So out of the blue yesterday (no updates, nothing new) I am no longer able to log out into the sleep function. Doing so brings a loop which comes right back to the log in screen. Anyone else have this odd problem?
Mod Edit: Moved the post to below the arrow in the template
It seems the post content was added prior to a standard template (which I’ve never seen at my end) instead of below the arrow.
However, the How to request support link is well worth checking out, if you haven’t done so already.
It will help people to provide assistance if you provide some system details, e.g.:
inxi -zv8
→ Place 3 backticks ``` on empty lines above and below your pasted output
~or~
→ highlight the pasted text and click the </> button at the top of the reply window.
I am not sure what is confusing here. When exiting a session instead of a full shutdown I log out and use the sleep function. I have fully updated system so
doesn’t seem to be an update issue. System goes to dark screen as would be
normal for “sleep” but instead loops back to the log in screen. I’m not sure how to be more concise than that and I’m certainly not an AI.
This is new - I thought you could either log out, OR use sleep. You were using Plasma in a previous post, if that’s the case then you should be presented with menu options for:
Lock
Log Out
Switch User
Sleep
Restart
Shutdown
The term ‘sleep’ is used for ‘systemctl suspend’ and you could try this in your terminal (to see if any errors occur).
Logging out would certainly take you straight to the log-in screen… we only use this to end a user session - then need to shutdown or suspend afterward from the log-in screen.
You cannot ‘log out into the sleep function’.
So, as requested, post your Journalctl and inxi outputs.
Your wording, I imagine;
that, along with a lack of context.
You haven’t given any system information that would indicate which Manjaro edition you’re using, for example. This makes it difficult for others to understand what you actually mean. No context.
Normally, one doesn’t:
You clearly mean something else, but it hasn’t been defined well enough by you for others to fully comprehend.
This is on you.
My best guess (from your original description) is that you clicked a “Logout” icon in your menu, or somewhere, and the resulting Logout screen (or dialog) doesn’t contain a separate “Sleep” icon.
But, this isn’t what you’ve told anyone; that’s not what “log out and use the sleep function” suggests; especially without context.
What comes to mind, however, is that (at least in Plasma) the shutdown/restart/logout screen options (several months ago) were reduced to only two icons per screen (one of the options mentioned, plus a cancel icon), depending on context).
Before that change sleep might have been included as an extra icon (totaling three icons per screen), but frankly, I don’t remember.
As I say, if you’re using Plasma, this might have been what you were trying to communicate; or it could be something else entirely.
Until you provide the requested System Information we can’t possibly know; and you clearly ignored the request for that information (from a Moderator in post #3).
So, you tell us, how are we to help you if you don’t put some thought and effort into your Support request?
As a Member of this forum since 2020, you should know better.
Your second post at least contains a little more information, and we might guess that your issue might be one of those already listed in recent Update Announcements under Known Issues and Solutions.
If you haven’t already, it may be worth reading through those items to find any that seem to fit your problem.
Please help us to help you.
At minimum, post your System Information, as requested.
Please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
( ksmserver was slotted for removal at some point … so far its still around )
Perhaps it was provided as some sort of … assumed example of what the original author of this thread was referring to? That doesnt make it make much more sense though … as we still do not know the DE of author, nor the actual intention behind their descriptions.
While we can obviously not offer anything definitive about this, without more actionable information from the OP (such as the inxi output requested several times), I will mention that I have experienced this myself on occasion.
If I impatiently perform an update from within the GUI (without having checked the list of packages to be updated), and then continue using the machine for a time, sometimes this happens; along with an inability to Logout, Restart or Shutdown via the (Plasma) GUI.
Now, I am not suggesting that this is either the cause of the OP’s issue, nor a solution to it. However, it is an opportunity to offer the following consideration for all that will entertain it:
In the case of an unresponsive shutdown/logout/end-session from the Plasma GUI I would normally perform one of these successfully
Not all that common mind you.
But sometimes the case with changes to plasma.
Something like systemctl reboot would similarly work, but the above are more graceful for ending the plasma session.
