A few days ago I had to format the Linux partition and reinstall Manjaro (Manjaro Vulcan 23.1.1).
I have formatted the partition to type Btfrs and installed Manjaro from scratch and changed the branch to unstable.
Everything is perfect, I am running kernel 6.6.8 and I have also installed 6.7-rc7.
But I have a problem: the computer never shuts down or restarts. I have tried both kernels and there is no way, the reboot or shutdown never completes.
When trying to restart or shut down, the screen goes black for a long time. Afterwards, the log that I show below is displayed (sorry for the photo, I took it with my mobile phone as best I could, I hope you can see something):
In this case, after waiting for about 15 minutes I got tired and powered off the computer, but I have tried leaving the computer on for even 2 hours, and it never turns off.
Do you have any idea what it could be?
Kernel log:
19:38:21.952 UTC Linux version 6.6.8-2-MANJARO (builduser@fv-az913-981) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Thu Dec 21 16:21:45 UTC 2023
19:38:21.952 UTC random: crng init done
19:38:21.953 UTC Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64 root=UUID=6934d43d-d41b-4aed-a03b-2d13b953eeac rw rootflags=subvol=@ quiet splash udev.log_priority=3
19:38:21.953 UTC Unknown kernel command line parameters "splash BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64", will be passed to user space.
19:38:21.954 UTC Speculative Return Stack Overflow: IBPB-extending microcode not applied!
19:38:21.954 UTC Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
19:38:21.954 UTC audit: type=2000 audit(1703619497.183:1): state=initialized audit_enabled=0 res=1
19:38:21.954 UTC ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
19:38:21.964 UTC SCSI subsystem initialized
19:38:21.965 UTC VFS: Disk quotas dquot_6.6.0
19:38:21.972 UTC pci 0000:00:00.2: can't derive routing for PCI INT A
19:38:21.972 UTC pci 0000:00:00.2: PCI INT A: not connected
19:38:21.972 UTC Initialise system trusted keyrings
19:38:21.972 UTC Key type blacklist registered
19:38:21.972 UTC integrity: Platform Keyring initialized
19:38:21.972 UTC integrity: Machine keyring initialized
19:38:21.972 UTC Key type asymmetric registered
19:38:21.972 UTC Asymmetric key parser 'x509' registered
19:38:21.974 UTC Loading compiled-in X.509 certificates
19:38:21.974 UTC Loaded X.509 cert 'Build time autogenerated kernel key: c071c707c9e3d2bdd78e51c4cdaf418758e4072a'
19:38:21.974 UTC Key type .fscrypt registered
19:38:21.974 UTC Key type fscrypt-provisioning registered
19:38:21.974 UTC integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
19:38:21.974 UTC integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
19:38:21.978 UTC nvme nvme0: missing or invalid SUBNQN field.
19:38:21.986 UTC ------------[ cut here ]------------
19:38:21.986 UTC WARNING: CPU: 11 PID: 189 at drivers/gpu/drm/amd/amdgpu/../display/dc/core/dc_resource.c:2569 calculate_phy_pix_clks+0xd1/0xe0 [amdgpu]
19:38:21.986 UTC Modules linked in: usbhid amdgpu(+) btrfs blake2b_generic libcrc32c i2c_algo_bit crc32c_generic drm_ttm_helper xor ttm raid6_pq drm_exec drm_suballoc_helper amdxcp drm_buddy gpu_sched nvme crc32c_intel drm_display_helper nvme_core xhci_pci sha256_ssse3 video xhci_pci_renesas cec nvme_common wmi
19:38:21.986 UTC CPU: 11 PID: 189 Comm: (udev-worker) Not tainted 6.6.8-2-MANJARO #1 146dce4c0b8863ad44f28ec2edb37ecbadc944c7
19:38:21.986 UTC Hardware name: Micro Computer (HK) Tech Limited UM580/F6BFC, BIOS 5.07 02/10/2023
19:38:21.986 UTC RIP: 0010:calculate_phy_pix_clks+0xd1/0xe0 [amdgpu]
19:38:21.986 UTC Code: ab aa aa aa c1 e1 04 48 0f af ca 48 c1 e9 24 eb a3 8d 14 f6 8d 0c 95 00 00 00 00 ba ab aa aa aa 48 0f af ca 48 c1 e9 24 eb 8a <0f> 0b eb 86 66 66 2e 0f 1f 84 00 00 00 00 00 90 90 90 90 90 90 90
19:38:21.986 UTC RSP: 0018:ffffc900032df660 EFLAGS: 00010297
19:38:21.986 UTC RAX: ffff88810f011800 RBX: ffff88810f011800 RCX: 000000000016a8c8
19:38:21.986 UTC RDX: 0000000000000005 RSI: 000000000016a8c8 RDI: ffff88810f011800
19:38:21.986 UTC RBP: ffff88810bf80000 R08: 0000000000000000 R09: ffff88810f011a90
19:38:21.986 UTC R10: 0000000000000006 R11: 0000000000000000 R12: ffff88810c8d6c00
19:38:21.986 UTC R13: ffff88810f011858 R14: ffff88810feea000 R15: ffff88810f011800
19:38:21.986 UTC FS: 00007f7d5609bcc0(0000) GS:ffff888fce8c0000(0000) knlGS:0000000000000000
19:38:21.986 UTC CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
19:38:21.986 UTC CR2: 000055670cbf07d0 CR3: 000000010b356000 CR4: 0000000000f50ee0
19:38:21.986 UTC PKRU: 55555554
19:38:21.986 UTC Call Trace:
19:38:21.986 UTC <TASK>
19:38:21.986 UTC ? calculate_phy_pix_clks+0xd1/0xe0 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC ? __warn+0x81/0x130
19:38:21.986 UTC ? report_bug+0x171/0x1a0
19:38:21.986 UTC ? handle_bug+0x3c/0x80
19:38:21.986 UTC ? exc_invalid_op+0x17/0x70
19:38:21.986 UTC ? asm_exc_invalid_op+0x1a/0x20
19:38:21.986 UTC dc_validate_stream+0x35/0xc0 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC create_validate_stream_for_sink+0x1fe/0x390 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC amdgpu_dm_connector_mode_valid+0x61/0x1b0 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC drm_connector_mode_valid+0x3b/0x60
19:38:21.986 UTC __drm_helper_update_and_validate+0xfe/0x3c0
19:38:21.986 UTC ? amdgpu_dm_connector_get_modes+0x28c/0x520 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC ? srso_alias_return_thunk+0x5/0x7f
19:38:21.986 UTC drm_helper_probe_single_connector_modes+0x2ab/0x540
19:38:21.986 UTC drm_client_modeset_probe+0x24b/0x1520
19:38:21.986 UTC ? __kmem_cache_alloc_node+0x1a6/0x340
19:38:21.986 UTC ? amdgpu_vm_bo_add+0x2e/0xb0 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC ? kmalloc_trace+0x2a/0xa0
19:38:21.986 UTC __drm_fb_helper_initial_config_and_unlock+0x3d/0x540
19:38:21.986 UTC ? amdgpu_driver_open_kms+0xe2/0x270 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC drm_fbdev_generic_client_hotplug+0x6a/0xb0
19:38:21.986 UTC drm_client_register+0x79/0xc0
19:38:21.986 UTC amdgpu_pci_probe+0x3be/0x450 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC local_pci_probe+0x45/0xa0
19:38:21.986 UTC pci_device_probe+0xc1/0x260
19:38:21.986 UTC ? sysfs_do_create_link_sd+0x6e/0xe0
19:38:21.986 UTC really_probe+0x19e/0x3e0
19:38:21.986 UTC ? __pfx___driver_attach+0x10/0x10
19:38:21.986 UTC __driver_probe_device+0x78/0x160
19:38:21.986 UTC driver_probe_device+0x1f/0x90
19:38:21.986 UTC __driver_attach+0xd2/0x1c0
19:38:21.986 UTC bus_for_each_dev+0x88/0xd0
19:38:21.986 UTC bus_add_driver+0x116/0x220
19:38:21.986 UTC driver_register+0x59/0x100
19:38:21.986 UTC ? __pfx_amdgpu_init+0x10/0x10 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
19:38:21.986 UTC do_one_initcall+0x5d/0x320
19:38:21.986 UTC do_init_module+0x60/0x240
19:38:21.986 UTC init_module_from_file+0x89/0xe0
19:38:21.986 UTC idempotent_init_module+0x120/0x2b0
19:38:21.986 UTC __x64_sys_finit_module+0x5e/0xb0
19:38:21.986 UTC do_syscall_64+0x60/0x90
19:38:21.986 UTC ? ksys_lseek+0x6c/0xb0
19:38:21.986 UTC ? syscall_exit_to_user_mode+0x2b/0x40
19:38:21.986 UTC ? do_syscall_64+0x6c/0x90
19:38:21.986 UTC ? ksys_read+0x6f/0xf0
19:38:21.986 UTC entry_SYSCALL_64_after_hwframe+0x6e/0xd8
19:38:21.986 UTC RIP: 0033:0x7f7d56b7c73d
19:38:21.986 UTC Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 95 0c 00 f7 d8 64 89 01 48
19:38:21.986 UTC RSP: 002b:00007ffcace1b8b8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
19:38:21.986 UTC RAX: ffffffffffffffda RBX: 000055670cacce80 RCX: 00007f7d56b7c73d
19:38:21.986 UTC RDX: 0000000000000000 RSI: 00007f7d56c89376 RDI: 0000000000000017
19:38:21.986 UTC RBP: 00007f7d56c89376 R08: 0000000000000001 R09: fffffffffffffe88
19:38:21.986 UTC R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
19:38:21.986 UTC R13: 000055670cacbed0 R14: 0000000000000000 R15: 000055670cacf540
19:38:21.986 UTC </TASK>
19:38:21.986 UTC ---[ end trace 0000000000000000 ]---
19:38:22.864 UTC ccp 0000:04:00.2: ccp: unable to access the device: you might be running a broken BIOS.
