Shutdown sometimes freezes laptop?
I’ve got this new Lenovo P16v Gen1 laptop, and am mostly quite happy with it (after finding I can switch the Strg & Fn buttons in BIOS)
A strange thing I’ve observed is that when I try to shutdown Manjaro, it often freezes the machine:
  • screen shows half transparent fade out effect
  • clock (where I’ve enabled seconds display) freezes
  • the caps-lock LED on the laptop’s keyboard flashes on & off ~2 times per second
Rebooting doesn’t seem to cause the same issue, shutting down from Windows 11 also works fine.
That is kernel panic - a situation where the kernel does not know what to do and if continuing it may damage the system.
What to do - possibly test the latest kernels available - preferably on unstable branch.
Hi @thomas85,
As far as I know, this is a kernel panic.
Best way to possibly track it down is logs. Not the wooden kind, though…
Finding errors for specific boot
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • and the --no-pager formats the output nicely for use here, on the forum;
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
Please provide said logs here if you wish fore us to take a look.
:bangbang: Tip :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
thank you for your replies @linux-aarhus & @Mirdarthos ! It is great to know that this caps-lock-flashing is “only” a kernel panic and not likely a hardware problem.
Sadly I’m not sure how many boots ago I last saw this issue, so I don’t know how to map the journalctl output to the kernel panic on shutdown event I’m trying to understand here.
Last shutdown was successful I believe, though it’s warning…crit log output looks everything but good:
Aug 01 15:11:03 LenovoP16v plasmashell[1226]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1722517335411: Unsupported image format
Aug 01 15:11:09 LenovoP16v ksmserver-logout-greeter[3330]: kf.windowsystem: static bool KX11Extras::compositingActive() may only be used on X11
Aug 01 15:11:09 LenovoP16v ksmserver-logout-greeter[3330]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Aug 01 15:11:09 LenovoP16v plasmashell[1226]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1722517335411: Unsupported image format
Aug 01 15:11:09 LenovoP16v plasmashell[1226]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Aug 01 15:11:12 LenovoP16v systemd[963]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Aug 01 15:11:12 LenovoP16v plasmashell[1226]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Aug 01 15:11:12 LenovoP16v keepassxc[1387]: Failed to unregister window menu, reason: org.freedesktop.DBus.Error.ServiceUnknown ("The name is not activatable")
Aug 01 15:11:12 LenovoP16v sddm[937]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Aug 01 15:11:12 LenovoP16v sddm[937]: Auth: sddm-helper (--socket /tmp/sddm-auth-d3c9430c-6e17-4c51-bfa1-c2b84c1592a5 --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user user --autologin) crashed (exit code 1)
Aug 01 15:11:12 LenovoP16v sddm[937]: Auth: sddm-helper exited with 1
Aug 01 15:11:12 LenovoP16v plasmashell[1226]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
Aug 01 15:11:12 LenovoP16v sddm[937]: Signal received: SIGTERM
Aug 01 15:11:12 LenovoP16v kwin_wayland[1013]: kwin_wayland_drm: atomic commit failed: Permission denied
Aug 01 15:11:12 LenovoP16v dbus-broker[852]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.33.
Aug 01 15:11:12 LenovoP16v wireplumber[1075]: pw.core: 0x6386d56f5220: leaked proxy 0x6386d564b1a0 id:7
Aug 01 15:11:12 LenovoP16v wireplumber[1075]: pw.core: 0x6386d56f5220: leaked proxy 0x6386d563cde0 id:8
Aug 01 15:11:12 LenovoP16v kwin_wayland[1013]: kwin_screencast: PipeWire remote error:  connection error
Aug 01 15:11:12 LenovoP16v kwin_wayland[1013]: QtDBus: cannot relay signals from parent QObject(0x62c2f8b7e040 "") unless they are emitted in the object's thread QThread(0x62c2f8a74278 "libinput-connection"). Current thread is QThread(0x62c2f886e960 "").
Aug 01 15:11:13 LenovoP16v dbus-broker-launch[851]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 01 15:11:14 LenovoP16v dbus-broker-launch[851]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 01 15:11:14 LenovoP16v kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
I believe directly before that I did a reboot which caused very few log entries with this filter:
Aug 01 14:54:21 LenovoP16v plasmashell[1142]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Aug 01 14:58:27 LenovoP16v plasmashell[1142]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Aug 01 14:58:29 LenovoP16v plasmashell[1142]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Aug 01 14:58:44 LenovoP16v krunner[47988]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Aug 01 14:58:44 LenovoP16v krunner[47988]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Aug 01 14:58:48 LenovoP16v krunner[47988]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
Aug 01 15:00:15 LenovoP16v plasmashell[1142]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1722505789310: Unsupported image format
Aug 01 15:00:18 LenovoP16v ksmserver-logout-greeter[49420]: kf.windowsystem: static bool KX11Extras::compositingActive() may only be used on X11
Aug 01 15:00:18 LenovoP16v ksmserver-logout-greeter[49420]: The cached device pixel ratio value was stale on window update.  Please file a QTBUG which explains how to reproduce.
3 boots before the current one might be the issue, but I’m not sure:
Aug 01 11:46:50 LenovoP16v systemsettings[2292]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_64 to IconPropertiesGroup_QMLTYPE_64
Aug 01 11:46:50 LenovoP16v kded6[1058]: org.kde.plasma.appmenu: Got an error
Aug 01 11:46:50 LenovoP16v systemsettings[2292]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
Aug 01 11:47:04 LenovoP16v ksplashqml[2353]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
Aug 01 11:47:06 LenovoP16v ksplashqml[2380]: Texture 0x7b58d42d60f0 () used with different accesses within the same pass, this is not allowed.
