Hi,
I noticed this issue for a long time. Usually during a system uptime (which means the computer was turned on until power off), if I am the only user login during that uptime, the shutdown process would be smooth. However, if multiple users have logged in during the uptime, even if they logged out, when I try to shutdown the computer, the shutdown process would be stuck at “a stop job is running for session 2 of user $USERNAME” until time out (1 and half minutes). I read some articles saying we can change the systems time out settings to reduce the waiting time, but I hope to find out what cause such an issue.
I check the journalctl output for my last boot time and the following should be the content related to the “running session 2” issue:
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Session 2 of User o0331dobe...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Session 8 of User o0331dobe...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Session c2 of User sddm...
Jan 24 21:05:49 Tu-PC systemd[1]: Removed slice Slice /system/modprobe.
Jan 24 21:05:49 Tu-PC audit[158317]: CRED_DISP pid=158317 uid=0 auid=1000 ses=8 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="o0331dobe" exe="/usr/bin/login" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC login[158317]: pam_unix(login:session): session closed for user o0331dobe
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target Graphical Interface.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target Multi-User System.
Jan 24 21:05:49 Tu-PC kernel: audit: type=1106 audit(1643047549.425:272): pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC kernel: audit: type=1104 audit(1643047549.425:273): pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC kernel: audit: type=1104 audit(1643047549.425:274): pid=158317 uid=0 auid=1000 ses=8 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="o0331dobe" exe="/usr/bin/login" hostname=Tu-PC addr=? terminal=/dev/tty2 res=suc>
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target Login Prompts.
Jan 24 21:05:49 Tu-PC sddm[2926]: Error from greeter session: "Process crashed"
Jan 24 21:05:49 Tu-PC sddm[2926]: Auth: sddm-helper crashed (exit code 15)
Jan 24 21:05:49 Tu-PC sddm[2926]: Auth: sddm-helper exited with 15
Jan 24 21:05:49 Tu-PC sddm[2926]: Greeter stopped.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target Sound Card.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target Timer Units.
Jan 24 21:05:49 Tu-PC systemd[1]: clamav-unofficial-sigs.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Clamav Unofficial Sigs Update timer.
Jan 24 21:05:49 Tu-PC systemd[1]: logrotate.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Daily rotation of log files.
Jan 24 21:05:49 Tu-PC systemd[1]: man-db.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Daily man-db regeneration.
Jan 24 21:05:49 Tu-PC systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Monthly clean packages cache.
Jan 24 21:05:49 Tu-PC systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Generate mirrorlist weekly.
Jan 24 21:05:49 Tu-PC systemd[1]: pkgfile-update.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped pkgfile database update timer.
Jan 24 21:05:49 Tu-PC systemd[1]: raid-check.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Run periodic raid volume scrub.
Jan 24 21:05:49 Tu-PC systemd[1]: sanoid.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Run Sanoid Every 15 Minutes.
Jan 24 21:05:49 Tu-PC systemd[1]: shadow.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Daily verification of password and group files.
Jan 24 21:05:49 Tu-PC systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Jan 24 21:05:49 Tu-PC systemd[1]: zpool-scrub@zbigdata.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Scrub ZFS pool weekly.
Jan 24 21:05:49 Tu-PC systemd[1]: zpool-scrub@zhome.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: zpool-scrub@zroot.timer: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target System Time Set.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target ZFS startup target.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target ZFS pool import target.
Jan 24 21:05:49 Tu-PC systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Closed LVM2 poll daemon socket.
Jan 24 21:05:49 Tu-PC systemd[1]: systemd-coredump.socket: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Closed Process Core Dump Socket.
Jan 24 21:05:49 Tu-PC systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Save/Restore Sound Card State...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Clam AntiVirus userspace daemon...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping ClamAV virus database updater...
Jan 24 21:05:49 Tu-PC freshclam[9000]: Update process terminated
Jan 24 21:05:49 Tu-PC audit[158317]: USER_END pid=158317 uid=0 auid=1000 ses=8 msg='op=PAM:session_close grantors=? acct="o0331dobe" exe="/usr/bin/login" hostname=Tu-PC addr=? terminal=/dev/tty2 res=failed'
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Getty on tty2...
Jan 24 21:05:49 Tu-PC login[158317]: pam_systemd(login:session): Failed to release session: Interrupted system call
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Initialize hardware monitoring sensors...
Jan 24 21:05:49 Tu-PC systemd[1]: Starting Generate shutdown-ramfs...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping NVIDIA fake powerd service...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Authorization Manager...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Simple Desktop Display Manager...