19:38:22.874 UTC ccp 0000:04:00.2: tee enabled
19:38:22.875 UTC ccp 0000:04:00.2: psp enabled
19:38:23.051 UTC cfg80211: Loading compiled-in X.509 certificates for regulatory database
19:38:23.051 UTC Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
19:38:23.200 UTC Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
19:38:23.270 UTC Bluetooth: hci0: AOSP quality report is not supported
19:38:23.311 UTC pcie_mp2_amd 0000:04:00.7: Failed to discover, sensors not enabled is 1
19:38:23.337 UTC ------------[ cut here ]------------
19:38:23.337 UTC list_add corruption. next->prev should be prev (ffff888106c17598), but was b9dfb1b652d3b358. (next=ffff888106c17598).
19:38:23.337 UTC WARNING: CPU: 3 PID: 409 at lib/list_debug.c:29 __list_add_valid_or_report+0x6a/0xa0
19:38:23.337 UTC Modules linked in: hid_sensor_accel_3d(+) hid_sensor_gyro_3d hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common intel_rapl_msr hid_sensor_hub intel_rapl_common snd_sof_amd_vangogh edac_mce_amd snd_sof_amd_rembrandt snd_sof_amd_renoir vfat kvm_amd snd_sof_amd_acp fat mt7921e(+) mt7921_common snd_sof_pci mt792x_lib snd_sof_xtensa_dsp kvm mt76_connac_lib snd_sof mt76 snd_hda_codec_conexant snd_sof_utils irqbypass snd_hda_codec_generic crct10dif_pclmul mac80211 snd_soc_core snd_hda_codec_hdmi ledtrig_audio crc32_pclmul libarc4 polyval_clmulni polyval_generic btusb snd_hda_intel snd_compress gf128mul btrtl ac97_bus ghash_clmulni_intel snd_intel_dspcfg btintel snd_pcm_dmaengine sha512_ssse3 snd_intel_sdw_acpi snd_pci_ps btbcm sha1_ssse3 snd_hda_codec snd_rpl_pci_acp6x btmtk aesni_intel snd_acp_pci crypto_simd snd_hda_core snd_acp_legacy_common cryptd bluetooth snd_pci_acp6x snd_hwdep ecdh_generic cfg80211 snd_pcm crc16 snd_pci_acp5x rapl snd_timer sp5100_tco snd_rn_pci_acp3x
19:38:23.337 UTC wmi_bmof snd_acp_config pcspkr snd snd_soc_acpi k10temp rfkill i2c_piix4 snd_pci_acp3x ccp amd_sfh(+) igc soundcore cm32181 joydev i2c_hid_acpi mousedev industrialio i2c_hid mac_hid i2c_dev crypto_user fuse loop dm_mod nfnetlink bpf_preload ip_tables x_tables usbhid amdgpu btrfs blake2b_generic libcrc32c i2c_algo_bit crc32c_generic drm_ttm_helper xor ttm raid6_pq drm_exec drm_suballoc_helper amdxcp drm_buddy gpu_sched nvme crc32c_intel drm_display_helper nvme_core xhci_pci sha256_ssse3 video xhci_pci_renesas cec nvme_common wmi
19:38:23.337 UTC CPU: 3 PID: 409 Comm: (udev-worker) Tainted: G W 6.6.8-2-MANJARO #1 146dce4c0b8863ad44f28ec2edb37ecbadc944c7
19:38:23.337 UTC Hardware name: Micro Computer (HK) Tech Limited UM580/F6BFC, BIOS 5.07 02/10/2023
19:38:23.337 UTC RIP: 0010:__list_add_valid_or_report+0x6a/0xa0
19:38:23.337 UTC Code: a5 ff 0f 0b 31 c0 e9 d5 2f 77 00 48 c7 c7 20 d0 49 8f e8 69 fe a5 ff 0f 0b eb e9 48 89 c1 48 c7 c7 48 d0 49 8f e8 56 fe a5 ff <0f> 0b eb d6 48 89 d1 48 89 c6 4c 89 c2 48 c7 c7 98 d0 49 8f e8 3d
19:38:23.337 UTC RSP: 0018:ffffc90001f279f8 EFLAGS: 00010082
19:38:23.337 UTC RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000027
19:38:23.337 UTC RDX: ffff888fce6e16c8 RSI: 0000000000000001 RDI: ffff888fce6e16c0
19:38:23.337 UTC RBP: ffffc90001f27a48 R08: 0000000000000000 R09: ffffc90001f27880
19:38:23.337 UTC R10: 0000000000000003 R11: ffffffff8fcca428 R12: ffff888106c17590
19:38:23.337 UTC R13: 0000000000000286 R14: ffffc90001f27a60 R15: ffff888106c17598
19:38:23.337 UTC FS: 00007ff33682bcc0(0000) GS:ffff888fce6c0000(0000) knlGS:0000000000000000
19:38:23.337 UTC CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
19:38:23.337 UTC CR2: 00005646a58f47e8 CR3: 000000010b568000 CR4: 0000000000f50ee0
19:38:23.337 UTC PKRU: 55555554
19:38:23.337 UTC Call Trace:
19:38:23.337 UTC <TASK>
19:38:23.337 UTC ? __list_add_valid_or_report+0x6a/0xa0
19:38:23.337 UTC ? __warn+0x81/0x130
19:38:23.337 UTC ? report_bug+0x171/0x1a0
19:38:23.337 UTC ? prb_read_valid+0x1b/0x30
19:38:23.337 UTC ? srso_alias_return_thunk+0x5/0x7f
19:38:23.337 UTC ? handle_bug+0x3c/0x80
19:38:23.337 UTC ? exc_invalid_op+0x17/0x70
19:38:23.337 UTC ? asm_exc_invalid_op+0x1a/0x20
19:38:23.337 UTC prepare_to_wait_event+0x10d/0x180
19:38:23.337 UTC amdtp_wait_for_response+0xe6/0x160 [amd_sfh 5ef895de2f45e692f28ed5fd839820ee39040321]
19:38:23.337 UTC ? queue_delayed_work_on+0x3d/0x50
19:38:23.337 UTC ? __pfx_autoremove_wake_function+0x10/0x10
19:38:23.337 UTC sensor_hub_get_feature+0xc6/0x170 [hid_sensor_hub e5eacd9d984426acc83f0909a778c86f6165cc87]
19:38:23.337 UTC hid_sensor_parse_common_attributes+0x217/0x310 [hid_sensor_iio_common 9effeffc62eb1b6e955f0af38abe27c6cbf3cfcb]
19:38:23.337 UTC hid_accel_3d_probe+0xb7/0x310 [hid_sensor_accel_3d a392c280be90d80814f01e7d6d634670f6dcd7c9]
19:38:23.337 UTC platform_probe+0x44/0xa0
19:38:23.337 UTC really_probe+0x19e/0x3e0
19:38:23.338 UTC ? __pfx___driver_attach+0x10/0x10
19:38:23.338 UTC __driver_probe_device+0x78/0x160
19:38:23.338 UTC driver_probe_device+0x1f/0x90
19:38:23.338 UTC __driver_attach+0xd2/0x1c0
19:38:23.338 UTC bus_for_each_dev+0x88/0xd0
19:38:23.338 UTC bus_add_driver+0x116/0x220
19:38:23.338 UTC driver_register+0x59/0x100
19:38:23.338 UTC ? __pfx_hid_accel_3d_platform_driver_init+0x10/0x10 [hid_sensor_accel_3d a392c280be90d80814f01e7d6d634670f6dcd7c9]
19:38:23.338 UTC do_one_initcall+0x5d/0x320
19:38:23.338 UTC do_init_module+0x60/0x240
19:38:23.338 UTC init_module_from_file+0x89/0xe0
19:38:23.338 UTC idempotent_init_module+0x120/0x2b0
19:38:23.338 UTC __x64_sys_finit_module+0x5e/0xb0
19:38:23.338 UTC do_syscall_64+0x60/0x90
19:38:23.338 UTC ? srso_alias_return_thunk+0x5/0x7f
19:38:23.338 UTC ? syscall_exit_to_user_mode+0x2b/0x40
19:38:23.338 UTC ? do_syscall_64+0x6c/0x90
19:38:23.338 UTC entry_SYSCALL_64_after_hwframe+0x6e/0xd8
19:38:23.338 UTC RIP: 0033:0x7ff33632c73d
19:38:23.338 UTC Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 95 0c 00 f7 d8 64 89 01 48
19:38:23.338 UTC RSP: 002b:00007ffcd7b7bdd8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
19:38:23.338 UTC RAX: ffffffffffffffda RBX: 00005646a5996280 RCX: 00007ff33632c73d
19:38:23.338 UTC RDX: 0000000000000004 RSI: 00007ff3368f0376 RDI: 0000000000000019
19:38:23.338 UTC RBP: 00007ff3368f0376 R08: 0000000000000001 R09: fffffffffffffe88
19:38:23.338 UTC R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
19:38:23.338 UTC R13: 00005646a5992de0 R14: 0000000000000000 R15: 00005646a5990dc0
19:38:23.338 UTC </TASK>
19:38:23.338 UTC ---[ end trace 0000000000000000 ]---
19:38:24.864 UTC BUG: unable to handle page fault for address: 0000000000035060
19:38:24.864 UTC #PF: supervisor write access in kernel mode
19:38:24.864 UTC #PF: error_code(0x0002) - not-present page
19:38:24.864 UTC Oops: 0002 [#1] PREEMPT SMP NOPTI
19:38:24.865 UTC CPU: 3 PID: 409 Comm: (udev-worker) Tainted: G W 6.6.8-2-MANJARO #1 146dce4c0b8863ad44f28ec2edb37ecbadc944c7
19:38:24.865 UTC Hardware name: Micro Computer (HK) Tech Limited UM580/F6BFC, BIOS 5.07 02/10/2023
19:38:24.865 UTC RIP: 0010:native_queued_spin_lock_slowpath+0x299/0x2e0
19:38:24.865 UTC Code: ff ff f3 90 8b 03 85 c0 74 ee eb f6 c1 ea 12 83 e0 03 83 ea 01 48 c1 e0 05 48 63 d2 48 05 40 50 03 00 48 03 04 d5 c0 dc 50 8f <48> 89 28 8b 45 08 85 c0 75 09 f3 90 8b 45 08 85 c0 74 f7 48 8b 55
19:38:24.865 UTC RSP: 0018:ffffc90001f279c8 EFLAGS: 00010006
19:38:24.865 UTC RAX: 0000000000035060 RBX: ffff888106c17590 RCX: 0000000000000002
19:38:24.865 UTC RDX: 00000000000001af RSI: 0000000006c17590 RDI: ffff888106c17590
19:38:24.865 UTC RBP: ffff888fce6f5040 R08: 0000000000000000 R09: 0000000000000000
19:38:24.865 UTC R10: 0000000000000001 R11: 0000000000000110 R12: 0000000000100000
19:38:24.865 UTC R13: 0000000000100000 R14: 0000000000000002 R15: ffff88810af09010
19:38:24.865 UTC FS: 00007ff33682bcc0(0000) GS:ffff888fce6c0000(0000) knlGS:0000000000000000
19:38:24.865 UTC CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
19:38:24.865 UTC CR2: 0000000000035060 CR3: 000000010b568000 CR4: 0000000000f50ee0
19:38:24.865 UTC PKRU: 55555554
19:38:24.865 UTC Call Trace:
19:38:24.865 UTC <TASK>
19:38:24.865 UTC ? __die+0x23/0x70
19:38:24.865 UTC ? page_fault_oops+0x171/0x4e0
19:38:24.865 UTC ? psi_group_change+0x213/0x3c0
19:38:24.865 UTC ? exc_page_fault+0x7f/0x180
19:38:24.865 UTC ? asm_exc_page_fault+0x26/0x30
19:38:24.865 UTC ? native_queued_spin_lock_slowpath+0x299/0x2e0
19:38:24.865 UTC _raw_spin_lock_irqsave+0x3d/0x50
19:38:24.865 UTC prepare_to_wait_event+0x24/0x180
19:38:24.865 UTC amdtp_wait_for_response+0xe6/0x160 [amd_sfh 5ef895de2f45e692f28ed5fd839820ee39040321]
19:38:24.865 UTC ? queue_delayed_work_on+0x3d/0x50
19:38:24.865 UTC ? __pfx_autoremove_wake_function+0x10/0x10
19:38:24.865 UTC sensor_hub_get_feature+0xc6/0x170 [hid_sensor_hub e5eacd9d984426acc83f0909a778c86f6165cc87]
19:38:24.865 UTC hid_sensor_parse_common_attributes+0x217/0x310 [hid_sensor_iio_common 9effeffc62eb1b6e955f0af38abe27c6cbf3cfcb]
19:38:24.865 UTC hid_accel_3d_probe+0xb7/0x310 [hid_sensor_accel_3d a392c280be90d80814f01e7d6d634670f6dcd7c9]
19:38:24.865 UTC ? srso_alias_return_thunk+0x5/0x7f
19:38:24.865 UTC platform_probe+0x44/0xa0
19:38:24.865 UTC really_probe+0x19e/0x3e0
19:38:24.865 UTC ? __pfx___driver_attach+0x10/0x10
19:38:24.865 UTC __driver_probe_device+0x78/0x160
19:38:24.865 UTC driver_probe_device+0x1f/0x90
19:38:24.865 UTC __driver_attach+0xd2/0x1c0
19:38:24.865 UTC bus_for_each_dev+0x88/0xd0
19:38:24.865 UTC bus_add_driver+0x116/0x220
19:38:24.865 UTC driver_register+0x59/0x100
19:38:24.866 UTC ? __pfx_hid_accel_3d_platform_driver_init+0x10/0x10 [hid_sensor_accel_3d a392c280be90d80814f01e7d6d634670f6dcd7c9]
19:38:24.866 UTC do_one_initcall+0x5d/0x320
19:38:24.866 UTC do_init_module+0x60/0x240
19:38:24.866 UTC init_module_from_file+0x89/0xe0
19:38:24.866 UTC idempotent_init_module+0x120/0x2b0
19:38:24.866 UTC __x64_sys_finit_module+0x5e/0xb0
19:38:24.866 UTC do_syscall_64+0x60/0x90
19:38:24.866 UTC ? srso_alias_return_thunk+0x5/0x7f
19:38:24.866 UTC ? syscall_exit_to_user_mode+0x2b/0x40
19:38:24.866 UTC ? do_syscall_64+0x6c/0x90
19:38:24.866 UTC entry_SYSCALL_64_after_hwframe+0x6e/0xd8
19:38:24.866 UTC RIP: 0033:0x7ff33632c73d
19:38:24.866 UTC Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 95 0c 00 f7 d8 64 89 01 48
19:38:24.866 UTC RSP: 002b:00007ffcd7b7bdd8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
19:38:24.866 UTC RAX: ffffffffffffffda RBX: 00005646a5996280 RCX: 00007ff33632c73d
19:38:24.866 UTC RDX: 0000000000000004 RSI: 00007ff3368f0376 RDI: 0000000000000019
19:38:24.866 UTC RBP: 00007ff3368f0376 R08: 0000000000000001 R09: fffffffffffffe88
19:38:24.866 UTC R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
19:38:24.866 UTC R13: 00005646a5992de0 R14: 0000000000000000 R15: 00005646a5990dc0
19:38:24.866 UTC </TASK>
19:38:24.866 UTC Modules linked in: qrtr cmac algif_hash algif_skcipher af_alg bnep hid_sensor_magn_3d hid_sensor_accel_3d(+) hid_sensor_gyro_3d hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common intel_rapl_msr hid_sensor_hub intel_rapl_common snd_sof_amd_vangogh edac_mce_amd snd_sof_amd_rembrandt snd_sof_amd_renoir vfat kvm_amd snd_sof_amd_acp fat mt7921e mt7921_common snd_sof_pci mt792x_lib snd_sof_xtensa_dsp kvm mt76_connac_lib snd_sof mt76 snd_hda_codec_conexant snd_sof_utils irqbypass snd_hda_codec_generic crct10dif_pclmul mac80211 snd_soc_core snd_hda_codec_hdmi ledtrig_audio crc32_pclmul libarc4 polyval_clmulni polyval_generic btusb snd_hda_intel snd_compress gf128mul btrtl ac97_bus ghash_clmulni_intel snd_intel_dspcfg btintel snd_pcm_dmaengine sha512_ssse3 snd_intel_sdw_acpi snd_pci_ps btbcm sha1_ssse3 snd_hda_codec snd_rpl_pci_acp6x btmtk aesni_intel snd_acp_pci crypto_simd snd_hda_core snd_acp_legacy_common cryptd bluetooth snd_pci_acp6x snd_hwdep ecdh_generic cfg80211 snd_pcm crc16
19:38:24.866 UTC snd_pci_acp5x rapl snd_timer sp5100_tco snd_rn_pci_acp3x wmi_bmof snd_acp_config pcspkr snd snd_soc_acpi k10temp rfkill i2c_piix4 snd_pci_acp3x ccp amd_sfh(+) igc soundcore cm32181 joydev i2c_hid_acpi mousedev industrialio i2c_hid mac_hid i2c_dev crypto_user fuse loop dm_mod nfnetlink bpf_preload ip_tables x_tables usbhid amdgpu btrfs blake2b_generic libcrc32c i2c_algo_bit crc32c_generic drm_ttm_helper xor ttm raid6_pq drm_exec drm_suballoc_helper amdxcp drm_buddy gpu_sched nvme crc32c_intel drm_display_helper nvme_core xhci_pci sha256_ssse3 video xhci_pci_renesas cec nvme_common wmi
19:38:24.866 UTC CR2: 0000000000035060
19:38:24.866 UTC ---[ end trace 0000000000000000 ]---
19:38:24.866 UTC RIP: 0010:native_queued_spin_lock_slowpath+0x299/0x2e0
19:38:24.866 UTC Code: ff ff f3 90 8b 03 85 c0 74 ee eb f6 c1 ea 12 83 e0 03 83 ea 01 48 c1 e0 05 48 63 d2 48 05 40 50 03 00 48 03 04 d5 c0 dc 50 8f <48> 89 28 8b 45 08 85 c0 75 09 f3 90 8b 45 08 85 c0 74 f7 48 8b 55