Aug 01 11:47:08 LenovoP16v ksplashqml[2380]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
Aug 01 11:47:10 LenovoP16v ksplashqml[2406]: Texture 0x7d86dc2d5e70 () used with different accesses within the same pass, this is not allowed.
Aug 01 11:47:11 LenovoP16v ksplashqml[2406]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
Aug 01 11:47:13 LenovoP16v ksplashqml[2433]: Texture 0x7505202d1960 () used with different accesses within the same pass, this is not allowed.
Aug 01 11:47:13 LenovoP16v ksplashqml[2433]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
Aug 01 11:47:20 LenovoP16v systemsettings[2292]: qml: Pushed pages do not conform to the rules. Please check the documentation.
Aug 01 11:47:20 LenovoP16v systemsettings[2292]: qrc:/kcm/kcm_sddm/main.qml:176:13: QML QQuickImage*: Protocol "" is unknown
Aug 01 11:47:20 LenovoP16v systemsettings[2292]: qrc:/kcm/kcm_sddm/main.qml:161:5: QML OverlaySheet: Binding loop detected for property "implicitHeight"
Aug 01 11:47:42 LenovoP16v systemd-coredump[2547]: [🡕] Process 2292 (systemsettings) of user 1000 dumped core.
                                                   Stack trace of thread 2292:
                                                   #0  0x00007337aacfcae3 _ZNK11KPageWidget11currentPageEv (libKF6WidgetsAddons.so.6 + 0xfcae3)
                                                   #1  0x00007337ab50e2bc _ZN10ModuleView12stateChangedEv (libsystemsettingsview.so.3 + 0x1e2bc)
                                                   #2  0x00007337a87a16f7 n/a (libQt6Core.so.6 + 0x1a16f7)
                                                   #3  0x00007337a87a16f7 n/a (libQt6Core.so.6 + 0x1a16f7)
                                                   #4  0x00007337a5a5b330 _ZN25KQuickManagedConfigModule11qt_metacallEN11QMetaObject4CallEiPPv (libKF6KCMUtilsQuick.so.6 + 0xe330)
                                                   #5  0x000073377be15fdf n/a (kcm_sddm.so + 0x14fdf)
                                                   #6  0x00007337a87a1784 n/a (libQt6Core.so.6 + 0x1a1784)
                                                   #7  0x000073377be1be9b n/a (kcm_sddm.so + 0x1ae9b)
                                                   #8  0x00007337a97c4d9c _ZN3QV414QObjectWrapper11setPropertyEPNS_15ExecutionEngineEP7QObjectPK16QQmlPropertyDataRKNS_5ValueE (libQt6Qml.so.6 + 0x1c4d9c)
                                                   #9  0x00007337a97c5a6e _ZN3QV414QObjectWrapper14setQmlPropertyEPNS_15ExecutionEngineERK14QQmlRefPointerI15QQmlContextDataEP7QObjectPNS_6StringE6QFlagsINS0_4FlagEERKNS_5ValueE (libQt6Qml.so.6 + 0x1c5a6e)
                                                   #10 0x00007337a97c5bfb _ZN3QV414QObjectWrapper10virtualPutEPNS_7ManagedENS_11PropertyKeyERKNS_5ValueEPS4_ (libQt6Qml.so.6 + 0x1c5bfb)
                                                   #11 0x00007337a979d228 _ZN3QV46Lookup14setterFallbackEPS0_PNS_15ExecutionEngineERNS_5ValueERKS4_ (libQt6Qml.so.6 + 0x19d228)
                                                   #12 0x00007337a9819b0a n/a (libQt6Qml.so.6 + 0x219b0a)
                                                   #13 0x00007337a981d353 n/a (libQt6Qml.so.6 + 0x21d353)
                                                   #14 0x00007337a9784ab6 n/a (libQt6Qml.so.6 + 0x184ab6)
                                                   #15 0x00007337a9787c51 _ZN3QV48Function4callEP7QObjectPPvPK9QMetaTypeiPNS_16ExecutionContextE (libQt6Qml.so.6 + 0x187c51)
                                                   #16 0x00007337a98bafc4 _ZN24QQmlJavaScriptExpression8evaluateEPPvPK9QMetaTypei (libQt6Qml.so.6 + 0x2bafc4)
                                                   #17 0x00007337a98651a3 _ZN25QQmlBoundSignalExpression8evaluateEPPv (libQt6Qml.so.6 + 0x2651a3)
                                                   #18 0x00007337a986a0bf n/a (libQt6Qml.so.6 + 0x26a0bf)
                                                   #19 0x00007337a98dba4c _ZN12QQmlNotifier10emitNotifyEP20QQmlNotifierEndpointPPv (libQt6Qml.so.6 + 0x2dba4c)
                                                   #20 0x00007337a87a144a n/a (libQt6Core.so.6 + 0x1a144a)
                                                   #21 0x00007337a9da9fe8 _ZN10QQuickItem11qt_metacallEN11QMetaObject4CallEiPPv (libQt6Quick.so.6 + 0x1a9fe8)
                                                   #22 0x00007337a1ad217f _ZN13QQuickControl11qt_metacallEN11QMetaObject4CallEiPPv (libQt6QuickTemplates2.so.6 + 0xd217f)
                                                   #23 0x00007337a1bafffe _ZN14QQuickComboBox11qt_metacallEN11QMetaObject4CallEiPPv (libQt6QuickTemplates2.so.6 + 0x1afffe)
                                                   #24 0x00007337a984a939 n/a (libQt6Qml.so.6 + 0x24a939)
                                                   #25 0x00007337a98fcc1a _ZN19QQmlPropertyPrivate5writeEP7QObjectRK16QQmlPropertyDataRK8QVariantRK14QQmlRefPointerI15QQmlContextDataE6QFlagsINS2_9WriteFlagEE (libQt6Qml.so.6 + 0x2fcc1a)
                                                   #26 0x00007337a98fe712 _ZN19QQmlPropertyPrivate18writeValuePropertyERK8QVariant6QFlagsIN16QQmlPropertyData9WriteFlagEE (libQt6Qml.so.6 + 0x2fe712)
                                                   #27 0x00007337a997e88b _ZN8QQmlBind4evalEv (libQt6Qml.so.6 + 0x37e88b)
                                                   #28 0x00007337a984a8f3 n/a (libQt6Qml.so.6 + 0x24a8f3)
                                                   #29 0x00007337a98fcc80 _ZN19QQmlPropertyPrivate5writeEP7QObjectRK16QQmlPropertyDataRK8QVariantRK14QQmlRefPointerI15QQmlContextDataE6QFlagsINS2_9WriteFlagEE (libQt6Qml.so.6 + 0x2fcc80)
                                                   #30 0x00007337a985b800 _ZN11QQmlBinding9slowWriteERK16QQmlPropertyDataS2_RKN3QV45ValueEb6QFlagsINS0_9WriteFlagEE (libQt6Qml.so.6 + 0x25b800)
