Hi! For some days I have struggled to solve a problem learning about Kubernetes.
I started with 3 Raspberry Pi: one 3B+ and two 4B. The 3B+ was intended to be the master and the two 4B agents (workers).
I used manjaro-arm-installer to prepare the SDcards. I had problems setting the Kubernetes Dashboard and tried several things, several times. Then I supposed that were something related to Raspberry Pi/ARM and began to try on VMs with Arch Linux. Same problem… Almost giving up I tried with VMs using Ubuntu Server 20.04. Then it worked! But as I prefer Manjaro/Arch I continued to search for the root cause. Finally I found!
https://wiki.archlinux.org/title/Kubernetes#Pods_cannot_communicate_when_using_Flannel_CNI_and_systemd-networkd
Then TODAY I get back to my Raspberry Pi…
With great surprise I found that after prepare the SDcards, as usual, none of them boot up!
The one connected to a monitor showed only the “circle thing motion”. None of them get past to login screen or get an IP address from router. Done again, same results. Then I prepared three other SDcards, new partition table and manjaro-arm-installer again. Now even the “circle thing motion” disapeared.
Maybe some update, from last thursday till today may caused this?
Strit
15 August 2021 20:13
2
Can you please post the contents of these files on the SD card:
/etc/fstab
/boot/cmdline.txt
Sure, I am repeating the process to copy all messages from console.
cmdline.txt
root=PARTUUID= rw rootwait console=serial0,115200 console=tty3 selinux=0 quiet splash plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=serial0,115200 usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0
fstab
# Static information about the filesystems.
# See fstab(5) for details.
# <file system> <dir> <type> <options> <dump> <pass>
PARTUUID=18407cfc-01 /boot vfat defaults 0 0
PARTUUID=18407cfc-02 / btrfs subvol=@,compress=zstd,defaults,noatime 0 0
PARTUUID=18407cfc-02 /home btrfs subvol=@home,compress=zstd,defaults,noatime 0 0
All output from manjaro-arm-installer
==> Proceeding....
-> Getting package lists ready for rpi4 minimal edition...
==> Getting /dev/sdb ready with btrfs for rpi4...
Error: /dev/sdb: unrecognised disk label
==> Creating install for rpi4...
-> Used device is /dev/sdb
-> Downloading latest aarch64 rootfs...
Manjaro-ARM-aarch64-latest.tar. 100%[====================================================>] 167,12M 17,5MB/s in 11s
-> Extracting aarch64 rootfs...
-> Setting up keyrings...
-> Generating mirrorlist...
-> Installing packages for minimal on rpi4...
core 237.4 KiB 203 KiB/s 00:01 [##########################################] 100%
extra 2.4 MiB 1053 KiB/s 00:02 [##########################################] 100%
community 6.0 MiB 2.77 MiB/s 00:02 [##########################################] 100%
warning: systemd-libs-249.2-1 is up to date -- reinstalling
resolving dependencies...
warning: dependency cycle detected:
warning: harfbuzz will be installed before its freetype2 dependency
Packages (119) argon2-20190702-3 binutils-2.35-1 bluez-libs-5.60-1 cairo-1.17.4-5 cryptsetup-2.3.6-1 dbus-1.12.20-1
device-mapper-2.03.12-1 diffutils-3.7-3 dnssec-anchors-20190629-3 elfutils-0.185-1 ell-0.42-1
file-5.40-5 fontconfig-2:2.13.94-1 freetype2-2.10.4-1 fribidi-1.0.10-1 fuse-common-3.10.4-1
fuse2-2.9.9-4 gdk-pixbuf2-2.42.6-2 gettext-0.21-1 graphite-1:1.3.14-1 grep-3.6-1 groff-1.22.4-6
gzip-1.10-3 harfbuzz-2.8.2-1 hwids-20210613-1 icu-69.1-1 iproute2-5.13.0-1 iptables-1:1.8.7-1
iputils-20210722-1 iw-5.9-1 json-c-0.15-1 kbd-2.4.0-2 kmod-29-1 ldns-1.7.1-2 less-1:590-1
libcroco-0.6.13-2 libdatrie-0.2.13-1 libdrm-2.4.107-1 libedit-20210522_3.1-1 libelf-0.185-1
libjpeg-turbo-2.1.0-1 libmnl-1.0.4-3 libnetfilter_conntrack-1.0.8-1 libnfnetlink-1.0.1-4 libnftnl-1.2.0-1
libnl-3.5.0-3 libnotify-0.7.9-1 libpcap-1.10.1-1 libpciaccess-0.16-2 libpipeline-1.5.3-1 libpng-1.6.37-3
libseccomp-2.5.1-2 libthai-0.1.28-2 libtiff-4.3.0-1 libusb-1.0.24-2 libx11-1.7.2-1 libxau-1.0.9-3
libxcb-1.14-1 libxdmcp-1.1.3-3 libxext-1.3.4-3 libxft-2.3.4-1 libxml2-2.9.10-9 libxrender-0.9.10-4
licenses-20200427-1 linux-firmware-20210716.b7c134f-1 lsb-release-1.4-13 lzo-2.10-3 mkinitcpio-30-2
mkinitcpio-busybox-1.33.1-1 pango-1:1.48.7-1 pciutils-3.7.0-1 pcre2-10.37-1 pixman-0.40.0-1 popt-1.18-1
procps-ng-3.3.17-1 psmisc-23.4-1 sed-4.8-1 shadow-4.8.1-4 shared-mime-info-2.0+57+gc1d1c70-1
systemd-sysvcompat-249.2-1 tar-1.34-1 util-linux-2.37.1-1 wireless-regdb-2021.04.21-1 xcb-proto-1.14.1-3
