For years, I used latt-dock and had dashboard as my main launcher. I assigned meta key for it and it worked well. Then, some development happen and meta was disabled from being a main and only key, instead it become a helper key, meaning it only is valid with combos, like meta+d and so on.
However, despite that change, my old configs were still working well and meta was my main key for launching dashboard. Unfortunately, I lately wanted to try out cutefish DE, installed it and then removed it after I was done with it. Since cutefish is using kwin and some of the plasma elements, it interfered with it somehow and reset some configs somewhere (not sure which one), but now META KEY IS NOT WORKING ANYMORE.
I tried changing kglobalshortcutsrc file. I assume that lines:
lattedock]
_k_friendly_name=Latte Dock
activate entry 1=none,Meta+1,Activate Entry 1
could be the ones I’m looking for. The system won’t let me assign meta anymore, so I tried altering this to meta only. I save it, relog and… the line is brought back. So no matter if I change it to:
activate entry 1=none,Meta,Activate Entry 1
it goes back to default Meta+1.
I assume, there is some global config in the /etc (probably) that is used to fix it or maybe some other mechanism repairing the broken entries in config? Plus, I’m not sure if that is the line or config I’m looking for.
Has someone an experience with it and know how to bring my shortcut back? When I old config, it didn’t change anything, so it may be some other config and finding out how to make that line permanently meta may not be a solution here.
I found this topic:
But when I applied meta+f1, launcher works exactly with meta+f1, not with meta alone. So this isn’t a solution. I open launcher so often, that it makes sense to have it with easily one hit key. Any shortcut with F+ is not convenient at all and unsuitable for common actions.