Jan 24 21:05:49 Tu-PC sddm[2926]: Signal received: SIGTERM
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Samba SMB Daemon...
Jan 24 21:05:49 Tu-PC sddm[2926]: Socket server stopping...
Jan 24 21:05:49 Tu-PC sddm[2926]: Socket server stopped.
Jan 24 21:05:49 Tu-PC sddm[2926]: Display server stopping...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Virtual Machine and Container Registration Service...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Load/Save Random Seed...
Jan 24 21:05:49 Tu-PC kernel: audit: type=1106 audit(1643047549.432:275): pid=158317 uid=0 auid=1000 ses=8 msg='op=PAM:session_close grantors=? acct="o0331dobe" exe="/usr/bin/login" hostname=Tu-PC addr=? terminal=/dev/tty2 res=failed'
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping TeamViewer remote control daemon...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Disk Manager...
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Daemon for power management...
Jan 24 21:05:49 Tu-PC systemd[1]: nvidia-fake-powerd.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped NVIDIA fake powerd service.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidia-fake-powerd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: systemd-machined.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Virtual Machine and Container Registration Service.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-machined comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: upower.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Daemon for power management.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: clamav-freshclam.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped ClamAV virus database updater.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=clamav-freshclam comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: smb.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Samba SMB Daemon.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: rtkit-daemon.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: getty@tty2.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Getty on tty2.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: polkit.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Authorization Manager.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: alsa-restore.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Save/Restore Sound Card State.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: systemd-random-seed.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Load/Save Random Seed.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: session-8.scope: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Session 8 of User o0331dobe.
Jan 24 21:05:49 Tu-PC mkinitcpio[158577]: ==> Starting build: none
Jan 24 21:05:49 Tu-PC sddm[2926]: Display server stopped.
Jan 24 21:05:49 Tu-PC sddm[2926]: Running display stop script "/usr/share/sddm/scripts/Xstop"
Jan 24 21:05:49 Tu-PC udisksd[8033]: udisks daemon version 2.9.4 exiting
Jan 24 21:05:49 Tu-PC mkinitcpio[158577]: -> Running build hook: [sd-shutdown]
Jan 24 21:05:49 Tu-PC systemd-logind[2746]: Session c2 logged out. Waiting for processes to exit.
Jan 24 21:05:49 Tu-PC systemd[1]: sddm.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Simple Desktop Display Manager.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: sddm.service: Consumed 11.825s CPU time.
Jan 24 21:05:49 Tu-PC systemd[1]: teamviewerd.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped TeamViewer remote control daemon.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=teamviewerd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd-logind[2746]: Session 8 logged out. Waiting for processes to exit.
Jan 24 21:05:49 Tu-PC systemd[1]: Removed slice Slice /system/getty.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping Samba NMB Daemon...
Jan 24 21:05:49 Tu-PC nmbd[9001]: [2022/01/24 21:05:49.462684, 0] ../../source3/nmbd/nmbd.c:59(terminate)
Jan 24 21:05:49 Tu-PC nmbd[9001]: Got SIGTERM: going down...
Jan 24 21:05:49 Tu-PC systemd-logind[2746]: Removed session 8.
Jan 24 21:05:49 Tu-PC systemd[1]: nmb.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Samba NMB Daemon.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped target Network is Online.
Jan 24 21:05:49 Tu-PC systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Network Manager Wait Online.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: udisks2.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Disk Manager.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: session-c2.scope: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Session c2 of User sddm.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping User Manager for UID 966...
Jan 24 21:05:49 Tu-PC systemd[156326]: Activating special unit Exit the Session...
Jan 24 21:05:49 Tu-PC systemd[156326]: Stopped target Main User Target.
Jan 24 21:05:49 Tu-PC systemd-logind[2746]: Removed session c2.
Jan 24 21:05:49 Tu-PC systemd[156326]: Stopping D-Bus User Message Bus...
Jan 24 21:05:49 Tu-PC systemd[156326]: Stopped D-Bus User Message Bus.
Jan 24 21:05:49 Tu-PC systemd[156326]: Stopped target Basic System.
Jan 24 21:05:49 Tu-PC systemd[156326]: Stopped target Paths.
Jan 24 21:05:49 Tu-PC systemd[156326]: Stopped target Sockets.
Jan 24 21:05:49 Tu-PC systemd[156326]: Stopped target Timers.
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed D-Bus User Message Bus Socket.
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed GnuPG network certificate management daemon.