xorgproto-2021.4-1 base-2-2 bash-completion-2.11-2 brcm-patchram-plus-r3.bee0942-5 btrfs-progs-5.13-1
crda-4.14-4 dhcpcd-9.4.0-1 firmware-raspberrypi-6-1.9 haveged-1.9.14-1 inxi-3.3.05.1-1 iwd-1.16-1
linux-rpi4-5.10.52-2 linux-rpi4-headers-5.10.52-2 man-db-2.9.4-2 man-pages-5.12-2 manjaro-release-21.08-1
manjaro-system-20210716-1 nano-5.8-1 ncdu-1.16-1 ntfs-3g-2017.3.23-5 openssh-8.6p1-1 parted-3.4-2
plymouth-0.9.5-7 plymouth-theme-manjaro-1-1 raspberrypi-bootloader-20210812-1
raspberrypi-bootloader-x-20210812-1 raspberrypi-userland-aarch64-git-r816.97bc818-1 rpi-eeprom-20210611-1
rpi4-post-install-20210126-1 sudo-1.9.7.p2-1 systemd-249.2-1 systemd-libs-249.2-1 usbutils-013-1
wpa_supplicant-2:2.9-8 zswap-arm-1-1
Total Installed Size: 1237.48 MiB
Net Upgrade Size: 1235.00 MiB
(119/119) checking keys in keyring [##########################################] 100%
(119/119) checking package integrity [##########################################] 100%
(119/119) loading package files [##########################################] 100%
(119/119) checking for file conflicts [##########################################] 100%
(119/119) checking available disk space [##########################################] 100%
( 1/119) installing file [##########################################] 100%
( 2/119) installing grep [##########################################] 100%
( 3/119) reinstalling systemd-libs [##########################################] 100%
( 4/119) installing procps-ng [##########################################] 100%
( 5/119) installing sed [##########################################] 100%
( 6/119) installing tar [##########################################] 100%
( 7/119) installing icu [##########################################] 100%
( 8/119) installing libxml2 [##########################################] 100%
( 9/119) installing libcroco [##########################################] 100%
( 10/119) installing gettext [##########################################] 100%
Optional dependencies for gettext
git: for autopoint infrastructure updates
( 11/119) installing hwids [##########################################] 100%
( 12/119) installing kmod [##########################################] 100%
( 13/119) installing pciutils [##########################################] 100%
( 14/119) installing psmisc [##########################################] 100%
( 15/119) installing shadow [##########################################] 100%
( 16/119) installing util-linux [##########################################] 100%
Optional dependencies for util-linux
python: python bindings to libmount [installed]
words: default dictionary for look
( 17/119) installing pcre2 [##########################################] 100%
( 18/119) installing less [##########################################] 100%
( 19/119) installing gzip [##########################################] 100%
( 20/119) installing licenses [##########################################] 100%
( 21/119) installing device-mapper [##########################################] 100%
( 22/119) installing popt [##########################################] 100%
( 23/119) installing json-c [##########################################] 100%
( 24/119) installing argon2 [##########################################] 100%
( 25/119) installing cryptsetup [##########################################] 100%
( 26/119) installing dbus [##########################################] 100%
( 27/119) installing libmnl [##########################################] 100%
( 28/119) installing libnftnl [##########################################] 100%
( 29/119) installing libnl [##########################################] 100%
( 30/119) installing libpcap [##########################################] 100%
( 31/119) installing libnfnetlink [##########################################] 100%
( 32/119) installing libnetfilter_conntrack [##########################################] 100%
( 33/119) installing iptables [##########################################] 100%
( 34/119) installing kbd [##########################################] 100%
( 35/119) installing libelf [##########################################] 100%
( 36/119) installing libseccomp [##########################################] 100%
( 37/119) installing systemd [##########################################] 100%
warning: directory permissions differ on /var/log/journal/
filesystem: 755 package: 2755
Initializing machine ID from container UUID.