                                                   #31 0x00007337a9863335 n/a (libQt6Qml.so.6 + 0x263335)
                                                   #32 0x00007337a985f8ed _ZN11QQmlBinding8doUpdateERKN24QQmlJavaScriptExpression13DeleteWatcherE6QFlagsIN16QQmlPropertyData9WriteFlagEERN3QV45ScopeE (libQt6Qml.so.6 + 0x25f8ed)
                                                   #33 0x00007337a985ec9e _ZN11QQmlBinding6updateE6QFlagsIN16QQmlPropertyData9WriteFlagEE (libQt6Qml.so.6 + 0x25ec9e)
                                                   #34 0x00007337a98dba4c _ZN12QQmlNotifier10emitNotifyEP20QQmlNotifierEndpointPPv (libQt6Qml.so.6 + 0x2dba4c)
                                                   #35 0x00007337a87a144a n/a (libQt6Core.so.6 + 0x1a144a)
                                                   #36 0x00007337a9970261 _ZN17QQmlVMEMetaObject8metaCallEP7QObjectN11QMetaObject4CallEiPPv (libQt6Qml.so.6 + 0x370261)
                                                   #37 0x00007337a984a939 n/a (libQt6Qml.so.6 + 0x24a939)
                                                   #38 0x00007337a9863a88 n/a (libQt6Qml.so.6 + 0x263a88)
                                                   #39 0x00007337a985f8ed _ZN11QQmlBinding8doUpdateERKN24QQmlJavaScriptExpression13DeleteWatcherE6QFlagsIN16QQmlPropertyData9WriteFlagEERN3QV45ScopeE (libQt6Qml.so.6 + 0x25f8ed)
                                                   #40 0x00007337a985ec9e _ZN11QQmlBinding6updateE6QFlagsIN16QQmlPropertyData9WriteFlagEE (libQt6Qml.so.6 + 0x25ec9e)
                                                   #41 0x00007337a98dba4c _ZN12QQmlNotifier10emitNotifyEP20QQmlNotifierEndpointPPv (libQt6Qml.so.6 + 0x2dba4c)
                                                   #42 0x00007337a87a144a n/a (libQt6Core.so.6 + 0x1a144a)
                                                   #43 0x00007337a984a8f3 n/a (libQt6Qml.so.6 + 0x24a8f3)
                                                   #44 0x00007337a9863a88 n/a (libQt6Qml.so.6 + 0x263a88)
                                                   #45 0x00007337a985f8ed _ZN11QQmlBinding8doUpdateERKN24QQmlJavaScriptExpression13DeleteWatcherE6QFlagsIN16QQmlPropertyData9WriteFlagEERN3QV45ScopeE (libQt6Qml.so.6 + 0x25f8ed)
                                                   #46 0x00007337a985ec9e _ZN11QQmlBinding6updateE6QFlagsIN16QQmlPropertyData9WriteFlagEE (libQt6Qml.so.6 + 0x25ec9e)
                                                   #47 0x00007337a98dba4c _ZN12QQmlNotifier10emitNotifyEP20QQmlNotifierEndpointPPv (libQt6Qml.so.6 + 0x2dba4c)
                                                   #48 0x00007337a87a144a n/a (libQt6Core.so.6 + 0x1a144a)
                                                   #49 0x000073377be1be9b n/a (kcm_sddm.so + 0x1ae9b)
                                                   #50 0x00007337a97c4d9c _ZN3QV414QObjectWrapper11setPropertyEPNS_15ExecutionEngineEP7QObjectPK16QQmlPropertyDataRKNS_5ValueE (libQt6Qml.so.6 + 0x1c4d9c)
                                                   #51 0x00007337a97c5a6e _ZN3QV414QObjectWrapper14setQmlPropertyEPNS_15ExecutionEngineERK14QQmlRefPointerI15QQmlContextDataEP7QObjectPNS_6StringE6QFlagsINS0_4FlagEERKNS_5ValueE (libQt6Qml.so.6 + 0x1c5a6e)
                                                   #52 0x00007337a97c5bfb _ZN3QV414QObjectWrapper10virtualPutEPNS_7ManagedENS_11PropertyKeyERKNS_5ValueEPS4_ (libQt6Qml.so.6 + 0x1c5bfb)
                                                   #53 0x00007337a979d228 _ZN3QV46Lookup14setterFallbackEPS0_PNS_15ExecutionEngineERNS_5ValueERKS4_ (libQt6Qml.so.6 + 0x19d228)
                                                   #54 0x00007337a9819b0a n/a (libQt6Qml.so.6 + 0x219b0a)
                                                   #55 0x00007337a981d353 n/a (libQt6Qml.so.6 + 0x21d353)
                                                   #56 0x00007337a9784ab6 n/a (libQt6Qml.so.6 + 0x184ab6)
                                                   #57 0x00007337a9787c51 _ZN3QV48Function4callEP7QObjectPPvPK9QMetaTypeiPNS_16ExecutionContextE (libQt6Qml.so.6 + 0x187c51)
                                                   #58 0x00007337a98bafc4 _ZN24QQmlJavaScriptExpression8evaluateEPPvPK9QMetaTypei (libQt6Qml.so.6 + 0x2bafc4)
                                                   #59 0x00007337a98651a3 _ZN25QQmlBoundSignalExpression8evaluateEPPv (libQt6Qml.so.6 + 0x2651a3)
                                                   #60 0x00007337a986a0bf n/a (libQt6Qml.so.6 + 0x26a0bf)
                                                   #61 0x00007337a98dba4c _ZN12QQmlNotifier10emitNotifyEP20QQmlNotifierEndpointPPv (libQt6Qml.so.6 + 0x2dba4c)
                                                   #62 0x00007337a87a144a n/a (libQt6Core.so.6 + 0x1a144a)
                                                   #63 0x00007337a9d98159 _ZN17QQuickItemPrivate23setEffectiveEnableRecurEP10QQuickItemb (libQt6Quick.so.6 + 0x198159)
                                                   Stack trace of thread 2295:
                                                   #0  0x00007337a811c39d __poll (libc.so.6 + 0x10839d)
                                                   #1  0x00007337a596e257 n/a (libQt6WaylandClient.so.6 + 0x60257)
                                                   #2  0x00007337a88c9747 n/a (libQt6Core.so.6 + 0x2c9747)
                                                   #3  0x00007337a80a6ded n/a (libc.so.6 + 0x92ded)
                                                   #4  0x00007337a812a0dc n/a (libc.so.6 + 0x1160dc)
                                                   Stack trace of thread 2293:
                                                   #1  0x00007337a660c92d n/a (libglib-2.0.so.0 + 0xbe92d)
                                                   #2  0x00007337a65a9fc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
