Secure boot blocked on enabled
As title says,my secure boot is blocked in BIOS i can’t unlock it even as administrator,should i just gave up on manjaro and install windows?i need windows for some extra games,i wanted dual boot but that seems impossible for my bios.
This is my system
  Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=8cc0adc2-bccf-4ff6-a805-aa5a9e28a8c7 rw quiet apparmor=1
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
  serial: <filter> UEFI-[Legacy]: American Megatrends v: 5205 date: 08/01/2019
  RAM: total: 15.63 GiB used: 4.1 GiB (26.2%)
  Info: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64
  type: MCP arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24)
  stepping: 1 microcode: 8108109 cache: L2: 2 MiB bogomips: 28744
  Speed: 2920 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz):
  1: 2920 2: 2584 3: 2896 4: 2549
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
  smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
  topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
  disabled, RSB filling
  Device-1: NVIDIA TU106 [GeForce GTX 1650] vendor: ASUSTeK driver: nvidia
  v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f0a class-ID: 0300
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
  s-diag: 554mm (21.8")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
  size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
  OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
  direct render: Yes
  Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
  class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: Trust GXT 232 Microphone type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:3 chip-ID: 145f:0254
  class-ID: 0300
  Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: no
  vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 06:00.0
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Local Storage: total: 942.7 GiB used: 181.07 GiB (19.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
  size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 rotation: SSD serial: <filter> rev: S5Z42105 temp: 33.9 C
  scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU750 size: 476.94 GiB
  block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
  serial: <filter> rev: 1R17 scheme: MBR
  ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
  used: 181.07 GiB (39.6%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  label: N/A uuid: 8cc0adc2-bccf-4ff6-a805-aa5a9e28a8c7
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Xenta Game mouse type: Keyboard,Mouse
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 1d57:ffa8 class-ID: 0301
  Device-2: 3-3:3 info: Trust GXT 232 Microphone type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  speed: 12 Mb/s power: 100mA chip-ID: 145f:0254 class-ID: 0300
  Device-3: 3-4:4 info: Razer USA RZ03-0274 Gaming Keyboard [Cynosa Lite]
  type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s power: 500mA chip-ID: 1532:023f class-ID: 0300
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 42.0 C mobo: 0 C gpu: nvidia temp: 34 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 26%
  Processes: 240 Uptime: 10h 15m wakeups: 0 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 Packages: 1255 pacman: 1244 lib: 345
  flatpak: 5 snap: 6 Shell: Bash v: 5.1.4 running-in: konsole inxi: 3.3.04
Have you tried this:
No,I didn’ t try this,thanks!I’ll read it now.
I’m back!Sorry that i took so much,but i disabled it,i installed windows on a another SSD,but from what I remeber i need to add Manjaro to windows boot manager?
Install Manjaro normally on its own SSD, and select Manjaro disk as boot device in your BIOS, make sure you have OS Prober enabled on Manjaro and it will detect your Windows installation, and add it to boot options from Manjaro disk when you will boot.
I did it guys!With windows boot manager and with the help of a app i added Manjaro,now i can boot into windows and manjaro freely:D,2 weeks of researching and failling,finnaly!
I would do what I suggested as a Windows update will probably destroy what you did later on. Your call.
I use secure boot, just need to to the trusted UEFI file (for execute the grub) and then, just restart…go one more time to bios and post up the “EFI” file in the start priority menu… No need to disable or enable just use it if you need it… Secure boot it’s just a fake “secure” it’s only a boot loader jsjsjs. If you need more info I can show you whit images.
Jsjsjsjs, first … switch the legacy to UEFI, and then you can use the UEFI start-up
Nvidia drivers are not signed…if u have nvidia driver then u have to sign with custom keys every time nvidia driver updates or u have to install the driver urself after signing with custom keys.
What Nvidia driver? Xstring?
