When I click on shutdown now from the KDE Plasma desktop it takes a very long time to shutdown. 9 minutes or longer
Is this normally over 1 minute.
I am running a Mid-Tower Corsair PC case with tipple boot Linux Mint, Manjaro and Windows 11 Pro.
I see the Gigabyte Aorus Motherboard flash screen and Manjaro underneath with dots crossing the screen during the one minute or longer.
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=9fb3e1d9-3b14-40d0-a8d1-7907cafe2031 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: Gigabyte model: X870 AORUS ELITE WIFI7 ICE v: x.x
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: F3i date: 12/03/2024
System RAM: System:
udev.log_priority=3
System RAM: total: 32 GiB available: 30.46 GiB used: 2.46 GiB (8.1%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX5M2E6000C36 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3006 min/max: 545/5733 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3006 2: 3006 3: 3006
4: 3006 5: 3006 6: 3006 7: 3006 8: 3006 9: 3006 10: 3006 11: 3006 12: 3006
13: 3006 14: 3006 15: 3006 16: 3006 17: 3006 18: 3006 19: 3006 20: 3006
21: 3006 22: 3006 23: 3006 24: 3006 bogomips: 225273
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
affected
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: Gigabyte driver: nvidia
v: 550.144.03 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none off: DP-6,DP-7 empty: HDMI-A-1,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:2803 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1, DP-2, DP-3, DP-4, DP-5, Writeback-1 bus-ID: 73:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 43.0 C
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 107 s-size: 608x342mm (23.94x13.46")
s-diag: 698mm (27.46") monitors: <missing: xrandr>
Monitor-1: DP-6 size-res: N/A modes: N/A
Monitor-2: DP-7 size-res: N/A modes: N/A
Monitor-3: Unknown-1 size-res: N/A modes: 1024x768
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: radeonsi
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.144.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
memory: 15.62 GiB
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Ti driver: N/A device-ID: 10de:2803 surfaces: xcb,xlib
device: 1 type: integrated-gpu name: AMD Radeon Graphics (RADV
RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e surfaces: xcb,xlib
wl: wayland-info x11: xdpyinfo,xprop
Device-1: NVIDIA AD106M High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 73:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 73:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8125
v: 9.014.01-NAPI modules: r8169 pcie: gen: 2 speed: 5 GT/s lanes: 1
port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK vendor: Foxconn driver: mt7925e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 14c3:7925
class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 0489:e124
Local Storage: total: 5 TiB used: 13.76 GiB (0.3%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500BX500SSD1
tech: SSD serial: <filter> fw-rev: 072 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000VN006-3CW104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: SC60 scheme: GPT
ID-1: / raw-size: 136.72 GiB size: 133.51 GiB (97.66%)
used: 13.68 GiB (10.2%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: 9fb3e1d9-3b14-40d0-a8d1-7907cafe2031
ID-2: /boot/efi raw-size: 406.9 MiB size: 403.7 MiB (99.22%)
used: 86.6 MiB (21.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 8648-3914
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 303.75 GiB fs: ntfs
label: Windows11 uuid: A4765FDEF32BC15E
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 219.07 GiB fs: ntfs label: Data1
uuid: 7A5C1D4884A8A8FB
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 269.36 GiB fs: ext4
label: LinuxMint uuid: 880b6f31-ff0f-4682-9ca9-4d67a23705f7
ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-6: /dev/sdb2 maj-min: 8:18 size: 976.56 GiB fs: ntfs label: HDDBackups
uuid: F64CBC1A4CBBD419
ID-7: /dev/sdb3 maj-min: 8:19 size: 465.66 GiB fs: ext4 label: timeshift
uuid: c69df89f-166d-4e20-85a1-40729bef8e76
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Integrated Express GIGABYTE Device type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
Device-2: 1-9:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e124 class-ID: e001 serial: <filter>
Device-3: 1-12:4 info: Corsair Lighting Node CORE type: HID
lanes: 1 mode: 1.1 power: 50mA chip-ID: 1b1c:0c1a class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 7-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Hub-9: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-10: 8-2:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-11: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-12: 9-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 9-1.2:3 info: Logitech Comfort Keyboard K290 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 98mA chip-ID: 046d:c31f class-ID: 0300
Device-2: 9-1.4:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1bcf:08a0 class-ID: 0301
Hub-13: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 48.4 C mobo: 45.0 C
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 41 C fan: 0% device: amdgpu
temp: 44.0 C
Packages: pm: pacman pkgs: 1276 libs: 360 tools: pamac pm: flatpak pkgs: 0
1: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
2: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
3: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
4: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
5: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
6: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
7: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
9: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
10: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
13: https://manjaro.ynh.ovh/stable/$repo/$arch
14: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
15: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
17: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
19: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
20: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
21: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
22: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
23: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
25: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
26: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
27: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
28: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
29: https://linorg.usp.br/manjaro/stable/$repo/$arch
30: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
31: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