                                                   #3  0x00007337a89a2cbd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a2cbd)
                                                   #4  0x00007337a874f01e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f01e)
                                                   #5  0x00007337a883a410 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a410)
                                                   #6  0x00007337a9540e4e n/a (libQt6DBus.so.6 + 0x2de4e)
                                                   #7  0x00007337a88c9747 n/a (libQt6Core.so.6 + 0x2c9747)
                                                   #8  0x00007337a80a6ded n/a (libc.so.6 + 0x92ded)
                                                   #9  0x00007337a812a0dc n/a (libc.so.6 + 0x1160dc)
                                                   Stack trace of thread 2307:
                                                   #5  0x00007337a883a560 _ZN7QThread3runEv (libQt6Core.so.6 + 0x23a560)
                                                   #6  0x00007337a88c9747 n/a (libQt6Core.so.6 + 0x2c9747)
                                                   #7  0x00007337a80a6ded n/a (libc.so.6 + 0x92ded)
                                                   #8  0x00007337a812a0dc n/a (libc.so.6 + 0x1160dc)
                                                   Stack trace of thread 2313:
                                                   #0  0x00007337a8127e9d syscall (libc.so.6 + 0x113e9d)
                                                   #1  0x00007337a6605a10 g_cond_wait (libglib-2.0.so.0 + 0xb7a10)
                                                   #2  0x00007337a657390c n/a (libglib-2.0.so.0 + 0x2590c)
                                                   #3  0x00007337a65df6b7 n/a (libglib-2.0.so.0 + 0x916b7)
                                                   #4  0x00007337a65da266 n/a (libglib-2.0.so.0 + 0x8c266)
                                                   #5  0x00007337a80a6ded n/a (libc.so.6 + 0x92ded)
                                                   #6  0x00007337a812a0dc n/a (libc.so.6 + 0x1160dc)
                                                   Stack trace of thread 2314:
                                                   #3  0x00007337a65aa01a n/a (libglib-2.0.so.0 + 0x5c01a)
                                                   Stack trace of thread 2296:
                                                   #0  0x00007337a80a34e9 n/a (libc.so.6 + 0x8f4e9)
                                                   #1  0x00007337a80a5ed9 pthread_cond_wait (libc.so.6 + 0x91ed9)
                                                   #2  0x0000733789c9bfae n/a (iris_dri.so + 0x9bfae)
                                                   #3  0x0000733789c79d5c n/a (iris_dri.so + 0x79d5c)
                                                   #4  0x0000733789c9bedd n/a (iris_dri.so + 0x9bedd)
                                                   Stack trace of thread 2294:
                                                   #2  0x00007337a88ce120 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x2ce120)
                                                   #3  0x00007337a596e1ef n/a (libQt6WaylandClient.so.6 + 0x601ef)
                                                   #4  0x00007337a88c9747 n/a (libQt6Core.so.6 + 0x2c9747)
                                                   Stack trace of thread 2320:
                                                   Stack trace of thread 2297:
                                                   Stack trace of thread 2315:
                                                   #2  0x00007337a65ab7b7 g_main_loop_run (libglib-2.0.so.0 + 0x5d7b7)
                                                   #3  0x00007337a2f91574 n/a (libgio-2.0.so.0 + 0x112574)
                                                   Stack trace of thread 2309:
                                                   Stack trace of thread 2336:
                                                   #1  0x00007337a80a6242 pthread_cond_timedwait (libc.so.6 + 0x92242)
                                                   #2  0x00007337a88ce0b8 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x2ce0b8)
                                                   #3  0x00007337a88c7db2 n/a (libQt6Core.so.6 + 0x2c7db2)
                                                   Stack trace of thread 2329:
                                                   Stack trace of thread 2321:
                                                   Stack trace of thread 2330:
                                                   Stack trace of thread 2328:
                                                   Stack trace of thread 2337:
                                                   Stack trace of thread 2323:
                                                   Stack trace of thread 2335:
                                                   Stack trace of thread 2338:
                                                   Stack trace of thread 2339:
                                                   Stack trace of thread 2341:
                                                   Stack trace of thread 2322:
                                                   Stack trace of thread 2488:
                                                   #6  0x00007337a9f63bd8 n/a (libQt6Quick.so.6 + 0x363bd8)
                                                   Stack trace of thread 2483:
                                                   Stack trace of thread 2340:
Aug 01 11:47:42 LenovoP16v systemd[870]: app-systemsettings@6d870006811a4fd0b2431100330be2c5.service: Main process exited, code=dumped, status=11/SEGV
Aug 01 11:47:42 LenovoP16v systemd[870]: app-systemsettings@6d870006811a4fd0b2431100330be2c5.service: Failed with result 'core-dump'.
