smed79
13 January 2024 07:24
1
Hey everyone
For a time I have a problem shutting down (turning off) my PC.
Clicking the “Shut Down ” button, everything seems performed normally, there is no errors on the display but the PC won’t turn off or shut down.
The last lines desplayed on screen are :
[OK] Reached target System Shutdown.
[OK] Reached target Late Shutdown Services.
[OK] Finished System Power Off.
[OK] Reached target System Power Off.
If i poweroff the computer via terminal ($ poweroff -f) the system freez
(i have to long press and hold the physical power button to shutdow/restart the PC ).
There is no problem with reboot , the system reboot normaly.
What setup i have to follow to debug the problem?
Thank you in advance for your help.
Zesko
13 January 2024 16:55
2
I think you’re not the only one having this problem.
A few days ago I had to format the Linux partition and reinstall Manjaro (Manjaro Vulcan 23.1.1).
I have formatted the partition to type Btfrs and installed Manjaro from scratch and changed the branch to unstable.
Everything is perfect, I am running kernel 6.6.8 and I have also installed 6.7-rc7.
But I have a problem: the computer never shuts down or restarts. I have tried both kernels and there is no way, the reboot or shutdown never completes.
When trying to restart or shut down, the scree…
Hi fellows!!! How i say before , when upgrade to linux 6.6 my system doenst power off, screen goes black but mouse and other indicators still on!!! Iǘe upgraded to linux 6.7 experimental (righ now) and all fine…Here the output of inxi -Fazy with 6.7…
~ inxi -Fazy
Kernel: 6.7.0-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86…
PS: I didn’t read all the way through.
smed79
24 January 2024 21:49
3
Some new lines msg after the last line i was reporting.