32: https://manjaro.kurdy.org/stable/$repo/$arch
33: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
35: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
36: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
37: https://mirrors.manjaro.org/repo/stable/$repo/$arch
38: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
39: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
40: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
41: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
42: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
43: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
44: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
45: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
46: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
47: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
48: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
49: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
50: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
51: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
52: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
53: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
54: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
55: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
56: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
57: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
58: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
59: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
60: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
61: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
62: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
63: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
64: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
65: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
66: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
67: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
68: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
69: https://repos.silknet.com/manjaro/stable/$repo/$arch
70: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
71: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
72: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
73: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
74: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
75: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
76: https://mirrors2.manjaro.org/stable/$repo/$arch
77: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
78: http://manjaro.mirror.ac.za/stable/$repo/$arch
79: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
80: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
81: https://muug.ca/mirror/manjaro/stable/$repo/$arch
82: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
83: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
84: http://mirror.fcix.net/manjaro/stable/$repo/$arch
85: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
86: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
87: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
88: https://mirror.easyname.at/manjaro/stable/$repo/$arch
89: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
90: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
91: https://mirror.23m.com/manjaro/stable/$repo/$arch
92: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
93: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
94: http://manjaro.grena.ge/stable/$repo/$arch
95: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
96: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
98: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
99: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
100: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
101: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
102: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
103: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
104: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
105: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
106: https://mirror.init7.net/manjaro/stable/$repo/$arch
107: https://mirror.koddos.net/manjaro/stable/$repo/$arch
108: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
109: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
110: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
111: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
112: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
113: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
114: https://mirrors.netix.net/manjaro/stable/$repo/$arch
115: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
116: https://mirror.funami.tech/manjaro/stable/$repo/$arch
117: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
118: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
119: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
120: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
121: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
122: https://mirror.seahost.de/manjaro/stable/$repo/$arch
123: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
124: https://mirror.dc.uz/manjaro/stable/$repo/$arch
125: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
126: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
127: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
128: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
129: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
130: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
131: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
132: https://mirror.zetup.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 478
1: cpu: 10.4% command: firefox pid: 1354 mem: 507.3 MiB (1.6%)
2: cpu: 8.6% command: firefox pid: 1531 mem: 275.0 MiB (0.8%)
3: cpu: 3.2% command: Xorg pid: 862 mem: 93.4 MiB (0.2%)
4: cpu: 3.1% command: firefox pid: 1621 mem: 253.2 MiB (0.8%)
5: cpu: 2.9% command: plasmashell pid: 997 mem: 491.4 MiB (1.5%)
Memory top: 5 of 478
1: mem: 507.3 MiB (1.6%) command: firefox pid: 1354 cpu: 10.4%
2: mem: 491.4 MiB (1.5%) command: plasmashell pid: 997 cpu: 2.9%
3: mem: 275.0 MiB (0.8%) command: firefox pid: 1531 cpu: 8.6%
4: mem: 253.2 MiB (0.8%) command: firefox pid: 1621 cpu: 3.1%
5: mem: 191.2 MiB (0.6%) command: kwin_x11 pid: 979 cpu: 2.7%
Processes: 478 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.15 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.37
affected
memory: 15.62 GiB
class-ID: 0280
uuid: 8648-3914
serial: <filter>
temp: 44.0 C
45: http://System:
udev.log_priority=3
affected
memory: 15.62 GiB
class-ID: 0280
uuid: 8648-3914
serial: <filter>
temp: 44.0 C
Processes:
CPU top: 5 of 478
tool: systemctl
Processes:
CPU top: 5 of 478
tool: systemctl