Aug 01 11:47:43 LenovoP16v kwin_wayland[921]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
Aug 01 11:47:43 LenovoP16v kwin_wayland[921]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
Aug 01 11:47:43 LenovoP16v baloorunner[2275]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
Aug 01 11:47:43 LenovoP16v baloorunner[2275]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
Aug 01 11:47:45 LenovoP16v kded6[1058]: org.kde.plasma.appmenu: Got an error
Aug 01 11:48:12 LenovoP16v ksmserver-logout-greeter[2615]: kf.windowsystem: static bool KX11Extras::compositingActive() may only be used on X11
Aug 01 11:48:12 LenovoP16v plasmashell[1120]: kf.windowsystem.wayland: Failed to recreate shadow for PlasmaQuick::AppletPopup_QML_181(0x5f7be7a011c0, name="popupWindow")
Aug 01 11:48:12 LenovoP16v plasmashell[1120]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
Aug 01 11:48:14 LenovoP16v systemd[870]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Aug 01 11:48:18 LenovoP16v kate[2568]: Failed to unregister window menu, reason: org.freedesktop.DBus.Error.ServiceUnknown ("The name is not activatable")
Aug 01 11:48:18 LenovoP16v plasmashell[1120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Aug 01 11:48:18 LenovoP16v plasmashell[1120]: QObject::killTimer: Timers cannot be stopped from another thread
Aug 01 11:48:18 LenovoP16v plasmashell[1120]: QObject::~QObject: Timers cannot be stopped from another thread
Aug 01 11:48:18 LenovoP16v keepassxc[1266]: Failed to unregister window menu, reason: org.freedesktop.DBus.Error.ServiceUnknown ("The name is not activatable")
Aug 01 11:48:18 LenovoP16v plasmashell[1120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
Aug 01 11:48:18 LenovoP16v sddm[846]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Aug 01 11:48:18 LenovoP16v sddm[846]: Auth: sddm-helper (--socket /tmp/sddm-auth-e2959239-e56e-49c1-b2dd-8a95e03e96cd --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user user --autologin) crashed (exit code 1)
Aug 01 11:48:18 LenovoP16v sddm[846]: Auth: sddm-helper exited with 1
Aug 01 11:48:18 LenovoP16v sddm[846]: Signal received: SIGTERM
Aug 01 11:48:18 LenovoP16v dbus-broker[749]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.34.
Aug 01 11:48:18 LenovoP16v wireplumber[982]: pw.core: 0x595e3faf1070: leaked proxy 0x595e3faacdd0 id:16
Aug 01 11:48:18 LenovoP16v wireplumber[982]: pw.core: 0x595e3faf1070: leaked proxy 0x595e3faae880 id:17
Aug 01 11:48:18 LenovoP16v kwin_wayland[921]: kwin_screencast: PipeWire remote error:  connection error
Aug 01 11:48:18 LenovoP16v kwin_wayland[921]: QtDBus: cannot relay signals from parent QObject(0x6082dabc0b00 "") unless they are emitted in the object's thread QThread(0x6082daa43978 "libinput-connection"). Current thread is QThread(0x6082da8f1960 "").
Aug 01 11:48:18 LenovoP16v dbus-broker-launch[748]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 01 11:48:19 LenovoP16v dbus-broker-launch[748]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 01 11:48:20 LenovoP16v kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Aug 01 11:48:20 LenovoP16v dbus-broker-launch[748]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Though I am a bit skeptic about the big gap in between two and 3 boots ago - I don’t think that there where over 3 hours in between those, so maybe the kernel-panic event causes the logs of this boot to get lost?
@linux-aarhus you told me to try a different kernel, which one? I’m currently on 6.9.10-1 - should I try the latest LTS one = 6.6.41-1 or the newest available one = 6.10.0-3?
I assume you are using stable branch cause you profile says so.
If your system is the intel 13700 then you may have one of the processors with the overvolting issue which has been discussed in a few topics.
I believe there is a microcode update planned from Intel - as I recall in August - but when I don’t know.
For plasma issues - unless you are a hardcore gamer - I will recommend switching to unstable and sync the system to linux610 and Plasma 6.1.3
 $ mbn info linux610 -q
Branch         : unstable
Version        : 6.10.2-1
Repository     : core
Build Date     : Sat 27 Jul 2024 15:06:54
Packager       : Manjaro Build Server <build@manjaro.org>
Branch         : testing
Version        : 6.10.0-3
Repository     : core
Build Date     : Mon 22 Jul 2024 03:51:12
Branch         : stable
Version        : 6.10.0-3
Repository     : core
It is of course also possible - on unstable - to test linux611
 $ mbn info linux611 -q
Branch         : unstable
Version        : 6.11.0rc1-1
Repository     : core
Build Date     : Tue 30 Jul 2024 13:13:42
Since you have a new laptop I would suggest trying the latest kernel.