19:38:24.866 UTC RSP: 0018:ffffc90001f279c8 EFLAGS: 00010006
19:38:24.866 UTC RAX: 0000000000035060 RBX: ffff888106c17590 RCX: 0000000000000002
19:38:24.866 UTC RDX: 00000000000001af RSI: 0000000006c17590 RDI: ffff888106c17590
19:38:24.866 UTC RBP: ffff888fce6f5040 R08: 0000000000000000 R09: 0000000000000000
19:38:24.866 UTC R10: 0000000000000001 R11: 0000000000000110 R12: 0000000000100000
19:38:24.866 UTC R13: 0000000000100000 R14: 0000000000000002 R15: ffff88810af09010
19:38:24.866 UTC FS: 00007ff33682bcc0(0000) GS:ffff888fce6c0000(0000) knlGS:0000000000000000
19:38:24.866 UTC CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
19:38:24.866 UTC CR2: 0000000000035060 CR3: 000000010b568000 CR4: 0000000000f50ee0
19:38:24.866 UTC PKRU: 55555554
19:38:28.867 UTC sddm-greeter[693]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
19:38:35.984 UTC warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
19:45:07.857 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=90 TOS=0x00 PREC=0x00 TTL=51 ID=19635 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:07.857 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=83 TOS=0x00 PREC=0x00 TTL=51 ID=19636 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:07.973 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=83 TOS=0x00 PREC=0x00 TTL=51 ID=19637 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:08.253 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=121 TOS=0x00 PREC=0x00 TTL=51 ID=19638 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:08.797 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=121 TOS=0x00 PREC=0x00 TTL=51 ID=19639 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:09.853 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=121 TOS=0x00 PREC=0x00 TTL=51 ID=19640 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:11.999 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=121 TOS=0x00 PREC=0x00 TTL=51 ID=19641 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:16.349 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=121 TOS=0x00 PREC=0x00 TTL=51 ID=19642 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:24.801 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:be:dd:50:0f:e8:08:00 SRC=135.181.38.249 DST=192.168.1.142 LEN=121 TOS=0x00 PREC=0x00 TTL=51 ID=19643 DF PROTO=TCP SPT=443 DPT=53236 WINDOW=501 RES=0x00 ACK PSH URGP=0
19:45:43.227 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=501 DF PROTO=UDP SPT=60000 DPT=35571 LEN=370
19:45:44.935 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=625 DF PROTO=UDP SPT=60000 DPT=35571 LEN=370
19:46:22.869 UTC [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:ec:be:dd:50:0f:e8:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=39155 DF PROTO=2
19:46:23.359 UTC [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:fb:58:47:ca:71:cb:43:08:00 SRC=192.168.1.140 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=43746 PROTO=2
19:47:43.345 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=3329 DF PROTO=UDP SPT=60000 DPT=52427 LEN=370
19:47:44.707 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=3442 DF PROTO=UDP SPT=60000 DPT=52427 LEN=370
19:47:46.165 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=3570 DF PROTO=UDP SPT=60000 DPT=52427 LEN=370
19:47:47.024 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=3626 DF PROTO=UDP SPT=60000 DPT=52427 LEN=370
19:48:27.872 UTC [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:ec:be:dd:50:0f:e8:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=12527 DF PROTO=2
19:48:28.363 UTC [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:fb:58:47:ca:71:cb:43:08:00 SRC=192.168.1.140 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=43750 PROTO=2
19:48:42.826 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=9054 DF PROTO=UDP SPT=60000 DPT=39246 LEN=370
19:48:49.875 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=9516 DF PROTO=UDP SPT=60000 DPT=57073 LEN=370
19:49:08.027 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=10782 DF PROTO=UDP SPT=60000 DPT=57073 LEN=370
19:49:29.702 UTC [UFW BLOCK] IN=eno1 OUT= MAC=58:47:ca:71:3c:5e:ec:2b:eb:d8:6a:3c:08:00 SRC=192.168.1.205 DST=192.168.1.142 LEN=390 TOS=0x00 PREC=0x00 TTL=64 ID=11976 DF PROTO=UDP SPT=60000 DPT=57073 LEN=370
19:50:32.879 UTC [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:ec:be:dd:50:0f:e8:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=15958 DF PROTO=2
19:50:33.372 UTC [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:fb:58:47:ca:71:cb:43:08:00 SRC=192.168.1.140 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=43752 PROTO=2
By the way, does anyone know how to copy all the log text displayed in KJournald? I had to copy it piece by piece.
IMPORTANT NOTE: I have verified that this bug does not occur with the linux-liquorix 6.6.8 and linux-xanmod-x64v3 6.6.8 kernels, it only occurs with the Manjaro 6.6.8 and 6.7-rc7 kernels, so everything seems to possibly indicate some type of patch or something that it has been added in the build.
I have also verified that this bug does not occur in the Manjaro 6.1.69 LTS kernel.
bedna
27 December 2023 13:12
4
If it works with 6.1, itās a kernel bug, most likely nothing manjaro can do about it.
Usually you copy from terminal with ctrl+shift+c
journalctl --list-boots --no-pager to show boots.
journalctl -b -1 --no-pager will list everything from last boot (and shutdown) in terminal.
But the problem is that it does work fine on versions 6.6.8 of Liquorix and XanMod kernelsā¦
I meant using the KJournald application, which allows me to view the logs using a graphical interfaceā¦
If you use KSystemLog (might need installing) instead of KJournald, you can highlight a range of entries & then use the File => Save menu to save them to a text file. Just a note though - KSystemLog requires entering the root (not user) password to access the logs.
But the problem with KSystemLog is that I cannot load a log, in KJournald it is very easy, I select a log from the list based on the time range it recorded and it loads it, so it is very easy to see the kernel error logs, In KSystemLog I have to start filtering by time to be able to get the logs I want to see and sometimes it is not easy to locate the error if you do not find the exact time it occurred.