Creating group sys with gid 3.
Creating group mem with gid 8.
Creating group ftp with gid 11.
Creating group mail with gid 12.
Creating group log with gid 19.
Creating group smmsp with gid 25.
Creating group proc with gid 26.
Creating group games with gid 50.
Creating group lock with gid 54.
Creating group network with gid 90.
Creating group floppy with gid 94.
Creating group scanner with gid 96.
Creating group power with gid 98.
Creating group adm with gid 999.
Creating group wheel with gid 998.
Creating group utmp with gid 997.
Creating group audio with gid 996.
Creating group disk with gid 995.
Creating group input with gid 994.
Creating group kmem with gid 993.
Creating group kvm with gid 992.
Creating group lp with gid 991.
Creating group optical with gid 990.
Creating group render with gid 989.
Creating group sgx with gid 988.
Creating group storage with gid 987.
Creating group tty with gid 5.
Creating group uucp with gid 986.
Creating group video with gid 985.
Creating group users with gid 984.
Creating group systemd-journal with gid 983.
Creating group rfkill with gid 982.
Creating group bin with gid 1.
Creating user bin (n/a) with uid 1 and gid 1.
Creating group daemon with gid 2.
Creating user daemon (n/a) with uid 2 and gid 2.
Creating user mail (n/a) with uid 8 and gid 12.
Creating user ftp (n/a) with uid 14 and gid 11.
Creating group http with gid 33.
Creating user http (n/a) with uid 33 and gid 33.
Creating group nobody with gid 65534.
Creating user nobody (Nobody) with uid 65534 and gid 65534.
Creating group dbus with gid 81.
Creating user dbus (System Message Bus) with uid 81 and gid 81.
Creating group systemd-journal-remote with gid 981.
Creating user systemd-journal-remote (systemd Journal Remote) with uid 981 and gid 981.
Creating group systemd-network with gid 980.
Creating user systemd-network (systemd Network Management) with uid 980 and gid 980.
Creating group systemd-oom with gid 979.
Creating user systemd-oom (systemd Userspace OOM Killer) with uid 979 and gid 979.
Creating group systemd-resolve with gid 978.
Creating user systemd-resolve (systemd Resolver) with uid 978 and gid 978.
Creating group systemd-timesync with gid 977.
Creating user systemd-timesync (systemd Time Synchronization) with uid 977 and gid 977.
Creating group systemd-coredump with gid 976.
Creating user systemd-coredump (systemd Core Dumper) with uid 976 and gid 976.
Creating group uuidd with gid 68.
Creating user uuidd (n/a) with uid 68 and gid 68.
Created symlink /etc/systemd/system/getty.target.wants/getty@tty1.service → /usr/lib/systemd/system/getty@.service.
Created symlink /etc/systemd/system/multi-user.target.wants/remote-fs.target → /usr/lib/systemd/system/remote-fs.target.