I’m not a gamer, and yes my CPU is an Intel Core i7-13700H.
So how and where do I switch to unstable? I can’t say that I like that though… Manjaro “stable” is already unstable enough for me.
Timeshift a snapshot
Plasma 6.0.5 is on stable - I hear the team says that Plasma 6.1 has issues - it must be somdthing related to gaming and nvidia - because I have had very few issues with Plasma 6.
Switch to default global theme - look-and-feel and sddm theme.
Then open a terminal and do a soft reboot
systemctl soft-reboot
Logout and switch to TTY - login and do
sudo pacman-mirrors -aS unstable
sudo pacman -Syu linux610
I have been using unstable since 2016-Q4 - and since you are not a gamer - despite the name, I am fairly certain you will find it stable :slight_smile: otherwise throw a :cake: at me.
If stable is unstable for you, then something is horribly wrong on your end and it’d be better to fix that.
But note: new hardware might be slightly troublesome when it was just released. And you have new hardware, so another distro might not even make a difference.
Anyway:
The newer the Hardware, you see probably a more stable system on unstable.
Anyways, its maybe not needed right now. Kernel 6.9 is EOL and i recommend to try Kernel 6.10 first before you switch to unstable.
You can switch Kernels also with the help of the GUI Menue under Taskbar>Settings>Manjaro Settings Manager>Kernel
You can also remove Splash and Quiet from Grub.
To see where your Log out is freezing.
sudo update-grub
is needed after changing this file.
I don’t mind to be throwed with a Black Forrest Cake also :wink:
I’ve actually switched kernels in the other direction = to the latest LTS kernel = 6.6.43-1 because that one seems to more reliably be able to boot up my laptop without crashing Xorg / freezing the system (no blinking caps-lock LED like described here) than 6.9.12-1 & 6.10.2-1 - see this thread for details:
I also didn’t notice any shutdown kernel panics lately, feels like around 5 shutdowns without the problem. I did switch to the unstable mirrors since then and the shutdown menu looks a bit different in KDE plasma since switching.
Yesterday it even reacted to the power button when I first booted with 6.6.43-1 - but that features gone again, it’s ignored like before. Strange.
it happened again last night. first I tried to put it to sleep, which failed. then I tried to put it in hibernation, which also failed. lastly I tried shutting it down, which ended in the fast blinking caps lock indicator. I’ve tried using the REISUB method which I previously setup end tested successfully, but it seems when the kernel has panicked it won’t listen to that anymore.
I can’t see anything (but the failed sleep and hibernation attempts) in my journal. Can you?
systemd[906]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service.
systemd[1]: Starting PackageKit Daemon...
PackageKit[182687]: daemon start
systemd[1]: Started PackageKit Daemon.
ksmserver-logout-greeter[182669]: kf.windowsystem: static bool KX11Extras::compositingActive() may only be used on X11
systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
plasmashell[1143]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
systemd[906]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
systemd[906]: Started dbus-:1.2-org.kde.Shutdown@0.service.
systemd[906]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Main process exited, code=exited, status=1/FAILURE
systemd[906]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
systemd[906]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Consumed 263ms CPU time, 390.3M memory peak.
thunderbird[2269]: JavaScript error: resource://gre/modules/ConduitsChild.sys.mjs, line 108: Error: sendRemoveListener on closed conduit owl@beonex.com.137438953473
thunderbird[1441]: JavaScript error: chrome://messenger/content/preferences/general.js, line 2071: NS_ERROR_ILLEGAL_VALUE: Component returned failure code: 0x80070057 (NS_ERROR_ILLEGAL_VALUE) [nsIObserverService.removeObserver]
systemd[906]: app-org.mozilla.Thunderbird@3f9f4acb07dc4b5fb86c16dd0486bb5a.service: Consumed 1min 41.958s CPU time, 2.1G memory peak, 861.8M memory swap peak.
konsole[5727]: kf.windowsystem: static int KX11Extras::currentDesktop() may only be used on X11
konsole[5727]: kf.windowsystem: static void KX11Extras::setOnDesktop(WId, int) may only be used on X11
systemd[906]: app-org.kde.dolphin@c049b002db6643c6ab0af64a95b4ccb8.service: Consumed 3.834s CPU time, 174.7M memory peak, 57.1M memory swap peak.
systemd[906]: app-org.kde.konsole@0066de7cce124209a490f9a3de6ff980.service: Consumed 9.411s CPU time, 197.5M memory peak, 64M memory swap peak.
systemd[906]: app-firefox@28c20afe990c4184b6e4495ad863babb.service: Consumed 15min 17.357s CPU time, 8.3G memory peak, 684.7M memory swap peak.
systemd[906]: Stopped target plasma-workspace-wayland.target.
systemd[906]: Stopped target KDE Plasma Workspace.
systemd[906]: Stopped target Startup of XDG autostart applications.
systemd[906]: Stopping Nextcloud...
systemd[906]: Stopping Geoclue Demo agent...
systemd[906]: Stopping Accessibility...
systemd[906]: Stopping MSM Notifier...
systemd-logind[797]: The system will power off now!
systemd-logind[797]: System is powering down.
systemd[906]: Stopping Telegram Desktop...
systemd[906]: Stopping Update Notifier Tray Icon...
systemd[906]: Stopping Signal...
systemd[906]: Stopping syncthing...
systemd[906]: Stopping Accessibility services bus...
systemd[906]: Stopping Virtual filesystem service...
systemd[906]: Stopping Virtual filesystem metadata service...
systemd[906]: Stopping KDE PolicyKit Authentication Agent...
systemd[906]: Stopping Powerdevil...
systemd[906]: Stopping Xdg Desktop Portal For KDE...
systemd[906]: Stopping Portal service...
systemd[906]: Stopping flatpak document portal service...
systemd[906]: Stopping sandboxed app permission store...
dbus-broker[1767]: Dispatched 4830 messages @ 1(±4)μs / message.
