Shortwave 1:1.1.1-6 does not build
With a recent update SHORTWAVE 1:1.1.1-6 does not build. “libhandy0” is required. Not available in the repos ?
la satisfaction des dépendances a échoué:
impossible de satisfaire la dépendance « libhandy0 » requise par shortwave
I uninstall it to try again but no go since it want to install the latest. I want to get back the previous version using downgrade but I cannot get it to work. It suggest to set a variable “set DOWNGRADE_FROM_ALA to 1” but that doesn’t work either. What the exact way to set that variable ?
TX
It’s been reported in the AUR comments. Use shortwave-git for now.
Hum, shortwave-git 1.1.1.r64.g20e39c6-3 doesn’t build either.
  • impossible de satisfaire la dépendance « libhandy-1.so » requise par shortwave-git
  • For now I install the flatpak version. Works fine.
    Tx
libhandy and libhandy0 will be in the next stable update, then you should have no issues.
   Updating git repository `https://gitlab.gnome.org/haecker-felix/libhandy-rs.git`
error: failed to get `libhandy` as a dependency of package `shortwave v0.0.0 (/home/bmaxa/zfs/bmaxa_data/cache/yay/shortwave/src/Shortwave-1.1.1)`
I believe that it won’t build until developer makes changes to code that relies on unstable library api…
libhandy 1.0.0 is now stable and Shortwave builds fine from the latest commit with it.
Just checked, now it builds. Last time I checked it didn’t.
Was hoping you were right. Unfortunately libhandy0 is still not in the Manjaro stable repos after the most recent stable update.
Oh, I thought GNOME 3.38.1 was going to be in yesterday’s stable update. :man_shrugging:
