Hello all
So, I’ve installed Manjaro (GNOME) about one year ago. Since then, I was waiting for the 5.x kernel to be LTS. Previously I was running on kernel 4.14 due to this problem. I’ve upgraded (again) to kernel 5.4.64 and still, I am experiencing semi-random freezes. Why I say semi-random ? Because when I open a tab in Firefox, it freezes for 5 seconds, when I code in VSCODE (electron) it randomly freezes during 5 seconds (could not identify a pattern). During normal usage, my RAM usage is usually under 5Gb with the swap often under 800Mb.
The problem is that I am not able to identify what is creating this issue. I have no clue where to start. My first guess would be RAM because whenever I make an action that requires RAM, the whole system freezes (mouse and keyboard unresponsive). Also, sometimes, when I’m reading code it occasionally freezes. The laptop is from 2017 so it is not that old.
I’ve previously checked Random freezes in fresh install and System random freeze but both are about AMD.
I would gladly appreciate some help regarding this issue.
uname: Linux 5.4.64-1-MANJARO x86_64 unknown unknown GNU/Linux
sudo inxi -Fxxxa --no-host:
system: Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=d890be66-c5e6-4537-926b-469fac60754b rw quiet
cryptdevice=UUID=37c5483c-7840-4724-b211-0378eac55be8:luks-37c5483c-7840-4724-b211-0378eac55be8
root=/dev/mapper/luks-37c5483c-7840-4724-b211-0378eac55be8
resume=/dev/mapper/luks-37c5483c-7840-4724-b211-0378eac55be8
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP ENVY Laptop 13-ad0xx v: Type1ProductConfigId serial: 5CG73820XP Chassis:
type: 10 serial: N/A
Mobo: HP model: 8349 v: KBC Version 39.35 serial: PGQUL00WB9518P UEFI: Insyde v: F.27 date: 11/19/2018
Battery: ID-1: BAT0 charge: 11.0 Wh condition: 48.0/48.0 Wh (100%) volts: 7.9/7.7 model: HP Primary type: Li-ion
serial: 09195 09/02/2017 status: Charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: 4023-00-00-00-00
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: 4058-00-00-00-00 charge: 55% (should be ignored)
CPU: Topology: Dual Core model: Intel Core i5-7200U socket: BGA1356 (U3E1) note: check bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6 L1 cache: 128 KiB L2 cache: 3072 KiB
L3 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
Speed: 2230 MHz min/max: 400/3100 MHz base/boost: 2400/8300 volts: 0.8 V ext-clock: 100 MHz Core speeds (MHz):
1: 1083 2: 1126 3: 1105 4: 1029
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo bus ID: 1-6:4 chip ID: 04f2:b5ed
Display: server: X.org 1.20.8 compositor: gnome-shell driver: intel unloaded: modesetting alternate: fbdev,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.4.64-1-MANJARO
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3040 bus ID: 02:00.0 chip ID: 8086:095a
IF: wlp2s0 state: up mac: 1c:4d:70:d7:f4:c4
IF-ID-1: docker0 state: down mac: 02:42:03:49:ec:3a
IF-ID-2: lxdbr0 state: down mac: 00:16:3e:60:b1:6f
IF-ID-3: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives: Local Storage: total: 238.47 GiB used: 151.73 GiB (63.6%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 238.47 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: 87PS10WSTAZT rev: 5KHA4102 scheme: GPT
Partition: ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%) used: 151.33 GiB (67.3%) fs: ext4 block size: 4096 B
dev: /dev/dm-0
Swap: Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.80 GiB used: 405.0 MiB (4.5%) priority: -2 dev: /dev/dm-1
Sensors: System Temperatures: cpu: 56.0 C mobo: 0.0 C
Info: Processes: 330 Uptime: 1h 34m Memory: 7.54 GiB used: 4.87 GiB (64.6%) Init: systemd v: 246 Compilers: gcc: 10.2.0
clang: 10.0.1 Packages: apt: 0 pacman: 1708 lib: 475 flatpak: 0 Shell: Bash (sudo) v: 5.0.18
running in: gnome-terminal inxi: 3.1.05
Edit: I’ve installed kernel 5.7.19-2 and it seems to worked without any complications. I wonder, what is with kernel 5.4.64 that is freezing my laptop ?
