Second LUKS password prompt
Since some recent update, I’m getting two prompts for my hard drive password. The first is the usual one, on the screen with the manufacturer’s logo, as expected. Then I see the GRUB menu, then it gets partway through starting the system and asks me again:
Please enter passphrase for disk WD_BLACK … (luks-5f…)::
There’s a photo of this prompt in my other thread: Temperature sensor/fan control not fully working
This used to not happen, one password entry was enough.
Here are some relevant files:
[fabian@nova ~]$ cat /etc/mkinitcpio.conf | grep -v -e ^# -e ^$
MODULES=()
BINARIES=()
FILES=(/crypto_keyfile.bin)
HOOKS=(base systemd keyboard autodetect modconf block sd-vconsole sd-encrypt filesystems fsck)
[fabian@nova ~]$ cat /etc/default/grub | grep -v -e ^# -e ^$
GRUB_DEFAULT=saved
GRUB_TIMEOUT=1
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="rd.luks.name=5f8bee24-4ef7-4133-a91d-725356237ac9=luks-5f8bee24-4ef7-4133-a91d-725356237ac9 luks.key=/crypto_keyfile.bin root=/dev/mapper/luks-5f8bee24-4ef7-4133-a91d-725356237ac9 splash snd-hda-intel.model=clevo-p950"
GRUB_CMDLINE_LINUX=""
GRUB_TIMEOUT_STYLE=menu
GRUB_TERMINAL_INPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
GRUB_DISABLE_RECOVERY=true
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
GRUB_SAVEDEFAULT=true
GRUB_DISABLE_OS_PROBER=false
GRUB_ENABLE_CRYPTODISK=y
Their current state is the result of a post from last year. It used to work fine with this setup.
There is a file /etc/mkinitcpio.conf.pacnew, but that would empty the FILES parameter and replace the HOOKS entry sd-encrypt with microcode and kms, which seems like a bad idea to just copy, especially since I don’t understand what it means. It also has a different order of hooks, maybe some of that would be useful, but it used to work without that additional prompt with the order that I currently have.
I have also started Linux 6.6, there I have the same issue.
How do I get rid of this second prompt?
The old Busybox init hooks were replaced with the Systemd init hooks. See mkinitcpio - ArchWiki
If you haven’t manually added / removed / modified mkinitcpio.conf yourself, then the defaults for an encrypted root filesystem should be fine along with the optional plymouth hook that is added during a Manjaro install.
##   This will create a systemd based initramfs which loads an encrypted root filesystem.
#    HOOKS=(base systemd autodetect microcode modconf kms keyboard sd-vconsole block sd-encrypt filesystems fsck)
No, sd-encrypt only replaces encrypt, and should only be used if you use the systemd hook instead of the base and udev hooks. Furthermore, if you use encryption, then you should also switch to the new rd.luks syntax in /etc/default/grub.
Given that this is all pretty incisive — especially for people unfamiliar with the innards of the mkinitcpio procedure to generate the initramfs — it is advised to stay with the old…
HOOKS=( base udev ... encrypt ...
… syntax. The Wiki page posted above by @Yochanan should tell you which hooks you need, and in what order.
I had the same issue with the second prompt for the luks password.
Creating a hard link from /etc/crypttab to /etc/crypttab.initramsfs sudo ln /etc/crypttab /etc/crypttab.initramfs solved that. See arch wiki - section 1.2.4 Using systemd-cryptsetup-generator.
For reference, my system changes are:
/etc/default/grub (# : busybox init hooks, non #: systemd init hooks)
#GRUB_CMDLINE_LINUX_DEFAULT=“cryptdevice=UUID=d74b9c8d-9bb0-4945-80a2-b917d8143295:luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 root=/dev/mapper/luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 udev.log_priority=3 nmi_watchdog=0 nowatchdog”
GRUB_CMDLINE_LINUX_DEFAULT=“rd.luks.name=d74b9c8d-9bb0-4945-80a2-b917d8143295=luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 root=/dev/mapper/luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 udev.log_priority=3 nmi_watchdog=0 nowatchdog”
/etc/mkinitcpio.conf (# : busybox init hooks, non #: systemd init hooks)
#HOOKS=(base udev autodetect microcode modconf kms block keyboard keymap consolefont encrypt filesystems fsck)
/etc/cryptab (no changes)
# name device password options
luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 UUID=d74b9c8d-9bb0-4945-80a2-b917d8143295 /crypto_keyfile.bin luks
I got the same issues after the update today
@heyjo
I just installed the latest system updates, rebooted, get some out of memory error, fixed that by disabling the integrated graphics in BIOS (no idea how that’s related, but it worked), then tried this post.