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed GCR ssh-agent wrapper.
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed p11-kit server.
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed PipeWire PulseAudio.
Jan 24 21:05:49 Tu-PC systemd[156326]: Closed PipeWire Multimedia System Socket.
Jan 24 21:05:49 Tu-PC systemd[156326]: Removed slice User Application Slice.
Jan 24 21:05:49 Tu-PC systemd[156326]: Reached target Shutdown.
Jan 24 21:05:49 Tu-PC systemd[156326]: Finished Exit the Session.
Jan 24 21:05:49 Tu-PC systemd[156326]: Reached target Exit the Session.
Jan 24 21:05:49 Tu-PC systemd[156327]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jan 24 21:05:49 Tu-PC systemd[1]: user@966.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped User Manager for UID 966.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: Stopping User Runtime Directory /run/user/966...
Jan 24 21:05:49 Tu-PC systemd[1]: run-user-966.mount: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Unmounted /run/user/966.
Jan 24 21:05:49 Tu-PC systemd[1]: user-runtime-dir@966.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped User Runtime Directory /run/user/966.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: Removed slice User Slice of UID 966.
Jan 24 21:05:49 Tu-PC audit: BPF prog-id=0 op=UNLOAD
Jan 24 21:05:49 Tu-PC mkinitcpio[158577]: ==> Build complete.
Jan 24 21:05:49 Tu-PC systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Finished Generate shutdown-ramfs.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: lm_sensors.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Initialize hardware monitoring sensors.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lm_sensors comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC clamd[2697]: Mon Jan 24 21:05:49 2022 -> Pid file removed.
Jan 24 21:05:49 Tu-PC clamd[2697]: Mon Jan 24 21:05:49 2022 -> --- Stopped at Mon Jan 24 21:05:49 2022
Jan 24 21:05:49 Tu-PC systemd[1]: clamav-daemon.service: Deactivated successfully.
Jan 24 21:05:49 Tu-PC systemd[1]: Stopped Clam AntiVirus userspace daemon.
Jan 24 21:05:49 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=clamav-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:49 Tu-PC systemd[1]: clamav-daemon.service: Consumed 13.687s CPU time.
Jan 24 21:06:08 Tu-PC kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Jan 24 21:06:08 Tu-PC kernel: sd 0:0:0:0: [sda] Stopping disk
Jan 24 21:07:19 Tu-PC systemd[1]: session-2.scope: Stopping timed out. Killing.
Jan 24 21:07:19 Tu-PC systemd[1]: session-2.scope: Killing process 9669 (kwin_x11) with signal SIGKILL.
Jan 24 21:07:19 Tu-PC systemd[1]: session-2.scope: Killing process 9834 (QQmlThread) with signal SIGKILL.
Jan 24 21:07:19 Tu-PC systemd[1]: session-2.scope: Failed with result 'timeout'.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopped Session 2 of User o0331dobe.
Jan 24 21:07:19 Tu-PC systemd[1]: session-2.scope: Consumed 6min 48.698s CPU time.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopping User Login Management...
Jan 24 21:07:19 Tu-PC systemd[1]: Stopping User Manager for UID 1000.
Here's the full journal of the last shutdown process
Jan 24 21:05:45 Tu-PC systemd[1]: Stopping User Manager for UID 1001...
Jan 24 21:05:45 Tu-PC systemd[157891]: Activating special unit Exit the Session...
Jan 24 21:05:45 Tu-PC systemd[157891]: Stopped target Main User Target.
Jan 24 21:05:45 Tu-PC systemd[157891]: Stopped target Basic System.
Jan 24 21:05:45 Tu-PC systemd[157891]: Stopped target Paths.
Jan 24 21:05:45 Tu-PC systemd[157891]: Stopped target Sockets.
Jan 24 21:05:45 Tu-PC systemd[157891]: Stopped target Timers.
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed D-Bus User Message Bus Socket.
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed GnuPG network certificate management daemon.
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed GCR ssh-agent wrapper.
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed p11-kit server.
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed PipeWire PulseAudio.
Jan 24 21:05:45 Tu-PC systemd[157891]: Closed PipeWire Multimedia System Socket.
Jan 24 21:05:45 Tu-PC systemd[157891]: Removed slice User Application Slice.
Jan 24 21:05:45 Tu-PC systemd[157891]: Reached target Shutdown.
Jan 24 21:05:45 Tu-PC systemd[157891]: Finished Exit the Session.
Jan 24 21:05:45 Tu-PC systemd[157891]: Reached target Exit the Session.
