Hello everyone,
I’m writing to you because I’m having trouble with my screen. I’m on a laptop, and when I plug in an external screen it’s not detected:
$ xrandr
Screen 0: minimum 16 x 16, current 3072 x 1920, maximum 32767 x 32767
eDP-1 connected primary 3072x1920+0+0 (normal left inverted right x axis y axis) 340mm x 220mm
3072x1920 59.99*+
2048x1536 59.95
1920x1440 59.97
1600x1200 59.87
1440x1080 59.99
1400x1050 59.98
1280x1024 59.89
1280x960 59.94
1152x864 59.96
1024x768 59.92
800x600 59.86
640x480 59.38
320x240 59.52
2560x1600 59.99
1920x1200 59.88
1680x1050 59.95
1440x900 59.89
1280x800 59.81
1152x720 59.97
960x600 59.63
928x580 59.88
800x500 59.50
768x480 59.90
720x480 59.71
640x400 59.95
320x200 58.96
2880x1620 59.96
2560x1440 59.96
2048x1152 59.90
1920x1080 59.96
1600x900 59.95
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.55
640x350 59.77
I tried reinstalling the nvidia drivers and testing different ones, but nothing worked…
I’m convinced it works because I have no problem using this screen when I log on with my Windows session.
$ sudo mhwd ✔
[sudo] Mot de passe de leom :
> 0000:01:00.0 (0300:10de:2520) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
video-hybrid-intel-nvidia-470xx-prime 2023.03.23 false PCI
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:46a6) Display controller Intel Corporation:
$ inxi -Fxxz ✔ 7s
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM
Type: Laptop System: Dell product: Inspiron 16 Plus 7620 v: N/A
Mobo: Dell model: 0V98G2 v: A00 serial: <superuser required> UEFI: Dell
v: 1.11.0 date: 03/14/2023
ID-1: BAT0 charge: 78.6 Wh (100.0%) condition: 78.6/84.3 Wh (93.2%)
volts: 12.9 min: 11.4 model: BYD DELL M59JH25 serial: <filter> status: full
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 1.2 MiB L2: 11.5 MiB
L3: 24 MiB
Speed (MHz): avg: 2587 high: 2700 min/max: 400/4600:4700:3500 cores:
1: 2700 2: 2700 3: 2700 4: 2700 5: 2700 6: 2700 7: 2700 8: 2700 9: 2700
10: 2700 11: 2700 12: 2700 13: 446 14: 2700 15: 2700 16: 2700 17: 2700
18: 2700 19: 2700 20: 2700 bogomips: 107560
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 530.41.03 arch: Ampere bus-ID: 0000:01:00.0
chip-ID: 10de:2520
Device-3: Microdia Integrated_Webcam_FHD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-6:4 chip-ID: 0c45:6739
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x09d5 res: 3072x1920 dpi: 226
diag: 407mm (16")
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 bus-ID: 1-10:5 chip-ID: 8087:0033
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 bus-ID: 0000:00:0e.0 chip-ID: 8086:467f
Local Storage: total: 953.87 GiB used: 228.58 GiB (24.0%)
ID-1: /dev/nvme0n1 vendor: KIOXIA model: KBG50ZNS1T02 NVMe 1024GB
size: 953.87 GiB speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 48.9 C
ID-1: / size: 335.36 GiB used: 37.53 GiB (11.2%) fs: ext4
dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 511 MiB used: 332 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p7
ID-3: /home size: 385.77 GiB used: 191.04 GiB (49.5%) fs: ext4
dev: /dev/nvme0n1p9
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 386 Uptime: 15m Memory: available: 31.04 GiB
used: 4.38 GiB (14.1%) Init: systemd v: 253 default: graphical Compilers:
gcc: 13.1.1 clang: 15.0.7 Packages: 1462 pm: pacman pkgs: 1439 pm: flatpak
pkgs: 11 pm: snap pkgs: 12 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.27
Does anyone have any tips for me? Thanks in advance for your help!
Léo
