Slow internet with Ethernet cable
Same result, but thanks you you all, I will keep looking then until I or someone finds it :stuck_out_tongue:
is browser dns cache set ?
Try to disable IPV6 in the Network Manager (and reboot)?
How can I check that and do it if its not?
I will try it as soon as I get home. In Ubuntu I remember it being on in automatic, but I guess it works different?
This seems like a DNS issue. Did you set any custom DNS?
You can try another one by setting it in NetworkManager.
Valid entries could be 1.1.1.1 (data goes to Cloudflare), 8.8.8.8 (data goes to Google) or 9.9.9.9 (data goes to Quad9).
It was that
I needed to set the DNS to 8.8.8.8 and restart the network (I did it entering nmtui in the terminal and deactivating-reactivating it).
Thank you all for the help <3