Jan 24 21:05:45 Tu-PC systemd[157892]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[chiayi] ruser=[<unknown>] rhost=[<unknown>]
Jan 24 21:05:45 Tu-PC systemd[1]: user@1001.service: Deactivated successfully.
Jan 24 21:05:45 Tu-PC systemd[1]: Stopped User Manager for UID 1001.
Jan 24 21:05:45 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1001 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:45 Tu-PC systemd[1]: Stopping User Runtime Directory /run/user/1001...
Jan 24 21:05:45 Tu-PC kernel: audit: type=1131 audit(1643047545.785:266): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1001 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:45 Tu-PC systemd[1]: run-user-1001.mount: Deactivated successfully.
Jan 24 21:05:45 Tu-PC systemd[1]: user-runtime-dir@1001.service: Deactivated successfully.
Jan 24 21:05:45 Tu-PC systemd[1]: Stopped User Runtime Directory /run/user/1001.
Jan 24 21:05:45 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1001 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:45 Tu-PC systemd[1]: Removed slice User Slice of UID 1001.
Jan 24 21:05:45 Tu-PC kernel: audit: type=1131 audit(1643047545.788:267): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1001 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:05:46 Tu-PC dbus-daemon[2699]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.97' (uid=0 pid=158542 comm="sudo systemctl reboot ")
Jan 24 21:05:46 Tu-PC dbus-daemon[2699]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 24 21:05:46 Tu-PC sudo[158542]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 24 21:05:49 Tu-PC audit[158542]: USER_AUTH pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="o0331dobe" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC audit[158542]: USER_ACCT pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="o0331dobe" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC sudo[158542]: o0331dobe : TTY=tty2 ; PWD=/home/o0331dobe ; USER=root ; COMMAND=/usr/bin/systemctl reboot
Jan 24 21:05:49 Tu-PC audit[158542]: CRED_REFR pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC sudo[158542]: pam_unix(sudo:session): session opened for user root(uid=0) by o0331dobe(uid=1000)
Jan 24 21:05:49 Tu-PC audit[158542]: USER_START pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC kernel: audit: type=1100 audit(1643047549.408:268): pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="o0331dobe" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC kernel: audit: type=1101 audit(1643047549.408:269): pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="o0331dobe" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC kernel: audit: type=1110 audit(1643047549.408:270): pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC kernel: audit: type=1105 audit(1643047549.408:271): pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC systemd-logind[2746]: System is rebooting.
Jan 24 21:05:49 Tu-PC sudo[158542]: pam_unix(sudo:session): session closed for user root
Jan 24 21:05:49 Tu-PC audit[158542]: USER_END pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:05:49 Tu-PC audit[158542]: CRED_DISP pid=158542 uid=1000 auid=1000 ses=8 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=Tu-PC addr=? terminal=/dev/tty2 res=success'
Jan 24 21:07:19 Tu-PC systemd[1]: Stopping User Manager for UID 1000...
Jan 24 21:07:19 Tu-PC systemd[9063]: Activating special unit Exit the Session...
Jan 24 21:07:19 Tu-PC systemd[9063]: Removed slice User Background Tasks Slice.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped target Main User Target.
Jan 24 21:07:19 Tu-PC systemd-logind[2746]: Removed session 2.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping Accessibility services bus...
Jan 24 21:07:19 Tu-PC gvfsd[10191]: A connection to the bus can't be made
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping D-Bus User Message Bus...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping User preferences database...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping Virtual filesystem service...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping Bluetooth OBEX service...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping PipeWire PulseAudio...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping Portal service...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping flatpak document portal service...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping sandboxed app permission store...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped User preferences database.
Jan 24 21:07:19 Tu-PC systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Jan 24 21:07:19 Tu-PC systemd[1]: Unmounted /run/user/1000/doc.
Jan 24 21:07:19 Tu-PC systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Jan 24 21:07:19 Tu-PC systemd[1]: Unmounted /run/user/1000/gvfs.
Jan 24 21:07:19 Tu-PC systemd[9063]: obex.service: Main process exited, code=exited, status=1/FAILURE
Jan 24 21:07:19 Tu-PC systemd[9063]: obex.service: Failed with result 'exit-code'.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped Bluetooth OBEX service.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped Virtual filesystem service.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped PipeWire PulseAudio.
Jan 24 21:07:19 Tu-PC systemd[9063]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Jan 24 21:07:19 Tu-PC systemd[9063]: xdg-document-portal.service: Failed with result 'exit-code'.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped flatpak document portal service.
