Hello everyone, I’m new to manjaro and i’d be grateful to receive some help regarding a problem I stumbled upon.
Recently, I moved from the buggy Windows 8.1 64bits to Manjaro xfce 64bits on my old laptop. Everything should be fine beside the internet connection with wi-fi. It’s very unstable and of bad quality. even tho I didn’t move it from it past usual spot. It’s been a week now and I also tried some fix from people with similar problem on the same distro. Such as :
sudo nano /etc/modprobe.d/iwlwifi.conf
options iwlmvm power_scheme=1
options iwlwifi power_save=0
And here is my config i heard was necessary to receive good help (if u need anymore more than that, please tell me) :
ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
link/ether 5c:ea:1d:8e:31:d3 brd ff:ff:ff:ff:ff:ff
inxi -fx
Info: dual core model: Intel Celeron N3060 bits: 64 type: MCP arch: Airmont
rev: 4 cache: L1: 112 KiB L2: 2 MiB
Speed (MHz): avg: 1657 high: 2480 min/max: 480/2480 cores: 1: 2480 2: 834
bogomips: 6402
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx
vnmi vpid xtopology xtpr
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=0ec11e53-d7e8-4c1d-950d-8c9def15cb71 rw quiet apparmor=1
security=apparmor resume=UUID=675c79fc-8475-4a2a-b683-e947497919e5
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron 15-3552 v: 4.2.0
serial: <filter> Chassis: type: 8 serial: <filter>
Mobo: Dell model: 079W3P v: A00 serial: <filter> UEFI-[Legacy]: Dell
v: 4.2.0 date: 10/27/2017
RAM: total: 3.75 GiB used: 1.31 GiB (34.9%)
Array-1: capacity: 8 GiB slots: 1 EC: None max-module-size: 8 GiB
note: est.
Device-1: A1_DIMM0 type: DDR3 detail: N/A size: 4 GiB speed:
spec: 1600 MT/s actual: 1066 MT/s volts: curr: 1.35 min: 1.35 max: 1.5
width (bits): data: 64 total: 64 manufacturer: 019800000198
part-no: KNWMX1-ETB serial: <filter>
Info: model: Intel Celeron N3060 bits: 64 type: MCP arch: Airmont family: 6
model-id: 0x4C (76) stepping: 4 microcode: 0x411
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 822 high: 1165 min/max: 480/2480 base/boost: 1600/2400
scaling: driver: intel_cpufreq governor: performance volts: 1.2 V
ext-clock: 80 MHz cores: 1: 1165 2: 480 bogomips: 6402
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Dell driver: i915 v: kernel ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b1
class-ID: 0300
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:6710 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0671 built: 2016 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:2284 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0036 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-2.1:6
chip-ID: 0cf3:e005 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 77.98 GiB (16.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C3
dev-links: cdrom
ID-1: / raw-size: 68.36 GiB size: 66.74 GiB (97.62%) used: 12.8 GiB (19.2%)
fs: ext4 block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0ec11e53-d7e8-4c1d-950d-8c9def15cb71
ID-2: /home raw-size: 388.61 GiB size: 381.44 GiB (98.16%)
used: 65.18 GiB (17.1%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: f51e4fd8-f606-494c-aa7c-e9ba96b44c9c
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.79 GiB used: 780 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 675c79fc-8475-4a2a-b683-e947497919e5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-2.1:6 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e005
class-ID: e001
Device-2: 1-2.2:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 1-5:3 info: Microdia Integrated Webcam type: Video
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 54.0 C mobo: 51.0 C
Fan Speeds (RPM): cpu: 0
Processes: 178 Uptime: 3d 7h 54m wakeups: 3 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1231
pacman: 1226 lib: 349 flatpak: 0 snap: 5 Shell: Bash (sudo) v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.15
