting for processes to exit.
huhti 19 15:15:46 jp-gentoo systemd[1]: udisks2.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Disk Manager.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1131 audit(1618834546.422:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo audit: BPF prog-id=13 op=UNLOAD
huhti 19 15:15:46 jp-gentoo audit: BPF prog-id=12 op=UNLOAD
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1334 audit(1618834546.432:119): prog-id=13 op=UNLOAD
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1334 audit(1618834546.432:120): prog-id=12 op=UNLOAD
huhti 19 15:15:46 jp-gentoo mkinitcpio[1785]: ==> Build complete.
huhti 19 15:15:46 jp-gentoo systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Finished Generate shutdown-ramfs.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1130 audit(1618834546.482:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo kernel: audit: type=1131 audit(1618834546.482:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1097]: pulseaudio.service: Succeeded.
huhti 19 15:15:46 jp-gentoo tlp[1787]: Applying power save settings...done.
huhti 19 15:15:46 jp-gentoo systemd[1]: tlp.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped TLP system startup/shutdown.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped target Multi-User System.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped target Login Prompts.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Modem Manager...
huhti 19 15:15:46 jp-gentoo ModemManager[675]: <info>  caught signal, shutting down...
huhti 19 15:15:46 jp-gentoo avahi-daemon[613]: Got SIGTERM, quitting.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
huhti 19 15:15:46 jp-gentoo avahi-daemon[613]: Leaving mDNS multicast group on interface enp34s0.IPv6 with address 2001:14ba:a4ed:9201:d0f7:aee6:d661:1821.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Periodic Command Scheduler...
huhti 19 15:15:46 jp-gentoo avahi-daemon[613]: Leaving mDNS multicast group on interface enp34s0.IPv4 with address 192.168.0.103.
huhti 19 15:15:46 jp-gentoo avahi-daemon[613]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Initialize hardware monitoring sensors...
huhti 19 15:15:46 jp-gentoo avahi-daemon[613]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
huhti 19 15:15:46 jp-gentoo NetworkManager[616]: <info>  [1618834546.6060] modem-manager: ModemManager no longer available
huhti 19 15:15:46 jp-gentoo ModemManager[675]: <info>  ModemManager is shut down
huhti 19 15:15:46 jp-gentoo crond[614]: (CRON) INFO (Shutting down)
huhti 19 15:15:46 jp-gentoo avahi-daemon[613]: avahi-daemon 0.8 exiting.
huhti 19 15:15:46 jp-gentoo systemd[1]: cronie.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Periodic Command Scheduler.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: avahi-daemon.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: ModemManager.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Modem Manager.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopping Authorization Manager...
huhti 19 15:15:46 jp-gentoo systemd[1]: polkit.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Authorization Manager.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo systemd[1]: lm_sensors.service: Succeeded.
huhti 19 15:15:46 jp-gentoo systemd[1]: Stopped Initialize hardware monitoring sensors.
huhti 19 15:15:46 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lm_sensors comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:46 jp-gentoo sddm[640]: Display server stopped.
huhti 19 15:15:46 jp-gentoo sddm[640]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
huhti 19 15:15:46 jp-gentoo sddm[640]: Removing display ":0" ...
huhti 19 15:15:46 jp-gentoo sddm[640]: Adding new display on vt 1 ...
huhti 19 15:15:46 jp-gentoo sddm[640]: Loading theme configuration from ""
huhti 19 15:15:46 jp-gentoo sddm[640]: Display server starting...
huhti 19 15:15:46 jp-gentoo sddm[640]: Adding cookie to "/var/run/sddm/{04aee9e9-f0a0-4937-97be-01ca6fdadf0a}"
huhti 19 15:15:46 jp-gentoo sddm[640]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{04aee9e9-f0a0-4937-97be-01ca6fdadf0a} -noreset -displayfd 18
huhti 19 15:15:47 jp-gentoo kdeconnectd[1780]: Qt: Session management error: Could not open network socket
huhti 19 15:15:47 jp-gentoo dbus-daemon[1107]: [session uid=1000 pid=1107] Successfully activated service 'org.kde.kdeconnect'
huhti 19 15:15:47 jp-gentoo kdeconnectd[1780]: The X11 connection broke (error 1). Did the X11 server die?