Jan 24 21:07:19 Tu-PC systemd[9063]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Jan 24 21:07:19 Tu-PC systemd[9063]: xdg-permission-store.service: Failed with result 'exit-code'.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped sandboxed app permission store.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping PipeWire Media Session Manager...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped D-Bus User Message Bus.
Jan 24 21:07:19 Tu-PC systemd[9063]: dbus.service: Consumed 1.025s CPU time.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped Portal service.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped Accessibility services bus.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped PipeWire Media Session Manager.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopping PipeWire Multimedia Service...
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped PipeWire Multimedia Service.
Jan 24 21:07:19 Tu-PC systemd[9063]: Removed slice User Core Session Slice.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped target Basic System.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped target Paths.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped target Sockets.
Jan 24 21:07:19 Tu-PC systemd[9063]: Stopped target Timers.
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed D-Bus User Message Bus Socket.
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed GnuPG network certificate management daemon.
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed GCR ssh-agent wrapper.
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed p11-kit server.
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed PipeWire PulseAudio.
Jan 24 21:07:19 Tu-PC systemd[9063]: Closed PipeWire Multimedia System Socket.
Jan 24 21:07:19 Tu-PC systemd[9063]: Removed slice User Application Slice.
Jan 24 21:07:19 Tu-PC systemd[9063]: app.slice: Consumed 2min 2.508s CPU time.
Jan 24 21:07:19 Tu-PC systemd[9063]: Reached target Shutdown.
Jan 24 21:07:19 Tu-PC systemd[9063]: Finished Exit the Session.
Jan 24 21:07:19 Tu-PC systemd[9063]: Reached target Exit the Session.
Jan 24 21:07:19 Tu-PC systemd[9064]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[o0331dobe] ruser=[<unknown>] rhost=[<unknown>]
Jan 24 21:07:19 Tu-PC systemd[1]: user@1000.service: Deactivated successfully.
Jan 24 21:07:19 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:19 Tu-PC systemd[1]: Stopped User Manager for UID 1000.
Jan 24 21:07:19 Tu-PC systemd[1]: user@1000.service: Consumed 2min 3.605s CPU time.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopping User Runtime Directory /run/user/1000...
Jan 24 21:07:19 Tu-PC kernel: kauditd_printk_skb: 23 callbacks suppressed
Jan 24 21:07:19 Tu-PC kernel: audit: type=1131 audit(1643047639.678:299): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:19 Tu-PC systemd[1]: run-user-1000.mount: Deactivated successfully.
Jan 24 21:07:19 Tu-PC systemd[1]: Unmounted /run/user/1000.
Jan 24 21:07:19 Tu-PC systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopped User Runtime Directory /run/user/1000.
Jan 24 21:07:19 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:19 Tu-PC systemd[1]: Removed slice User Slice of UID 1000.
Jan 24 21:07:19 Tu-PC systemd[1]: user-1000.slice: Consumed 8min 52.504s CPU time.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopping Permit User Sessions...
Jan 24 21:07:19 Tu-PC systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopped Permit User Sessions.
Jan 24 21:07:19 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:19 Tu-PC systemd[1]: Stopped target Network.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopped target Remote File Systems.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopping Network Manager...
Jan 24 21:07:19 Tu-PC NetworkManager[2704]: <info> [1643047639.6863] caught SIGTERM, shutting down normally.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopping WPA supplicant...
Jan 24 21:07:19 Tu-PC kernel: audit: type=1131 audit(1643047639.682:300): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:19 Tu-PC kernel: audit: type=1131 audit(1643047639.682:301): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:19 Tu-PC systemd[1]: systemd-logind.service: Deactivated successfully.
Jan 24 21:07:19 Tu-PC systemd[1]: Stopped User Login Management.