I, the non-expert, don’t see anything. But, as I mentioned, I’m no expert.
However, for giggles I’d say test Kernel 6.1, or 6.6, the latest two LTS versions as I have it. At this point, it can’t really do any harm…Well, not as far as I know, anyway.
:man_shrugging:
All your issues - I am begining to suspect your RAM - I suggest boot a live ISO and test your RAM.
@Mirdarthos
I am running Kernel 6.6.44-1 since it felt like this was the most stable so far.
@linux-aarhus
Okey, I’m gonna try this memtest+86 thing, will report back on results.
so while I was out running an errand I left memtest86+ running for a few hours - it completed multiple passes without any error and was still running strong before I rebooted it. So at least the normal memory has no problems. Maybe the video card’s memory?
At this point I’m thinking anything is possible, although I don’t know how to test it, except eliminate it.
I found this tool, looks like no video memory problems either (when comparing with the example output shown here: https://unix.stackexchange.com/questions/712931/how-can-i-test-my-gpu-ram-integrity
$ memtest_vulkan
https://github.com/GpuZelenograd/memtest_vulkan v0.5.0 by GpuZelenograd
To finish testing use Ctrl+C
1: Bus=0x01:00 DevId=0x25BC   6GB NVIDIA RTX A1000 6GB Laptop GPU
Standard 5-minute test of 1: Bus=0x01:00 DevId=0x25BC   6GB NVIDIA RTX A1000 6GB Laptop GPU
      1 iteration. Passed  0.0744 seconds  written:    2.6GB 104.2GB/sec        checked:    5.2GB 106.8GB/sec
     15 iteration. Passed  1.0432 seconds  written:   36.8GB 104.2GB/sec        checked:   73.5GB 106.4GB/sec
     83 iteration. Passed  5.0612 seconds  written:  178.5GB 104.4GB/sec        checked:  357.0GB 106.5GB/sec
    487 iteration. Passed 30.0133 seconds  written: 1060.5GB 104.6GB/sec        checked: 2121.0GB 106.7GB/sec
    891 iteration. Passed 30.0071 seconds  written: 1060.5GB 104.6GB/sec        checked: 2121.0GB 106.8GB/sec
   1296 iteration. Passed 30.0640 seconds  written: 1063.1GB 104.7GB/sec        checked: 2126.2GB 106.8GB/sec
   1701 iteration. Passed 30.0339 seconds  written: 1063.1GB 104.8GB/sec        checked: 2126.2GB 106.9GB/sec
   2107 iteration. Passed 30.0425 seconds  written: 1065.8GB 105.0GB/sec        checked: 2131.5GB 107.2GB/sec
   2512 iteration. Passed 30.0339 seconds  written: 1063.1GB 104.8GB/sec        checked: 2126.2GB 106.9GB/sec
   2917 iteration. Passed 30.0665 seconds  written: 1063.1GB 104.6GB/sec        checked: 2126.2GB 106.8GB/sec
   3322 iteration. Passed 30.0562 seconds  written: 1063.1GB 104.7GB/sec        checked: 2126.2GB 106.8GB/sec
   3726 iteration. Passed 30.0035 seconds  written: 1060.5GB 104.6GB/sec        checked: 2121.0GB 106.8GB/sec
Had another one of those unrecoverable kernel panics, but this time he showed me some details on the screen:
Mod edit: large image removed
journalctl -b -1 doesn’t show any of that:
Aug 09 19:44:01 LenovoP16v NetworkManager[839]: <info>  [1723225441.0462] dhcp6 (wlp0s20f3): state changed new lease, address=fdfa:1109:20::c92
Aug 09 19:44:03 LenovoP16v kscreenlocker_greet[39415]: Failed to write to the pipe: Bad file descriptor.
Aug 09 19:44:09 LenovoP16v systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Aug 09 19:44:12 LenovoP16v systemd[952]: Created slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
Aug 09 19:44:12 LenovoP16v systemd[952]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service.
Aug 09 19:44:12 LenovoP16v systemd[1]: Starting PackageKit Daemon...
Aug 09 19:44:12 LenovoP16v PackageKit[39753]: daemon start
Aug 09 19:44:12 LenovoP16v systemd[1]: Started PackageKit Daemon.
Aug 09 19:44:12 LenovoP16v ksmserver-logout-greeter[39736]: kf.windowsystem: static bool KX11Extras::compositingActive() may only be used on X11
Aug 09 19:44:15 LenovoP16v systemd[952]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
Aug 09 19:44:15 LenovoP16v systemd[952]: Started dbus-:1.2-org.kde.Shutdown@0.service.
Aug 09 19:44:15 LenovoP16v konsole[17292]: kf.windowsystem: static int KX11Extras::currentDesktop() may only be used on X11
Aug 09 19:44:15 LenovoP16v konsole[17292]: kf.windowsystem: static void KX11Extras::setOnDesktop(WId, int) may only be used on X11
Aug 09 19:44:15 LenovoP16v systemd[952]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Main process exited, code=exited, status=1/FAILURE
Aug 09 19:44:15 LenovoP16v systemd[952]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Aug 09 19:44:15 LenovoP16v systemd[952]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Consumed 606ms CPU time, 346.9M memory peak.
Aug 09 19:44:15 LenovoP16v systemd[952]: plasma-xembedsniproxy.service: Consumed 1.122s CPU time, 5.6M memory peak.
Aug 09 19:44:15 LenovoP16v systemd[952]: plasma-gmenudbusmenuproxy.service: Consumed 1.119s CPU time, 3.8M memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped target plasma-workspace-wayland.target.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped target KDE Plasma Workspace.