:: Append 'init=/usr/lib/systemd/systemd' to your kernel command line in your
bootloader to replace sysvinit with systemd, or install systemd-sysvcompat
Optional dependencies for systemd
libmicrohttpd: remote journald capabilities
quota-tools: kernel-level quota management
systemd-sysvcompat: symlink package to provide sysvinit binaries [pending]
polkit: allow administration as unprivileged user
curl: machinectl pull-tar and pull-raw [installed]
libfido2: unlocking LUKS2 volumes with FIDO2 token
tpm2-tss: unlocking LUKS2 volumes with TPM2
( 38/119) installing systemd-sysvcompat [##########################################] 100%
( 39/119) installing iputils [##########################################] 100%
( 40/119) installing iproute2 [##########################################] 100%
Optional dependencies for iproute2
db: userspace arp daemon [installed]
libcap: tipc [installed]
linux-atm: ATM support
( 41/119) installing base [##########################################] 100%
Optional dependencies for base
linux: bare metal support [pending]
( 42/119) installing libpng [##########################################] 100%
( 43/119) installing libjpeg-turbo [##########################################] 100%
( 44/119) installing libtiff [##########################################] 100%
Optional dependencies for libtiff
freeglut: for using tiffgt
( 45/119) installing shared-mime-info [##########################################] 100%
( 46/119) installing gdk-pixbuf2 [##########################################] 100%
Optional dependencies for gdk-pixbuf2
libwmf: Load .wmf and .apm
libopenraw: Load .dng, .cr2, .crw, .nef, .orf, .pef, .arw, .erf, .mrw, and .raf
libavif: Load .avif
libheif: Load .heif, .heic, and .avif
librsvg: Load .svg, .svgz, and .svg.gz
webp-pixbuf-loader: Load .webp
( 47/119) installing libnotify [##########################################] 100%
( 48/119) installing manjaro-system [##########################################] 100%
( 49/119) installing lsb-release [##########################################] 100%
( 50/119) installing manjaro-release [##########################################] 100%
( 51/119) installing sudo [##########################################] 100%
warning: directory permissions differ on /etc/sudoers.d/
filesystem: 755 package: 750
( 52/119) installing parted [##########################################] 100%
( 53/119) installing libedit [##########################################] 100%
( 54/119) installing dnssec-anchors [##########################################] 100%
( 55/119) installing ldns [##########################################] 100%
Optional dependencies for ldns
libpcap: ldns-dpa tool [installed]
( 56/119) installing openssh [##########################################] 100%
Optional dependencies for openssh
xorg-xauth: X11 forwarding
x11-ssh-askpass: input passphrase in X
libfido2: FIDO/U2F support
( 57/119) installing haveged [##########################################] 100%
( 58/119) installing inxi [##########################################] 100%
Optional dependencies for inxi
bind-tools: dig: -i wlan IP
bluez-tools: bt-adapter: -E bluetooth data (if no hciconfig)
curl: -i (if no dig); -w,-W; -U [installed]
dmidecode: -M if no sys machine data; -m
doas: -Dx hddtemp-user; -o file-user (alt for sudo)
file: -o unmounted file system (if no lsblk) [installed]
freeipmi: ipmi-sensors: -s IPMI sensors (servers)
hddtemp: -Dx show hdd temp, if no drivetemp module
iproute2: ip: -i ip LAN [installed]
kmod: modinfo: Ax; -Nx module version [installed]
ipmitool: -s IPMI sensors (servers)
lm_sensors: sensors: -s sensors output
mesa-demos: glxinfo: -G glx info
net-tools: ifconfig: -i ip LAN (deprecated)
perl-io-socket-ssl: -U; -w,-W; -i (if dig not installed)
perl-json-xs: --output json - required for export (legacy)
smartmontools: smartctl: -Da advanced data
systemd-sysvcompat: runlevel: -I fallback to Perl [installed]
sudo: -Dx hddtemp-user; -o file-user [installed]
tree: --debugger 20,21 /sys tree
upower: -sx attached device battery info
usbutils: lsusb: -A usb audio; -J (optional); -N usb networking [pending]
wget: -i (if no dig); -w,-W; -U
wmctrl: -S active window manager (fallback)
xorg-xdpyinfo: xdpyinfo: -G multi screen resolution
xorg-xprop: xprop: -S desktop data
xorg-xrandr: xrandr: -G single screen resolution
( 59/119) installing ncdu [##########################################] 100%
( 60/119) installing nano [##########################################] 100%
( 61/119) installing dhcpcd [##########################################] 100%
Optional dependencies for dhcpcd
openresolv: resolvconf support
( 62/119) installing man-pages [##########################################] 100%
( 63/119) installing groff [##########################################] 100%
Optional dependencies for groff
netpbm: for use together with man -H command interaction in browsers
psutils: for use together with man -H command interaction in browsers
libxaw: for gxditview
perl-file-homedir: for use with glilypond
( 64/119) installing libpipeline [##########################################] 100%
( 65/119) installing man-db [##########################################] 100%
Optional dependencies for man-db
gzip [installed]
( 66/119) installing fuse-common [##########################################] 100%
