lately i noticed random crashes in the system no matter if the pc is on for a long or short time, or if the usage is intense or idle even
System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=ad685fd6-0b1e-4bf3-a5d1-ceb1fa66d3b0 rw quiet apparmor=1
security=apparmor udev.log_priority=3 iommu=pt idle=nomwait rcu_nocbs=0-15
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Gigabyte model: AX370-Gaming 5 serial: <filter> UEFI: American Megatrends v: F50e
date: 07/02/2020
CPU: Topology: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1 stepping: 1
microcode: 8001138 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 108623
Speed: 3492 MHz min/max: N/A Core speeds (MHz): 1: 3492 2: 3491 3: 3493 4: 3480 5: 3493 6: 3495 7: 3487 8: 2998
9: 3490 10: 3473 11: 3493 12: 3493 13: 3483 14: 3484 15: 3487 16: 3485
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 07:00.0 chip ID: 1002:67df
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu FAILED: ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 92 size: 531x298mm (20.9x11.7") diag: 609mm (24")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.37.0 5.7.15-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5
direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 07:00.1 chip ID: 1002:aaf0
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 09:00.3 chip ID: 1022:1457
Sound Server: ALSA v: k5.7.15-1-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.6.0-k port: e000 bus ID: 04:00.0
chip ID: 8086:1539
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte driver: alx v: kernel port: d000
bus ID: 05:00.0 chip ID: 1969:e0b1
IF: enp5s0 state: down mac: <filter>
Drives: Local Storage: total: 3.64 TiB used: 2.23 TiB (61.2%)
ID-1: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 023 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD30EZRX-00DC0B0 size: 2.73 TiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 0A80 scheme: GPT
Partition: ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%) used: 11.88 GiB (12.4%) fs: ext4 dev: /dev/sda1
ID-2: /home raw size: 833.37 GiB size: 819.29 GiB (98.31%) used: 159.72 GiB (19.5%) fs: ext4 dev: /dev/sda2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 42.4 C mobo: N/A gpu: amdgpu temp: 34 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1099
Info: Processes: 319 Uptime: 9m Memory: 31.31 GiB used: 1.93 GiB (6.2%) Init: systemd v: 245 Compilers: gcc: 10.1.0
Packages: pacman: 1331 lib: 391 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05 ```
check in journal log
sudo journalctl -b0 ( -b -1 boot before , etc ... )
[sudo] senha para eduardo:
-- Logs begin at Fri 2020-08-21 15:09:55 JST, end at Mon 2020-08-24 18:54:57 JST. --
ago 24 14:51:29 eduardo-ax370gaming5 kernel: Linux version 5.7.15-1-MANJARO (builduser@LEGION) (gcc version 10.1.0 (GCC), GNU ld (GNU Binutils) 2.34.0) #1 SMP PREEMPT Tue Aug 11 15:00:37 UTC 2020
ago 24 14:51:29 eduardo-ax370gaming5 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=ad685fd6-0b1e-4bf3-a5d1-ceb1fa66d3b0 rw quiet apparmor=1 security=apparmor udev.log_priority=3 iommu=pt idle=nomwait rcu_nocbs=0-15
ago 24 14:51:29 eduardo-ax370gaming5 kernel: KERNEL supported cpus:
ago 24 14:51:29 eduardo-ax370gaming5 kernel: Intel GenuineIntel
ago 24 14:51:29 eduardo-ax370gaming5 kernel: AMD AuthenticAMD
ago 24 14:51:29 eduardo-ax370gaming5 kernel: Hygon HygonGenuine
ago 24 14:51:29 eduardo-ax370gaming5 kernel: Centaur CentaurHauls
ago 24 14:51:29 eduardo-ax370gaming5 kernel: zhaoxin Shanghai
ago 24 14:51:29 eduardo-ax370gaming5 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
ago 24 14:51:29 eduardo-ax370gaming5 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
ago 24 14:51:29 eduardo-ax370gaming5 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
ago 24 14:51:29 eduardo-ax370gaming5 kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
ago 24 14:51:29 eduardo-ax370gaming5 kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-provided physical RAM map:
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009e01fff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x0000000009e02000-0x0000000009ffffff] reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20afff] ACPI NVS
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x000000000a20b000-0x000000000affffff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x000000000b020000-0x00000000db48efff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000db48f000-0x00000000db61ffff] reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000db620000-0x00000000db7a3fff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000db7a4000-0x00000000dbbc1fff] ACPI NVS
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000dbbc2000-0x00000000dca18fff] reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000dca19000-0x00000000dcac0fff] type 20
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000dcac1000-0x00000000deffffff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: BIOS-e820: [mem 0x0000000100000000-0x000000081f37ffff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: NX (Execute Disable) protection: active
ago 24 14:51:29 eduardo-ax370gaming5 kernel: efi: EFI v2.70 by American Megatrends
ago 24 14:51:29 eduardo-ax370gaming5 kernel: efi: ACPI 2.0=0xdbb3e000 ACPI=0xdbb3e000 SMBIOS=0xdc902000 SMBIOS 3.0=0xdc901000 ESRT=0xd9df3c98
ago 24 14:51:29 eduardo-ax370gaming5 kernel: SMBIOS 3.2.0 present.
