Happy new year everyone,
I’ve been having a problem recently where whenever I open a game or similar full screen application, my second monitor becomes unusable. This only happens when the item on the second monitor is something like a youtube video or something that moves around a lot. When I put something like that on the monitor, it becomes incredibly laggy, and constantly looks like its redrawing new frames like an old TV. I’m thinking this might be something with nvidia settings but im not sure how to mess with that
System information
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=b07453a6-cfde-4f37-8e50-6f90b53b72b6 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: Z370M MORTAR (MS-7B54) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.20 date: 03/08/2018
Info: 6-Core model: Intel Core i5-8600K bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 9216 KiB
bogomips: 43212
Speed: 800 MHz min/max: 800/4300 MHz Core speeds (MHz): 1: 812 2: 804 3: 804
4: 808 5: 809 6: 878
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c03
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 101 s-size: 1930x543mm (76.0x21.4")
s-diag: 2005mm (78.9")
Monitor-1: DVI-D-0 res: 3840x2160 hz: 60 dpi: 204
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: DP-0 res: 3840x2160 hz: 60 dpi: 185 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
Device-2: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f1
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-1:2 chip ID: 046d:0825 serial: <filter>
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
IF: enp0s31f6 state: down mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus ID: 2-4:2 chip ID: 0b95:1790 serial: <filter>
IF: enp0s20f0u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.05 TiB used: 344.18 GiB (16.4%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC26 scheme: GPT
ID-2: /dev/sdb model: SATA SSD size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 61.2 scheme: GPT
ID-1: / raw size: 43.95 GiB size: 43.00 GiB (97.86%) used: 38.51 GiB (89.6%)
fs: ext4 dev: /dev/sdb5
ID-2: /home raw size: 735.62 GiB size: 723.08 GiB (98.29%)
used: 305.66 GiB (42.3%) fs: ext4 dev: /dev/sda3
ID-1: swap-1 type: partition size: 3.84 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb6
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 56 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 51%
Processes: 225 Uptime: 17m Memory: 15.60 GiB used: 6.39 GiB (41.0%)
Init: systemd v: 246 target: graphical.target Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: 1759 pacman: 1733 lib: 441 flatpak: 18 snap: 8
Shell: Zsh v: 5.8 running in: yakuake inxi: 3.1.08
Please update by
sudo pacman-mirrors -f && sudo pacman -Syyu
I updated and rebooted, the problem persists