huhti 19 15:15:47 jp-gentoo dbus-daemon[1107]: [session uid=1000 pid=1107] Activating service name='org.freedesktop.Notifications' requested by ':1.60' (uid=1000 pid=1780 comm="/usr/lib/kdeconnectd ")
huhti 19 15:15:47 jp-gentoo sddm[640]: Setting default cursor
huhti 19 15:15:47 jp-gentoo sddm[640]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
huhti 19 15:15:47 jp-gentoo sddm[640]: Display server started.
huhti 19 15:15:47 jp-gentoo sddm[640]: Socket server starting...
huhti 19 15:15:47 jp-gentoo sddm[640]: Socket server started.
huhti 19 15:15:47 jp-gentoo sddm[640]: Loading theme configuration from "/usr/share/sddm/themes/breath2/theme.conf"
huhti 19 15:15:47 jp-gentoo sddm[640]: Greeter starting...
huhti 19 15:15:47 jp-gentoo sddm[640]: Signal received: SIGTERM
huhti 19 15:15:47 jp-gentoo sddm[640]: Socket server stopping...
huhti 19 15:15:47 jp-gentoo sddm[640]: Socket server stopped.
huhti 19 15:15:47 jp-gentoo sddm[640]: Display server stopping...
huhti 19 15:15:47 jp-gentoo sddm-helper[2068]: [PAM] Starting...
huhti 19 15:15:47 jp-gentoo audit[2068]: USER_AUTH pid=2068 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:47 jp-gentoo audit[2068]: USER_ACCT pid=2068 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
huhti 19 15:15:47 jp-gentoo sddm-helper[2068]: [PAM] Authenticating...
huhti 19 15:15:47 jp-gentoo sddm-helper[2068]: [PAM] returning.
huhti 19 15:15:48 jp-gentoo sddm[640]: Display server stopped.
huhti 19 15:15:48 jp-gentoo sddm[640]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
huhti 19 15:15:48 jp-gentoo sddm[640]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
huhti 19 15:15:48 jp-gentoo systemd[1]: sddm.service: Succeeded.
huhti 19 15:15:48 jp-gentoo systemd[1]: Stopped Simple Desktop Display Manager.
huhti 19 15:15:48 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:16:47 jp-gentoo plasma_waitforname[2063]: org.kde.knotifications: WaitForName: Service was not registered within timeout
huhti 19 15:16:47 jp-gentoo dbus-daemon[1107]: [session uid=1000 pid=1107] Activated service 'org.freedesktop.Notifications' failed: Process org.freedesktop.Notifications exited with status 1
huhti 19 15:17:16 jp-gentoo systemd[1]: session-2.scope: Stopping timed out. Killing.
huhti 19 15:17:16 jp-gentoo systemd[1]: session-2.scope: Killing process 1173 (kwin_x11) with signal SIGKILL.
huhti 19 15:17:16 jp-gentoo systemd[1]: session-2.scope: Killing process 1225 (QQmlThread) with signal SIGKILL.
huhti 19 15:17:16 jp-gentoo systemd[1]: session-2.scope: Killing process 1323 (CPMMListener) with signal SIGKILL.
huhti 19 15:17:16 jp-gentoo systemd[1]: session-2.scope: Killing process 1340 (kwin_x11) with signal SIGKILL.
huhti 19 15:17:16 jp-gentoo systemd[1]: session-2.scope: Failed with result 'timeout'.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Session 2 of user jp.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping User Login Management...