ago 24 14:51:29 eduardo-ax370gaming5 kernel: DMI: Gigabyte Technology Co., Ltd. AX370-Gaming 5/AX370-Gaming 5, BIOS F50e 07/02/2020
ago 24 14:51:29 eduardo-ax370gaming5 kernel: tsc: Fast TSC calibration failed
ago 24 14:51:29 eduardo-ax370gaming5 kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
ago 24 14:51:29 eduardo-ax370gaming5 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: last_pfn = 0x81f380 max_arch_pfn = 0x400000000
ago 24 14:51:29 eduardo-ax370gaming5 kernel: MTRR default type: uncachable
ago 24 14:51:29 eduardo-ax370gaming5 kernel: MTRR fixed ranges enabled:
ago 24 14:51:29 eduardo-ax370gaming5 kernel: 00000-9FFFF write-back
ago 24 14:51:29 eduardo-ax370gaming5 kernel: A0000-BFFFF write-through
ago 24 14:51:29 eduardo-ax370gaming5 kernel: C0000-FFFFF write-protect
ago 24 14:51:29 eduardo-ax370gaming5 kernel: MTRR variable ranges enabled:
ago 24 14:51:29 eduardo-ax370gaming5 kernel: 0 base 000000000000 mask FFFF80000000 write-back
ago 24 14:51:29 eduardo-ax370gaming5 kernel: 1 base 000080000000 mask FFFFC0000000 write-back
ago 24 14:51:29 eduardo-ax370gaming5 kernel: 2 base 0000C0000000 mask FFFFE0000000 write-back
ago 24 14:51:29 eduardo-ax370gaming5 kernel: 3 disabled
ago 24 14:51:29 eduardo-ax370gaming5 kernel: 4 disabled
ago 24 14:51:29 eduardo-ax370gaming5 kernel: 5 disabled
ago 24 14:51:29 eduardo-ax370gaming5 kernel: 6 disabled```
This might be linked to my post Continuation of: Are there any NVME/SSD related bug fixes in Linux 5.6 vis-a-vis 5.4?
Try the following:
mv /boot/amd-ucode.img /boot/amd-ucode.bin
reboot
At the grub prompt, use e to edit the grub commandline and delete /boot/amd-ucode.img from the initrd argument list. Then press F10 to boot, and finally run:
update-grub
Let me know if this helps.
I didn’t understand how to edit the grub command line, can you post a photo?
It’s very easy. Just press e when you get the grub prompt. Believe me, no photo is needed.
What command do I run at the grub prompt?
Eu rodei esse comando e o sistema não iniciou mais, tive que instalar de novo
At the grub prompt, you do not have to run any command. Instead, you have to edit the last line (beginning with initrd) to delete /boot/amd-ucode.img from the argument list.
After deleting /boot/amd-ucode.img from the argument list, press F10
bourne
24 August 2020 13:35
10
Before booting to grub prompt, you should first run as root: mv /boot/amd-ucode.img /boot/amd-ucode.bin
Afterwards, you should run as root: update-grub
I’ve been seeing and in the case of the tip the person had an nvme, I use normal ssd
bourne
24 August 2020 15:09
12
The post is my own. I earlier had a normal SSD, and Linux would show the same freeze symptoms. I then switched to NVME, where the problem continued. After spending immense amount of time and money, I zeroed in on the problem: /boot/amd-ucode.img
The fix worked for me. Perhaps it may work for you as well.
I found a tip to put GRUB_CMDLINE_LINUX_DEFAULT which is processor.max_cstate = 5, and it seems to make more sense on first generation processors which is my case, but I will test both
bourne
24 August 2020 15:37
15
My processor is also Ryzen 1st gen. I am 90% sure my fix will work for you as well.