Aug 09 19:44:18 LenovoP16v sudo[17514]: pam_unix(sudo:session): session closed for user root
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped target Startup of XDG autostart applications.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Nextcloud...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Geoclue Demo agent...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Accessibility...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping MSM Notifier...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Telegram Desktop...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Update Notifier Tray Icon...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping syncthing...
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [monitor] 2024/08/09 19:44:18 INFO: Signal 15 received; exiting
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Accessibility services bus...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Virtual filesystem service...
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [47C2J] 2024/08/09 19:44:18 INFO: QUIC listener ([::]:22000) shutting down
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [47C2J] 2024/08/09 19:44:18 INFO: Lost primary connection to 3FLCOHY at 192.168.16.170:22000-192.168.16.8:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-5VA3K9VKJ7LCU489SCG2DHM3DA: Syncthing is being stopped (0 remain)
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Virtual filesystem metadata service...
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [47C2J] 2024/08/09 19:44:18 INFO: Connection to 3FLCOHY at 192.168.16.170:22000-192.168.16.8:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256/LAN-P10-5VA3K9VKJ7LCU489SCG2DHM3DA closed: Syncthing is being stopped
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [47C2J] 2024/08/09 19:44:18 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping KDE PolicyKit Authentication Agent...
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [47C2J] 2024/08/09 19:44:18 INFO: Lost primary connection to OMP3K6Y at 192.168.16.170:22000-192.168.16.234:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-5VA3R2VI1KE5M45VM16090DM38: Syncthing is being stopped (0 remain)
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [47C2J] 2024/08/09 19:44:18 INFO: Connection to OMP3K6Y at 192.168.16.170:22000-192.168.16.234:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-5VA3R2VI1KE5M45VM16090DM38 closed: Syncthing is being stopped
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [47C2J] 2024/08/09 19:44:18 INFO: Lost primary connection to RYHQKU3 at 192.168.16.170:22000-192.168.16.166:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-5VA40G6HCRL8ON95JA3L6ITU0Q: Syncthing is being stopped (0 remain)
Aug 09 19:44:18 LenovoP16v syncthing[1496]: [47C2J] 2024/08/09 19:44:18 INFO: Connection to RYHQKU3 at 192.168.16.170:22000-192.168.16.166:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-5VA40G6HCRL8ON95JA3L6ITU0Q closed: Syncthing is being stopped
Aug 09 19:44:18 LenovoP16v dbus-broker[1807]: Dispatched 1378 messages @ 3(±8)μs / message.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Powerdevil...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Xdg Desktop Portal For KDE...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping Portal service...
Aug 09 19:44:18 LenovoP16v kded6[1145]: Service  ":1.44" unregistered
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping flatpak document portal service...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping sandboxed app permission store...
Aug 09 19:44:18 LenovoP16v kded6[1145]: Service  ":1.43" unregistered
Aug 09 19:44:18 LenovoP16v systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Aug 09 19:44:18 LenovoP16v systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Portal service.
Aug 09 19:44:18 LenovoP16v systemd[952]: xdg-desktop-portal.service: Consumed 1.580s CPU time, 8.8M memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped flatpak document portal service.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped sandboxed app permission store.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped KDE PolicyKit Authentication Agent.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Powerdevil.
Aug 09 19:44:18 LenovoP16v systemd[952]: plasma-powerdevil.service: Consumed 1.434s CPU time, 34.1M memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Xdg Desktop Portal For KDE.
Aug 09 19:44:18 LenovoP16v systemd[952]: plasma-xdg-desktop-portal-kde.service: Consumed 1.057s CPU time, 50.1M memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped MSM Notifier.
Aug 09 19:44:18 LenovoP16v systemd[952]: app-msm_kde_notifier@autostart.service: Consumed 1.348s CPU time, 28.5M memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Geoclue Demo agent.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Accessibility.
Aug 09 19:44:18 LenovoP16v systemd[952]: app-kaccess@autostart.service: Consumed 1.848s CPU time, 23.6M memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Update Notifier Tray Icon.
Aug 09 19:44:18 LenovoP16v systemd[952]: app-pamac\x2dtray\x2dplasma@autostart.service: Consumed 1min 19.633s CPU time, 2.3G memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Virtual filesystem service.
Aug 09 19:44:18 LenovoP16v kded6[1145]: Service  ":1.63" unregistered
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Accessibility services bus.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Telegram Desktop.
Aug 09 19:44:18 LenovoP16v systemd[952]: app-org.telegram.desktop@autostart.service: Consumed 3.808s CPU time, 926.1M memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Virtual filesystem metadata service.
Aug 09 19:44:18 LenovoP16v polkitd[842]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.37, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Aug 09 19:44:18 LenovoP16v kded6[1145]: Service  ":1.57" unregistered
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped target KDE Plasma Workspace Core.
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping KDE Daemon 6...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopping KDE Plasma Workspace...
Aug 09 19:44:18 LenovoP16v systemd[952]: Stopped Nextcloud.
Aug 09 19:44:18 LenovoP16v systemd[952]: app-Nextcloud@autostart.service: Consumed 45min 44.208s CPU time, 7.2G memory peak.
Aug 09 19:44:18 LenovoP16v systemd[952]: app-org.kde.konsole@bda808fe7f0443219b7a03fe7fae2eec.service: Consumed 47.682s CPU time, 581.6M memory peak.
Aug 09 19:44:18 LenovoP16v plasmashell[1196]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Aug 09 19:44:18 LenovoP16v systemd-logind[843]: The system will power off now!
Aug 09 19:44:18 LenovoP16v systemd-logind[843]: System is powering down.