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping User Manager for UID 1000...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Removed slice User Background Tasks Slice.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped target Main User Target.
huhti 19 15:17:16 jp-gentoo gamemoded[1104]: ERROR: Failure when processing the bus: Connection reset by peer
huhti 19 15:17:16 jp-gentoo gamemoded[1104]: v1.6.1
huhti 19 15:17:16 jp-gentoo gamemoded[1104]: Successfully initialised bus with name [com.feralinteractive.GameMode]...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping Accessibility services bus...
huhti 19 15:17:16 jp-gentoo gvfsd[1324]: A connection to the bus can't be made
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping D-Bus User Message Bus...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping User preferences database...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping gamemoded...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping Virtual filesystem service...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping Virtual filesystem metadata service...
huhti 19 15:17:16 jp-gentoo systemd-logind[621]: Removed session 2.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping Multimedia Service...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping Portal service...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping flatpak document portal service...
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopping sandboxed app permission store...
huhti 19 15:17:16 jp-gentoo systemd[1097]: dconf.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped User preferences database.
huhti 19 15:17:16 jp-gentoo systemd[1097]: xdg-permission-store.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped sandboxed app permission store.
huhti 19 15:17:16 jp-gentoo systemd[1097]: run-user-1000-gvfs.mount: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: run-user-1000-gvfs.mount: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounted /run/user/1000/gvfs.
huhti 19 15:17:16 jp-gentoo systemd[1097]: run-user-1000-doc.mount: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: xdg-document-portal.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped flatpak document portal service.
huhti 19 15:17:16 jp-gentoo systemd[1097]: pipewire.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped Multimedia Service.
huhti 19 15:17:16 jp-gentoo systemd[1097]: gvfs-metadata.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped Virtual filesystem metadata service.
huhti 19 15:17:16 jp-gentoo systemd[1097]: gvfs-daemon.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: run-user-1000-doc.mount: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounted /run/user/1000/doc.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped Virtual filesystem service.
huhti 19 15:17:16 jp-gentoo systemd[1097]: gamemoded.service: Main process exited, code=exited, status=1/FAILURE
huhti 19 15:17:16 jp-gentoo systemd[1097]: gamemoded.service: Failed with result 'exit-code'.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped gamemoded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Removed slice User Core Session Slice.
huhti 19 15:17:16 jp-gentoo systemd[1097]: dbus.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped D-Bus User Message Bus.
huhti 19 15:17:16 jp-gentoo systemd[1097]: xdg-desktop-portal.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped Portal service.
huhti 19 15:17:16 jp-gentoo systemd[1097]: at-spi-dbus-bus.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped Accessibility services bus.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped target Basic System.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped target Paths.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped target Sockets.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Stopped target Timers.
huhti 19 15:17:16 jp-gentoo systemd[1097]: dbus.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed D-Bus User Message Bus Socket.
huhti 19 15:17:16 jp-gentoo systemd[1097]: dirmngr.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed GnuPG network certificate management daemon.
huhti 19 15:17:16 jp-gentoo systemd[1097]: gpg-agent-browser.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
huhti 19 15:17:16 jp-gentoo systemd[1097]: gpg-agent-extra.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
huhti 19 15:17:16 jp-gentoo systemd[1097]: gpg-agent-ssh.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed GnuPG cryptographic agent (ssh-agent emulation).
huhti 19 15:17:16 jp-gentoo systemd[1097]: gpg-agent.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed GnuPG cryptographic agent and passphrase cache.
huhti 19 15:17:16 jp-gentoo systemd[1097]: p11-kit-server.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed p11-kit server.
huhti 19 15:17:16 jp-gentoo systemd[1097]: pipewire.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed Multimedia System.
huhti 19 15:17:16 jp-gentoo systemd[1097]: pulseaudio.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Closed Sound System.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Removed slice User Application Slice.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Reached target Shutdown.
huhti 19 15:17:16 jp-gentoo systemd[1097]: systemd-exit.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Finished Exit the Session.
huhti 19 15:17:16 jp-gentoo systemd[1097]: Reached target Exit the Session.