I also get the same problem, but it does seem to be a little inconsistent, Iāve had it shutdown successfully but the other times it does not like you describe, and you have to manually power off your PC.
I donāt think it is causing any harm, so for now you should be OK to just deal with it and once your screen goes black, after a couple of seconds, power off your computer.
I donāt seem to see any journal recovery going on on boot up, so it looks like the system does successfully shut down to a point where it considers it a success.
Yes, I have no problem dealing with this, but what I want to say is that in the Liquorix 6.6.8 and XanMod 6.6.8 kernels this error does not happen. If it were an error in the kernel base, it would happen in all 3: in Liquorix, in XanMod and in Manjaro. But it only happens in Manjaro, so I understand that it is not an error in the kernel base, otherwise it should fail in the other two as well.
When youāre in the desktop, can you go to TTY1, by pressing Ctrl + Alt + F1. (You can get back to desktop with Ctrl + Alt + F2).
Do you have what looks like boot text in there that ends with āStarted CUPS Schedulerā or something like that?
I suspect that is what is holding up my machine from powering off as that is the last thing that I see.
Jaypee
28 December 2023 04:25
11
I see you have the same GPU I got a month ago. Sapphire PULSE, to be exact. Problems started ever since.
Same as you, sometimes the machine doesnāt shut down. Good to see another Manjaro user with a similar issue, because Iām considering RMAāing my card.
Does your shutdown process hang at the end? My machine reboots on an unsuccessful shutdown.
This occurs once or twice a week, so itās a pain to troubleshoot. It does seem 7800 XTs can start acting up when it comes to switching power states, according to what Iāve read on the web. There was a testing patch concerning power states on AMD GPUs in the Unstable branch for about a week, from late November to early December, which made all my shutdowns reboots. This is why Iām suspecting 7800 XTs are sensitive to what power state theyāre at.
Not planning to hijack this thread any further, since OP doesnāt seem to have similar hardware.
This may (or may not) be related, but considering where the process seems to halt, this might be worth looking at.
Disable UFW for a few shutdowns and see if it persists.
I have disabled the UFW, but it still failsā¦
12:36:13.885 UTC Linux version 6.6.8-2-MANJARO (builduser@fv-az913-981) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Thu Dec 21 16:21:45 UTC 2023
12:36:13.886 UTC random: crng init done
12:36:13.888 UTC Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64 root=UUID=6934d43d-d41b-4aed-a03b-2d13b953eeac rw rootflags=subvol=@ quiet splash udev.log_priority=3
12:36:13.888 UTC Unknown kernel command line parameters "splash BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64", will be passed to user space.
12:36:13.889 UTC Speculative Return Stack Overflow: IBPB-extending microcode not applied!
12:36:13.889 UTC Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
12:36:13.889 UTC audit: type=2000 audit(1703766970.183:1): state=initialized audit_enabled=0 res=1
12:36:13.890 UTC ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
12:36:13.900 UTC SCSI subsystem initialized
12:36:13.901 UTC VFS: Disk quotas dquot_6.6.0
12:36:13.910 UTC pci 0000:00:00.2: can't derive routing for PCI INT A
12:36:13.910 UTC pci 0000:00:00.2: PCI INT A: not connected
12:36:13.910 UTC Initialise system trusted keyrings
12:36:13.910 UTC Key type blacklist registered
12:36:13.910 UTC integrity: Platform Keyring initialized
12:36:13.910 UTC integrity: Machine keyring initialized
12:36:13.910 UTC Key type asymmetric registered
12:36:13.910 UTC Asymmetric key parser 'x509' registered
12:36:13.913 UTC Loading compiled-in X.509 certificates
12:36:13.913 UTC Loaded X.509 cert 'Build time autogenerated kernel key: c071c707c9e3d2bdd78e51c4cdaf418758e4072a'
12:36:13.913 UTC Key type .fscrypt registered
12:36:13.913 UTC Key type fscrypt-provisioning registered
12:36:13.913 UTC integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
12:36:13.913 UTC integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
12:36:13.917 UTC nvme nvme0: missing or invalid SUBNQN field.
12:36:13.923 UTC clocksource: timekeeping watchdog on CPU4: Marking clocksource 'tsc' as unstable because the skew is too large:
12:36:13.923 UTC clocksource: 'hpet' wd_nsec: 510592896 wd_now: 2294163 wd_last: 1b9b3ba mask: ffffffff
12:36:13.923 UTC clocksource: 'tsc' cs_nsec: 506668815 cs_now: c95d1c440 cs_last: c349d3840 mask: ffffffffffffffff
12:36:13.923 UTC clocksource: Clocksource 'tsc' skewed -3924081 ns (-3 ms) over watchdog 'hpet' interval of 510592896 ns (510 ms)
12:36:13.923 UTC clocksource: 'tsc' is current clocksource.
12:36:13.923 UTC TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
12:36:13.923 UTC clocksource: Checking clocksource tsc synchronization from CPU 0 to CPUs 1,3,8-10,13-15.
12:36:13.926 UTC ------------[ cut here ]------------
12:36:13.926 UTC WARNING: CPU: 2 PID: 190 at drivers/gpu/drm/amd/amdgpu/../display/dc/core/dc_resource.c:2569 calculate_phy_pix_clks+0xd1/0xe0 [amdgpu]
12:36:13.926 UTC Modules linked in: usbhid amdgpu(+) btrfs blake2b_generic libcrc32c crc32c_generic i2c_algo_bit xor drm_ttm_helper raid6_pq ttm drm_exec drm_suballoc_helper amdxcp drm_buddy gpu_sched nvme crc32c_intel sha256_ssse3 drm_display_helper nvme_core xhci_pci cec xhci_pci_renesas video nvme_common wmi
12:36:13.926 UTC CPU: 2 PID: 190 Comm: (udev-worker) Not tainted 6.6.8-2-MANJARO #1 146dce4c0b8863ad44f28ec2edb37ecbadc944c7
12:36:13.926 UTC Hardware name: Micro Computer (HK) Tech Limited UM580/F6BFC, BIOS 5.07 02/10/2023
12:36:13.926 UTC RIP: 0010:calculate_phy_pix_clks+0xd1/0xe0 [amdgpu]
12:36:13.926 UTC Code: ab aa aa aa c1 e1 04 48 0f af ca 48 c1 e9 24 eb a3 8d 14 f6 8d 0c 95 00 00 00 00 ba ab aa aa aa 48 0f af ca 48 c1 e9 24 eb 8a <0f> 0b eb 86 66 66 2e 0f 1f 84 00 00 00 00 00 90 90 90 90 90 90 90
12:36:13.926 UTC RSP: 0018:ffffc900032ff6c0 EFLAGS: 00010297
12:36:13.926 UTC RAX: ffff88811266b800 RBX: ffff88811266b800 RCX: 000000000016a8c8
12:36:13.926 UTC RDX: 0000000000000005 RSI: 000000000016a8c8 RDI: ffff88811266b800
12:36:13.926 UTC RBP: ffff88810c5e0000 R08: 0000000000000000 R09: ffff88811266ba90
12:36:13.926 UTC R10: 0000000000000006 R11: 0000000000000000 R12: ffff888101eec200
12:36:13.926 UTC R13: ffff88811266b858 R14: ffff88810c88e000 R15: ffff88811266b800
12:36:13.926 UTC FS: 00007fa3dc8a0cc0(0000) GS:ffff888fce680000(0000) knlGS:0000000000000000