I made the hardlink, didn’t help. I tried the default/grub and mkinitcpio.conf changes, except with my hard drive ID, of course, got errors for “udev.log_priority=3” and “nowatchdog”, removed those, restarted and… well, I didn’t get a second password prompt… but it also didn’t boot anymore. :upside_down_face: I also tried reverting to the version from my old post that I linked, since apparently some changed had happened in the meantime, that didn’t change anything. So now I’m again at the state from before, except with the hardlink (which seems to do nothing).
I’ll try some stuff with the first two replies next, but they’re a bit overwhelming. I didn’t really plan to puzzle together a bunch of system components myself, I just want a password prompt and then the system should boot… :(
@Yochanan
The line suggested here is what I had also just tried together with Grub changes. Making only this mkinitcpio.conf change didn’t change anything, but at least it didn’t break the boot.
Next I tried to puzzle together a line myself from the information in the wiki.
  • It says that adding “base” can provide a fallback shell if I also add “SYSTEMD_SULOGIN_FORCE=1” to the kernel parameters, which another page tells me should be at /boot/loader/entries/arch.conf. But I don’t even have /boot/loader. Is that reason for concern? Anyway, I guess I won’t add “base” for now.
  • I have intentionally not added “sd-vconsole” or “keymap”, because when I originally set up this system, the password prompt used the US keyboard layout and to get around that, I basically reverse-translated the intended password into a different one, so pressing the key labels in a way that looks like I’m typing the intended password instead gives the computer that modified password. Confusing to say, but intutive to use, as long as I don’t change it. The second password prompt actually uses the German keyboard layout (like the booted system), so there I need to use the reverse-translated password (and look it up every time).
I’ve now puzzled together these two lines, for systemd and busybox:
HOOKS=(systemd microcode modconf keyboard block sd-encrypt filesystems fsck)
HOOKS=(base udev microcode modconf keyboard block encrypt filesystems fsck)
Both work for booting, but both still require a second password input, even with German keyboard layout for some reason. And yes, I did run sudo mkinitcpio -P after every modification.
Some more command outputs and current Grub command line:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=2
GRUB_CMDLINE_LINUX_DEFAULT=“rd.luks.name=d74b9c8d-9bb0-4945-80a2-b917d8143295=luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 root=/dev/mapper/luks-d74b9c8d-9bb0-4945-80a2-b917d8143295 nmi_watchdog=0”
GRUB_GFXMODE=auto
[fabian@nova ~]$ cat /etc/modprobe.d/firewalld-sysctls.conf
install nf_conntrack /usr/bin/modprobe --ignore-install nf_conntrack $CMDLINE_OPTS && /sbin/sysctl --quiet --pattern 'net[.]netfilter[.]nf_conntrack.*' --system
[fabian@nova ~]$ cat /etc/modprobe.d/mhwd-gpu.conf
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
[fabian@nova ~]$ cat /etc/modprobe.d/tuxedo_keyboard.conf
options tuxedo_keyboard color=RED
[fabian@nova ~]$ modprobe -c
blacklist nouveau
blacklist ttm
blacklist drm
blacklist nouveau
blacklist nova_core
blacklist nova_drm
blacklist dvb_usb_rtl28xxu
blacklist e4000
blacklist rtl2832
blacklist uniwill_laptop
install mlx4_core /usr/bin/modprobe --ignore-install mlx4_core $CMDLINE_OPTS && (if [ -f /usr/lib/rdma/mlx4-setup.sh -a -f /etc/rdma/mlx4.conf ]; then /usr/lib/rdma/mlx4-setup.sh < /etc/rdma/mlx4.conf; fi; /usr/bin/modprobe mlx4_en; if /usr/bin/modinfo mlx4_ib > /dev/null 2>&1; then /usr/bin/modprobe mlx4_ib; fi)