huhti 19 15:17:16 jp-gentoo systemd[1098]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[jp] ruser=[<unknown>] rhost=[<unknown>]
huhti 19 15:17:16 jp-gentoo systemd[1]: user@1000.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped User Manager for UID 1000.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo kernel: kauditd_printk_skb: 9 callbacks suppressed
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.728:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping User Runtime Directory /run/user/1000...
huhti 19 15:17:16 jp-gentoo systemd[1]: run-user-1000.mount: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounted /run/user/1000.
huhti 19 15:17:16 jp-gentoo systemd[1]: user-runtime-dir@1000.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped User Runtime Directory /run/user/1000.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Removed slice User Slice of UID 1000.
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.738:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping Permit User Sessions...
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-user-sessions.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Permit User Sessions.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Network.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Remote File Systems.
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.745:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping Network Manager...
huhti 19 15:17:16 jp-gentoo NetworkManager[616]: <info>  [1618834636.7518] caught SIGTERM, shutting down normally.
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-logind.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped User Login Management.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.765:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo NetworkManager[616]: <info>  [1618834636.7948] dhcp4 (enp34s0): canceled DHCP transaction
huhti 19 15:17:16 jp-gentoo NetworkManager[616]: <info>  [1618834636.7949] dhcp4 (enp34s0): state changed bound -> done
huhti 19 15:17:16 jp-gentoo NetworkManager[616]: <info>  [1618834636.7949] device (enp34s0): DHCPv4: trying to acquire a new lease within 90 seconds
huhti 19 15:17:16 jp-gentoo NetworkManager[616]: <info>  [1618834636.7952] dhcp6 (enp34s0): canceled DHCP transaction
huhti 19 15:17:16 jp-gentoo NetworkManager[616]: <info>  [1618834636.7952] dhcp6 (enp34s0): state changed bound -> done
huhti 19 15:17:16 jp-gentoo NetworkManager[616]: <info>  [1618834636.7956] manager: NetworkManager state is now CONNECTED_SITE
huhti 19 15:17:16 jp-gentoo dbus-daemon[615]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=616 comm="/usr/bin/NetworkManager --no-daemon ")
huhti 19 15:17:16 jp-gentoo dbus-daemon[615]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
huhti 19 15:17:16 jp-gentoo NetworkManager[616]: <info>  [1618834636.8049] exiting (success)
huhti 19 15:17:16 jp-gentoo systemd[1]: NetworkManager.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Network Manager.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping D-Bus System Message Bus...
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.831:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: dbus.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped D-Bus System Message Bus.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Basic System.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Paths.
huhti 19 15:17:16 jp-gentoo systemd[1]: cups.path: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped CUPS Scheduler.
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.845:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Slices.
huhti 19 15:17:16 jp-gentoo systemd[1]: Removed slice User and Session Slice.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Sockets.
huhti 19 15:17:16 jp-gentoo systemd[1]: avahi-daemon.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
huhti 19 15:17:16 jp-gentoo systemd[1]: cups.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Closed CUPS Scheduler.
huhti 19 15:17:16 jp-gentoo systemd[1]: dbus.socket: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Closed D-Bus System Message Bus Socket.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target System Initialization.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Local Encrypted Volumes.
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-ask-password-console.path: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-ask-password-wall.path: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping Set Up Additional Binary Formats...
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-sysctl.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Apply Kernel Variables.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-modules-load.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Load Kernel Modules.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping Network Time Synchronization...
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.875:138): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.875:139): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-binfmt.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Set Up Additional Binary Formats.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo audit[2092]: SYSTEM_SHUTDOWN pid=2092 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1131 audit(1618834636.878:140): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo kernel: audit: type=1128 audit(1618834636.878:141): pid=2092 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-timesyncd.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Network Time Synchronization.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-update-utmp.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Create Volatile Files and Directories.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Local File Systems.
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounting /boot/efi...
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounting /mnt/faaast...
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounting /tmp...
huhti 19 15:17:16 jp-gentoo systemd[1]: mnt-faaast.mount: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounted /mnt/faaast.