( 67/119) installing fuse2 [##########################################] 100%
( 68/119) installing ntfs-3g [##########################################] 100%
( 69/119) installing libusb [##########################################] 100%
( 70/119) installing usbutils [##########################################] 100%
Optional dependencies for usbutils
python: for lsusb.py usage [installed]
coreutils: for lsusb.py usage [installed]
( 71/119) installing zswap-arm [##########################################] 100%
( 72/119) installing bash-completion [##########################################] 100%
( 73/119) installing ell [##########################################] 100%
( 74/119) installing iwd [##########################################] 100%
( 75/119) installing linux-firmware [##########################################] 100%
( 76/119) installing mkinitcpio-busybox [##########################################] 100%
( 77/119) installing diffutils [##########################################] 100%
( 78/119) installing mkinitcpio [##########################################] 100%
Optional dependencies for mkinitcpio
xz: Use lzma or xz compression for the initramfs image [installed]
bzip2: Use bzip2 compression for the initramfs image [installed]
lzop: Use lzo compression for the initramfs image
lz4: Use lz4 compression for the initramfs image [installed]
mkinitcpio-nfs-utils: Support for root filesystem on NFS
( 79/119) installing firmware-raspberrypi [##########################################] 100%
( 80/119) installing linux-rpi4 [##########################################] 100%
===> Installing default cmdline.txt file to /boot/...
===> Installing default config.txt file to /boot/...
Optional dependencies for linux-rpi4
crda: to set the correct wireless channels of your country [pending]
( 81/119) installing linux-rpi4-headers [##########################################] 100%
( 82/119) installing raspberrypi-bootloader-x [##########################################] 100%
( 83/119) installing raspberrypi-bootloader [##########################################] 100%
( 84/119) installing elfutils [##########################################] 100%
( 85/119) installing binutils [##########################################] 100%
( 86/119) installing rpi-eeprom [##########################################] 100%
Optional dependencies for rpi-eeprom
raspberrypi-firmware: Use this on an armv7h (32bit) system. [pending]
raspberrypi-userland-aarch64: Use this on an aarch64 (64bit) system. [pending]
( 87/119) installing raspberrypi-userland-aarch64-git [##########################################] 100%
( 88/119) installing libpciaccess [##########################################] 100%
( 89/119) installing libdrm [##########################################] 100%
( 90/119) installing libdatrie [##########################################] 100%
( 91/119) installing libthai [##########################################] 100%
( 92/119) installing lzo [##########################################] 100%
( 93/119) installing graphite [##########################################] 100%
( 94/119) installing harfbuzz [##########################################] 100%
Optional dependencies for harfbuzz
cairo: hb-view program [pending]
chafa: hb-view program
( 95/119) installing freetype2 [##########################################] 100%
( 96/119) installing fontconfig [##########################################] 100%
Creating fontconfig configuration...
Rebuilding fontconfig cache...
( 97/119) installing xcb-proto [##########################################] 100%
( 98/119) installing libxdmcp [##########################################] 100%
( 99/119) installing libxau [##########################################] 100%
(100/119) installing libxcb [##########################################] 100%
(101/119) installing xorgproto [##########################################] 100%
(102/119) installing libx11 [##########################################] 100%
(103/119) installing libxext [##########################################] 100%
(104/119) installing libxrender [##########################################] 100%
(105/119) installing pixman [##########################################] 100%
(106/119) installing cairo [##########################################] 100%
(107/119) installing libxft [##########################################] 100%
(108/119) installing fribidi [##########################################] 100%
(109/119) installing pango [##########################################] 100%
(110/119) installing plymouth [##########################################] 100%
Optional dependencies for plymouth
ttf-dejavu: For true type font support
xf86-video-fbdev: Support special graphic cards on early startup
cantarell-fonts: True Type support for BGRT theme
(111/119) installing plymouth-theme-manjaro [##########################################] 100%
==> To activate the theme, run as root:
==> plymouth-set-default-theme -R materia-manjaro
(112/119) installing wireless-regdb [##########################################] 100%
(113/119) installing iw [##########################################] 100%
(114/119) installing crda [##########################################] 100%
Uncomment the right regulatory domain in /etc/conf.d/wireless-regdom.