Jan 24 21:07:19 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:19 Tu-PC kernel: audit: type=1131 audit(1643047639.698:302): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:19 Tu-PC audit: BPF prog-id=0 op=UNLOAD
Jan 24 21:07:19 Tu-PC kernel: audit: type=1334 audit(1643047639.738:303): prog-id=0 op=UNLOAD
Jan 24 21:07:19 Tu-PC kernel: r8169 0000:27:00.0 enp39s0: Link is Down
Jan 24 21:07:20 Tu-PC NetworkManager[2704]: <info> [1643047640.1977] device (wlp42s0f1u1): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Jan 24 21:07:20 Tu-PC NetworkManager[2704]: <info> [1643047640.2268] device (wlp42s0f1u1): set-hw-addr: reset MAC address to 74:DA:38:A6:0E:95 (unmanage)
Jan 24 21:07:20 Tu-PC dbus-daemon[2699]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=2704 comm="/usr/bin/NetworkManager --no-daemon ")
Jan 24 21:07:20 Tu-PC dbus-daemon[2699]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Jan 24 21:07:20 Tu-PC NetworkManager[2704]: <info> [1643047640.2363] exiting (success)
Jan 24 21:07:20 Tu-PC systemd[1]: NetworkManager.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Network Manager.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC kernel: audit: type=1131 audit(1643047640.262:304): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC wpa_supplicant[5477]: nl80211: deinit ifname=wlp42s0f1u1 disabled_11b_rates=0
Jan 24 21:07:20 Tu-PC wpa_supplicant[5477]: wlp42s0f1u1: CTRL-EVENT-TERMINATING
Jan 24 21:07:20 Tu-PC systemd[1]: wpa_supplicant.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped WPA supplicant.
Jan 24 21:07:20 Tu-PC systemd[1]: wpa_supplicant.service: Consumed 1.683s CPU time.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: Stopping D-Bus System Message Bus...
Jan 24 21:07:20 Tu-PC kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp42s0f1u1: link becomes ready
Jan 24 21:07:20 Tu-PC kernel: audit: type=1131 audit(1643047640.312:305): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: dbus.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped D-Bus System Message Bus.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: dbus.service: Consumed 2.226s CPU time.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Basic System.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Path Units.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Slice Units.
Jan 24 21:07:20 Tu-PC systemd[1]: Removed slice Virtual Machine and Container Slice.
Jan 24 21:07:20 Tu-PC systemd[1]: Removed slice User and Session Slice.
Jan 24 21:07:20 Tu-PC systemd[1]: user.slice: Consumed 8min 54.663s CPU time.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Socket Units.
Jan 24 21:07:20 Tu-PC systemd[1]: clamav-daemon.socket: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Closed Socket for Clam AntiVirus userspace daemon.
Jan 24 21:07:20 Tu-PC systemd[1]: dbus.socket: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Closed D-Bus System Message Bus Socket.
Jan 24 21:07:20 Tu-PC systemd[1]: libvirtd-admin.socket: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Closed Libvirt admin socket.
Jan 24 21:07:20 Tu-PC systemd[1]: libvirtd-ro.socket: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Closed Libvirt local read-only socket.
Jan 24 21:07:20 Tu-PC systemd[1]: libvirtd.socket: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Closed Libvirt local socket.
Jan 24 21:07:20 Tu-PC systemd[1]: virtlockd.socket: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Closed Virtual machine lock manager socket.
Jan 24 21:07:20 Tu-PC systemd[1]: virtlogd.socket: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Closed Virtual machine log manager socket.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target System Initialization.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Local Encrypted Volumes.
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Jan 24 21:07:20 Tu-PC kernel: audit: type=1131 audit(1643047640.318:306): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Local Integrity Protected Volumes.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Local Verity Protected Volumes.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopping Set Up Additional Binary Formats...
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-sysctl.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Apply Kernel Variables.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-modules-load.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Load Kernel Modules.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopping Network Time Synchronization...
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-update-done.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Update is Completed.
Jan 24 21:07:20 Tu-PC kernel: audit: type=1131 audit(1643047640.335:307): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC kernel: audit: type=1131 audit(1643047640.335:308): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: ldconfig.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-journal-catalog-update.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Rebuild Journal Catalog.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-binfmt.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Set Up Additional Binary Formats.
Jan 24 21:07:20 Tu-PC audit[159138]: SYSTEM_SHUTDOWN pid=159138 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Jan 24 21:07:20 Tu-PC systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Network Time Synchronization.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Create Volatile Files and Directories.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Local File Systems.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting /boot...
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting /home/VM...
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting /home/chiayi/Downloads...
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting /home/chiayi/Videos...
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting /home/o0331dobe/Downloads...
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting /home/o0331dobe/Videos...
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting /run/credentials/systemd-sysusers.service...
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting Temporary Directory /tmp...
Jan 24 21:07:20 Tu-PC systemd[1]: boot.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted /boot.
Jan 24 21:07:20 Tu-PC audit: BPF prog-id=0 op=UNLOAD
Jan 24 21:07:20 Tu-PC systemd[1]: home-VM.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted /home/VM.
Jan 24 21:07:20 Tu-PC systemd[1]: home-chiayi-Downloads.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted /home/chiayi/Downloads.
