Hi
first I’m not good in English.
I have a Dell latitude E7440 with just on-board Intel graphic.
I bought two HDMI cables and both of them don’t work. after connecting them to the TV, laptop and TV detect the connection but nothing show on TV.
about two weeks ago I found if I reduce the output resolution, TV will show my desktop but if I connect the charger to laptop, TV will not show anything. and if anyone turn on/off any electric device, connection will disconnect for a second.
but now, I get a LG monitor and a VGA to HDMI cable, again I have the same problem but this time, if I reduce the resolution it will not work.
if I unplug the monitor VGA from the converter cable, I got check signal cable
message on the monitor.
UPDATE