It will automatically be set on boot.
(115/119) installing btrfs-progs [##########################################] 100%
Optional dependencies for btrfs-progs
python: libbtrfsutil python bindings [installed]
e2fsprogs: btrfs-convert [installed]
reiserfsprogs: btrfs-convert
(116/119) installing bluez-libs [##########################################] 100%
(117/119) installing brcm-patchram-plus [##########################################] 100%
(118/119) installing wpa_supplicant [##########################################] 100%
(119/119) installing rpi4-post-install [##########################################] 100%
Configuration file /usr/lib/systemd/system/attach-bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Created symlink /etc/systemd/system/multi-user.target.wants/attach-bluetooth.service → /usr/lib/systemd/system/attach-bluetooth.service.
Created symlink /etc/systemd/system/multi-user.target.wants/stop-dmesg.service → /usr/lib/systemd/system/stop-dmesg.service.
Editing mkinitcpio.conf...
Editing cmdline.txt...
Editing config.txt...
==> Building image from preset: /etc/mkinitcpio.d/linux-rpi4.preset: 'default'
-> -k 5.10.52-2-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 5.10.52-2-MANJARO-ARM
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [plymouth]
==> ERROR: file not found: `/etc/os-release'
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
==> WARNING: errors were encountered during the build. The image may not be complete.
error: command failed to execute correctly
( 1/16) Creating system user accounts...
Creating group dhcpcd with gid 975.
Creating user dhcpcd (dhcpcd privilege separation) with uid 975 and gid 975.
( 2/16) Updating journal message catalog...
( 3/16) Reloading system manager configuration...
Skipped: Current root is not booted.
( 4/16) Updating udev hardware database...
( 5/16) Applying kernel sysctl settings...
( 6/16) Creating temporary files...
Unsupported ioctl: cmd=0x5000940e
Failed to create directory or subvolume "/var": Function not implemented
Failed to create directory or subvolume "/home": Function not implemented
Failed to create directory or subvolume "/srv": Function not implemented
Failed to create directory or subvolume "/var/lib/portables": Function not implemented
Failed to create directory or subvolume "/var/lib/machines": Function not implemented
Failed to create directory or subvolume "/tmp": Function not implemented
Failed to create directory or subvolume "/var/tmp": Function not implemented
Failed to open file "/sys/devices/system/cpu/microcode/reload": Read-only file system
( 7/16) Reloading device manager configuration...
Skipped: Device manager is not running.
( 8/16) Arming ConditionNeedsUpdate...
( 9/16) Updating fontconfig configuration...
(10/16) Updating module dependencies...
(11/16) Updating linux-rpi4 module dependencies...
(12/16) Updating linux-rpi4 initcpios...
(13/16) Updating linux initcpios...
(14/16) Reloading system bus configuration...
(15/16) Updating fontconfig cache...
(16/16) Updating the MIME type database...
-> Enabling services...
Enabling systemd-networkd.service ...
Enabling dhcpcd.service ...
Enabling sshd.service ...
Enabling iwd.service ...
Enabling zswap-arm.service ...
Enabling systemd-oomd.service ...
bootsplash-hide-when-booted.service not found in rootfs. Skipping.
bootsplash-show-on-shutdown.service not found in rootfs. Skipping.
-> Applying overlay for minimal...
-> Setting up users...
-> Setting password for root ...
-> Adding user...
-> Enabling user services...
No user services for minimal edition
-> Setting up system settings...
Generating locales...
en_US.UTF-8... done
Generation complete.
Correcting permissions from overlay...
-> Adding btrfs support to system...
-> Cleaning install for unwanted files...
==> rpi4 minimal install complete
==> Writing bootloader and cleaning up after install...
Set boot partition to 18407cfc-01 in /etc/fstab...
Set root partition to 18407cfc-02 in the relevant boot script...
Set root partition to 18407cfc-02 in /etc/fstab if applicable...
-> If you get an error stating 'failed to preserve ownership ... Operation not permitted', it's expected, since the boot partition is FAT32 and does not support ownership permissions...
==> Time : 5.53 minutes...