12:36:13.926 UTC CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
12:36:13.926 UTC CR2: 0000559979227138 CR3: 000000010b6fe000 CR4: 0000000000f50ee0
12:36:13.926 UTC PKRU: 55555554
12:36:13.926 UTC Call Trace:
12:36:13.926 UTC <TASK>
12:36:13.926 UTC ? calculate_phy_pix_clks+0xd1/0xe0 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.926 UTC ? __warn+0x81/0x130
12:36:13.926 UTC ? report_bug+0x171/0x1a0
12:36:13.926 UTC ? handle_bug+0x3c/0x80
12:36:13.926 UTC ? exc_invalid_op+0x17/0x70
12:36:13.926 UTC ? asm_exc_invalid_op+0x1a/0x20
12:36:13.926 UTC dc_validate_stream+0x35/0xc0 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.926 UTC create_validate_stream_for_sink+0x1fe/0x390 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.926 UTC amdgpu_dm_connector_mode_valid+0x61/0x1b0 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.926 UTC drm_connector_mode_valid+0x3b/0x60
12:36:13.926 UTC __drm_helper_update_and_validate+0xfe/0x3c0
12:36:13.926 UTC ? amdgpu_dm_connector_get_modes+0x28c/0x520 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.926 UTC ? srso_alias_return_thunk+0x5/0x7f
12:36:13.926 UTC drm_helper_probe_single_connector_modes+0x2ab/0x540
12:36:13.926 UTC drm_client_modeset_probe+0x24b/0x1520
12:36:13.926 UTC ? __kmem_cache_alloc_node+0x1a6/0x340
12:36:13.926 UTC ? amdgpu_vm_bo_add+0x2e/0xb0 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.926 UTC ? kmalloc_trace+0x2a/0xa0
12:36:13.926 UTC __drm_fb_helper_initial_config_and_unlock+0x3d/0x540
12:36:13.926 UTC ? amdgpu_driver_open_kms+0xe2/0x270 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.926 UTC drm_fbdev_generic_client_hotplug+0x6a/0xb0
12:36:13.926 UTC drm_client_register+0x79/0xc0
12:36:13.926 UTC amdgpu_pci_probe+0x3be/0x450 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.926 UTC local_pci_probe+0x45/0xa0
12:36:13.927 UTC pci_device_probe+0xc1/0x260
12:36:13.927 UTC ? sysfs_do_create_link_sd+0x6e/0xe0
12:36:13.927 UTC really_probe+0x19e/0x3e0
12:36:13.927 UTC ? __pfx___driver_attach+0x10/0x10
12:36:13.927 UTC __driver_probe_device+0x78/0x160
12:36:13.927 UTC driver_probe_device+0x1f/0x90
12:36:13.927 UTC __driver_attach+0xd2/0x1c0
12:36:13.927 UTC bus_for_each_dev+0x88/0xd0
12:36:13.927 UTC bus_add_driver+0x116/0x220
12:36:13.927 UTC driver_register+0x59/0x100
12:36:13.927 UTC ? __pfx_amdgpu_init+0x10/0x10 [amdgpu 52694bdeee024ab6bd56aaaf8af75da9203d43d5]
12:36:13.927 UTC do_one_initcall+0x5d/0x320
12:36:13.927 UTC do_init_module+0x60/0x240
12:36:13.927 UTC init_module_from_file+0x89/0xe0
12:36:13.927 UTC idempotent_init_module+0x120/0x2b0
12:36:13.927 UTC __x64_sys_finit_module+0x5e/0xb0
12:36:13.927 UTC do_syscall_64+0x60/0x90
12:36:13.927 UTC ? srso_alias_return_thunk+0x5/0x7f
12:36:13.927 UTC ? ksys_lseek+0x6c/0xb0
12:36:13.927 UTC ? syscall_exit_to_user_mode+0x2b/0x40
12:36:13.927 UTC ? do_syscall_64+0x6c/0x90
12:36:13.927 UTC entry_SYSCALL_64_after_hwframe+0x6e/0xd8
12:36:13.927 UTC RIP: 0033:0x7fa3dd38173d
12:36:13.927 UTC Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 95 0c 00 f7 d8 64 89 01 48
12:36:13.927 UTC RSP: 002b:00007ffdfcc82308 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
12:36:13.927 UTC RAX: ffffffffffffffda RBX: 00005599791e1310 RCX: 00007fa3dd38173d
12:36:13.927 UTC RDX: 0000000000000000 RSI: 00007fa3dd48e376 RDI: 0000000000000019
12:36:13.927 UTC RBP: 00007fa3dd48e376 R08: 0000000000000001 R09: fffffffffffffe88
12:36:13.927 UTC R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
12:36:13.927 UTC R13: 00005599791e06b0 R14: 0000000000000000 R15: 00005599791e4190
12:36:13.927 UTC </TASK>
12:36:13.927 UTC ---[ end trace 0000000000000000 ]---
12:36:14.670 UTC ccp 0000:04:00.2: ccp: unable to access the device: you might be running a broken BIOS.
12:36:14.682 UTC ccp 0000:04:00.2: tee enabled
12:36:14.686 UTC ccp 0000:04:00.2: psp enabled
12:36:14.870 UTC cfg80211: Loading compiled-in X.509 certificates for regulatory database
12:36:14.870 UTC Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
12:36:15.119 UTC pcie_mp2_amd 0000:04:00.7: Failed to discover, sensors not enabled is 1
12:36:15.149 UTC Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
12:36:15.182 UTC ------------[ cut here ]------------
12:36:15.182 UTC list_add corruption. next->prev should be prev (ffff8881063febd8), but was 4ad56d1fb81bbda9. (next=ffff8881063febd8).
12:36:15.182 UTC WARNING: CPU: 2 PID: 439 at lib/list_debug.c:29 __list_add_valid_or_report+0x6a/0xa0
12:36:15.182 UTC Modules linked in: hid_sensor_accel_3d(+) hid_sensor_gyro_3d hid_sensor_magn_3d intel_rapl_common hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common hid_sensor_hub edac_mce_amd vfat fat snd_sof_amd_vangogh kvm_amd snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp kvm snd_sof_pci mt7921e(+) snd_sof_xtensa_dsp mt7921_common snd_hda_codec_conexant snd_sof irqbypass mt792x_lib snd_hda_codec_generic btusb snd_sof_utils crct10dif_pclmul ledtrig_audio mt76_connac_lib btrtl crc32_pclmul snd_hda_codec_hdmi btintel snd_soc_core polyval_clmulni mt76 btbcm polyval_generic snd_hda_intel btmtk snd_compress gf128mul snd_intel_dspcfg ac97_bus ghash_clmulni_intel mac80211 snd_pcm_dmaengine snd_intel_sdw_acpi sha512_ssse3 snd_pci_ps bluetooth sha1_ssse3 snd_rpl_pci_acp6x snd_hda_codec snd_acp_pci aesni_intel libarc4 snd_acp_legacy_common snd_hda_core crypto_simd snd_pci_acp6x ecdh_generic cryptd crc16 snd_hwdep snd_pci_acp5x rapl cfg80211 snd_rn_pci_acp3x snd_pcm sp5100_tco wmi_bmof
12:36:15.182 UTC snd_acp_config snd_timer pcspkr snd_soc_acpi i2c_piix4 igc k10temp snd_pci_acp3x snd rfkill amd_sfh(+) ccp soundcore cm32181 i2c_hid_acpi industrialio joydev mousedev i2c_hid mac_hid i2c_dev crypto_user fuse dm_mod loop nfnetlink bpf_preload ip_tables x_tables usbhid amdgpu btrfs blake2b_generic libcrc32c crc32c_generic i2c_algo_bit xor drm_ttm_helper raid6_pq ttm drm_exec drm_suballoc_helper amdxcp drm_buddy gpu_sched nvme crc32c_intel sha256_ssse3 drm_display_helper nvme_core xhci_pci cec xhci_pci_renesas video nvme_common wmi
12:36:15.182 UTC CPU: 2 PID: 439 Comm: (udev-worker) Tainted: G W 6.6.8-2-MANJARO #1 146dce4c0b8863ad44f28ec2edb37ecbadc944c7
12:36:15.182 UTC Hardware name: Micro Computer (HK) Tech Limited UM580/F6BFC, BIOS 5.07 02/10/2023
12:36:15.182 UTC RIP: 0010:__list_add_valid_or_report+0x6a/0xa0
12:36:15.183 UTC Code: a5 ff 0f 0b 31 c0 e9 d5 2f 77 00 48 c7 c7 20 d0 e9 87 e8 69 fe a5 ff 0f 0b eb e9 48 89 c1 48 c7 c7 48 d0 e9 87 e8 56 fe a5 ff <0f> 0b eb d6 48 89 d1 48 89 c6 4c 89 c2 48 c7 c7 98 d0 e9 87 e8 3d
12:36:15.183 UTC RSP: 0018:ffffc900006a39f8 EFLAGS: 00010082