Jan 24 21:07:20 Tu-PC systemd[1]: home-chiayi-Videos.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted /home/chiayi/Videos.
Jan 24 21:07:20 Tu-PC systemd[1]: home-o0331dobe-Videos.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted /home/o0331dobe/Videos.
Jan 24 21:07:20 Tu-PC systemd[1]: run-credentials-systemd\x2dsysusers.service.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted /run/credentials/systemd-sysusers.service.
Jan 24 21:07:20 Tu-PC systemd[1]: tmp.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted Temporary Directory /tmp.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Swaps.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivating swap /dev/disk/by-id/nvme-Force_MP600_21038229000128553384-part2...
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivating swap /dev/disk/by-id/nvme-Force_MP600_21048229000128553DBB-part2...
Jan 24 21:07:20 Tu-PC systemd[1]: home-o0331dobe-Downloads.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted /home/o0331dobe/Downloads.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounting home.mount...
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2did-nvme\x2dForce_MP600_21048229000128553DBB\x2dpart2.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-id/nvme-Force_MP600_21048229000128553DBB-part2.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2dpartlabel-Linux\x5cx20swap.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-partlabel/Linux\x20swap.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2did-nvme\x2deui.6479a746e0202e1e\x2dpart2.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-id/nvme-eui.6479a746e0202e1e-part2.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:22:00.0\x2dnvme\x2d1\x2dpart2.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:22:00.0-nvme-1-part2.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2dpartuuid-263a418c\x2dde3c\x2d4236\x2d9f0f\x2d022e37ca4a1a.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-partuuid/263a418c-de3c-4236-9f0f-022e37ca4a1a.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2dlabel-swap1.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-label/swap1.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-nvme1n1p2.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/nvme1n1p2.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2dlabel-swap0.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-label/swap0.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2did-nvme\x2deui.6479a74600200e45\x2dpart2.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-id/nvme-eui.6479a74600200e45-part2.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2dpartuuid-65331768\x2d7ebe\x2d4e75\x2d9d73\x2dae7c85f9eae5.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-partuuid/65331768-7ebe-4e75-9d73-ae7c85f9eae5.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2did-nvme\x2dForce_MP600_21038229000128553384\x2dpart2.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-id/nvme-Force_MP600_21038229000128553384-part2.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2dnvme\x2d1\x2dpart2.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:01:00.0-nvme-1-part2.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-nvme0n1p2.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/nvme0n1p2.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2duuid-5af3f596\x2d1068\x2d457f\x2d9d64\x2d4db5aa649caa.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-uuid/5af3f596-1068-457f-9d64-4db5aa649caa.
Jan 24 21:07:20 Tu-PC systemd[1]: dev-disk-by\x2duuid-388de0df\x2d1d0b\x2d4f78\x2db6a7\x2d2888859d3fa1.swap: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Deactivated swap /dev/disk/by-uuid/388de0df-1d0b-4f78-b6a7-2888859d3fa1.
Jan 24 21:07:20 Tu-PC systemd[1]: home.mount: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Unmounted home.mount.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped target Preparation for Local File Systems.
Jan 24 21:07:20 Tu-PC systemd[1]: Reached target Unmount All Filesystems.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Create Static Device Nodes in /dev.
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-sysusers.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Create System Users.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:20 Tu-PC systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Jan 24 21:07:20 Tu-PC systemd[1]: Stopped Remount Root and Kernel File Systems.
Jan 24 21:07:20 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:21 Tu-PC kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jan 24 21:07:21 Tu-PC kernel: ata1.00: supports DRM functions and may not be fully accessible
Jan 24 21:07:21 Tu-PC kernel: ata1.00: disabling queued TRIM support
Jan 24 21:07:21 Tu-PC kernel: ata1.00: configured for UDMA/133
Jan 24 21:07:21 Tu-PC kernel: sd 0:0:0:0: [sda] Starting disk
Jan 24 21:07:21 Tu-PC kernel: ata1.00: Enabling discard_zeroes_data
Jan 24 21:07:21 Tu-PC systemd[1]: lvm2-monitor.service: Deactivated successfully.
Jan 24 21:07:21 Tu-PC systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Jan 24 21:07:21 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:21 Tu-PC systemd[1]: Reached target System Shutdown.
Jan 24 21:07:21 Tu-PC systemd[1]: Reached target Late Shutdown Services.
Jan 24 21:07:21 Tu-PC systemd[1]: systemd-reboot.service: Deactivated successfully.
