Thanks, here’s the details.
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=3f08b67c-591e-401d-810f-612a135a525c rw quiet apparmor=1
security=apparmor resume=UUID=ab12a64a-a0e9-4c4b-a1c4-db7688fbabf4
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20AQ006HUS v: ThinkPad T440s
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20AQ006HUS v: 0B98401 WIN serial: UEFI: LENOVO
v: GJETA2WW (2.52 ) date: 05/23/2019
ID-1: BAT0 charge: 15.8 Wh condition: 16.3/23.2 Wh (70%) volts: 12.1/11.1
model: SONY 45N1111 type: Li-poly serial: status: Unknown
ID-2: BAT1 charge: 40.7 Wh condition: 44.4/47.5 Wh (94%) volts: 12.0/10.8
model: SMP 45N1736 type: Li-ion serial: status: Discharging
Info: Dual Core model: Intel Core i7-4600U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
L2 cache: 4096 KiB
bogomips: 21559
Speed: 798 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 835 2: 803 3: 896
4: 868
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:5
chip ID: 04ca:7035
Display: x11 server: X,Org 1.20.10 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.2.3 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240 driver: e1000e
v: kernel port: 3080 bus ID: 00:19.0 chip ID: 8086:155a
IF: enp0s25 state: down mac:
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: efa0
bus ID: 03:00.0 chip ID: 8086:08b2
IF: wlp3s0 state: up mac:
Local Storage: total: 678.01 GiB used: 20.90 GiB (3.1%)
ID-1: /dev/mmcblk0 model: SB128 size: 119.08 GiB block size: physical: 512 B
logical: 512 B serial: scheme: MBR
SMART Message: Unknown smartctl error. Unable to get data.
ID-2: /dev/sda vendor: PNY model: CS900 480GB SSD size: 447.13 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial:
rev: 06B3 scheme: GPT
ID-3: /dev/sdb model: SSD 120GB size: 111.79 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: rev: 9A0 scheme: GPT
ID-1: / raw size: 98.75 GiB size: 96.70 GiB (97.92%) used: 20.88 GiB (21.6%)
fs: ext4 dev: /dev/sdb2
ID-1: swap-1 type: partition size: 12.74 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3
System Temperatures: cpu: 49.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 199 Uptime: 1m Memory: 11.58 GiB used: 1018.2 MiB (8.6%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1293 lib: 390
flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.08
Thanks for the guide