[peracchi@helios ~]$
Strit
15 August 2021 20:34
6
Edit your cmdline.txt file and put in 18407cfc-02 for root=PARTUUID.
You also need to put in the btrfs stuff, no idea why it didn’t do it for you. Do you run the installer from a system that has btrfs-progs installed?
rootflags=subvol=@ needs to go in the front of cmdline.txt.
Everything was working perfectly (except my thing with kubernetes) on last thursday, for sure. I repeat exact same steps. On thursday, because I still have no idea what was causing the problem with kubernetes, I tried several times alternating between EXT4 and BTRFS on manjaro-arm-installer.
I am using manjaro-kde-21.1-210809-linux513.iso install on my notebook.
I have another notebook with Manjaro. Will turn it on, not update anything and try manjaro-arm-installer on it to see if generated SDcard works as usual…
Strit
15 August 2021 20:56
8
Yeah.
@Darksky changed how the kernels do the cmdline.txt lately. That’s what changed.
I asked about the btrfs-progs, because of the errors in your install output:
On the older notebook, which I does not let update, at least the SDcard boots and keep “circulating”.
In cmdline.txt add root=PARTUUID=18407cfc-02 rootfstype=btrfs
I do not know about the other variables in your fstab but maybe it will get picked up when booting when it reads fstab.
With just these modifications to cmdline.txt it boots up ok again.
I need to check the new PARTUUID because I used manjaro-arm-installer again (on the older notebook).
I added rootflags=subvol=@ to the begining of the line and added the new PARTUUID after root=PARTUUID=
I still does not fully understand what caused this…
What change result in this situation:
change to manajro-arm-installer
change to Manjaro KDE 21.1
both
Strit
15 August 2021 21:34
12
None of them.
The change was in linux-rpi4.
And as I am too newbie to fix it manually myself, I will wait a new version that goes back to 100% user-friendly manjaro-arm-installer !
Thanks @Strit and @Darksky for your attention, help and work!
Without a doubt Manjaro it’s one of the best distro (if not THE BEST) because of your work and the great community.
The other images have been using PARTUUID= for a while. I had wanted to change to do the same with the pi4 kernels but never did. Then I was testing a pi kernel the other day and it did not boot with what was being used LABEL=. So I asked @Strit for help converting it. It tested ok with just installing the kernel but never was tested using the tools to build an image.
He is now looking to change the tools to make it work. It is just one of those things where one thing changed affects another that we were not aware of.
Thanks for running across this issue.
Strit
15 August 2021 22:00
15
I already downloaded version v1.4.6 of manjaro-arm-installer and are going to generate three SDcards (for one Raspberry Pi 3B+ and two Raspberry Pi 4B).
Will give feedback as soon as I finish.
Output of the first run of v1.4.6 of manjaro-arm-installer :
==> Proceeding....
Manjaro-ARM-aarch64-latest.tar. 100%[====================================================>] 167,12M 17,5MB/s in 9,7s
core 237.4 KiB 118 KiB/s 00:02 [##########################################] 100%
extra 2.4 MiB 492 KiB/s 00:05 [##########################################] 100%
community 6.0 MiB 321 KiB/s 00:19 [##########################################] 100%
libavif: Load .avif
gzip [installed]
-> Adding user...
en_US.UTF-8... done
Set boot partition to 3a2a2426-01 in /etc/fstab...
Set root partition to 3a2a2426-02 in the relevant boot script and /etc/fstab...
==> Time : 5.83 minutes...
Something still wrong, after a long time with the “circle thing” on screen, the Raspberry Pi 3B+ with the first SDcard shows only on screen:
[ 5.033834] usb 1-1.2: device descriptor read/64, error -32
The other two RPI4 doesn´t not respond ping, should be with the same error.
Strit
15 August 2021 22:47
19
That’s not related to this though. It looks like usb/sd issues.
Contents of cmdline.txt and fstab :
rootflags=subvol=@ rootfstype=btrfs root=PARTUUID=3a2a2426-02 rw rootwait console=serial0,115200 console=tty3 selinux=0 quiet splash plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=serial0,115200 usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0
PARTUUID=3a2a2426-01 /boot vfat defaults 0 0
PARTUUID= / btrfs subvol=@,compress=zstd,defaults,noatime 0 0
PARTUUID= /home btrfs subvol=@home,compress=zstd,defaults,noatime 0 0