install libnvdimm /usr/bin/ndctl load-keys ; /sbin/modprobe --ignore-install libnvdimm $CMDLINE_OPTS
install ib_qib modprobe -i ib_qib $CMDLINE_OPTS && /usr/lib/rdma/truescale-serdes.cmds start
options btusb reset=1
options nvidia "NVreg_DynamicPowerManagement=0x00"
options nvidia NVreg_UseKernelSuspendNotifiers=1
options nvidia NVreg_TemporaryFilePath=/var/tmp
options nvidia NVreg_PreserveVideoMemoryAllocations=1
options bonding max_bonds=0
options dummy numdummies=0
options ifb numifbs=0
options kvm enable_virt_at_load=0
softdep ext4 pre: crc32c
softdep cifs
softdep cifs
softdep cifs
softdep cifs
softdep cifs
softdep cifs
softdep cifs
softdep cifs
softdep cifs
softdep cifs
softdep cifs
softdep ksmbd pre: crc32
softdep ksmbd pre: gcm
softdep ksmbd pre: ccm
softdep ksmbd pre: aead2
softdep ksmbd pre: sha512
softdep ksmbd pre: sha256
softdep ksmbd pre: cmac
softdep ksmbd pre: aes
softdep ksmbd pre: nls
softdep ksmbd pre: md5
softdep ksmbd pre: hmac
softdep ksmbd pre: ecb
softdep btrfs pre: blake2b-256
softdep btrfs pre: sha256
softdep btrfs pre: xxhash64
softdep btrfs pre: crc32c
softdep f2fs pre: crc32
softdep bcachefs pre: xxhash
softdep bcachefs pre: poly1305
softdep bcachefs pre: chacha20
softdep bcachefs pre: sha256
softdep bcachefs pre: crc64
softdep bcachefs pre: crc32c
softdep lrw pre: ecb
softdep xts pre: ecb
softdep libcrc32c pre: crc32c
softdep irq_madera pre: madera
softdep gpio_madera pre: pinctrl-madera
softdep simatic_ipc_leds_gpio_core pre: platform:leds-gpio
softdep simatic_ipc_leds_gpio_apollolake pre: simatic-ipc-leds-gpio-core platform:apollolake-pinctrl
softdep simatic_ipc_leds_gpio_f7188x pre: simatic-ipc-leds-gpio-core gpio_f7188x
softdep simatic_ipc_leds_gpio_elkhartlake pre: simatic-ipc-leds-gpio-core platform:elkhartlake-pinctrl
softdep ipmi_msghandler post: ipmi_devintf
softdep arizona_i2c pre: arizona_ldo1
softdep arizona_spi pre: arizona_ldo1
softdep wm8994 pre: wm8994_regulator
softdep intel_lpss pre: platform:idma64
softdep dax_hmem pre: cxl_acpi
softdep cxl_acpi pre: cxl_port
softdep cxl_mem pre: cxl_port
softdep csiostor pre: cxgb4
softdep spi_pxa2xx_platform pre: dw_dmac
softdep dsa_loop pre: dsa_loop_bdinfo
softdep genet pre: mdio-bcm-unimac
softdep r8169 pre: realtek
softdep ohci_platform pre: ehci_platform
softdep mgb4 pre: platform:xiic-i2c platform:xilinx_spi spi-nor
softdep max31760 pre: regmap_i2c
softdep ufshcd_core pre: governor_simpleondemand
softdep qat_4xxx pre: crypto-intel_qat
softdep qat_420xx pre: crypto-intel_qat
softdep amd_pmf pre: amdtee
softdep intel_atomisp2_led pre: asus_nb_wmi
softdep intel_skl_int3472_tps68470 pre: clk-tps68470 tps68470-regulator
softdep pcengines_apuv2 pre: platform:gpio_amd_fch platform:leds-gpio platform:gpio_keys_polled
softdep simatic_ipc_batt_apollolake pre: simatic-ipc-batt platform:apollolake-pinctrl
softdep simatic_ipc_batt_elkhartlake pre: simatic-ipc-batt platform:elkhartlake-pinctrl
softdep simatic_ipc_batt_f7188x pre: simatic-ipc-batt gpio_f7188x platform:elkhartlake-pinctrl platform:alderlake-pinctrl
softdep sel3350_platform pre: pinctrl_broxton leds-gpio
softdep vfio post: vfio_iommu_type1 vfio_iommu_spapr_tce
softdep snd_sof_intel_hda pre: snd-hda-codec-hdmi
softdep act_mpls post: mpls_gso
softdep xt_LOG pre: nf_log_syslog
softdep xt_NFLOG pre: nfnetlink_log
softdep xt_TRACE pre: nf_log_syslog
softdep mpls_iptunnel post: mpls_gso
I’ve just changed that NVidia option to “0x00”, hoping to fix some unrelated issues.
