Hello! So, I installed Manjaro after using Ubuntu for a while. It works great so far, all but the internet.
It takes a long time to start loading a page, like if I had a lot of ping, it can take like 5 seconds to start loading a page. I have checked my internet and is okay. It’s also not a cable or something because in Ubuntu or Windows in the same PC it works correctly so it has to be something here.
This is my result after running inxi -Fxxxz
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
serial: <filter>
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x serial: <filter>
UEFI-[Legacy]: American Megatrends v: F5 date: 01/08/2019
Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+
rev: 2 cache: L2: 4 MiB
bogomips: 102434
Speed: 2679 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 2679 2: 2686 3: 1370 4: 1378 5: 1378 6: 1378 7: 1376 8: 1370 9: 2806
10: 2769 11: 1459 12: 1313 13: 1368 14: 1326 15: 1376 16: 1372
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: PNY driver: nvidia
v: 470.63.01 bus-ID: 09:00.0 chip-ID: 10de:1e89 class-ID: 0300
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: PNY driver: snd_hda_intel
v: kernel bus-ID: 09:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media KIMU PRO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 0d8c:9703
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel port: f000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.69 TiB used: 168.11 GiB (9.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 120GB size: 111.79 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: BB6Q scheme: GPT
ID-2: /dev/sdb vendor: Kingston model: SA400S37240G size: 223.57 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0100 scheme: MBR
ID-3: /dev/sdc vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC45 scheme: MBR
ID-4: /dev/sdd vendor: Kingston model: SA400S37480G size: 447.13 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: B1C2 scheme: GPT
ID-5: /dev/sde type: USB vendor: Kingston model: DataTraveler 2.0
size: 14.42 GiB type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / size: 214.77 GiB used: 12.45 GiB (5.8%) fs: btrfs dev: /dev/sdb1
ID-2: /home size: 214.77 GiB used: 12.45 GiB (5.8%) fs: btrfs
dev: /dev/sdb1
ID-3: /var/log size: 214.77 GiB used: 12.45 GiB (5.8%) fs: btrfs
dev: /dev/sdb1
dev: /dev/sdb2
System Temperatures: cpu: 49.1 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
Processes: 403 Uptime: 14m wakeups: 0 Memory: 15.58 GiB
used: 2.76 GiB (17.7%) Init: systemd v: 249 Compilers: gcc: 11.1.0
Packages: pacman: 1002 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.08