Jan 24 21:07:21 Tu-PC systemd[1]: Finished System Reboot.
Jan 24 21:07:21 Tu-PC audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:21 Tu-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 21:07:21 Tu-PC systemd[1]: Reached target System Reboot.
Jan 24 21:07:21 Tu-PC systemd[1]: Shutting down.
Jan 24 21:07:21 Tu-PC audit: BPF prog-id=0 op=UNLOAD
Jan 24 21:07:21 Tu-PC systemd-shutdown[1]: Syncing filesystems and block devices.
Jan 24 21:07:23 Tu-PC systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Jan 24 21:07:23 Tu-PC systemd-journald[1235]: Journal stopped
Here's my system information
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: initrd=\amd-ucode.img initrd=\intel-ucode.img
initrd=\initramfs-5.15-x86_64.img zfs=zroot/manjaro/root rw
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C37 v: 3.0
serial: <superuser required>
Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.D4
date: 04/09/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3108 high: 3599 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3598 2: 2879
3: 2927 4: 3597 5: 3592 6: 2873 7: 2874 8: 2879 9: 3598 10: 2874 11: 2879
12: 3599 13: 2874 14: 2874 15: 2881 16: 2944 bogomips: 121636
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Gigabyte driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0 chip-ID: 10de:1e82
class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:3 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 3840x2160 s-dpi: 159 s-size: 613x352mm (24.1x13.9")
s-diag: 707mm (27.8")
Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.6") diag: 698mm (27.5")
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 2d:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: down mac: <filter>
Device-2: Edimax Edimax AC1750 USB type: USB driver: rtl8814au
bus-ID: 1-1:2 chip-ID: 7392:a833 class-ID: 0000 serial: <filter>
IF: wlp42s0f1u1 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Supported mdraid levels: raid1
Device-1: md127 maj-min: 9:127 type: mdraid level: mirror status: active
Info: report: 2/2 UU blocks: 526272 chunk-size: N/A super-blocks: 1.0
Components: Online:
0: nvme0n1p1 maj-min: 259:1 size: 514 MiB
1: nvme1n1p1 maj-min: 259:5 size: 514 MiB
Device-2: zbigdata type: zfs status: ONLINE level: linear raw:
size: 1.81 TiB free: 1.07 TiB allocated: 761 GiB zfs-fs: size: 1.76 TiB
free: 1.01 TiB
Components: Online:
1: sdb maj-min: 8:16 size: 1.82 TiB
Device-3: zhome type: zfs status: ONLINE level: linear raw: size: 464 GiB
free: 243 GiB allocated: 221 GiB zfs-fs: size: 449.62 GiB free: 228.78 GiB
Components: Online:
1: sda maj-min: 8:0 size: 465.76 GiB
Device-4: zroot type: zfs status: ONLINE level: mirror raw: size: 920 GiB
free: 716 GiB allocated: 204 GiB zfs-fs: size: 891.5 GiB free: 687.55 GiB
Components: Online:
1: nvme0n1p3 maj-min: 259:3 size: 921.01 GiB
2: nvme1n1p3 maj-min: 259:7 size: 921.01 GiB
Local Storage: total: raw: 4.09 TiB usable: 5.35 TiB used: 1.07 TiB (20.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
lanes: 4 type: SSD serial: <filter> rev: EGFM13.0 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Corsair model: Force MP600
lanes: 4 type: SSD serial: <filter> rev: EGFM13.0 temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX002-2DV164
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
ID-1: / raw-size: N/A size: 860.85 GiB used: 173.3 GiB (20.1%) fs: zfs
logical: zroot/manjaro/root
ID-2: /boot raw-size: 512.9 MiB size: 511.9 MiB (99.80%)
used: 130.3 MiB (25.4%) fs: vfat dev: /dev/md127p1 maj-min: 259:8
ID-3: /home raw-size: N/A size: 371.57 GiB used: 142.79 GiB (38.4%)
fs: zfs logical: zhome/manjaro/home
ID-1: swap-1 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p2 maj-min: 259:6
ID-2: swap-2 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -3
dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 31.0 C mobo: 32.0 C gpu: nvidia temp: 43 C
Fan Speeds (RPM): fan-1: 1279 fan-2: 2351 fan-3: 802 fan-4: 590 fan-5: 0
fan-6: 0 fan-7: 1247 gpu: nvidia fan: 0%
Processes: 568 Uptime: 42m wakeups: 10 Memory: 15.61 GiB
used: 9.11 GiB (58.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1703 lib: 397 Shell: Zsh v: 5.8
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.12
