Hey guys,
got a little problem with my GPU sensors on my RX 6900XT. For whatever reason I cannot seem to get any data out of them. I tried to go for radeon-profile and CoreCtrl. CoreCtrl shows a [GPU 0] but every sensor shows 0 MHz / 0 W / 0 % except “Used memory”. radeon-profile doesn’t even get my GPU at all and crashes when I refresh in order to look for devices.
Now, as they both seem to have problems with my setup and someone over at Reddit posted that his GPU was picking up fine (didn’t get any answer from him yet), I wonder if either my software is at fault or even my whole graphics card.
I’ve seen this thread where someone had the same issues as I had, apparently, but he didn’t post a solution. It seemed to just “randomly work” suddenly.
Can anyone verify that hey have the same issues? I tried to go for kernel 5.10 (which at least showed me my mem clock @ 1000MHz), over 5.11 to the current version of 5.12 (test branch) which both resulted in no information on sensors.
I am pretty new to the whole AMD GPU stuff as I had a GTX 980 before that - so I might even miss some packages, which I don’t really know what it could be.
Here’s my inxi:
System: Kernel: 5.12.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=ccca6ae4-42b9-4201-91d9-3dbe6689b0a8 rw quiet
udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE V2 v: x.x serial: <filter> UEFI: American Megatrends LLC.
v: F13c date: 02/17/2021
CPU: Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 family: 19 (25) model-id: 21 (33)
stepping: N/A microcode: A201009 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 121423
Speed: 2277 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 2277 2: 2217 3: 2291 4: 2368 5: 2213
6: 2285 7: 2221 8: 2218 9: 2221 10: 2414 11: 2304 12: 2417 13: 2218 14: 2216 15: 2207 16: 2207
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: wayland server: X.Org 1.21.0.99 compositor: kwin_wayland driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :1 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1355x381mm (53.3x15.0") s-diag: 1408mm (55.4")
Monitor-1: XWAYLAND0 res: 5120x1440 hz: 120 dpi: 109 size: 1190x340mm (46.9x13.4") diag: 1238mm (48.7")
OpenGL: renderer: AMD SIENNA_CICHLID (DRM 3.40.0 5.12.0-1-MANJARO LLVM 11.1.0) v: 4.6 Mesa 20.3.4
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: Yamaha MG-XU type: USB driver: snd-usb-audio bus-ID: 5-2.1:4 chip-ID: 0499:1703 class-ID: 0102
Device-3: Logitech HD Webcam B910 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-3.2.3:7 chip-ID: 046d:0823
Sound Server-1: ALSA v: k5.12.0-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.23 running: yes
Network: Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus-ID: 5-3.2.2:6
chip-ID: 0a12:0001 class-ID: e001
Drives: Local Storage: total: 3.43 TiB used: 1.15 TiB (33.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 PRO Series size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 5B0Q scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST32000641AS size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC13 scheme: MBR
Partition: ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%) used: 172.68 GiB (74.0%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat dev: /dev/sdb1
maj-min: 8:17
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 44.9 C mobo: N/A
Info: Processes: 357 Uptime: 26m wakeups: 0 Memory: 31.36 GiB used: 6.62 GiB (21.1%) Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1459 pacman: 1454 lib: 434 flatpak: 5 Shell: fish v: 3.1.2
running-in: konsole inxi: 3.3.03
Thanks, guys.
(Not sure)