All those mkinitcpio.conf changes don’t seem right to me, now that I’ve read the wiki some more. It seems like I can only use encryption or not use encryption, I can’t fix issues with it this way. The path to the key file is already in that config file, where it has been forever, but apparently it’s not used anymore for some reason. So maybe it’s just a bug?
And making Grub changes seem weird, too, because the Grub menu is already long gone when this second password prompt appears.
Mod edit: @mentions added and consecutive posts merged.
I am not that fit into the encryption stuff, but there might be something with those two actually different passwords. That would mean 2 keyfiles i guess? Is home on a separate partition?
Well, they’re not really different passwords, it’s one password that I need to input in two different ways, because the keyboard layout changes in between. E.g. if I would have wanted a < in my password, I instead set that character to \, because that way I can press the key next to LShift, which has the label “<” on my keyboard, but the computer receives “\”. So I normally don’t have to think about the layout issue at all, it just works.
But then, once the system has halfway booted and loaded the German keyboard layout, I need to enter “\” by pressing AltGr+ß, which is the key next to 0 on my keyboard. At least I think so… I just made this example up and already confused myself. I simply have all the variants that might come up saved in my password database and look them up whenever necessary.
And as if this wasn’t enough yet, specifically my own laptop also has custom keyboard engraving for my personal made up layout, which again shuffles around some special characters, e.g. “\” would instead be on AltGr+7… once I actually get around to setting up that layout in software, which I still haven’t done after multiple years, so instead I basically type blind, because all the labels are wrong. :upside_down_face:
Anyway… I have one single password and one single key file, /crypto_keyfile.bin. The second password prompt is confusing, but doable. That’s all that matters for this thread.
The second password prompt does not appear when I select any of the kernels with “Manjaro” in their name in GRUB! I thought they were completely identical to the same version numbers above (there was even some known issue post recently about kernels appearing multiple times in that list), but apparently not! My list is something like “Linux 6.18, Linux 6.12, Linux 6.6, Manjaro 6.18, Manjaro 6.12, Manjaro 6.6”, except the second half has much longer names.
So now I still have no idea why this happens with the other kernels, maybe there are separate configuration files for them somewhere. But since GRUB remembers my last start configuration, I can just keep it on the version with “Manjaro” and everything works. Not really a satisfying solution, since I don’t know why anything happened (and the default launch option is still broken, I have to keep the “advanced options” active), but still a solution. I can now once again start my laptop, immediately enter the password and then walk away for a couple minutes, until my autostart script has done everything.
If anyone knows how to fix the other kernel versions, that would still be nice to know and I’ll try it if I get any suggestions.
I think the correct syntax is rd.luks.key=/crypto_keyfile.bin
I also had a second password prompt when I initially switched to the sd-encrypt hook and specifying the password file location as above resolved it.
Also, the line below is needed in /etc/mkinitcpio.conf to add the keyfile to the initramfs :
Source :