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-fsck@dev-disk-by\x2duuid-9477a9d1\x2d47fc\x2d4f4b\x2da05f\x2d24cd2755ab8e.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped File System Check on /dev/disk/by-uuid/9477a9d1-47fc-4f4b-a05f-24cd2755ab8e.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-9477a9d1\x2d47fc\x2d4f4b\x2da05f\x2d24cd2755ab8e comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: tmp.mount: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounted /tmp.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Swap.
huhti 19 15:17:16 jp-gentoo systemd[1]: boot-efi.mount: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Unmounted /boot/efi.
huhti 19 15:17:16 jp-gentoo systemd[1]: Reached target Unmount All Filesystems.
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-fsck@dev-disk-by\x2duuid-B5D2\x2d5542.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped File System Check on /dev/disk/by-uuid/B5D2-5542.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-B5D2\x2d5542 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Removed slice system-systemd\x2dfsck.slice.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped target Local File Systems (Pre).
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-remount-fs.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Remount Root and Kernel File Systems.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-fsck-root.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped File System Check on Root Device.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Create Static Device Nodes in /dev.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: lvm2-monitor.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Reached target Shutdown.
huhti 19 15:17:16 jp-gentoo systemd[1]: Reached target Final Step.
huhti 19 15:17:16 jp-gentoo systemd[1]: systemd-reboot.service: Succeeded.
huhti 19 15:17:16 jp-gentoo systemd[1]: Finished Reboot.
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
huhti 19 15:17:16 jp-gentoo systemd[1]: Reached target Reboot.
huhti 19 15:17:17 jp-gentoo systemd[1]: Shutting down.
huhti 19 15:17:16 jp-gentoo audit: BPF prog-id=6 op=UNLOAD
huhti 19 15:17:16 jp-gentoo audit: BPF prog-id=5 op=UNLOAD
huhti 19 15:17:16 jp-gentoo audit: BPF prog-id=4 op=UNLOAD
huhti 19 15:17:16 jp-gentoo audit: BPF prog-id=3 op=UNLOAD
huhti 19 15:17:16 jp-gentoo audit: BPF prog-id=8 op=UNLOAD
huhti 19 15:17:16 jp-gentoo audit: BPF prog-id=7 op=UNLOAD
huhti 19 15:17:17 jp-gentoo systemd[1]: Using hardware watchdog 'SP5100 TCO timer', version 0, device /dev/watchdog
huhti 19 15:17:17 jp-gentoo systemd[1]: Set hardware watchdog to 10min.
huhti 19 15:17:17 jp-gentoo kernel: watchdog: watchdog0: watchdog did not stop!
huhti 19 15:17:17 jp-gentoo systemd-shutdown[1]: Syncing filesystems and block devices.
huhti 19 15:17:17 jp-gentoo systemd-shutdown[1]: Sending SIGTERM to remaining processes...
huhti 19 15:17:17 jp-gentoo systemd-journald[383]: Journal stopped
Seems that kwin doesn’t want to die, and has to be SIGKILL’d due to stop job timing out, and sddm wants to restart itself?
Edit: Nevermind, kglobalaccel still misbehaves from time to time, just less frequently.
Hmm…
According to KDE bug tracker, this issue was fixed, and I cannot see any new reports for a month. Yet still I’m getting these.
plasma-kglobalaccel.service (the last line was supposed to be a fix for this issue)
[Unit]
Description=KDE Global Shortcuts Server
PartOf=graphical-session.target
[Service]
ExecStart=/usr/bin/kglobalaccel5
BusName=org.kde.kglobalaccel
Slice=background.slice
TimeoutSec=5sec
Restart=on-failure
# Exit status 1 is used when the X11 connection drops
RestartPreventExitStatus=1
Me too. I had to edit “stop job” timeout settings to get this at least more tolerable. “Stop job” waiting happens with every shutdown by me.
Do you guys run other session or open apps in other TTY?
