Hello, after running sensors-detect i no longer have any GPU info, what are my options here? tried all the alternatives in sensors-detect and info about detecting sensors on 5700xt is sparse. Reinstalling Manjaro will fix this, but thats not very optimal.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