12:36:15.183 UTC RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000027
12:36:15.183 UTC RDX: ffff888fce6a16c8 RSI: 0000000000000001 RDI: ffff888fce6a16c0
12:36:15.183 UTC RBP: ffffc900006a3a48 R08: 0000000000000000 R09: ffffc900006a3880
12:36:15.183 UTC R10: 0000000000000003 R11: ffffffff886ca428 R12: ffff8881063febd0
12:36:15.183 UTC R13: 0000000000000286 R14: ffffc900006a3a60 R15: ffff8881063febd8
12:36:15.183 UTC FS: 00007fcd87336cc0(0000) GS:ffff888fce680000(0000) knlGS:0000000000000000
12:36:15.183 UTC CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
12:36:15.183 UTC CR2: 0000557cd21aede8 CR3: 000000010b5ee000 CR4: 0000000000f50ee0
12:36:15.183 UTC PKRU: 55555554
12:36:15.183 UTC Call Trace:
12:36:15.183 UTC <TASK>
12:36:15.183 UTC ? __list_add_valid_or_report+0x6a/0xa0
12:36:15.183 UTC ? __warn+0x81/0x130
12:36:15.183 UTC ? report_bug+0x171/0x1a0
12:36:15.183 UTC ? prb_read_valid+0x1b/0x30
12:36:15.183 UTC ? srso_alias_return_thunk+0x5/0x7f
12:36:15.183 UTC ? handle_bug+0x3c/0x80
12:36:15.183 UTC ? exc_invalid_op+0x17/0x70
12:36:15.183 UTC ? asm_exc_invalid_op+0x1a/0x20
12:36:15.183 UTC prepare_to_wait_event+0x10d/0x180
12:36:15.183 UTC amdtp_wait_for_response+0xe6/0x160 [amd_sfh 5ef895de2f45e692f28ed5fd839820ee39040321]
12:36:15.183 UTC ? queue_delayed_work_on+0x3d/0x50
12:36:15.183 UTC ? __pfx_autoremove_wake_function+0x10/0x10
12:36:15.184 UTC sensor_hub_get_feature+0xc6/0x170 [hid_sensor_hub e5eacd9d984426acc83f0909a778c86f6165cc87]
12:36:15.184 UTC hid_sensor_parse_common_attributes+0x217/0x310 [hid_sensor_iio_common 9effeffc62eb1b6e955f0af38abe27c6cbf3cfcb]
12:36:15.184 UTC hid_accel_3d_probe+0xb7/0x310 [hid_sensor_accel_3d a392c280be90d80814f01e7d6d634670f6dcd7c9]
12:36:15.184 UTC ? srso_alias_return_thunk+0x5/0x7f
12:36:15.184 UTC platform_probe+0x44/0xa0
12:36:15.184 UTC really_probe+0x19e/0x3e0
12:36:15.184 UTC ? __pfx___driver_attach+0x10/0x10
12:36:15.184 UTC __driver_probe_device+0x78/0x160
12:36:15.184 UTC driver_probe_device+0x1f/0x90
12:36:15.184 UTC __driver_attach+0xd2/0x1c0
12:36:15.184 UTC bus_for_each_dev+0x88/0xd0
12:36:15.184 UTC bus_add_driver+0x116/0x220
12:36:15.184 UTC driver_register+0x59/0x100
12:36:15.184 UTC ? __pfx_hid_accel_3d_platform_driver_init+0x10/0x10 [hid_sensor_accel_3d a392c280be90d80814f01e7d6d634670f6dcd7c9]
12:36:15.184 UTC do_one_initcall+0x5d/0x320
12:36:15.184 UTC do_init_module+0x60/0x240
12:36:15.184 UTC init_module_from_file+0x89/0xe0
12:36:15.184 UTC idempotent_init_module+0x120/0x2b0
12:36:15.184 UTC __x64_sys_finit_module+0x5e/0xb0
12:36:15.184 UTC do_syscall_64+0x60/0x90
12:36:15.184 UTC ? syscall_exit_to_user_mode+0x2b/0x40
12:36:15.184 UTC ? do_syscall_64+0x6c/0x90
12:36:15.184 UTC entry_SYSCALL_64_after_hwframe+0x6e/0xd8
12:36:15.184 UTC RIP: 0033:0x7fcd876cb73d
12:36:15.184 UTC Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 95 0c 00 f7 d8 64 89 01 48
12:36:15.184 UTC RSP: 002b:00007ffe985ce6e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
12:36:15.184 UTC RAX: ffffffffffffffda RBX: 0000557cd2270ec0 RCX: 00007fcd876cb73d
12:36:15.184 UTC RDX: 0000000000000004 RSI: 00007fcd87c40376 RDI: 000000000000002a
12:36:15.184 UTC RBP: 00007fcd87c40376 R08: 0000000000000001 R09: fffffffffffffe88
12:36:15.184 UTC R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
12:36:15.184 UTC R13: 0000557cd22664c0 R14: 0000000000000000 R15: 0000557cd22748c0
12:36:15.184 UTC </TASK>
12:36:15.184 UTC ---[ end trace 0000000000000000 ]---
12:36:15.219 UTC Bluetooth: hci0: AOSP quality report is not supported
12:36:16.689 UTC BUG: unable to handle page fault for address: ffffffffffffffe8
12:36:16.689 UTC #PF: supervisor read access in kernel mode
12:36:16.689 UTC #PF: error_code(0x0000) - not-present page
12:36:16.689 UTC Oops: 0000 [#1] PREEMPT SMP NOPTI
12:36:16.689 UTC CPU: 2 PID: 439 Comm: (udev-worker) Tainted: G W 6.6.8-2-MANJARO #1 146dce4c0b8863ad44f28ec2edb37ecbadc944c7
12:36:16.689 UTC Hardware name: Micro Computer (HK) Tech Limited UM580/F6BFC, BIOS 5.07 02/10/2023
12:36:16.689 UTC RIP: 0010:prepare_to_wait_event+0xf6/0x180
12:36:16.689 UTC Code: 08 49 8d 74 24 08 49 8d 57 e8 4c 89 f9 49 39 f7 74 1d 49 89 f7 eb 13 48 8b 42 18 49 89 cf 48 8d 50 e8 48 39 c6 74 08 48 89 c1 <f6> 02 20 75 e8 49 8b 17 4c 89 fe 4c 89 f7 48 89 14 24 e8 53 7c 52
12:36:16.689 UTC RSP: 0018:ffffc900006a3a00 EFLAGS: 00010017
12:36:16.690 UTC RAX: ffffc900006a3a60 RBX: 0000000000000001 RCX: 0000000000000000
12:36:16.690 UTC RDX: ffffffffffffffe8 RSI: ffff8881063febd8 RDI: ffff8881063febd0
12:36:16.690 UTC RBP: ffffc900006a3a48 R08: 0000000000000000 R09: 0000000000000000
12:36:16.690 UTC R10: 0000000000000001 R11: 0000000000000110 R12: ffff8881063febd0
12:36:16.690 UTC R13: 0000000000000286 R14: ffffc900006a3a60 R15: ffff8881063febd8
12:36:16.690 UTC FS: 00007fcd87336cc0(0000) GS:ffff888fce680000(0000) knlGS:0000000000000000
12:36:16.690 UTC CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
12:36:16.690 UTC CR2: ffffffffffffffe8 CR3: 000000010b5ee000 CR4: 0000000000f50ee0
12:36:16.690 UTC PKRU: 55555554
12:36:16.690 UTC Call Trace:
12:36:16.690 UTC <TASK>
12:36:16.690 UTC ? __die+0x23/0x70
12:36:16.690 UTC ? page_fault_oops+0x171/0x4e0
12:36:16.690 UTC ? srso_alias_return_thunk+0x5/0x7f
12:36:16.690 UTC ? exc_page_fault+0x175/0x180
12:36:16.690 UTC ? asm_exc_page_fault+0x26/0x30
12:36:16.690 UTC ? prepare_to_wait_event+0xf6/0x180
12:36:16.690 UTC amdtp_wait_for_response+0xe6/0x160 [amd_sfh 5ef895de2f45e692f28ed5fd839820ee39040321]
12:36:16.690 UTC ? queue_delayed_work_on+0x3d/0x50
12:36:16.690 UTC ? __pfx_autoremove_wake_function+0x10/0x10
12:36:16.690 UTC sensor_hub_get_feature+0xc6/0x170 [hid_sensor_hub e5eacd9d984426acc83f0909a778c86f6165cc87]
12:36:16.690 UTC hid_sensor_parse_common_attributes+0x217/0x310 [hid_sensor_iio_common 9effeffc62eb1b6e955f0af38abe27c6cbf3cfcb]
12:36:16.690 UTC hid_accel_3d_probe+0xb7/0x310 [hid_sensor_accel_3d a392c280be90d80814f01e7d6d634670f6dcd7c9]
12:36:16.690 UTC platform_probe+0x44/0xa0
12:36:16.690 UTC really_probe+0x19e/0x3e0
12:36:16.690 UTC ? __pfx___driver_attach+0x10/0x10
12:36:16.690 UTC __driver_probe_device+0x78/0x160
12:36:16.690 UTC driver_probe_device+0x1f/0x90
12:36:16.690 UTC __driver_attach+0xd2/0x1c0
12:36:16.690 UTC bus_for_each_dev+0x88/0xd0
12:36:16.690 UTC bus_add_driver+0x116/0x220
12:36:16.690 UTC driver_register+0x59/0x100
12:36:16.690 UTC ? __pfx_hid_accel_3d_platform_driver_init+0x10/0x10 [hid_sensor_accel_3d a392c280be90d80814f01e7d6d634670f6dcd7c9]
12:36:16.690 UTC do_one_initcall+0x5d/0x320
12:36:16.690 UTC do_init_module+0x60/0x240
12:36:16.690 UTC init_module_from_file+0x89/0xe0
12:36:16.690 UTC idempotent_init_module+0x120/0x2b0
12:36:16.690 UTC __x64_sys_finit_module+0x5e/0xb0
12:36:16.690 UTC do_syscall_64+0x60/0x90
12:36:16.690 UTC ? syscall_exit_to_user_mode+0x2b/0x40
12:36:16.690 UTC ? do_syscall_64+0x6c/0x90
12:36:16.690 UTC entry_SYSCALL_64_after_hwframe+0x6e/0xd8
12:36:16.690 UTC RIP: 0033:0x7fcd876cb73d
12:36:16.690 UTC Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 95 0c 00 f7 d8 64 89 01 48
12:36:16.690 UTC RSP: 002b:00007ffe985ce6e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
12:36:16.690 UTC RAX: ffffffffffffffda RBX: 0000557cd2270ec0 RCX: 00007fcd876cb73d
12:36:16.690 UTC RDX: 0000000000000004 RSI: 00007fcd87c40376 RDI: 000000000000002a
12:36:16.690 UTC RBP: 00007fcd87c40376 R08: 0000000000000001 R09: fffffffffffffe88
12:36:16.690 UTC R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
12:36:16.691 UTC R13: 0000557cd22664c0 R14: 0000000000000000 R15: 0000557cd22748c0
12:36:16.691 UTC </TASK>
12:36:16.691 UTC Modules linked in: qrtr cmac algif_hash algif_skcipher af_alg bnep intel_rapl_msr hid_sensor_accel_3d(+) hid_sensor_gyro_3d hid_sensor_magn_3d intel_rapl_common hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common hid_sensor_hub edac_mce_amd vfat fat snd_sof_amd_vangogh kvm_amd snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp kvm snd_sof_pci mt7921e snd_sof_xtensa_dsp mt7921_common snd_hda_codec_conexant snd_sof irqbypass mt792x_lib snd_hda_codec_generic btusb snd_sof_utils crct10dif_pclmul ledtrig_audio mt76_connac_lib btrtl crc32_pclmul snd_hda_codec_hdmi btintel snd_soc_core polyval_clmulni mt76 btbcm polyval_generic snd_hda_intel btmtk snd_compress gf128mul snd_intel_dspcfg ac97_bus ghash_clmulni_intel mac80211 snd_pcm_dmaengine snd_intel_sdw_acpi sha512_ssse3 snd_pci_ps bluetooth sha1_ssse3 snd_rpl_pci_acp6x snd_hda_codec snd_acp_pci aesni_intel libarc4 snd_acp_legacy_common snd_hda_core crypto_simd snd_pci_acp6x ecdh_generic cryptd crc16 snd_hwdep snd_pci_acp5x
12:36:16.691 UTC rapl cfg80211 snd_rn_pci_acp3x snd_pcm sp5100_tco wmi_bmof snd_acp_config snd_timer pcspkr snd_soc_acpi i2c_piix4 igc k10temp snd_pci_acp3x snd rfkill amd_sfh(+) ccp soundcore cm32181 i2c_hid_acpi industrialio joydev mousedev i2c_hid mac_hid i2c_dev crypto_user fuse dm_mod loop nfnetlink bpf_preload ip_tables x_tables usbhid amdgpu btrfs blake2b_generic libcrc32c crc32c_generic i2c_algo_bit xor drm_ttm_helper raid6_pq ttm drm_exec drm_suballoc_helper amdxcp drm_buddy gpu_sched nvme crc32c_intel sha256_ssse3 drm_display_helper nvme_core xhci_pci cec xhci_pci_renesas video nvme_common wmi
12:36:16.691 UTC CR2: ffffffffffffffe8
12:36:16.691 UTC ---[ end trace 0000000000000000 ]---
12:36:16.691 UTC RIP: 0010:prepare_to_wait_event+0xf6/0x180
12:36:16.691 UTC Code: 08 49 8d 74 24 08 49 8d 57 e8 4c 89 f9 49 39 f7 74 1d 49 89 f7 eb 13 48 8b 42 18 49 89 cf 48 8d 50 e8 48 39 c6 74 08 48 89 c1 <f6> 02 20 75 e8 49 8b 17 4c 89 fe 4c 89 f7 48 89 14 24 e8 53 7c 52
12:36:16.691 UTC RSP: 0018:ffffc900006a3a00 EFLAGS: 00010017
12:36:16.691 UTC RAX: ffffc900006a3a60 RBX: 0000000000000001 RCX: 0000000000000000
12:36:16.691 UTC RDX: ffffffffffffffe8 RSI: ffff8881063febd8 RDI: ffff8881063febd0
12:36:16.691 UTC RBP: ffffc900006a3a48 R08: 0000000000000000 R09: 0000000000000000
12:36:16.691 UTC R10: 0000000000000001 R11: 0000000000000110 R12: ffff8881063febd0
12:36:16.691 UTC R13: 0000000000000286 R14: ffffc900006a3a60 R15: ffff8881063febd8
12:36:16.691 UTC FS: 00007fcd87336cc0(0000) GS:ffff888fce680000(0000) knlGS:0000000000000000
12:36:16.691 UTC CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
12:36:16.691 UTC CR2: ffffffffffffffe8 CR3: 000000010b5ee000 CR4: 0000000000f50ee0
12:36:16.691 UTC PKRU: 55555554
12:36:20.799 UTC sddm-greeter[696]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
12:36:28.956 UTC warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
bedna
28 December 2023 13:39
14
There you have it.
Use the kernel that works until the bug, whatever it is, is resolved.
When trying out newer kernels in the future and it still is not fixed, use REISUO and REISUB instead of holding/pressing the button to shut down/reboot:
Difficulty: ā
ā
āāā
This tutorial was created because people are using a hard power off during freezes, so this will teach you how to turn off your computer when everything is frozen using softer means.
So whenever you see someone saying they had to āPower Offā or āHard Resetā their system without doing a REISUB, please send them here!
If youāre reading this in response to a question, please click the green link above this text to bring you to the full unabridged text of the tutorialā¦
Well, if the topic was to comment and somehow get it to the Manjaro people that I think there is a bug in the latest compilations of their kernel, to prevent this error from appearing in the 6.7 branch because I see that this bug also occurs in this version of Manjaro. I hope they can read this thread.
Right now I can work without problems with Liquorix 6.6.8 or XanMod 6.6.8, since the bug does not occur in them, so that is not the problem, the issue, as I said, was to somehow get this to the people of Manjaro.
Letās try to attract some extra attention to this. @philm
In the meantime, please post output from these commands; they will likely be useful for reference:
journalctl --boot=-1 --priority=3 --catalog --no-pager
I understand they may be busy at the moment, but Iām sure someone from the Team will look at this as soon as they are able.
Thanks for reporting this. Cheers.
Update:- I found this related Arch thread Cannot Shutdown/poweroff with AMD Radeon 7800 XT . Certainly the issue isnāt uncommon for this card; and I noticed a similar mention in comments of Unstable Update December 2023 , so I imagine the Team is aware of it.
philm
8 January 2024 03:02
17
This looks like this:
https://bugzilla.kernel.org/show_bug.cgi?id=217876
Can you pass amdgpu.mcbp=0 as kernel parameter at boot to see if that resolves your issue?
I opened that bug several months ago, but it was a different bug, in that case what happened is that when browsing the web with a Chromium browser, the Linux randomly crashed in the 6.5 kernel, but it was already fixed.
I have tried to introduce that line that you mention (set amdgpu.mcbp=0 in the boot process) but it still fails the same, I have also made a first compilation (it takes me almost 3 hours to compile) commenting on the lines that you have indicated related to AMD GPU, but it still fails the same. Iām doing another build now having commented on all the patches, to confirm that at least that way it works correctly, because if not, I donāt know what to thinkā¦
